[GRASS-SVN] r66020 - grass/trunk/scripts/r.unpack
svn_grass at osgeo.org
Tue Aug 25 18:06:06 PDT 2015
Author: annakrat
Date: 2015-08-25 18:06:06 -0700 (Tue, 25 Aug 2015)
New Revision: 66020
grass/trunk/scripts/r.unpack/r.unpack.py
r.unpack: fix importing to xy location
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py 2015-08-26 00:55:05 UTC (rev 66019)
+++ grass/trunk/scripts/r.unpack/r.unpack.py 2015-08-26 01:06:06 UTC (rev 66020)
@@ -106,34 +106,41 @@
diff_result_1 = diff_result_2 = None
proj_info_file_1 = 'PROJ_INFO'
- proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
- if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
- filename_b=proj_info_file_2,
- proj=True):
- diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
- proj_units_file_1 = 'PROJ_UNITS'
- proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
- if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
- filename_b=proj_units_file_2,
- units=True):
- diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
- if diff_result_1 or diff_result_2:
- if diff_result_1:
- grass.warning(_("Difference between PROJ_INFO file of packed map "
- "and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
- if diff_result_2:
- grass.warning(_("Difference between PROJ_UNITS file of packed map "
- "and of current location:\n{diff}").format(diff=''.join(diff_result_2)))
- grass.fatal(_("Projection of dataset does not appear to match current location."
- " In case of no significant differences in the projection definitions,"
- " use the -o flag to ignore them and use"
- " current location definition."))
+ proj_info_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_INFO')
+ skip_projection_check = False
+ if not os.path.exists(proj_info_file_1):
+ if os.path.exists(proj_info_file_2):
+ grass.fatal(_("PROJ_INFO file is missing, unpack raster map in XY (unprojected) location."))
+ skip_projection_check = True # XY location
+ if not skip_projection_check:
+ if not grass.compare_key_value_text_files(filename_a=proj_info_file_1,
+ filename_b=proj_info_file_2,
+ proj=True):
+ diff_result_1 = diff_files(proj_info_file_1, proj_info_file_2)
+ proj_units_file_1 = 'PROJ_UNITS'
+ proj_units_file_2 = os.path.join(mset_dir, '..', 'PERMANENT', 'PROJ_UNITS')
+ if not grass.compare_key_value_text_files(filename_a=proj_units_file_1,
+ filename_b=proj_units_file_2,
+ units=True):
+ diff_result_2 = diff_files(proj_units_file_1, proj_units_file_2)
+ if diff_result_1 or diff_result_2:
+ if diff_result_1:
+ grass.warning(_("Difference between PROJ_INFO file of packed map "
+ "and of current location:\n{diff}").format(diff=''.join(diff_result_1)))
+ if diff_result_2:
+ grass.warning(_("Difference between PROJ_UNITS file of packed map "
+ "and of current location:\n{diff}").format(diff=''.join(diff_result_2)))
+ grass.fatal(_("Projection of dataset does not appear to match current location."
+ " In case of no significant differences in the projection definitions,"
+ " use the -o flag to ignore them and use"
+ " current location definition."))
# install in $MAPSET
for element in ['cats', 'cell', 'cellhd', 'cell_misc', 'colr', 'fcell', 'hist']:
if not os.path.exists(element):
