[GRASS-SVN] r66029 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Wed Aug 26 07:02:27 PDT 2015
Author: wenzeslaus
Date: 2015-08-26 07:02:27 -0700 (Wed, 26 Aug 2015)
New Revision: 66029
grass/trunk/scripts/g.extension/g.extension.py
g.extension: we don't need to check dependencies when just listing local extensions
Fixes issue when GUI was started, listed addons for module tree and failed because of missing make, gcc (and svn potentionally).
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2015-08-26 13:30:23 UTC (rev 66028)
+++ grass/trunk/scripts/g.extension/g.extension.py 2015-08-26 14:02:27 UTC (rev 66029)
@@ -178,6 +178,8 @@
def check_progs():
"""Check if the necessary programs are available"""
+ # TODO: we need svn for the Subversion repo downloads
+ # also git would be tested once supported
for prog in ('make', 'gcc'):
if not grass.find_program(prog, '--help'):
grass.fatal(_("'%s' required. Please install '%s' first.")
@@ -1624,7 +1626,7 @@
def main():
# check dependecies
- if sys.platform != "win32":
+ if not flags['a'] and sys.platform != "win32":
check_progs()
original_url = options['url']
