[GRASS-SVN] r65012 - grass/trunk/vector/v.vol.rst
svn_grass at osgeo.org
Tue Apr 7 02:59:02 PDT 2015
Author: neteler
Date: 2015-04-07 02:59:02 -0700 (Tue, 07 Apr 2015)
New Revision: 65012
grass/trunk/vector/v.vol.rst/v.vol.rst.html
v.vol.rst manual: zmult -> zscale
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html 2015-04-07 09:47:42 UTC (rev 65011)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html 2015-04-07 09:59:02 UTC (rev 65012)
@@ -22,13 +22,13 @@
<p>At first, data points are checked for identical positions and points
that are closer to each other than given <b>dmin</b> are removed.
-Parameters <b>wmult</b> and <b>zmult</b> allow the user to re-scale
+Parameters <b>wmult</b> and <b>zscale</b> allow the user to re-scale
the w-values and z-coordinates of the point data (useful e.g. for
transformation of elevations given in feet to meters, so that the
proper values of gradient and curvatures can be computed).
-Rescaling of z-coordinates (<b>zmult</b>) is also needed when the distances
+Rescaling of z-coordinates (<b>zscale</b>) is also needed when the distances
in vertical direction are much smaller than the horizontal
-distances; if that is the case, the value of <b>zmult</b>
+distances; if that is the case, the value of <b>zscale</b>
should be selected so that the vertical and horizontal distances
have about the same magnitude.
@@ -69,7 +69,7 @@
<div class="code"><pre>
# preparation as in above example
-v.vol.rst elevrand_3d wcol=soilrange elevation=soilrange zmult=100 where="soilrange > 3"
+v.vol.rst elevrand_3d wcol=soilrange elevation=soilrange zscale=100 where="soilrange > 3"
</pre></div>
@@ -91,7 +91,7 @@
<p><div class="code"><pre>
v.info -c precip3d
g.region n=5530000 s=5275000 w=4186000 e=4631000 res=500 -p
-v.vol.rst -c input=precip3d wcolumn=precip zmult=50 segmax=700 cvdev=cvdevmap tension=10
+v.vol.rst -c input=precip3d wcolumn=precip zscale=50 segmax=700 cvdev=cvdevmap tension=10
v.db.select cvdevmap
v.univar cvdevmap col=flt1 type=point
</pre></div>
@@ -100,11 +100,11 @@
recommended to plot the CV error as curve while modifying
the parameters.
<p>The best approach is to start with <b>tension</b>, <b>smooth</b>
-and <b>zmult</b> with rough steps, or to set <b>zmult</b> to a
+and <b>zscale</b> with rough steps, or to set <b>zscale</b> to a
constant somewhere between 30-60. This helps to find minimal RMSE
values while then finer steps can be used in all parameters. The
reasonable range is <b>tension</b>=10...100,
-<b>smooth</b>=0.1...1.0, <b>zmult</b>=10...100.
+<b>smooth</b>=0.1...1.0, <b>zscale</b>=10...100.
<p>In <em>v.vol.rst</em> the tension parameter is much more sensitive to
changes than in <em>v.surf.rst</em>,
therefore the user should always check the
@@ -209,7 +209,7 @@
### Second part: 3D interpolation from 3D point data
# interpolate volume to "soilrange" voxel map
-v.vol.rst input=elevrand_3d wcol=soilrange elevation=soilrange zmult=100
+v.vol.rst input=elevrand_3d wcol=soilrange elevation=soilrange zscale=100
# visualize I: in GRASS GIS wxGUI
g.gui
