[GRASS-SVN] r67040 - in grass/trunk: include/vect lib/vector/Vlib
svn_grass at osgeo.org
Tue Dec 8 15:54:18 PST 2015
Author: martinl
Date: 2015-12-08 15:54:17 -0800 (Tue, 08 Dec 2015)
New Revision: 67040
grass/trunk/include/vect/dig_defines.h
grass/trunk/lib/vector/Vlib/build_pg.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/Vlib/write_pg.c
rename SF_UNKNOWN to SF_GEOMETRY (SF_UNKNOWN defined in oaidl.h on Windows)
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h 2015-12-08 23:37:07 UTC (rev 67039)
+++ grass/trunk/include/vect/dig_defines.h 2015-12-08 23:54:17 UTC (rev 67040)
@@ -233,7 +233,7 @@
typedef enum
- SF_UNKNOWN = 0, /* unknown type, non-standard */
+ SF_GEOMETRY = 0, /* unknown type, non-standard */
SF_POINT = 1, /* 0-dimensional geometric object */
SF_LINESTRING = 2, /* 1-dimensional geometric object with linear
interpolation between Points */
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2015-12-08 23:37:07 UTC (rev 67039)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2015-12-08 23:54:17 UTC (rev 67040)
@@ -71,7 +71,7 @@
return 0;
pg_info->inTransaction = FALSE;
- if (pg_info->feature_type == SF_UNKNOWN)
+ if (pg_info->feature_type == SF_GEOMETRY)
return 1;
if (build == plus->built)
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2015-12-08 23:37:07 UTC (rev 67039)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2015-12-08 23:54:17 UTC (rev 67040)
@@ -290,7 +290,7 @@
pg_info->cache.fid = -1;
/* unknown feature type */
- pg_info->feature_type = SF_UNKNOWN;
+ pg_info->feature_type = SF_GEOMETRY;
PQclear(res);
@@ -425,7 +425,7 @@
else if (G_strcasecmp(type, "GEOMETRYCOLLECTION") == 0)
return SF_GEOMETRYCOLLECTION;
else
- return SF_UNKNOWN;
+ return SF_GEOMETRY;
G_debug(3, "ftype_from_string(): type='%s' -> %d", type, sf_type);
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2015-12-08 23:37:07 UTC (rev 67039)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2015-12-08 23:54:17 UTC (rev 67040)
@@ -478,7 +478,7 @@
return (int)sf_type;
- if (sf_type == SF_UNKNOWN || sf_type == SF_NONE) {
+ if (sf_type == SF_GEOMETRY || sf_type == SF_NONE) {
G_warning(_("Feature without geometry. Skipped."));
pg_info->cache.lines_next = pg_info->cache.lines_num = 0;
continue;
@@ -752,7 +752,7 @@
\param[out] fparts used for building pseudo-topology (or NULL)
\return simple feature type
- \return SF_UNKNOWN on error
+ \return SF_GEOMETRY on error
SF_FeatureType Vect__cache_feature_pg(const char *data, int skip_polygon,
int force_type,
@@ -785,7 +785,7 @@
if (nbytes > 0) {
G_debug(3, "Vect__cache_feature_pg(): invalid geometry");
G_warning(_("Invalid WKB content: %d bytes"), nbytes);
else {
G_debug(3, "Vect__cache_feature_pg(): no geometry");
@@ -803,7 +803,7 @@
G_warning(_("Reading EWKB with 4-dimensional coordinates (XYZM) "
"is not supported"));
/* G_free(wkb_data); */
/* PostGIS EWKB format includes an SRID, but this won't be
@@ -823,7 +823,7 @@
if (nbytes < 9 && nbytes != -1) {
/* Get the geometry feature type. For now we assume that geometry
@@ -891,7 +891,7 @@
- return ret > 0 ? ftype : SF_UNKNOWN;
+ return ret > 0 ? ftype : SF_GEOMETRY;
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2015-12-08 23:37:07 UTC (rev 67039)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2015-12-08 23:54:17 UTC (rev 67040)
@@ -104,7 +104,7 @@
pg_info = &(Map->fInfo.pg);
- if (pg_info->feature_type == SF_UNKNOWN) {
+ if (pg_info->feature_type == SF_GEOMETRY) {
/* create PostGIS table if doesn't exist */
if (create_pg_layer(Map, type) < 0)
return -1;
@@ -730,7 +730,7 @@
case (SF_POLYGON25D):
geom_type = "POLYGONZ";
break;
- case (SF_UNKNOWN):
+ case (SF_GEOMETRY):
geom_type = "GEOMETRY";
break;
default:
@@ -1098,7 +1098,7 @@
pg_info->feature_type = SF_POLYGON25D;
break;
case -2:
break;
default:
G_warning(_("Unsupported geometry type (%d)"), type);
@@ -1169,7 +1169,7 @@
return "LINE";
else if (sftype == SF_POLYGON)
return "POLYGON";
- else if (sftype == SF_UNKNOWN || sftype == SF_GEOMETRYCOLLECTION)
+ else if (sftype == SF_GEOMETRY || sftype == SF_GEOMETRYCOLLECTION)
return "COLLECTION";
else
G_warning(_("Unsupported feature type %d"), sftype);
@@ -1218,7 +1218,7 @@
return -1;
@@ -1374,7 +1374,7 @@
return -1;
