[GRASS-SVN] r65143 - grass-addons/grass7/gui/wxpython/wx.mwprecip
Sun Apr 26 14:28:56 PDT 2015
Author: krejcmat
Date: 2015-04-26 14:28:55 -0700 (Sun, 26 Apr 2015)
New Revision: 65143
   grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
del t.register file creator
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2015-04-26 20:27:14 UTC (rev 65142)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2015-04-26 21:28:55 UTC (rev 65143)
@@ -516,19 +516,6 @@
         except IOError as (errno, strerror):
             grass.fatal('Cannot write temporal registration file  %s' % os.path.join(self.path, TMPname))
-        # creating textfile for t.register input
-        filename = "timewin_%s" % prefix + "vec_" + str(self.timestamp_min).replace(' ', '_') + "|" + str(
-            self.timestamp_max).replace(' ', '_')
-        try:
-            self.temporalRegPath = os.path.join(self.path, filename)
-            io4 = open(self.temporalRegPath, 'w+')
-            io4.writelines(tgrass_vector)
-            io4.close()
-        except IOError as (errno, strerror):
-            grass.fatal('Cannot write temporal reg file  %s' % os.path.join(self.path, TMPname))
-            # drop temp table
-            # sql = "DROP TABLE %s.%s" % (self.schema, self.database.recordTableName)
         grass.message('creating time windows-done')
     def logMsg(self, msg):
@@ -1245,12 +1232,12 @@
     def createTimedataset(self, datasetName=None, datasetTitle=None,
                           datasetTdescription=None, temporalType='absolute',
                           semanticType='mean'):
-        if datasetName is None:
-            self.datasetName = self.datasetName
-        if datasetTitle is None:
-            self.datasetTitle = self.datasetTitle
-        if datasetTdescription is None:
-            self.datasetTdescription = self.datasetTdescription
+        if datasetName is not None:
+            self.datasetName = datasetName
+        if datasetTitle is not None:
+            self.datasetTitle = datasetTitle
+        if datasetTdescription is not None:
+            self.datasetTdescription = datasetTdescription
         # print '--'*10
         # #print self.datasetName
@@ -1299,7 +1286,6 @@
         grass.message('Registring maps to temporal database-done')
 class Database():
     def __init__(self, name=None, user=None, password=None,
                  host=None, port=None, nodeVecMapName='node', linkVecMapName='link',
