[GRASS-SVN] r65011 - grass-addons/grass7/vector/v.vol.idw
svn_grass at osgeo.org
Tue Apr 7 02:47:42 PDT 2015
Author: neteler
Date: 2015-04-07 02:47:42 -0700 (Tue, 07 Apr 2015)
New Revision: 65011
grass-addons/grass7/vector/v.vol.idw/main.c
v.vol.idw Addon: use G_malloc()/G_free(); msg cosmetics
Modified: grass-addons/grass7/vector/v.vol.idw/main.c
--- grass-addons/grass7/vector/v.vol.idw/main.c 2015-04-07 09:42:07 UTC (rev 65010)
+++ grass-addons/grass7/vector/v.vol.idw/main.c 2015-04-07 09:47:42 UTC (rev 65011)
@@ -183,7 +183,7 @@
Rast3d_get_window(®ion);
Rast3d_read_window(®ion, NULL);
- fprintf(stderr,"Region from getWindow: %d %d %d\n", region.rows, region.cols, region.depths);
+ G_debug(1, "Region from getWindow: %d %d %d", region.rows, region.cols, region.depths);
map3d = Rast3d_open_new_opt_tile_size(output->answer, RASTER3D_USE_CACHE_DEFAULT, ®ion, FCELL_TYPE, 32);
if (map3d == NULL)
G_fatal_error(_("Unable to create output map"));
@@ -195,17 +195,18 @@
lev_res = region.tb_res;
sz = Nr * Nc * Nl;
/*start the interpolation*/
- data = (float *) malloc( sz * sizeof(float) );
+ data = (float *) G_malloc( sz * sizeof(float) );
if (!data)
G_fatal_error(_("Error: out of memory\n"));
nsearch = npts < search_points ? npts : search_points; /*nsearch will get the value one of the minimum */
- fprintf (stderr, "Interpolating raster map <%s> ... %d levels ... ", output->answer, Nl);
+ G_message(_("Interpolating raster map <%s> ... %d levels ... "), output->answer, Nl);
cnt=0;
z = region.top + lev_res/2.0;
for (lev = 0; lev < Nl; lev++)
+ G_message(_("Processing level %d"), lev + 1);
z -=lev_res;
y = region.north + region.ns_res/2.0;
for (row = 0; row < Nr; row++)
@@ -277,11 +278,11 @@
}/*cols*/
}/*rows*/
}/*levels*/
- free(data);
+ G_free(data);
if (!Rast3d_close(map3d))
G_fatal_error(_("Unable to close new 3d raster map"));
- fprintf (stderr, "Done\n");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
