[GRASS-SVN] r66037 - grass/trunk/man
Wed Aug 26 17:31:43 PDT 2015
Author: wenzeslaus
Date: 2015-08-26 17:31:43 -0700 (Wed, 26 Aug 2015)
New Revision: 66037
Added:
   grass/trunk/man/build_class_graphical.py
   grass/trunk/man/Makefile
   grass/trunk/man/build_html.py
docs: build same pages as for module families/categories/classes but with images
Images are indentified based on the module name which is determined from the HTML file name.
Modified: grass/trunk/man/Makefile
--- grass/trunk/man/Makefile	2015-08-26 21:24:29 UTC (rev 66036)
+++ grass/trunk/man/Makefile	2015-08-27 00:31:43 UTC (rev 66037)
@@ -23,7 +23,7 @@
 IDXCATS := $(foreach cat,$(categories),$(lastword $(subst :, ,$(cat))))
-IDXSRC = full_index index topics keywords graphical_index $(IDXCATS)
+IDXSRC = full_index index topics keywords graphical_index class_graphical $(IDXCATS)
 INDICES := $(patsubst %,$(HTMLDIR)/%.html,$(IDXSRC))
@@ -73,6 +73,12 @@
 	$(PYTHON) ./build_graphical_index.py $(HTMLDIR)
 endef
+define build_class_graphical
+GISBASE="$(RUN_GISBASE)" ARCH="$(ARCH)" ARCH_DISTDIR="$(ARCH_DISTDIR)" \
+	VERSION_NUMBER=$(GRASS_VERSION_NUMBER) VERSION_DATE=$(GRASS_VERSION_DATE) \
+	$(PYTHON) ./build_class_graphical.py $(HTMLDIR)
+endef
 $(HTMLDIR)/topics.html: $(ALL_HTML)
 	$(call build_topics)
 	touch $@
@@ -93,6 +99,11 @@
 	$(call build_graphical_index)
 	touch $@
+# TODO: this should be done in the same way as category_rule
+$(HTMLDIR)/class_graphical.html: $(ALL_HTML)
+	$(call build_class_graphical)
+	touch $@
 define category_rule
 $$(HTMLDIR)/$(2).html: $$(wildcard $$(HTMLDIR)/$(1).*.html) build_class.py build_html.py
 	$$(call build,class,$(1) $(2))
Added: grass/trunk/man/build_class_graphical.py
--- grass/trunk/man/build_class_graphical.py	                        (rev 0)
+++ grass/trunk/man/build_class_graphical.py	2015-08-27 00:31:43 UTC (rev 66037)
@@ -0,0 +1,238 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:    build_class_graphical
+# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE:   Build page with modules per family/class/category with images
+# COPYRIGHT: (C) 2015 by Vaclav Petras and the GRASS Development Team
+#        This program is free software under the GNU General Public
+#        License (>=v2). Read the file COPYING that comes with GRASS
+#        for details.
+import sys
+import os
+import fnmatch
+#from build_html import *
+from build_html import (
+    default_year, header1_tmpl, grass_version,
+    modclass_intro_tmpl, to_title, html_files,
+    check_for_desc_override, get_desc, write_html_footer, replace_file,
+header_graphical_index_tmpl = """\
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+<style>
+.img-list {
+    margin: 0;
+    padding: 0;
+    list-style-type: none;
+.img-list li {
+    padding: 5px;
+    overflow: auto;
+.img-list li:hover {
+    background-color: #eee;
+.img-list li a {
+    color: initial;
+    text-decoration: none;
+    display: block;
+.img-list li img {
+    width: 10%;
+    float: left;
+    margin: 0 15px 0 0;
+    background: white;
+.img-list li img.default-img {
+    width: 40px;
+    padding-left: 30px;
+    padding-right: 30px;
+.img-list li .desc {
+    margin: 0px;
+.img-list li .name {
+    margin: 5px;
+    display: block;
+    color: #409940;
+    font-weight: bold;
+    font-style: italic;
+</style>
+</head>
+<body style="width: 99%">
+<div id="container">
+<a href="index.html"><img src="grass_logo.png" alt="GRASS logo"></a>
+<hr class="header">
+<h2>Graphical index of GRASS GIS modules</h2>
+def file_matches(filename, patterns):
+    for pattern in patterns:
+        if fnmatch.fnmatch(filename, pattern):
+            return True
+    return False
+def starts_with_module(string, module):
+    # not solving:
+    # module = module.replace('wxGUI.', 'g.gui.')
+    # TODO: matches g.mapsets images for g.mapset and d.rast.num for d.rast
+    if string.startswith(module.replace('.', '_')):
+        return True
+    if string.startswith(module.replace('.', '')):
+        return True
+    if string.startswith(module):
+        return True
+    return False
+def get_module_image(module, images):
+    candidates = []
+    for image in images:
+        if starts_with_module(image, module):
+            candidates.append(image)
+    if len(candidates) == 1:
+        # matches g.mapsets images for g.mapset and d.rast.num for d.rast
+        return candidates[0]
+    if not candidates:
+        return None
+    for image in candidates:
+        basename, unused = image.rsplit('.', 1)
+        if basename == module.replace('.', '_'):
+            return image
+        if basename == module.replace('.', ''):
+            return image
+        if basename == module:
+            return image
+    return sorted(candidates,
+                  lambda first, second: cmp(len(first), len(second)))[0]
+def generate_page_for_category(short_family, module_family, imgs, year,
+                               skip_no_image=False):
+    filename = module_family + "_graphical.html"
+    output = open(filename + ".tmp", 'wb')
+    output.write(header1_tmpl.substitute(
+        title="GRASS GIS %s Reference "
+              "Manual: Graphical index" % grass_version))
+    output.write(header_graphical_index_tmpl)
+    if module_family.lower() not in ['general', 'misc', 'postscript']:
+        if module_family == 'raster3d':
+            # covert keyword to nice form
+            module_family = '3D raster'
+        output.write(modclass_intro_tmpl.substitute(
+            modclass=module_family, modclass_lower=module_family.lower()))
+    if module_family == 'wxGUI':
+        output.write("<h3>wxGUI components:</h3>")
+    elif module_family == 'guimodules':
+        output.write("<h3>g.gui.* modules:</h3>")
+    else:
+        output.write("<h3>{} modules:</h3>".format(to_title(module_family)))
+    output.write('<ul class="img-list">')
+    #for all modules:
+    for cmd in html_files(short_family, ignore_gui=False):
+        basename = os.path.splitext(cmd)[0]
+        desc = check_for_desc_override(basename)
+        if desc is None:
+            desc = get_desc(cmd)
+        img = get_module_image(basename, imgs)
+        img_class = 'linkimg'
+        if skip_no_image and not img:
+            continue
+        elif not img:
+            img = 'grass_logo.png'
+            img_class = 'default-img'
+        if basename.startswith('wxGUI'):
+            basename = basename.replace('.', ' ')
+        output.write(
+            '<li>'
+            '<a href="{html}">'
+            '<img class="{img_class}" src="{img}">'
+            '<span class="name">{name}</span> '
+            '<span class="desc">{desc}</span>'
+            '</a>'
+            '</li>'
+            .format(html=cmd, img=img, name=basename,
+                    desc=desc, img_class=img_class))
+    output.write('</ul>')
+    write_html_footer(output, "index.html", year)
+    output.close()
+    replace_file(filename)
+# TODO: dependencies in makefile for this have to be fixed
+# TODO: there is a potential overlap with other scripts (-> refactoring)
+def main():
+    year = default_year
+    html_dir = sys.argv[1]
+    os.chdir(html_dir)
+    img_extensions = ['png', 'jpg', 'gif']
+    img_patterns = ['*.' + extension for extension in img_extensions]
+    imgs = []
+    for filename in os.listdir(html_dir):
+        if file_matches(filename, img_patterns):
+            imgs.append(filename)
+    # using term family
+    # category has its meaning in GRASS already
+    # class has its meaning in Python, plus it is a synonym for category
+    # TODO: what would be user friendly is unclear
+    families = [
+        ('d', 'display'),
+        ('db', 'database'),
+        ('g', 'general'),
+        ('i', 'imagery'),
+        ('m', 'misc'),
+        ('ps', 'postscript'),
+        ('r', 'raster'),
+        ('r3', 'raster3d'),
+        ('t', 'temporal'),
+        ('v', 'vector'),
+        ('wxGUI', 'wxGUI'),
+        ('g.gui', 'guimodules'),
+    # partial compatibility with build_class.py
+    # first arg is dist html dir but the 3 other are like first 3 there
+    if len(sys.argv) > 2:
+        short_family = sys.argv[2]
+        module_family = sys.argv[3]
+        classes = [(short_family, module_family)]
+        if len(sys.argv) > 4:
+            year = sys.argv[4]
+    for short_family, module_family in families:
+        generate_page_for_category(short_family, module_family, imgs,
+                                   year=year, skip_no_image=True)
+if __name__ == '__main__':
+    main()
Modified: grass/trunk/man/build_html.py
--- grass/trunk/man/build_html.py	2015-08-26 21:24:29 UTC (rev 66036)
+++ grass/trunk/man/build_html.py	2015-08-27 00:31:43 UTC (rev 66037)
@@ -359,14 +359,14 @@
 def copy_file(src, dst):
     write_file(dst, read_file(src))
-def html_files(cls = None):
+def html_files(cls=None, ignore_gui=True):
     for cmd in sorted(os.listdir(html_dir)):
         if cmd.endswith(".html") and \
            (cls in [None, '*'] or cmd.startswith(cls + ".")) and \
            (cls != '*' or len(cmd.split('.')) >= 3) and \
            cmd not in ["full_index.html", "index.html"] and \
            cmd not in exclude_mods and \
-           not cmd.startswith("wxGUI."):
+           (ignore_gui and not cmd.startswith("wxGUI.") or not ignore_gui):
             yield cmd
 def write_html_header(f, title, ismain = False, body_width = "99%"):
