[GRASS-SVN] r66035 - grass-addons/grass7/vector/v.in.gbif
svn_grass at osgeo.org
Wed Aug 26 14:16:59 PDT 2015
Author: hellik
Date: 2015-08-26 14:16:59 -0700 (Wed, 26 Aug 2015)
New Revision: 66035
grass-addons/grass7/vector/v.in.gbif/Makefile
grass-addons/grass7/vector/v.in.gbif/v.in.gbif.html
grass-addons/grass7/vector/v.in.gbif/v.in.gbif.py
v.in.gbif: module_svn_propset.sh
Modified: grass-addons/grass7/vector/v.in.gbif/Makefile
--- grass-addons/grass7/vector/v.in.gbif/Makefile 2015-08-26 21:12:46 UTC (rev 66034)
+++ grass-addons/grass7/vector/v.in.gbif/Makefile 2015-08-26 21:16:59 UTC (rev 66035)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = v.in.gbif
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = v.in.gbif
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.in.gbif/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Modified: grass-addons/grass7/vector/v.in.gbif/v.in.gbif.html
--- grass-addons/grass7/vector/v.in.gbif/v.in.gbif.html 2015-08-26 21:12:46 UTC (rev 66034)
+++ grass-addons/grass7/vector/v.in.gbif/v.in.gbif.html 2015-08-26 21:16:59 UTC (rev 66035)
@@ -1,44 +1,44 @@
-<h2>DESCRIPTION</h2>
-<em>v.in.gbif</em> imports <a href="http://www.gbif.org/">GBIF</a>
-species distribution data. The location must be in latlon (WGS84).
-<p>
-The species distribution data downloaded from <a href="http://www.gbif.org/">GBIF</a>
-hast to be unzipped before importing the csv file.
-</p>
-<p>
-<em>v.in.gbif</em> saves the data to a <a href="http://www.gdal.org">GDAL</a>
-<a href="http://www.gdal.org/drv_vrt.html">VRT - Virtual Datasource</a>
-which will be imported by <a href="v.in.ogr.html">v.in.ogr</a>. The VRT data set
-can be used in any GDAL aware software.
-As some column names in the original data set are similar to <a
-href="http://www.postgresql.org/docs/devel/static/sql-keywords-appendix.html">SQL reserverd key words</a>,
-the columns will renamed with the prefix <i>g_</i>.
-</p>
-<h2>EXAMPLE</h2>
-<div class="code">
- <pre>
- v.in.gbif vector= cat=40102 dir=C:\tmp distance=25
- v.in.gbif input=C:\data\0004248-150811131857512\0004248-150811131857512.csv output_vrt=chondrilla.vrt dir=C:\data\0004248-150811131857512\ output=chondrilla
- </pre>
-</div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.in.ascii.html">v.in.ascii</a>
-<a href="v.in.ogr.html">v.in.ogr</a>
-</em>
-<h2>AUTHOR</h2>
-Helmut Kudrnovsky
-<p>
-<i>Last changed: $Date: 2014-11-13 23:06:04 +0100 (Do, 13 Nov 2014) $</i>
+<h2>DESCRIPTION</h2>
+<em>v.in.gbif</em> imports <a href="http://www.gbif.org/">GBIF</a>
+species distribution data. The location must be in latlon (WGS84).
+<p>
+The species distribution data downloaded from <a href="http://www.gbif.org/">GBIF</a>
+hast to be unzipped before importing the csv file.
+</p>
+<p>
+<em>v.in.gbif</em> saves the data to a <a href="http://www.gdal.org">GDAL</a>
+<a href="http://www.gdal.org/drv_vrt.html">VRT - Virtual Datasource</a>
+which will be imported by <a href="v.in.ogr.html">v.in.ogr</a>. The VRT data set
+can be used in any GDAL aware software.
+As some column names in the original data set are similar to <a
+href="http://www.postgresql.org/docs/devel/static/sql-keywords-appendix.html">SQL reserverd key words</a>,
+the columns will renamed with the prefix <i>g_</i>.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+ v.in.gbif vector= cat=40102 dir=C:\tmp distance=25
+ v.in.gbif input=C:\data\0004248-150811131857512\0004248-150811131857512.csv output_vrt=chondrilla.vrt dir=C:\data\0004248-150811131857512\ output=chondrilla
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.in.ascii.html">v.in.ascii</a>
+<a href="v.in.ogr.html">v.in.ogr</a>
+</em>
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date$</i>
</p>
\ No newline at end of file
Property changes on: grass-addons/grass7/vector/v.in.gbif/v.in.gbif.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass-addons/grass7/vector/v.in.gbif/v.in.gbif.py
--- grass-addons/grass7/vector/v.in.gbif/v.in.gbif.py 2015-08-26 21:12:46 UTC (rev 66034)
+++ grass-addons/grass7/vector/v.in.gbif/v.in.gbif.py 2015-08-26 21:16:59 UTC (rev 66035)
@@ -1,174 +1,174 @@
-#!/usr/bin/env python
-MODULE: v.in.gbif
-AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
-PURPOSE: Imports GBIF species distribution data by saving original data to
- a GDAL VRT and importing the VRT by v.in.ogr
-COPYRIGHT: (C) 2015 by the GRASS Development Team
- This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
-#%module
-#% description: importing of GBIF species distribution data
-#% keyword: vector
-#% keyword: geometry
-#%end
-#%option G_OPT_F_INPUT
-#% key: input
-#% required: yes
-#%end
-#%option G_OPT_F_OUTPUT
-#% key: output_vrt
-#% description: VRT file (with vrt extension)
-#% required: yes
-#%end
-#%option G_OPT_M_DIR
-#% key: dir
-#% description: Directory where the output will be found
-#% required : yes
-#%end
-#%option G_OPT_V_OUTPUT
-#% key: output
-#% description: name of imported GBIF data set
-#% required : yes
-#%end
-import sys
-import os
-import csv
-import math
-import grass.script as grass
-if not os.environ.has_key("GISBASE"):
- grass.message( "You must be in GRASS GIS to run this program." )
- sys.exit(1)
-def main():
- # check for unsupported locations
- in_proj = grass.parse_command('g.proj', flags='g')
- if in_proj['unit'].lower() == 'Meter':
- grass.fatal(_("Projected locations are not supported"))
- if in_proj['unit'].lower() == 'US survey foot':
- if in_proj['name'].lower() == 'xy_location_unprojected':
- grass.fatal(_("xy-locations are not supported"))
- gbifraw = options['input']
- directory = options['dir']
- gbifvrt = options['output_vrt']
- gbifimported = options['output']
- gbif_vrt_layer = options['output_vrt'].split('.')[0]
- gbifcsv = gbif_vrt_layer+'.csv'
- global tmp
- # Extract vector line
- grass.message( "Starting importing GBIF data ..." )
- grass.message( "preparing data for vrt ..." )
- # new quoted GBIF csv file
- new_gbif_csv = os.path.join( directory, gbifcsv )
- # quote raw data
- with open('%s' % (gbifraw), 'rb') as csvinfile:
- gbifreader = csv.reader(csvinfile, delimiter='\t')
- with open ('%s' % (new_gbif_csv), 'wb') as csvoutfile:
- gbifwriter = csv.writer(csvoutfile, quotechar='"', quoting=csv.QUOTE_ALL)
- for row in gbifreader:
- gbifwriter.writerow(row)
- grass.message( "----" )
- # write vrt
- grass.message( "writing vrt ..." )
- new_gbif_vrt = os.path.join( directory, gbifvrt )
- f = open('%s' % (new_gbif_vrt), 'wt')
- f.write("""<OGRVRTDataSource>
- <OGRVRTLayer name="%s">
- <SrcDataSource relativeToVRT="1">%s</SrcDataSource>
- <GeometryType>wkbPoint</GeometryType>
- <LayerSRS>WGS84</LayerSRS>
- <Field name="g_gbifid" src="gbifid" type="Integer" />
- <Field name="g_datasetkey" src="datasetkey" type="String" width="255" />
- <Field name="g_occurrenceid" src="occurrenceid" type="String" width="255" />
- <Field name="g_kingdom" src="kingdom" type="String" width="50" />
- <Field name="g_phylum" src="phylum" type="String" width="50" />
- <Field name="g_class" src="class" type="String" width="50" />
- <Field name="g_order" src="order" type="String" width="50" />
- <Field name="g_family" src="family" type="String" width="100" />
- <Field name="g_genus" src="genus" type="String" width="255" />
- <Field name="g_species" src="species" type="String" width="255" />
- <Field name="g_infraspecificepithet" src="infraspecificepithet" type="String" width="100" />
- <Field name="g_taxonrank" src="taxonrank" type="String" width="50" />
- <Field name="g_scientificname" src="scientificname" type="String" width="255" />
- <Field name="g_countrycode" src="countrycode" type="String" width="25" />
- <Field name="g_locality" src="locality" type="String" width="255" />
- <Field name="g_publishingorgkey" src="publishingorgkey" type="String" width="255" />
- <Field name="g_decimallatitude" src="decimallatitude" type="Real" />
- <Field name="g_decimallongitude" src="decimallongitude" type="Real" />
- <Field name="g_elevation" src="elevation" type="Real" />
- <Field name="g_elevationaccuracy" src="elevationaccuracy" type="String" width="50" />
- <Field name="g_depth" src="depth" type="String" width="255" />
- <Field name="g_depthaccuracy" src="depthaccuracy" type="String" width="255" />
- <Field name="g_eventdate" src="eventdate" type="String" width="255" />
- <Field name="g_day" src="day" type="Integer" width="255" />
- <Field name="g_month" src="month" type="Integer" width="255" />
- <Field name="g_year" src="year" type="Integer" width="255" />
- <Field name="g_taxonkey" src="taxonkey" type="String" width="100" />
- <Field name="g_specieskey" src="specieskey" type="String" width="100" />
- <Field name="g_basisofrecord" src="basisofrecord" type="String" width="100" />
- <Field name="g_institutioncode" src="institutioncode" type="String" width="100" />
- <Field name="g_collectioncode" src="collectioncode" type="String" width="100" />
- <Field name="g_catalognumber" src="catalognumber" type="String" width="255" />
- <Field name="g_recordnumber" src="recordnumber" type="String" width="255" />
- <Field name="g_identifiedby" src="identifiedby" type="String" width="255" />
- <Field name="g_rights" src="rights" type="String" width="255" />
- <Field name="g_rightsholder" src="rightsholder" type="String" width="255" />
- <Field name="g_recordedby" src="recordedby" type="String" width="255" />
- <Field name="g_typestatus" src="typestatus" type="String" width="255" />
- <Field name="g_establishmentmeans" src="establishmentmeans" type="String" width="255" />
- <Field name="g_lastinterpreted" src="lastinterpreted" type="String" width="255" />
- <Field name="g_mediatype" src="mediatype" type="String" width="100" />
- <Field name="g_issue" src="issue" type="String" width="255" />
- <GeometryField encoding="PointFromColumns" x="decimallongitude" y="decimallatitude"/>
- </OGRVRTLayer>
- </OGRVRTDataSource>""" % (gbif_vrt_layer, gbifcsv) )
- f.close()
- # Give information where output file are saved
- grass.message( "GBIF vrt files:" )
- grass.message( gbifvrt )
- grass.message( "-" )
- grass.message( gbifcsv )
- grass.message( "are saved in:" )
- grass.message( directory )
- # import GBIF vrt
- grass.message( "importing GBIF vrt ..." )
- grass.run_command("v.in.ogr", input = new_gbif_vrt,
- layer = gbif_vrt_layer,
- output = gbifimported,
- quiet = True)
- grass.message( "..." )
- # v.in.gbif done!
- grass.message( "importing GBIF data done!" )
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+#!/usr/bin/env python
+MODULE: v.in.gbif
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE: Imports GBIF species distribution data by saving original data to
+ a GDAL VRT and importing the VRT by v.in.ogr
+COPYRIGHT: (C) 2015 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+#%module
+#% description: importing of GBIF species distribution data
+#% keyword: vector
+#% keyword: geometry
+#%end
+#%option G_OPT_F_INPUT
+#% key: input
+#% required: yes
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: output_vrt
+#% description: VRT file (with vrt extension)
+#% required: yes
+#%end
+#%option G_OPT_M_DIR
+#% key: dir
+#% description: Directory where the output will be found
+#% required : yes
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: output
+#% description: name of imported GBIF data set
+#% required : yes
+#%end
+import sys
+import os
+import csv
+import math
+import grass.script as grass
+if not os.environ.has_key("GISBASE"):
+ grass.message( "You must be in GRASS GIS to run this program." )
+ sys.exit(1)
+def main():
+ # check for unsupported locations
+ in_proj = grass.parse_command('g.proj', flags='g')
+ if in_proj['unit'].lower() == 'Meter':
+ grass.fatal(_("Projected locations are not supported"))
+ if in_proj['unit'].lower() == 'US survey foot':
+ if in_proj['name'].lower() == 'xy_location_unprojected':
+ grass.fatal(_("xy-locations are not supported"))
+ gbifraw = options['input']
+ directory = options['dir']
+ gbifvrt = options['output_vrt']
+ gbifimported = options['output']
+ gbif_vrt_layer = options['output_vrt'].split('.')[0]
+ gbifcsv = gbif_vrt_layer+'.csv'
+ global tmp
+ # Extract vector line
+ grass.message( "Starting importing GBIF data ..." )
+ grass.message( "preparing data for vrt ..." )
+ # new quoted GBIF csv file
+ new_gbif_csv = os.path.join( directory, gbifcsv )
+ # quote raw data
+ with open('%s' % (gbifraw), 'rb') as csvinfile:
+ gbifreader = csv.reader(csvinfile, delimiter='\t')
+ with open ('%s' % (new_gbif_csv), 'wb') as csvoutfile:
+ gbifwriter = csv.writer(csvoutfile, quotechar='"', quoting=csv.QUOTE_ALL)
+ for row in gbifreader:
+ gbifwriter.writerow(row)
+ grass.message( "----" )
+ # write vrt
+ grass.message( "writing vrt ..." )
+ new_gbif_vrt = os.path.join( directory, gbifvrt )
+ f = open('%s' % (new_gbif_vrt), 'wt')
+ f.write("""<OGRVRTDataSource>
+ <OGRVRTLayer name="%s">
+ <SrcDataSource relativeToVRT="1">%s</SrcDataSource>
+ <GeometryType>wkbPoint</GeometryType>
+ <LayerSRS>WGS84</LayerSRS>
+ <Field name="g_gbifid" src="gbifid" type="Integer" />
+ <Field name="g_datasetkey" src="datasetkey" type="String" width="255" />
+ <Field name="g_occurrenceid" src="occurrenceid" type="String" width="255" />
+ <Field name="g_kingdom" src="kingdom" type="String" width="50" />
+ <Field name="g_phylum" src="phylum" type="String" width="50" />
+ <Field name="g_class" src="class" type="String" width="50" />
+ <Field name="g_order" src="order" type="String" width="50" />
+ <Field name="g_family" src="family" type="String" width="100" />
+ <Field name="g_genus" src="genus" type="String" width="255" />
+ <Field name="g_species" src="species" type="String" width="255" />
+ <Field name="g_infraspecificepithet" src="infraspecificepithet" type="String" width="100" />
+ <Field name="g_taxonrank" src="taxonrank" type="String" width="50" />
+ <Field name="g_scientificname" src="scientificname" type="String" width="255" />
+ <Field name="g_countrycode" src="countrycode" type="String" width="25" />
+ <Field name="g_locality" src="locality" type="String" width="255" />
+ <Field name="g_publishingorgkey" src="publishingorgkey" type="String" width="255" />
+ <Field name="g_decimallatitude" src="decimallatitude" type="Real" />
+ <Field name="g_decimallongitude" src="decimallongitude" type="Real" />
+ <Field name="g_elevation" src="elevation" type="Real" />
+ <Field name="g_elevationaccuracy" src="elevationaccuracy" type="String" width="50" />
+ <Field name="g_depth" src="depth" type="String" width="255" />
+ <Field name="g_depthaccuracy" src="depthaccuracy" type="String" width="255" />
+ <Field name="g_eventdate" src="eventdate" type="String" width="255" />
+ <Field name="g_day" src="day" type="Integer" width="255" />
+ <Field name="g_month" src="month" type="Integer" width="255" />
+ <Field name="g_year" src="year" type="Integer" width="255" />
+ <Field name="g_taxonkey" src="taxonkey" type="String" width="100" />
+ <Field name="g_specieskey" src="specieskey" type="String" width="100" />
+ <Field name="g_basisofrecord" src="basisofrecord" type="String" width="100" />
+ <Field name="g_institutioncode" src="institutioncode" type="String" width="100" />
+ <Field name="g_collectioncode" src="collectioncode" type="String" width="100" />
+ <Field name="g_catalognumber" src="catalognumber" type="String" width="255" />
+ <Field name="g_recordnumber" src="recordnumber" type="String" width="255" />
+ <Field name="g_identifiedby" src="identifiedby" type="String" width="255" />
+ <Field name="g_rights" src="rights" type="String" width="255" />
+ <Field name="g_rightsholder" src="rightsholder" type="String" width="255" />
+ <Field name="g_recordedby" src="recordedby" type="String" width="255" />
+ <Field name="g_typestatus" src="typestatus" type="String" width="255" />
+ <Field name="g_establishmentmeans" src="establishmentmeans" type="String" width="255" />
+ <Field name="g_lastinterpreted" src="lastinterpreted" type="String" width="255" />
+ <Field name="g_mediatype" src="mediatype" type="String" width="100" />
+ <Field name="g_issue" src="issue" type="String" width="255" />
+ <GeometryField encoding="PointFromColumns" x="decimallongitude" y="decimallatitude"/>
+ </OGRVRTLayer>
+ </OGRVRTDataSource>""" % (gbif_vrt_layer, gbifcsv) )
+ f.close()
+ # Give information where output file are saved
+ grass.message( "GBIF vrt files:" )
+ grass.message( gbifvrt )
+ grass.message( "-" )
+ grass.message( gbifcsv )
+ grass.message( "are saved in:" )
+ grass.message( directory )
+ # import GBIF vrt
+ grass.message( "importing GBIF vrt ..." )
+ grass.run_command("v.in.ogr", input = new_gbif_vrt,
+ layer = gbif_vrt_layer,
+ output = gbifimported,
+ quiet = True)
+ grass.message( "..." )
+ # v.in.gbif done!
+ grass.message( "importing GBIF data done!" )
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.in.gbif/v.in.gbif.py
+ text/x-python
+ native
