[GRASS-SVN] r66053 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical
svn_grass at osgeo.org
Fri Aug 28 07:31:20 PDT 2015
Author: Giulia
Date: 2015-08-28 07:31:20 -0700 (Fri, 28 Aug 2015)
New Revision: 66053
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
r.green: several bugs on input and output files
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2015-08-28 14:30:29 UTC (rev 66052)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2015-08-28 14:31:20 UTC (rev 66053)
@@ -662,7 +662,7 @@
contour=options['contour'], overwrite=gcore.overwrite())
if options['resolution']:
struct_opts['resolution'] = options['resolution']
- gcore.run_command('r.green.hydro.strucintake_idture', **struct_opts)
+ gcore.run_command('r.green.hydro.structure', **struct_opts)
gcore.run_command('v.build', map=output_struct)
