[GRASS-SVN] r66036 - in grass/trunk: gui/wxpython/core lib/python/script
svn_grass at osgeo.org
Wed Aug 26 14:24:29 PDT 2015
Author: annakrat
Date: 2015-08-26 14:24:29 -0700 (Wed, 26 Aug 2015)
New Revision: 66036
grass/trunk/gui/wxpython/core/toolboxes.py
grass/trunk/lib/python/script/task.py
wxGUI: fix loading addons (with different locale) which are compiled for different version - use only byte strings
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py 2015-08-26 21:16:59 UTC (rev 66035)
+++ grass/trunk/gui/wxpython/core/toolboxes.py 2015-08-26 21:24:29 UTC (rev 66036)
@@ -628,12 +628,6 @@
try:
task = gtask.parse_interface(module)
except ScriptError as e:
- e = _encode_string(e.value)
- # for some reason this works well only if it is separate
- sys.stderr.write("%s\n" % module)
- sys.stderr.write("%s\n" % e)
- return '', ''
- except UnicodeDecodeError as e:
sys.stderr.write("%s\n%s\n" % (module, e))
return '', ''
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py 2015-08-26 21:16:59 UTC (rev 66035)
+++ grass/trunk/lib/python/script/task.py 2015-08-26 21:24:29 UTC (rev 66036)
@@ -493,7 +493,7 @@
if p.returncode != 0:
raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
- "\n\nDetails: %(det)s") % {'cmd': cmd, 'det': decode(cmderr)}
+ "\n\nDetails: %(det)s") % {'cmd': cmd, 'det': cmderr}
except OSError as e:
