[GRASS-SVN] r66019 - grass/trunk/scripts/v.unpack
Tue Aug 25 17:55:05 PDT 2015
Author: annakrat
Date: 2015-08-25 17:55:05 -0700 (Tue, 25 Aug 2015)
New Revision: 66019
   grass/trunk/scripts/v.unpack/v.unpack.py
v.unpack: fix importing to xy location
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py	2015-08-26 00:25:55 UTC (rev 66018)
+++ grass/trunk/scripts/v.unpack/v.unpack.py	2015-08-26 00:55:05 UTC (rev 66019)
@@ -110,33 +110,40 @@
     loc_proj = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
     loc_proj_units = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
-    diff_result_1 = diff_result_2 = None
-    if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_INFO'),
-                                              filename_b=loc_proj, proj=True):
-        diff_result_1 = diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
-                                         loc_proj)
+    skip_projection_check = False
+    if not os.path.exists(os.path.join(tmp_dir, 'PROJ_INFO')):
+        if os.path.exists(loc_proj):
+            grass.fatal(_("PROJ_INFO file is missing, unpack vector map in XY (unprojected) location."))
+        skip_projection_check = True  # XY location
-    if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_UNITS'),
-                                              filename_b=loc_proj_units,
-                                              units=True):
-        diff_result_2 = diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
-                                         loc_proj_units)
+    if not skip_projection_check:
+        diff_result_1 = diff_result_2 = None
+        if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_INFO'),
+                                                  filename_b=loc_proj, proj=True):
+            diff_result_1 = diff_files(os.path.join(tmp_dir, 'PROJ_INFO'),
+                                             loc_proj)
+        if not grass.compare_key_value_text_files(filename_a=os.path.join(tmp_dir, 'PROJ_UNITS'),
+                                                  filename_b=loc_proj_units,
+                                                  units=True):
+            diff_result_2 = diff_files(os.path.join(tmp_dir, 'PROJ_UNITS'),
+                                             loc_proj_units)
+        if diff_result_1 or diff_result_2:
+            if flags['o']:
+                grass.warning(_("Projection information does not match. Proceeding..."))
+            else:
+                if diff_result_1:
+                    grass.warning(_("Difference between PROJ_INFO file of packed map "
+                                    "and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
+                if diff_result_2:
+                    grass.warning(_("Difference between PROJ_UNITS file of packed map "
+                                    "and of current location:\n{diff}").format(diff=''.join(diff_result_2)))
+                grass.fatal(_("Projection of dataset does not appear to match current location."
+                              " In case of no significant differences in the projection definitions,"
+                              " use the -o flag to ignore them and use"
+                              " current location definition."))
-    if diff_result_1 or diff_result_2:
-        if flags['o']:
-            grass.warning(_("Projection information does not match. Proceeding..."))
-        else:
-            if diff_result_1:
-                grass.warning(_("Difference between PROJ_INFO file of packed map "
-                                "and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
-            if diff_result_2:
-                grass.warning(_("Difference between PROJ_UNITS file of packed map "
-                                "and of current location:\n{diff}").format(diff=''.join(diff_result_2)))
-            grass.fatal(_("Projection of dataset does not appear to match current location."
-                          " In case of no significant differences in the projection definitions,"
-                          " use the -o flag to ignore them and use"
-                          " current location definition."))
     # new db
     fromdb = os.path.join(tmp_dir, 'db.sqlite')
     # copy file
