[GRASS-SVN] r67215 - in grass/trunk/lib: raster raster3d
svn_grass at osgeo.org
Fri Dec 18 00:37:56 PST 2015
Author: mmetz
Date: 2015-12-18 00:37:56 -0800 (Fri, 18 Dec 2015)
New Revision: 67215
grass/trunk/lib/raster/init.c
grass/trunk/lib/raster/open.c
grass/trunk/lib/raster/put_row.c
grass/trunk/lib/raster3d/fpcompress.c
rasterlib, raster3dlib: use new compression fns
Modified: grass/trunk/lib/raster/init.c
--- grass/trunk/lib/raster/init.c 2015-12-18 08:30:15 UTC (rev 67214)
+++ grass/trunk/lib/raster/init.c 2015-12-18 08:37:56 UTC (rev 67215)
@@ -77,7 +77,7 @@
static int init(void)
- char *zlib, *nulls;
+ char *zlib, *nulls, *ctype;
Rast__init_window();
@@ -96,6 +96,18 @@
zlib = getenv("GRASS_INT_ZLIB");
R__.compression_type = (!zlib || atoi(zlib)) ? 2 : 1;
+ ctype = getenv("GRASS_COMPRESSOR");
+ /* 1: RLE
+ * 2: ZLIB (DEFLATE)
+ * 3: LZ4
+ * 4: BZIP2 */
+ if (ctype) {
+ /* ask gislib */
+ R__.compression_type = G_get_compressor(ctype);
+ if (R__.compression_type < 1)
+ R__.compression_type = 2; /* default to ZLIB */
nulls = getenv("GRASS_COMPRESS_NULLS");
R__.compress_nulls = (nulls && atoi(nulls)) ? 1 : 0;
Modified: grass/trunk/lib/raster/open.c
--- grass/trunk/lib/raster/open.c 2015-12-18 08:30:15 UTC (rev 67214)
+++ grass/trunk/lib/raster/open.c 2015-12-18 08:37:56 UTC (rev 67215)
@@ -217,6 +217,21 @@
r_name, r_mapset);
+ /* compressor */
+ if (MAP_TYPE != CELL_TYPE) {
+ /* fp maps do not use RLE */
+ /* previously, compressed simply meant yes (ZLIB) or no
+ * now compressed encodes compressor type
+ * 0: not compressed
+ * 1, 2: ZLIB
+ * 3: LZ4
+ * 4: BZIP2
+ * etc */
+ if (cellhd.compressed == 1)
+ cellhd.compressed = 2;
+ /* TODO: test if compressor type is supported */
if (cellhd.proj != R__.rd_window.proj)
G_fatal_error(_("Raster map <%s> is in different projection than current region. "
"Found <%s>, should be <%s>."),
@@ -634,6 +649,8 @@
fcb->cellhd = R__.wr_window;
if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
@@ -657,6 +674,11 @@
Rast_quant_init(&(fcb->quant));
+ if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type != CELL_TYPE &&
+ fcb->cellhd.compressed == 1) {
+ fcb->cellhd.compressed = 2;
/* save name and mapset, and tempfile name */
fcb->name = map;
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c 2015-12-18 08:30:15 UTC (rev 67214)
+++ grass/trunk/lib/raster/put_row.c 2015-12-18 08:37:56 UTC (rev 67215)
@@ -122,12 +122,12 @@
row, fcb->name, strerror(errno));
-static void write_data_compressed(int fd, int row, unsigned char *buf, int n)
+static void write_data_compressed(int fd, int row, unsigned char *buf, int n, int compressor)
struct fileinfo *fcb = &R__.fileinfo[fd];
int nwrite = fcb->nbytes * n;
- if (G_zlib_write(fcb->data_fd, buf, nwrite) < 0)
+ if (G_write_compressed(fcb->data_fd, buf, nwrite, compressor) < 0)
G_fatal_error(_("Error writing compressed FP data for row %d of <%s>: %s"),
@@ -205,7 +205,7 @@
convert_double(work_buf, size, null_buf, rast, row, n);
if (compressed)
- write_data_compressed(fd, row, work_buf, n);
+ write_data_compressed(fd, row, work_buf, n, fcb->cellhd.compressed);
else
write_data(fd, row, work_buf, n);
@@ -322,15 +322,6 @@
n -= count;
- return nwrite;
-static int zlib_compress(unsigned char *dst, unsigned char *src, int n,
- int nbytes)
- int total = nbytes * n;
- int nwrite = G_zlib_compress(src, total, dst, total);
return (nwrite >= total) ? 0 : nwrite;
@@ -338,7 +329,7 @@
int row, int n, int zeros_r_nulls)
- int compressed = fcb->cellhd.compressed;
+ int compressed = (fcb->open_mode == OPEN_NEW_COMPRESSED);
int len = compressed ? sizeof(CELL) : fcb->nbytes;
unsigned char *work_buf, *wk;
ssize_t nwrite;
@@ -379,10 +370,16 @@
compressed_buf[0] = work_buf[0] = nbytes;
/* then compress the data */
- nwrite = compressed == 1
- ? rle_compress(compressed_buf + 1, work_buf + 1, n, nbytes)
- : zlib_compress(compressed_buf + 1, work_buf + 1, n, nbytes);
+ if (fcb->cellhd.compressed == 1)
+ nwrite = rle_compress(compressed_buf + 1, work_buf + 1, n, nbytes);
+ else {
+ nwrite = G_compress(work_buf + 1, total, compressed_buf + 1, total,
+ fcb->cellhd.compressed);
+ if (nwrite >= total)
+ nwrite = 0;
if (nwrite > 0) {
nwrite++;
@@ -508,9 +505,9 @@
compressed_buf = G_alloca(size + 1);
- nwrite = G_zlib_compress(flags, size, compressed_buf, size);
+ nwrite = G_compress(flags, size, compressed_buf, size, fcb->cellhd.compressed);
- if (nwrite < size) {
+ if (nwrite > 0 && nwrite < size) {
if (write(fcb->null_fd, compressed_buf, nwrite) != nwrite)
G_fatal_error(_("Error writing compressed null data for row %d of <%s>"),
row, fcb->name);
Modified: grass/trunk/lib/raster3d/fpcompress.c
--- grass/trunk/lib/raster3d/fpcompress.c 2015-12-18 08:30:15 UTC (rev 67214)
+++ grass/trunk/lib/raster3d/fpcompress.c 2015-12-18 08:37:56 UTC (rev 67215)
@@ -704,7 +704,7 @@
&nBytes, &offsetMantissa);
*compressBuf = 0;
- status = G_zlib_write(fd, (unsigned char *)compressBuf, nBytes + 1);
+ status = G_write_compressed(fd, (unsigned char *)compressBuf, nBytes + 1, 2);
if (status < 0) {
Rast3d_error("Rast3d_fpcompress_write_xdr_nums: write error");
@@ -726,8 +726,8 @@
char *src, *dest, *srcStop;
nBytes = (isFloat ? XDR_FLOAT_LENGTH : XDR_DOUBLE_LENGTH);
- status = G_zlib_read(fd, fileBytes, (unsigned char *)compressBuf,
- nofNum * nBytes + 1);
+ status = G_read_compressed(fd, fileBytes, (unsigned char *)compressBuf,
+ nofNum * nBytes + 1, 2);
if (status < 0) {
Rast3d_error("Rast3d_fpcompress_read_xdr_nums: read error");
