[GRASS-SVN] r65010 - grass-addons/grass7/vector/v.vol.idw
svn_grass at osgeo.org
Tue Apr 7 02:42:07 PDT 2015
Author: neteler
Date: 2015-04-07 02:42:07 -0700 (Tue, 07 Apr 2015)
New Revision: 65010
grass-addons/grass7/vector/v.vol.idw/main.c
v.vol.idw Addon: remove trailing white spaces
Modified: grass-addons/grass7/vector/v.vol.idw/main.c
--- grass-addons/grass7/vector/v.vol.idw/main.c 2015-04-06 21:30:55 UTC (rev 65009)
+++ grass-addons/grass7/vector/v.vol.idw/main.c 2015-04-07 09:42:07 UTC (rev 65010)
@@ -3,11 +3,9 @@
* MODULE: v.to.rast3
* AUTHOR(S): Original s.to.rast3: Jaro Hofierka, Geomodel s.r.o. (original contributor)
- * 9/2005 Upgrade to GRASS 6 by Radim Blazek
- * Soeren Gebbert <soeren.gebbert gmx.de>
- * OGR support by Martin Landa <landa.martin gmail.com>
+ * 3/2015 Upgrade to GRASS GIS 7 by Noortheen Raja J
* PURPOSE: Converts vector points to 3D raster
- * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2015 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -32,7 +30,7 @@
double w, z, east, north;
double dist;
-struct Point *points = NULL;
+struct Point *points = NULL;
struct Point *list;
int main(int argc, char *argv[])
@@ -42,13 +40,13 @@
int nfield;
RASTER3D_Region region;
- struct Map_info InMap; /*input map*/
+ struct Map_info InMap; /*input map*/
struct line_pnts *Points;
struct line_cats *Cats;
RASTER3D_Map *map3d = NULL;
float *data, value;
int lev, col, row, Nc, Nr, Nl, sz, i, n, max, cnt, current_row, current_depth;
- double x, y, z, w, lev_res, dx, dy, dz, dist, maxdist, sum1, sum2;
+ double x, y, z, w, lev_res, dx, dy, dz, dist, maxdist, sum1, sum2;
int nrec, ctype, cat;
@@ -63,10 +61,10 @@
G_add_keyword(_("Volume"));
G_add_keyword(_("voxel"));
G_add_keyword(_("interpolation"));
- G_add_keyword(_("IDW"));
+ G_add_keyword(_("IDW"));
module->description =
_("Interpolates point data to a 3D raster map using "
- "Inverse Distance Weighting (IDW) algorithm.");
+ "Inverse Distance Weighting (IDW) algorithm.");
input = G_define_standard_option(G_OPT_V_INPUT);
input->required = YES;
@@ -76,7 +74,7 @@
field = G_define_standard_option(G_OPT_V_FIELD);
field->required = NO;
field->label = _("Number of vector layer field attribute to use for calculation");
- field->description = NULL;
+ field->description = NULL;
output = G_define_standard_option(G_OPT_R3_OUTPUT);
output->key = "output";
@@ -93,13 +91,13 @@
npoints->type = TYPE_INTEGER ;
npoints->required = YES ;
npoints->description="Number of interpolation points";
- npoints->answer = "12";
+ npoints->answer = "12";
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
if (G_legal_filename(output->answer) < 0)
- G_fatal_error(_("%s=%s - illegal name\n"), output->key, output->answer);
+ G_fatal_error(_("%s=%s - illegal name\n"), output->key, output->answer);
if(sscanf(npoints->answer,"%d", &search_points) != 1 || search_points<1){
G_usage();
@@ -114,10 +112,10 @@
if (!Vect_is_3d(&InMap))
G_fatal_error(_("Vector is not 3D"));
- nfield = Vect_get_field_number(&InMap, field->answer); /*layer number; mostly one*/
+ nfield = Vect_get_field_number(&InMap, field->answer); /*layer number;mostly one*/
db_CatValArray_init(&cvarr);
- Fi = Vect_get_field(&InMap, nfield); /*The particular level of layer*/
+ Fi = Vect_get_field(&InMap, nfield); /*The particular level of layer*/
if (Fi == NULL)
G_fatal_error(_("Database connection not defined for layer <%s>"), field->answer);
@@ -129,7 +127,7 @@
/* Note: do not check if the column exists in the table because it may be expression */
- nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, column->answer, NULL, &cvarr);/*Number of selected records*/
+ nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, column->answer, NULL, &cvarr); /*Number of selected records*/
G_debug(2, "nrec = %d", nrec);
if (nrec < 0)
G_fatal_error(_("Unable to select data from table"));
@@ -155,7 +153,7 @@
G_fatal_error(_("Unable to read vector map"));
if (type == -2)
- break; /* EOF */
+ break; /* EOF */
if (!(type & GV_POINTS))
continue;
@@ -175,15 +173,15 @@
w = ival;}
else
{ret = db_CatValArray_get_value_double(&cvarr, cat, &w);}/*ret will be 0 if completed successfully*/
- newpoint(w, z, x, y);/*adding the each point to the points array*/
+ newpoint(w, z, x, y); /*adding the each point to the points array*/
Vect_close(&InMap);
/*Terminate if the vector map is empty*/
if (npts == 0)
- G_fatal_error(_("%s: no data points found\n"), argv[0]);
+ G_fatal_error(_("%s: no data points found\n"), argv[0]);
- Rast3d_get_window(®ion);
- Rast3d_read_window(®ion, NULL);
+ Rast3d_get_window(®ion);
+ Rast3d_read_window(®ion, NULL);
fprintf(stderr,"Region from getWindow: %d %d %d\n", region.rows, region.cols, region.depths);
map3d = Rast3d_open_new_opt_tile_size(output->answer, RASTER3D_USE_CACHE_DEFAULT, ®ion, FCELL_TYPE, 32);
@@ -199,7 +197,7 @@
/*start the interpolation*/
data = (float *) malloc( sz * sizeof(float) );
if (!data)
- G_fatal_error(_("Error: out of memory\n"));
+ G_fatal_error(_("Error: out of memory\n"));
nsearch = npts < search_points ? npts : search_points; /*nsearch will get the value one of the minimum */
fprintf (stderr, "Interpolating raster map <%s> ... %d levels ... ", output->answer, Nl);
@@ -207,12 +205,12 @@
cnt=0;
z = region.top + lev_res/2.0;
for (lev = 0; lev < Nl; lev++)
- z -=lev_res;
+ z -=lev_res;
y = region.north + region.ns_res/2.0;
for (row = 0; row < Nr; row++)
- G_percent (row, Nr, 2);
+ G_percent (row, Nr, 2);
y -= region.ns_res;
x = region.west - region.ew_res/2.0;
for (col = 0; col < Nc; col++)
@@ -273,7 +271,7 @@
data[cnt] = (sum1/sum2);
- value = data[cnt];
+ value = data[cnt];
cnt++;
Rast3d_put_float (map3d, col, row, lev, value);
}/*cols*/
@@ -281,8 +279,8 @@
}/*levels*/
free(data);
- if (!Rast3d_close(map3d))
- G_fatal_error(_("Unable to close new 3d raster map"));
+ if (!Rast3d_close(map3d))
+ G_fatal_error(_("Unable to close new 3d raster map"));
fprintf (stderr, "Done\n");
exit(EXIT_SUCCESS);
@@ -297,6 +295,6 @@
points[npts].north = north;
points[npts].east = east;
points[npts].z = z;
- points[npts].w = w;
+ points[npts].w = w;
npts++;
