[GRASS-SVN] r66028 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Wed Aug 26 06:30:24 PDT 2015
Author: huhabla
Date: 2015-08-26 06:30:23 -0700 (Wed, 26 Aug 2015)
New Revision: 66028
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass vector: Added to_wkt to Node class
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2015-08-26 12:30:33 UTC (rev 66027)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2015-08-26 13:30:23 UTC (rev 66028)
@@ -373,7 +373,7 @@
:param vtype: the name of type to query; the supported values are:
*areas*, *dblinks*, *faces*, *holes*, *islands*,
- *kernels*, *line_points*, *lines*, *nodes*,
+ *kernels*, *line_points*, *lines*, *nodes*, *points*,
*update_lines*, *update_nodes*, *volumes*
:type vtype: str
:param idonly: variable to return only the id of features instead of
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-26 12:30:33 UTC (rev 66027)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-08-26 13:30:23 UTC (rev 66028)
@@ -1133,7 +1133,7 @@
param v_id: The unique node id
param c_mapinfo: A valid pointer to the mapinfo object
- param **kwords: Ignored
+ param **kwords: Ignored
self.id = v_id # vector id
self.c_mapinfo = c_mapinfo
@@ -1170,6 +1170,12 @@
ctypes.byref(y), ctypes.byref(z))
return (x.value, y.value) if self.is2D else (x.value, y.value, z.value)
+ def to_wkt(self):
+ """Return a "well know text" (WKT) geometry string. ::
+ return "POINT(%s)" % ' '.join(['%f' % coord
+ for coord in self.coords()])
def ilines(self, only_in=False, only_out=False):
"""Return a generator with all lines id connected to a node.
The line id is negative if line is ending on the node and positive if
