[GRASS-SVN] r66052 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial
svn_grass at osgeo.org
Fri Aug 28 07:30:29 PDT 2015
Author: Giulia
Date: 2015-08-28 07:30:29 -0700 (Fri, 28 Aug 2015)
New Revision: 66052
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
r.green: struct as optional parameter and renamed all the tmp files
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py 2015-08-28 13:15:23 UTC (rev 66051)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py 2015-08-28 14:30:29 UTC (rev 66052)
@@ -26,7 +26,7 @@
#%option G_OPT_V_INPUT
#% key: struct
#% label: Name of the input vector map with the structure of the plants
-#% required: yes
+#% required: no
#%end
@@ -499,7 +499,7 @@
import random
import numpy as np
+from grass.script import core as gcore
from grass.exceptions import ParameterError
from grass.script.core import parser, overwrite, warning
from grass.pygrass.modules.shortcuts import raster as r
@@ -528,7 +528,7 @@
def rname(base):
- return '%s_%03d' % (base, random.randint(0, 1000))
+ return 'tmprgreen_%i_%s' % (os.getpid(), base)
def check_raster_or_landuse(opts, params):
@@ -844,14 +844,20 @@
def main(opts, flgs):
+ pid = os.getpid()
+ pat = "tmprgreen_%i_*" % pid
+ atexit.register(cleanup,
+ pattern=pat,
+ debug=False)
# check or generate raster map from rules files
ecovalues = ['landvalue', 'tributes', 'stumpage', 'rotation', 'age',
'min_exc', 'max_exc']
(lan, tri, stu, rot, age,
excmin, excmax) = check_raster_or_landuse(opts, ecovalues)
- upper = opts['upper'] if opts['upper'] else 'tmp_upper'
- comp = opts['compensation'] if opts['compensation'] else 'tmp_compensation'
- exc = opts['excavation'] if opts['excavation'] else 'tmp_excavation'
+ upper = opts['upper'] if opts['upper'] else ('tmprgreen_%i_upper' % pid)
+ comp = opts['compensation'] if opts['compensation'] else ('tmprgreen_%i_compensation' % pid)
+ exc = opts['excavation'] if opts['excavation'] else ('tmprgreen_%i_excavation' % pid)
vlayer = int(opts['struct_layer'])
plant, mset = (opts['plant'].split('@') if '@' in opts['plant'] else (opts['plant'], ''))
@@ -1003,27 +1009,27 @@
function=max_NPV,
exclude=['intake_id', 'side', 'power',
'gross_head', 'discharge'])
- vec = VectorTopo(opts['output_struct'])
- vec.open('rw')
- vec.table.columns.add('max_NPV','VARCHAR(3)')
- list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
+ if opts['output_struct']:
+ vec = VectorTopo(opts['output_struct'])
+ vec.open('rw')
+ vec.table.columns.add('max_NPV','VARCHAR(3)')
+ list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
+ for i in range(0,len(list_intakeid)):
+ vec.rewind()
+ list_npv=list(vec.table.execute('SELECT NPV FROM %s WHERE intake_id=%i;' % (vec.table.name, list_intakeid[i][0])).fetchall())
+ npvmax=max(list_npv)[0]
+ for line in vec:
+ if line.attrs['intake_id'] == list_intakeid[i][0]:
+ if line.attrs['NPV'] == npvmax:
+ line.attrs['max_NPV']='yes'
+ else:
+ line.attrs['max_NPV']='no'
- for i in range(0,len(list_intakeid)):
- vec.rewind()
- list_npv=list(vec.table.execute('SELECT NPV FROM %s WHERE intake_id=%i;' % (vec.table.name, list_intakeid[i][0])).fetchall())
- npvmax=max(list_npv)[0]
- for line in vec:
- if line.attrs['intake_id'] == list_intakeid[i][0]:
- if line.attrs['NPV'] == npvmax:
- line.attrs['max_NPV']='yes'
- else:
- line.attrs['max_NPV']='no'
+ vec.table.conn.commit()
+ vec.close()
- vec.table.conn.commit()
- vec.close()
if __name__ == "__main__":
main(*parser())
