[GRASS-SVN] r62093 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Fri Sep 26 07:04:13 PDT 2014
Author: neteler
Date: 2014-09-26 07:04:13 -0700 (Fri, 26 Sep 2014)
New Revision: 62093
grass/trunk/vector/v.select/copy_tabs.c
v.select: create DB index
Modified: grass/trunk/vector/v.select/copy_tabs.c
--- grass/trunk/vector/v.select/copy_tabs.c 2014-09-26 13:12:21 UTC (rev 62092)
+++ grass/trunk/vector/v.select/copy_tabs.c 2014-09-26 14:04:13 UTC (rev 62093)
@@ -11,6 +11,7 @@
int i, ttype, ntabs;
struct field_info *IFi, *OFi;
+ dbDriver *Driver;
ntabs = 0;
@@ -18,7 +19,7 @@
/* Number of output tabs */
for (i = 0; i < Vect_get_num_dblinks(In); i++) {
- int f, j;
+ int j, f=0;
IFi = Vect_get_dblink(In, i);
@@ -67,5 +68,18 @@
Vect_map_add_dblink(Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
+ Driver = db_start_driver_open_database(OFi->driver,
+ Vect_subst_var(OFi->database, Out));
+ if (Driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ OFi->database, OFi->driver);
+ if (db_create_index2(Driver, OFi->table, OFi->key) != DB_OK)
+ G_warning(_("Unable to create index"));
+ if (db_grant_on_table
+ (Driver, OFi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ OFi->table);
+ db_close_database_shutdown_driver(Driver);
