[GRASS-SVN] r67216 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Dec 18 00:42:45 PST 2015
Author: mmetz
Date: 2015-12-18 00:42:45 -0800 (Fri, 18 Dec 2015)
New Revision: 67216
Added:
grass/trunk/lib/gis/lz4.c
grass/trunk/lib/gis/lz4.h
libgis: include lz4
Added: grass/trunk/lib/gis/lz4.c
--- grass/trunk/lib/gis/lz4.c (rev 0)
+++ grass/trunk/lib/gis/lz4.c 2015-12-18 08:42:45 UTC (rev 67216)
@@ -0,0 +1,1516 @@
+ LZ4 - Fast LZ compression algorithm
+ Copyright (C) 2011-2015, Yann Collet.
+ BSD 2-Clause License (http://www.opensource.org/licenses/bsd-license.php)
+ Redistribution and use in source and binary forms, with or without
+ modification, are permitted provided that the following conditions are
+ met:
+ * Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+ * Redistributions in binary form must reproduce the above
+ copyright notice, this list of conditions and the following disclaimer
+ in the documentation and/or other materials provided with the
+ distribution.
+ THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+ A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ You can contact the author at :
+ - LZ4 source repository : https://github.com/Cyan4973/lz4
+ - LZ4 public forum : https://groups.google.com/forum/#!forum/lz4c
+* Tuning parameters
+ * HEAPMODE :
+ * Select how default compression functions will allocate memory for their hash table,
+ * in memory stack (0:default, fastest), or in memory heap (1:requires malloc()).
+#define HEAPMODE 0
+ * ACCELERATION_DEFAULT :
+ * Select "acceleration" for LZ4_compress_fast() when parameter value <= 0
+#define ACCELERATION_DEFAULT 1
+* CPU Feature Detection
+ * LZ4_FORCE_SW_BITCOUNT
+ * Define this parameter if your target system or compiler does not support hardware bit count
+#if defined(_MSC_VER) && defined(_WIN32_WCE) /* Visual Studio for Windows CE does not support Hardware bit count */
+# define LZ4_FORCE_SW_BITCOUNT
+#endif
+* Includes
+#include "lz4.h"
+* Compiler Options
+#ifdef _MSC_VER /* Visual Studio */
+# define FORCE_INLINE static __forceinline
+# include <intrin.h>
+# pragma warning(disable : 4127) /* disable: C4127: conditional expression is constant */
+# pragma warning(disable : 4293) /* disable: C4293: too large shift (32-bits) */
+#else
+# if defined(__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */
+# if defined(__GNUC__) || defined(__clang__)
+# define FORCE_INLINE static inline __attribute__((always_inline))
+# else
+# endif
+# else
+# endif /* __STDC_VERSION__ */
+#endif /* _MSC_VER */
+/* LZ4_GCC_VERSION is defined into lz4.h */
+#if (LZ4_GCC_VERSION >= 302) || (__INTEL_COMPILER >= 800) || defined(__clang__)
+# define expect(expr,value) (__builtin_expect ((expr),(value)) )
+#else
+# define expect(expr,value) (expr)
+#endif
+#define likely(expr) expect((expr) != 0, 1)
+#define unlikely(expr) expect((expr) != 0, 0)
+* Memory routines
+#include <stdlib.h> /* malloc, calloc, free */
+#define ALLOCATOR(n,s) calloc(n,s)
+#define FREEMEM free
+#include <string.h> /* memset, memcpy */
+#define MEM_INIT memset
+* Basic Types
+#if defined (__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */
+# include <stdint.h>
+ typedef uint8_t BYTE;
+ typedef uint16_t U16;
+ typedef uint32_t U32;
+ typedef int32_t S32;
+ typedef uint64_t U64;
+#else
+ typedef unsigned char BYTE;
+ typedef unsigned short U16;
+ typedef unsigned int U32;
+ typedef signed int S32;
+ typedef unsigned long long U64;
+#endif
+* Reading and writing into memory
+#define STEPSIZE sizeof(size_t)
+static unsigned LZ4_64bits(void) { return sizeof(void*)==8; }
+static unsigned LZ4_isLittleEndian(void)
+ const union { U32 i; BYTE c[4]; } one = { 1 }; /* don't use static : performance detrimental */
+ return one.c[0];
+static U16 LZ4_read16(const void* memPtr)
+ U16 val16;
+ memcpy(&val16, memPtr, 2);
+ return val16;
+static U16 LZ4_readLE16(const void* memPtr)
+ if (LZ4_isLittleEndian())
+ return LZ4_read16(memPtr);
+ else
+ const BYTE* p = (const BYTE*)memPtr;
+ return (U16)((U16)p[0] + (p[1]<<8));
+static void LZ4_writeLE16(void* memPtr, U16 value)
+ memcpy(memPtr, &value, 2);
+ else
+ BYTE* p = (BYTE*)memPtr;
+ p[0] = (BYTE) value;
+ p[1] = (BYTE)(value>>8);
+static U32 LZ4_read32(const void* memPtr)
+ U32 val32;
+ memcpy(&val32, memPtr, 4);
+ return val32;
+static U64 LZ4_read64(const void* memPtr)
+ U64 val64;
+ memcpy(&val64, memPtr, 8);
+ return val64;
+static size_t LZ4_read_ARCH(const void* p)
+ if (LZ4_64bits())
+ return (size_t)LZ4_read64(p);
+ else
+ return (size_t)LZ4_read32(p);
+static void LZ4_copy4(void* dstPtr, const void* srcPtr) { memcpy(dstPtr, srcPtr, 4); }
+static void LZ4_copy8(void* dstPtr, const void* srcPtr) { memcpy(dstPtr, srcPtr, 8); }
+/* customized version of memcpy, which may overwrite up to 7 bytes beyond dstEnd */
+static void LZ4_wildCopy(void* dstPtr, const void* srcPtr, void* dstEnd)
+ BYTE* d = (BYTE*)dstPtr;
+ const BYTE* s = (const BYTE*)srcPtr;
+ BYTE* e = (BYTE*)dstEnd;
+ do { LZ4_copy8(d,s); d+=8; s+=8; } while (d<e);
+* Common Constants
+#define MINMATCH 4
+#define COPYLENGTH 8
+#define LASTLITERALS 5
+#define MFLIMIT (COPYLENGTH+MINMATCH)
+static const int LZ4_minLength = (MFLIMIT+1);
+#define KB *(1 <<10)
+#define MB *(1 <<20)
+#define GB *(1U<<30)
+#define MAXD_LOG 16
+#define MAX_DISTANCE ((1 << MAXD_LOG) - 1)
+#define ML_BITS 4
+#define ML_MASK ((1U<<ML_BITS)-1)
+#define RUN_BITS (8-ML_BITS)
+#define RUN_MASK ((1U<<RUN_BITS)-1)
+* Common Utils
+#define LZ4_STATIC_ASSERT(c) { enum { LZ4_static_assert = 1/(int)(!!(c)) }; } /* use only *after* variable declarations */
+* Common functions
+static unsigned LZ4_NbCommonBytes (register size_t val)
+ if (LZ4_64bits())
+# if defined(_MSC_VER) && defined(_WIN64) && !defined(LZ4_FORCE_SW_BITCOUNT)
+ unsigned long r = 0;
+ _BitScanForward64( &r, (U64)val );
+ return (int)(r>>3);
+# elif (defined(__clang__) || (LZ4_GCC_VERSION >= 304)) && !defined(LZ4_FORCE_SW_BITCOUNT)
+ return (__builtin_ctzll((U64)val) >> 3);
+# else
+ static const int DeBruijnBytePos[64] = { 0, 0, 0, 0, 0, 1, 1, 2, 0, 3, 1, 3, 1, 4, 2, 7, 0, 2, 3, 6, 1, 5, 3, 5, 1, 3, 4, 4, 2, 5, 6, 7, 7, 0, 1, 2, 3, 3, 4, 6, 2, 6, 5, 5, 3, 4, 5, 6, 7, 1, 2, 4, 6, 4, 4, 5, 7, 2, 6, 5, 7, 6, 7, 7 };
+ return DeBruijnBytePos[((U64)((val & -(long long)val) * 0x0218A392CDABBD3FULL)) >> 58];
+# endif
+ else /* 32 bits */
+# if defined(_MSC_VER) && !defined(LZ4_FORCE_SW_BITCOUNT)
+ unsigned long r;
+ _BitScanForward( &r, (U32)val );
+ return (__builtin_ctz((U32)val) >> 3);
+# else
+ static const int DeBruijnBytePos[32] = { 0, 0, 3, 0, 3, 1, 3, 0, 3, 2, 2, 1, 3, 2, 0, 1, 3, 3, 1, 2, 2, 2, 2, 0, 3, 1, 2, 0, 1, 0, 1, 1 };
+ return DeBruijnBytePos[((U32)((val & -(S32)val) * 0x077CB531U)) >> 27];
+# endif
+ else /* Big Endian CPU */
+ if (LZ4_64bits())
+ _BitScanReverse64( &r, val );
+ return (unsigned)(r>>3);
+ return (__builtin_clzll((U64)val) >> 3);
+# else
+ unsigned r;
+ if (!(val>>32)) { r=4; } else { r=0; val>>=32; }
+ if (!(val>>16)) { r+=2; val>>=8; } else { val>>=24; }
+ r += (!val);
+ return r;
+# endif
+ _BitScanReverse( &r, (unsigned long)val );
+ return (__builtin_clz((U32)val) >> 3);
+# else
+ unsigned r;
+ if (!(val>>16)) { r=2; val>>=8; } else { r=0; val>>=24; }
+ r += (!val);
+ return r;
+# endif
+static unsigned LZ4_count(const BYTE* pIn, const BYTE* pMatch, const BYTE* pInLimit)
+ const BYTE* const pStart = pIn;
+ while (likely(pIn<pInLimit-(STEPSIZE-1)))
+ size_t diff = LZ4_read_ARCH(pMatch) ^ LZ4_read_ARCH(pIn);
+ if (!diff) { pIn+=STEPSIZE; pMatch+=STEPSIZE; continue; }
+ pIn += LZ4_NbCommonBytes(diff);
+ return (unsigned)(pIn - pStart);
+ if (LZ4_64bits()) if ((pIn<(pInLimit-3)) && (LZ4_read32(pMatch) == LZ4_read32(pIn))) { pIn+=4; pMatch+=4; }
+ if ((pIn<(pInLimit-1)) && (LZ4_read16(pMatch) == LZ4_read16(pIn))) { pIn+=2; pMatch+=2; }
+ if ((pIn<pInLimit) && (*pMatch == *pIn)) pIn++;
+#ifndef LZ4_COMMONDEFS_ONLY
+* Local Constants
+#define LZ4_HASHLOG (LZ4_MEMORY_USAGE-2)
+#define HASHTABLESIZE (1 << LZ4_MEMORY_USAGE)
+#define HASH_SIZE_U32 (1 << LZ4_HASHLOG) /* required as macro for static allocation */
+static const int LZ4_64Klimit = ((64 KB) + (MFLIMIT-1));
+static const U32 LZ4_skipTrigger = 6; /* Increase this value ==> compression run slower on incompressible data */
+* Local Structures and types
+typedef struct {
+ U32 hashTable[HASH_SIZE_U32];
+ U32 currentOffset;
+ U32 initCheck;
+ const BYTE* dictionary;
+ BYTE* bufferStart; /* obsolete, used for slideInputBuffer */
+ U32 dictSize;
+} LZ4_stream_t_internal;
+typedef enum { notLimited = 0, limitedOutput = 1 } limitedOutput_directive;
+typedef enum { byPtr, byU32, byU16 } tableType_t;
+typedef enum { noDict = 0, withPrefix64k, usingExtDict } dict_directive;
+typedef enum { noDictIssue = 0, dictSmall } dictIssue_directive;
+typedef enum { endOnOutputSize = 0, endOnInputSize = 1 } endCondition_directive;
+typedef enum { full = 0, partial = 1 } earlyEnd_directive;
+* Local Utils
+int LZ4_versionNumber (void) { return LZ4_VERSION_NUMBER; }
+int LZ4_compressBound(int isize) { return LZ4_COMPRESSBOUND(isize); }
+int LZ4_sizeofState() { return LZ4_STREAMSIZE; }
+* Compression functions
+static U32 LZ4_hashSequence(U32 sequence, tableType_t const tableType)
+ if (tableType == byU16)
+ return (((sequence) * 2654435761U) >> ((MINMATCH*8)-(LZ4_HASHLOG+1)));
+ else
+ return (((sequence) * 2654435761U) >> ((MINMATCH*8)-LZ4_HASHLOG));
+static const U64 prime5bytes = 889523592379ULL;
+static U32 LZ4_hashSequence64(size_t sequence, tableType_t const tableType)
+ const U32 hashLog = (tableType == byU16) ? LZ4_HASHLOG+1 : LZ4_HASHLOG;
+ const U32 hashMask = (1<<hashLog) - 1;
+ return ((sequence * prime5bytes) >> (40 - hashLog)) & hashMask;
+static U32 LZ4_hashSequenceT(size_t sequence, tableType_t const tableType)
+ if (LZ4_64bits())
+ return LZ4_hashSequence64(sequence, tableType);
+ return LZ4_hashSequence((U32)sequence, tableType);
+static U32 LZ4_hashPosition(const void* p, tableType_t tableType) { return LZ4_hashSequenceT(LZ4_read_ARCH(p), tableType); }
+static void LZ4_putPositionOnHash(const BYTE* p, U32 h, void* tableBase, tableType_t const tableType, const BYTE* srcBase)
+ switch (tableType)
+ case byPtr: { const BYTE** hashTable = (const BYTE**)tableBase; hashTable[h] = p; return; }
+ case byU32: { U32* hashTable = (U32*) tableBase; hashTable[h] = (U32)(p-srcBase); return; }
+ case byU16: { U16* hashTable = (U16*) tableBase; hashTable[h] = (U16)(p-srcBase); return; }
+static void LZ4_putPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
+ U32 h = LZ4_hashPosition(p, tableType);
+ LZ4_putPositionOnHash(p, h, tableBase, tableType, srcBase);
+static const BYTE* LZ4_getPositionOnHash(U32 h, void* tableBase, tableType_t tableType, const BYTE* srcBase)
+ if (tableType == byPtr) { const BYTE** hashTable = (const BYTE**) tableBase; return hashTable[h]; }
+ if (tableType == byU32) { U32* hashTable = (U32*) tableBase; return hashTable[h] + srcBase; }
+ { U16* hashTable = (U16*) tableBase; return hashTable[h] + srcBase; } /* default, to ensure a return */
+static const BYTE* LZ4_getPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
+ return LZ4_getPositionOnHash(h, tableBase, tableType, srcBase);
+FORCE_INLINE int LZ4_compress_generic(
+ void* const ctx,
+ const char* const source,
+ char* const dest,
+ const int inputSize,
+ const int maxOutputSize,
+ const limitedOutput_directive outputLimited,
+ const tableType_t tableType,
+ const dict_directive dict,
+ const dictIssue_directive dictIssue,
+ const U32 acceleration)
+ LZ4_stream_t_internal* const dictPtr = (LZ4_stream_t_internal*)ctx;
+ const BYTE* ip = (const BYTE*) source;
+ const BYTE* base;
+ const BYTE* lowLimit;
+ const BYTE* const lowRefLimit = ip - dictPtr->dictSize;
+ const BYTE* const dictionary = dictPtr->dictionary;
+ const BYTE* const dictEnd = dictionary + dictPtr->dictSize;
+ const size_t dictDelta = dictEnd - (const BYTE*)source;
+ const BYTE* anchor = (const BYTE*) source;
+ const BYTE* const iend = ip + inputSize;
+ const BYTE* const mflimit = iend - MFLIMIT;
+ const BYTE* const matchlimit = iend - LASTLITERALS;
+ BYTE* op = (BYTE*) dest;
+ BYTE* const olimit = op + maxOutputSize;
+ U32 forwardH;
+ size_t refDelta=0;
+ /* Init conditions */
+ if ((U32)inputSize > (U32)LZ4_MAX_INPUT_SIZE) return 0; /* Unsupported input size, too large (or negative) */
+ switch(dict)
+ case noDict:
+ default:
+ base = (const BYTE*)source;
+ lowLimit = (const BYTE*)source;
+ break;
+ case withPrefix64k:
+ base = (const BYTE*)source - dictPtr->currentOffset;
+ lowLimit = (const BYTE*)source - dictPtr->dictSize;
+ break;
+ case usingExtDict:
+ break;
+ if ((tableType == byU16) && (inputSize>=LZ4_64Klimit)) return 0; /* Size too large (not within 64K limit) */
+ if (inputSize<LZ4_minLength) goto _last_literals; /* Input too small, no compression (all literals) */
+ /* First Byte */
+ LZ4_putPosition(ip, ctx, tableType, base);
+ ip++; forwardH = LZ4_hashPosition(ip, tableType);
+ /* Main Loop */
+ for ( ; ; )
+ const BYTE* match;
+ BYTE* token;
+ const BYTE* forwardIp = ip;
+ unsigned step = 1;
+ unsigned searchMatchNb = acceleration << LZ4_skipTrigger;
+ /* Find a match */
+ do {
+ U32 h = forwardH;
+ ip = forwardIp;
+ forwardIp += step;
+ step = (searchMatchNb++ >> LZ4_skipTrigger);
+ if (unlikely(forwardIp > mflimit)) goto _last_literals;
+ match = LZ4_getPositionOnHash(h, ctx, tableType, base);
+ if (dict==usingExtDict)
+ if (match<(const BYTE*)source)
+ refDelta = dictDelta;
+ lowLimit = dictionary;
+ else
+ refDelta = 0;
+ forwardH = LZ4_hashPosition(forwardIp, tableType);
+ LZ4_putPositionOnHash(ip, h, ctx, tableType, base);
+ } while ( ((dictIssue==dictSmall) ? (match < lowRefLimit) : 0)
+ || ((tableType==byU16) ? 0 : (match + MAX_DISTANCE < ip))
+ || (LZ4_read32(match+refDelta) != LZ4_read32(ip)) );
+ /* Catch up */
+ while ((ip>anchor) && (match+refDelta > lowLimit) && (unlikely(ip[-1]==match[refDelta-1]))) { ip--; match--; }
+ /* Encode Literal length */
+ unsigned litLength = (unsigned)(ip - anchor);
+ token = op++;
+ if ((outputLimited) && (unlikely(op + litLength + (2 + 1 + LASTLITERALS) + (litLength/255) > olimit)))
+ return 0; /* Check output limit */
+ if (litLength>=RUN_MASK)
+ int len = (int)litLength-RUN_MASK;
+ *token=(RUN_MASK<<ML_BITS);
+ for(; len >= 255 ; len-=255) *op++ = 255;
+ *op++ = (BYTE)len;
+ else *token = (BYTE)(litLength<<ML_BITS);
+ /* Copy Literals */
+ LZ4_wildCopy(op, anchor, op+litLength);
+ op+=litLength;
+_next_match:
+ /* Encode Offset */
+ LZ4_writeLE16(op, (U16)(ip-match)); op+=2;
+ /* Encode MatchLength */
+ unsigned matchLength;
+ if ((dict==usingExtDict) && (lowLimit==dictionary))
+ const BYTE* limit;
+ match += refDelta;
+ limit = ip + (dictEnd-match);
+ if (limit > matchlimit) limit = matchlimit;
+ matchLength = LZ4_count(ip+MINMATCH, match+MINMATCH, limit);
+ ip += MINMATCH + matchLength;
+ if (ip==limit)
+ unsigned more = LZ4_count(ip, (const BYTE*)source, matchlimit);
+ matchLength += more;
+ ip += more;
+ else
+ matchLength = LZ4_count(ip+MINMATCH, match+MINMATCH, matchlimit);
+ if ((outputLimited) && (unlikely(op + (1 + LASTLITERALS) + (matchLength>>8) > olimit)))
+ if (matchLength>=ML_MASK)
+ *token += ML_MASK;
+ matchLength -= ML_MASK;
+ for (; matchLength >= 510 ; matchLength-=510) { *op++ = 255; *op++ = 255; }
+ if (matchLength >= 255) { matchLength-=255; *op++ = 255; }
+ *op++ = (BYTE)matchLength;
+ else *token += (BYTE)(matchLength);
+ anchor = ip;
+ /* Test end of chunk */
+ if (ip > mflimit) break;
+ /* Fill table */
+ LZ4_putPosition(ip-2, ctx, tableType, base);
+ /* Test next position */
+ match = LZ4_getPosition(ip, ctx, tableType, base);
+ else
+ refDelta = 0;
+ if ( ((dictIssue==dictSmall) ? (match>=lowRefLimit) : 1)
+ && (match+MAX_DISTANCE>=ip)
+ && (LZ4_read32(match+refDelta)==LZ4_read32(ip)) )
+ { token=op++; *token=0; goto _next_match; }
+ /* Prepare next loop */
+ forwardH = LZ4_hashPosition(++ip, tableType);
+_last_literals:
+ /* Encode Last Literals */
+ const size_t lastRun = (size_t)(iend - anchor);
+ if ((outputLimited) && ((op - (BYTE*)dest) + lastRun + 1 + ((lastRun+255-RUN_MASK)/255) > (U32)maxOutputSize))
+ if (lastRun >= RUN_MASK)
+ size_t accumulator = lastRun - RUN_MASK;
+ *op++ = RUN_MASK << ML_BITS;
+ for(; accumulator >= 255 ; accumulator-=255) *op++ = 255;
+ *op++ = (BYTE) accumulator;
+ else
+ *op++ = (BYTE)(lastRun<<ML_BITS);
+ memcpy(op, anchor, lastRun);
+ op += lastRun;
+ /* End */
+ return (int) (((char*)op)-dest);
+int LZ4_compress_fast_extState(void* state, const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
+ LZ4_resetStream((LZ4_stream_t*)state);
+ if (acceleration < 1) acceleration = ACCELERATION_DEFAULT;
+ if (maxOutputSize >= LZ4_compressBound(inputSize))
+ if (inputSize < LZ4_64Klimit)
+ return LZ4_compress_generic(state, source, dest, inputSize, 0, notLimited, byU16, noDict, noDictIssue, acceleration);
+ else
+ return LZ4_compress_generic(state, source, dest, inputSize, 0, notLimited, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+ else
+ return LZ4_compress_generic(state, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
+ else
+ return LZ4_compress_generic(state, source, dest, inputSize, maxOutputSize, limitedOutput, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+int LZ4_compress_fast(const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
+#if (HEAPMODE)
+ void* ctxPtr = ALLOCATOR(1, sizeof(LZ4_stream_t)); /* malloc-calloc always properly aligned */
+#else
+ LZ4_stream_t ctx;
+ void* ctxPtr = &ctx;
+#endif
+ int result = LZ4_compress_fast_extState(ctxPtr, source, dest, inputSize, maxOutputSize, acceleration);
+#if (HEAPMODE)
+ FREEMEM(ctxPtr);
+#endif
+ return result;
+int LZ4_compress_default(const char* source, char* dest, int inputSize, int maxOutputSize)
+ return LZ4_compress_fast(source, dest, inputSize, maxOutputSize, 1);
+/* hidden debug function */
+/* strangely enough, gcc generates faster code when this function is uncommented, even if unused */
+int LZ4_compress_fast_force(const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
+ LZ4_stream_t ctx;
+ LZ4_resetStream(&ctx);
+ return LZ4_compress_generic(&ctx, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
+ else
+ return LZ4_compress_generic(&ctx, source, dest, inputSize, maxOutputSize, limitedOutput, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+* destSize variant
+static int LZ4_compress_destSize_generic(
+ void* const ctx,
+ const char* const src,
+ char* const dst,
+ int* const srcSizePtr,
+ const int targetDstSize,
+ const tableType_t tableType)
+ const BYTE* ip = (const BYTE*) src;
+ const BYTE* base = (const BYTE*) src;
+ const BYTE* lowLimit = (const BYTE*) src;
+ const BYTE* anchor = ip;
+ const BYTE* const iend = ip + *srcSizePtr;
+ BYTE* op = (BYTE*) dst;
+ BYTE* const oend = op + targetDstSize;
+ BYTE* const oMaxLit = op + targetDstSize - 2 /* offset */ - 8 /* because 8+MINMATCH==MFLIMIT */ - 1 /* token */;
+ BYTE* const oMaxMatch = op + targetDstSize - (LASTLITERALS + 1 /* token */);
+ BYTE* const oMaxSeq = oMaxLit - 1 /* token */;
+ U32 forwardH;
+ if (targetDstSize < 1) return 0; /* Impossible to store anything */
+ if ((U32)*srcSizePtr > (U32)LZ4_MAX_INPUT_SIZE) return 0; /* Unsupported input size, too large (or negative) */
+ if ((tableType == byU16) && (*srcSizePtr>=LZ4_64Klimit)) return 0; /* Size too large (not within 64K limit) */
+ if (*srcSizePtr<LZ4_minLength) goto _last_literals; /* Input too small, no compression (all literals) */
+ /* First Byte */
+ *srcSizePtr = 0;
+ /* Main Loop */
+ for ( ; ; )
+ BYTE* token;
+ unsigned searchMatchNb = 1 << LZ4_skipTrigger;
+ do {
+ U32 h = forwardH;
+ ip = forwardIp;
+ goto _last_literals;
+ } while ( ((tableType==byU16) ? 0 : (match + MAX_DISTANCE < ip))
+ || (LZ4_read32(match) != LZ4_read32(ip)) );
+ /* Catch up */
+ while ((ip>anchor) && (match > lowLimit) && (unlikely(ip[-1]==match[-1]))) { ip--; match--; }
+ token = op++;
+ if (op + ((litLength+240)/255) + litLength > oMaxLit)
+ /* Not enough space for a last match */
+ op--;
+ unsigned len = litLength - RUN_MASK;
+ op += litLength;
+_next_match:
+ size_t matchLength;
+ if (op + ((matchLength+240)/255) > oMaxMatch)
+ /* Match description too long : reduce it */
+ matchLength = (15-1) + (oMaxMatch-op) * 255;
+ //printf("offset %5i, matchLength%5i \n", (int)(ip-match), matchLength + MINMATCH);
+ while (matchLength >= 255) { matchLength-=255; *op++ = 255; }
+ anchor = ip;
+ /* Test end of block */
+ if (op > oMaxSeq) break;
+ /* Fill table */
+ if ( (match+MAX_DISTANCE>=ip)
+ && (LZ4_read32(match)==LZ4_read32(ip)) )
+_last_literals:
+ size_t lastRunSize = (size_t)(iend - anchor);
+ if (op + 1 /* token */ + ((lastRunSize+240)/255) /* litLength */ + lastRunSize /* literals */ > oend)
+ /* adapt lastRunSize to fill 'dst' */
+ lastRunSize = (oend-op) - 1;
+ lastRunSize -= (lastRunSize+240)/255;
+ ip = anchor + lastRunSize;
+ if (lastRunSize >= RUN_MASK)
+ size_t accumulator = lastRunSize - RUN_MASK;
+ else
+ *op++ = (BYTE)(lastRunSize<<ML_BITS);
+ memcpy(op, anchor, lastRunSize);
+ op += lastRunSize;
+ /* End */
+ *srcSizePtr = (int) (((const char*)ip)-src);
+ return (int) (((char*)op)-dst);
+static int LZ4_compress_destSize_extState (void* state, const char* src, char* dst, int* srcSizePtr, int targetDstSize)
+ if (targetDstSize >= LZ4_compressBound(*srcSizePtr)) /* compression success is guaranteed */
+ return LZ4_compress_fast_extState(state, src, dst, *srcSizePtr, targetDstSize, 1);
+ else
+ if (*srcSizePtr < LZ4_64Klimit)
+ return LZ4_compress_destSize_generic(state, src, dst, srcSizePtr, targetDstSize, byU16);
+ else
+ return LZ4_compress_destSize_generic(state, src, dst, srcSizePtr, targetDstSize, LZ4_64bits() ? byU32 : byPtr);
+int LZ4_compress_destSize(const char* src, char* dst, int* srcSizePtr, int targetDstSize)
+#if (HEAPMODE)
+ void* ctx = ALLOCATOR(1, sizeof(LZ4_stream_t)); /* malloc-calloc always properly aligned */
+#else
+ LZ4_stream_t ctxBody;
+ void* ctx = &ctxBody;
+#endif
+ int result = LZ4_compress_destSize_extState(ctx, src, dst, srcSizePtr, targetDstSize);
+#if (HEAPMODE)
+ FREEMEM(ctx);
+#endif
+ return result;
+* Streaming functions
+LZ4_stream_t* LZ4_createStream(void)
+ LZ4_stream_t* lz4s = (LZ4_stream_t*)ALLOCATOR(8, LZ4_STREAMSIZE_U64);
+ LZ4_STATIC_ASSERT(LZ4_STREAMSIZE >= sizeof(LZ4_stream_t_internal)); /* A compilation error here means LZ4_STREAMSIZE is not large enough */
+ LZ4_resetStream(lz4s);
+ return lz4s;
+void LZ4_resetStream (LZ4_stream_t* LZ4_stream)
+ MEM_INIT(LZ4_stream, 0, sizeof(LZ4_stream_t));
+int LZ4_freeStream (LZ4_stream_t* LZ4_stream)
+ FREEMEM(LZ4_stream);
+ return (0);
+#define HASH_UNIT sizeof(size_t)
+int LZ4_loadDict (LZ4_stream_t* LZ4_dict, const char* dictionary, int dictSize)
+ LZ4_stream_t_internal* dict = (LZ4_stream_t_internal*) LZ4_dict;
+ const BYTE* p = (const BYTE*)dictionary;
+ const BYTE* const dictEnd = p + dictSize;
+ const BYTE* base;
+ if ((dict->initCheck) || (dict->currentOffset > 1 GB)) /* Uninitialized structure, or reuse overflow */
+ LZ4_resetStream(LZ4_dict);
+ if (dictSize < (int)HASH_UNIT)
+ dict->dictionary = NULL;
+ dict->dictSize = 0;
+ return 0;
+ if ((dictEnd - p) > 64 KB) p = dictEnd - 64 KB;
+ dict->currentOffset += 64 KB;
+ base = p - dict->currentOffset;
+ dict->dictionary = p;
+ dict->dictSize = (U32)(dictEnd - p);
+ dict->currentOffset += dict->dictSize;
+ while (p <= dictEnd-HASH_UNIT)
+ LZ4_putPosition(p, dict->hashTable, byU32, base);
+ p+=3;
+ return dict->dictSize;
+static void LZ4_renormDictT(LZ4_stream_t_internal* LZ4_dict, const BYTE* src)
+ if ((LZ4_dict->currentOffset > 0x80000000) ||
+ ((size_t)LZ4_dict->currentOffset > (size_t)src)) /* address space overflow */
+ /* rescale hash table */
+ U32 delta = LZ4_dict->currentOffset - 64 KB;
+ const BYTE* dictEnd = LZ4_dict->dictionary + LZ4_dict->dictSize;
+ int i;
+ for (i=0; i<HASH_SIZE_U32; i++)
+ if (LZ4_dict->hashTable[i] < delta) LZ4_dict->hashTable[i]=0;
+ else LZ4_dict->hashTable[i] -= delta;
+ LZ4_dict->currentOffset = 64 KB;
+ if (LZ4_dict->dictSize > 64 KB) LZ4_dict->dictSize = 64 KB;
+ LZ4_dict->dictionary = dictEnd - LZ4_dict->dictSize;
+int LZ4_compress_fast_continue (LZ4_stream_t* LZ4_stream, const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
+ LZ4_stream_t_internal* streamPtr = (LZ4_stream_t_internal*)LZ4_stream;
+ const BYTE* const dictEnd = streamPtr->dictionary + streamPtr->dictSize;
+ const BYTE* smallest = (const BYTE*) source;
+ if (streamPtr->initCheck) return 0; /* Uninitialized structure detected */
+ if ((streamPtr->dictSize>0) && (smallest>dictEnd)) smallest = dictEnd;
+ LZ4_renormDictT(streamPtr, smallest);
+ /* Check overlapping input/dictionary space */
+ const BYTE* sourceEnd = (const BYTE*) source + inputSize;
+ if ((sourceEnd > streamPtr->dictionary) && (sourceEnd < dictEnd))
+ streamPtr->dictSize = (U32)(dictEnd - sourceEnd);
+ if (streamPtr->dictSize > 64 KB) streamPtr->dictSize = 64 KB;
+ if (streamPtr->dictSize < 4) streamPtr->dictSize = 0;
+ streamPtr->dictionary = dictEnd - streamPtr->dictSize;
+ /* prefix mode : source data follows dictionary */
+ if (dictEnd == (const BYTE*)source)
+ int result;
+ if ((streamPtr->dictSize < 64 KB) && (streamPtr->dictSize < streamPtr->currentOffset))
+ result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, dictSmall, acceleration);
+ else
+ result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, noDictIssue, acceleration);
+ streamPtr->dictSize += (U32)inputSize;
+ streamPtr->currentOffset += (U32)inputSize;
+ return result;
+ /* external dictionary mode */
+ int result;
+ result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, dictSmall, acceleration);
+ else
+ result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, noDictIssue, acceleration);
+ streamPtr->dictionary = (const BYTE*)source;
+ streamPtr->dictSize = (U32)inputSize;
+ return result;
+/* Hidden debug function, to force external dictionary mode */
+int LZ4_compress_forceExtDict (LZ4_stream_t* LZ4_dict, const char* source, char* dest, int inputSize)
+ LZ4_stream_t_internal* streamPtr = (LZ4_stream_t_internal*)LZ4_dict;
+ int result;
+ const BYTE* smallest = dictEnd;
+ if (smallest > (const BYTE*) source) smallest = (const BYTE*) source;
+ LZ4_renormDictT((LZ4_stream_t_internal*)LZ4_dict, smallest);
+ result = LZ4_compress_generic(LZ4_dict, source, dest, inputSize, 0, notLimited, byU32, usingExtDict, noDictIssue, 1);
+ return result;
+int LZ4_saveDict (LZ4_stream_t* LZ4_dict, char* safeBuffer, int dictSize)
+ const BYTE* previousDictEnd = dict->dictionary + dict->dictSize;
+ if ((U32)dictSize > 64 KB) dictSize = 64 KB; /* useless to define a dictionary > 64 KB */
+ if ((U32)dictSize > dict->dictSize) dictSize = dict->dictSize;
+ memmove(safeBuffer, previousDictEnd - dictSize, dictSize);
+ dict->dictionary = (const BYTE*)safeBuffer;
+ dict->dictSize = (U32)dictSize;
+ return dictSize;
+* Decompression functions
+ * This generic decompression function cover all use cases.
+ * It shall be instantiated several times, using different sets of directives
+ * Note that it is essential this generic function is really inlined,
+ * in order to remove useless branches during compilation optimization.
+FORCE_INLINE int LZ4_decompress_generic(
+ char* const dest,
+ int inputSize,
+ int outputSize, /* If endOnInput==endOnInputSize, this value is the max size of Output Buffer. */
+ int endOnInput, /* endOnOutputSize, endOnInputSize */
+ int partialDecoding, /* full, partial */
+ int targetOutputSize, /* only used if partialDecoding==partial */
+ int dict, /* noDict, withPrefix64k, usingExtDict */
+ const BYTE* const lowPrefix, /* == dest if dict == noDict */
+ const BYTE* const dictStart, /* only if dict==usingExtDict */
+ const size_t dictSize /* note : = 0 if noDict */
+ /* Local Variables */
+ BYTE* const oend = op + outputSize;
+ BYTE* cpy;
+ BYTE* oexit = op + targetOutputSize;
+ const BYTE* const lowLimit = lowPrefix - dictSize;
+ const BYTE* const dictEnd = (const BYTE*)dictStart + dictSize;
+ const size_t dec32table[] = {4, 1, 2, 1, 4, 4, 4, 4};
+ const size_t dec64table[] = {0, 0, 0, (size_t)-1, 0, 1, 2, 3};
+ const int safeDecode = (endOnInput==endOnInputSize);
+ const int checkOffset = ((safeDecode) && (dictSize < (int)(64 KB)));
+ /* Special cases */
+ if ((partialDecoding) && (oexit> oend-MFLIMIT)) oexit = oend-MFLIMIT; /* targetOutputSize too high => decode everything */
+ if ((endOnInput) && (unlikely(outputSize==0))) return ((inputSize==1) && (*ip==0)) ? 0 : -1; /* Empty output buffer */
+ if ((!endOnInput) && (unlikely(outputSize==0))) return (*ip==0?1:-1);
+ /* Main Loop */
+ while (1)
+ unsigned token;
+ size_t length;
+ /* get literal length */
+ token = *ip++;
+ if ((length=(token>>ML_BITS)) == RUN_MASK)
+ unsigned s;
+ do
+ s = *ip++;
+ length += s;
+ while (likely((endOnInput)?ip<iend-RUN_MASK:1) && (s==255));
+ if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)(op))) goto _output_error; /* overflow detection */
+ if ((safeDecode) && unlikely((size_t)(ip+length)<(size_t)(ip))) goto _output_error; /* overflow detection */
+ /* copy literals */
+ cpy = op+length;
+ if (((endOnInput) && ((cpy>(partialDecoding?oexit:oend-MFLIMIT)) || (ip+length>iend-(2+1+LASTLITERALS))) )
+ || ((!endOnInput) && (cpy>oend-COPYLENGTH)))
+ if (partialDecoding)
+ if (cpy > oend) goto _output_error; /* Error : write attempt beyond end of output buffer */
+ if ((endOnInput) && (ip+length > iend)) goto _output_error; /* Error : read attempt beyond end of input buffer */
+ else
+ if ((!endOnInput) && (cpy != oend)) goto _output_error; /* Error : block decoding must stop exactly there */
+ if ((endOnInput) && ((ip+length != iend) || (cpy > oend))) goto _output_error; /* Error : input must be consumed */
+ memcpy(op, ip, length);
+ ip += length;
+ op += length;
+ break; /* Necessarily EOF, due to parsing restrictions */
+ LZ4_wildCopy(op, ip, cpy);
+ ip += length; op = cpy;
+ /* get offset */
+ match = cpy - LZ4_readLE16(ip); ip+=2;
+ if ((checkOffset) && (unlikely(match < lowLimit))) goto _output_error; /* Error : offset outside destination buffer */
+ /* get matchlength */
+ length = token & ML_MASK;
+ if (length == ML_MASK)
+ unsigned s;
+ do
+ if ((endOnInput) && (ip > iend-LASTLITERALS)) goto _output_error;
+ s = *ip++;
+ length += s;
+ } while (s==255);
+ if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)op)) goto _output_error; /* overflow detection */
+ length += MINMATCH;
+ /* check external dictionary */
+ if ((dict==usingExtDict) && (match < lowPrefix))
+ if (unlikely(op+length > oend-LASTLITERALS)) goto _output_error; /* doesn't respect parsing restriction */
+ if (length <= (size_t)(lowPrefix-match))
+ /* match can be copied as a single segment from external dictionary */
+ match = dictEnd - (lowPrefix-match);
+ memmove(op, match, length); op += length;
+ else
+ /* match encompass external dictionary and current segment */
+ size_t copySize = (size_t)(lowPrefix-match);
+ memcpy(op, dictEnd - copySize, copySize);
+ op += copySize;
+ copySize = length - copySize;
+ if (copySize > (size_t)(op-lowPrefix)) /* overlap within current segment */
+ BYTE* const endOfMatch = op + copySize;
+ const BYTE* copyFrom = lowPrefix;
+ while (op < endOfMatch) *op++ = *copyFrom++;
+ else
+ memcpy(op, lowPrefix, copySize);
+ op += copySize;
+ continue;
+ /* copy repeated sequence */
+ cpy = op + length;
+ if (unlikely((op-match)<8))
+ const size_t dec64 = dec64table[op-match];
+ op[0] = match[0];
+ op[1] = match[1];
+ op[2] = match[2];
+ op[3] = match[3];
+ match += dec32table[op-match];
+ LZ4_copy4(op+4, match);
+ op += 8; match -= dec64;
+ } else { LZ4_copy8(op, match); op+=8; match+=8; }
+ if (unlikely(cpy>oend-12))
+ if (cpy > oend-LASTLITERALS) goto _output_error; /* Error : last LASTLITERALS bytes must be literals */
+ if (op < oend-8)
+ LZ4_wildCopy(op, match, oend-8);
+ match += (oend-8) - op;
+ op = oend-8;
+ while (op<cpy) *op++ = *match++;
+ else
+ LZ4_wildCopy(op, match, cpy);
+ op=cpy; /* correction */
+ /* end of decoding */
+ if (endOnInput)
+ return (int) (((char*)op)-dest); /* Nb of output bytes decoded */
+ else
+ return (int) (((const char*)ip)-source); /* Nb of input bytes read */
+ /* Overflow error detected */
+_output_error:
+ return (int) (-(((const char*)ip)-source))-1;
+int LZ4_decompress_safe(const char* source, char* dest, int compressedSize, int maxDecompressedSize)
+ return LZ4_decompress_generic(source, dest, compressedSize, maxDecompressedSize, endOnInputSize, full, 0, noDict, (BYTE*)dest, NULL, 0);
+int LZ4_decompress_safe_partial(const char* source, char* dest, int compressedSize, int targetOutputSize, int maxDecompressedSize)
+ return LZ4_decompress_generic(source, dest, compressedSize, maxDecompressedSize, endOnInputSize, partial, targetOutputSize, noDict, (BYTE*)dest, NULL, 0);
+int LZ4_decompress_fast(const char* source, char* dest, int originalSize)
+ return LZ4_decompress_generic(source, dest, 0, originalSize, endOnOutputSize, full, 0, withPrefix64k, (BYTE*)(dest - 64 KB), NULL, 64 KB);
+/* streaming decompression functions */
+typedef struct
+ const BYTE* externalDict;
+ size_t extDictSize;
+ const BYTE* prefixEnd;
+ size_t prefixSize;
+} LZ4_streamDecode_t_internal;
+ * If you prefer dynamic allocation methods,
+ * LZ4_createStreamDecode()
+ * provides a pointer (void*) towards an initialized LZ4_streamDecode_t structure.
+LZ4_streamDecode_t* LZ4_createStreamDecode(void)
+ LZ4_streamDecode_t* lz4s = (LZ4_streamDecode_t*) ALLOCATOR(1, sizeof(LZ4_streamDecode_t));
+ return lz4s;
+int LZ4_freeStreamDecode (LZ4_streamDecode_t* LZ4_stream)
+ return 0;
+ * LZ4_setStreamDecode
+ * Use this function to instruct where to find the dictionary
+ * This function is not necessary if previous data is still available where it was decoded.
+ * Loading a size of 0 is allowed (same effect as no dictionary).
+ * Return : 1 if OK, 0 if error
+int LZ4_setStreamDecode (LZ4_streamDecode_t* LZ4_streamDecode, const char* dictionary, int dictSize)
+ LZ4_streamDecode_t_internal* lz4sd = (LZ4_streamDecode_t_internal*) LZ4_streamDecode;
+ lz4sd->prefixSize = (size_t) dictSize;
+ lz4sd->prefixEnd = (const BYTE*) dictionary + dictSize;
+ lz4sd->externalDict = NULL;
+ lz4sd->extDictSize = 0;
+ return 1;
+*_continue() :
+ These decoding functions allow decompression of multiple blocks in "streaming" mode.
+ Previously decoded blocks must still be available at the memory position where they were decoded.
+ If it's not possible, save the relevant part of decoded data into a safe buffer,
+ and indicate where it stands using LZ4_setStreamDecode()
+int LZ4_decompress_safe_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int compressedSize, int maxOutputSize)
+ int result;
+ if (lz4sd->prefixEnd == (BYTE*)dest)
+ result = LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize,
+ endOnInputSize, full, 0,
+ usingExtDict, lz4sd->prefixEnd - lz4sd->prefixSize, lz4sd->externalDict, lz4sd->extDictSize);
+ if (result <= 0) return result;
+ lz4sd->prefixSize += result;
+ lz4sd->prefixEnd += result;
+ else
+ lz4sd->extDictSize = lz4sd->prefixSize;
+ lz4sd->externalDict = lz4sd->prefixEnd - lz4sd->extDictSize;
+ usingExtDict, (BYTE*)dest, lz4sd->externalDict, lz4sd->extDictSize);
+ lz4sd->prefixSize = result;
+ lz4sd->prefixEnd = (BYTE*)dest + result;
+ return result;
+int LZ4_decompress_fast_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int originalSize)
+ int result;
+ result = LZ4_decompress_generic(source, dest, 0, originalSize,
+ endOnOutputSize, full, 0,
+ lz4sd->prefixSize += originalSize;
+ lz4sd->prefixEnd += originalSize;
+ else
+ lz4sd->externalDict = (BYTE*)dest - lz4sd->extDictSize;
+ lz4sd->prefixSize = originalSize;
+ lz4sd->prefixEnd = (BYTE*)dest + originalSize;
+ return result;
+Advanced decoding functions :
+*_usingDict() :
+ These decoding functions work the same as "_continue" ones,
+ the dictionary must be explicitly provided within parameters
+FORCE_INLINE int LZ4_decompress_usingDict_generic(const char* source, char* dest, int compressedSize, int maxOutputSize, int safe, const char* dictStart, int dictSize)
+ if (dictSize==0)
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, noDict, (BYTE*)dest, NULL, 0);
+ if (dictStart+dictSize == dest)
+ if (dictSize >= (int)(64 KB - 1))
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, withPrefix64k, (BYTE*)dest-64 KB, NULL, 0);
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, noDict, (BYTE*)dest-dictSize, NULL, 0);
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, usingExtDict, (BYTE*)dest, (const BYTE*)dictStart, dictSize);
+int LZ4_decompress_safe_usingDict(const char* source, char* dest, int compressedSize, int maxOutputSize, const char* dictStart, int dictSize)
+ return LZ4_decompress_usingDict_generic(source, dest, compressedSize, maxOutputSize, 1, dictStart, dictSize);
+int LZ4_decompress_fast_usingDict(const char* source, char* dest, int originalSize, const char* dictStart, int dictSize)
+ return LZ4_decompress_usingDict_generic(source, dest, 0, originalSize, 0, dictStart, dictSize);
+/* debug function */
+int LZ4_decompress_safe_forceExtDict(const char* source, char* dest, int compressedSize, int maxOutputSize, const char* dictStart, int dictSize)
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, endOnInputSize, full, 0, usingExtDict, (BYTE*)dest, (const BYTE*)dictStart, dictSize);
+* Obsolete Functions
+/* obsolete compression functions */
+int LZ4_compress_limitedOutput(const char* source, char* dest, int inputSize, int maxOutputSize) { return LZ4_compress_default(source, dest, inputSize, maxOutputSize); }
+int LZ4_compress(const char* source, char* dest, int inputSize) { return LZ4_compress_default(source, dest, inputSize, LZ4_compressBound(inputSize)); }
+int LZ4_compress_limitedOutput_withState (void* state, const char* src, char* dst, int srcSize, int dstSize) { return LZ4_compress_fast_extState(state, src, dst, srcSize, dstSize, 1); }
+int LZ4_compress_withState (void* state, const char* src, char* dst, int srcSize) { return LZ4_compress_fast_extState(state, src, dst, srcSize, LZ4_compressBound(srcSize), 1); }
+int LZ4_compress_limitedOutput_continue (LZ4_stream_t* LZ4_stream, const char* src, char* dst, int srcSize, int maxDstSize) { return LZ4_compress_fast_continue(LZ4_stream, src, dst, srcSize, maxDstSize, 1); }
+int LZ4_compress_continue (LZ4_stream_t* LZ4_stream, const char* source, char* dest, int inputSize) { return LZ4_compress_fast_continue(LZ4_stream, source, dest, inputSize, LZ4_compressBound(inputSize), 1); }
+These function names are deprecated and should no longer be used.
+They are only provided here for compatibility with older user programs.
+- LZ4_uncompress is totally equivalent to LZ4_decompress_fast
+- LZ4_uncompress_unknownOutputSize is totally equivalent to LZ4_decompress_safe
+int LZ4_uncompress (const char* source, char* dest, int outputSize) { return LZ4_decompress_fast(source, dest, outputSize); }
+int LZ4_uncompress_unknownOutputSize (const char* source, char* dest, int isize, int maxOutputSize) { return LZ4_decompress_safe(source, dest, isize, maxOutputSize); }
+/* Obsolete Streaming functions */
+int LZ4_sizeofStreamState() { return LZ4_STREAMSIZE; }
+static void LZ4_init(LZ4_stream_t_internal* lz4ds, BYTE* base)
+ MEM_INIT(lz4ds, 0, LZ4_STREAMSIZE);
+ lz4ds->bufferStart = base;
+int LZ4_resetStreamState(void* state, char* inputBuffer)
+ if ((((size_t)state) & 3) != 0) return 1; /* Error : pointer is not aligned on 4-bytes boundary */
+ LZ4_init((LZ4_stream_t_internal*)state, (BYTE*)inputBuffer);
+ return 0;
+void* LZ4_create (char* inputBuffer)
+ void* lz4ds = ALLOCATOR(8, LZ4_STREAMSIZE_U64);
+ LZ4_init ((LZ4_stream_t_internal*)lz4ds, (BYTE*)inputBuffer);
+ return lz4ds;
+char* LZ4_slideInputBuffer (void* LZ4_Data)
+ LZ4_stream_t_internal* ctx = (LZ4_stream_t_internal*)LZ4_Data;
+ int dictSize = LZ4_saveDict((LZ4_stream_t*)LZ4_Data, (char*)ctx->bufferStart, 64 KB);
+ return (char*)(ctx->bufferStart + dictSize);
+/* Obsolete streaming decompression functions */
+int LZ4_decompress_safe_withPrefix64k(const char* source, char* dest, int compressedSize, int maxOutputSize)
+ return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, endOnInputSize, full, 0, withPrefix64k, (BYTE*)dest - 64 KB, NULL, 64 KB);
+int LZ4_decompress_fast_withPrefix64k(const char* source, char* dest, int originalSize)
+ return LZ4_decompress_generic(source, dest, 0, originalSize, endOnOutputSize, full, 0, withPrefix64k, (BYTE*)dest - 64 KB, NULL, 64 KB);
+#endif /* LZ4_COMMONDEFS_ONLY */
Added: grass/trunk/lib/gis/lz4.h
--- grass/trunk/lib/gis/lz4.h (rev 0)
+++ grass/trunk/lib/gis/lz4.h 2015-12-18 08:42:45 UTC (rev 67216)
@@ -0,0 +1,360 @@
+ Header File
+ met:
+ distribution.
+#pragma once
+#if defined (__cplusplus)
+extern "C" {
+#endif
+ * lz4.h provides block compression functions, and gives full buffer control to programmer.
+ * If you need to generate inter-operable compressed data (respecting LZ4 frame specification),
+ * and can let the library handle its own memory, please use lz4frame.h instead.
+* Version
+#define LZ4_VERSION_MAJOR 1 /* for breaking interface changes */
+#define LZ4_VERSION_MINOR 7 /* for new (non-breaking) interface capabilities */
+#define LZ4_VERSION_RELEASE 1 /* for tweaks, bug-fixes, or development */
+#define LZ4_VERSION_NUMBER (LZ4_VERSION_MAJOR *100*100 + LZ4_VERSION_MINOR *100 + LZ4_VERSION_RELEASE)
+int LZ4_versionNumber (void);
+* Tuning parameter
+ * LZ4_MEMORY_USAGE :
+ * Memory usage formula : N->2^N Bytes (examples : 10 -> 1KB; 12 -> 4KB ; 16 -> 64KB; 20 -> 1MB; etc.)
+ * Increasing memory usage improves compression ratio
+ * Reduced memory usage can improve speed, due to cache effect
+ * Default value is 14, for 16KB, which nicely fits into Intel x86 L1 cache
+#define LZ4_MEMORY_USAGE 14
+* Simple Functions
+int LZ4_compress_default(const char* source, char* dest, int sourceSize, int maxDestSize);
+int LZ4_decompress_safe (const char* source, char* dest, int compressedSize, int maxDecompressedSize);
+LZ4_compress_default() :
+ Compresses 'sourceSize' bytes from buffer 'source'
+ into already allocated 'dest' buffer of size 'maxDestSize'.
+ Compression is guaranteed to succeed if 'maxDestSize' >= LZ4_compressBound(sourceSize).
+ It also runs faster, so it's a recommended setting.
+ If the function cannot compress 'source' into a more limited 'dest' budget,
+ compression stops *immediately*, and the function result is zero.
+ As a consequence, 'dest' content is not valid.
+ This function never writes outside 'dest' buffer, nor read outside 'source' buffer.
+ sourceSize : Max supported value is LZ4_MAX_INPUT_VALUE
+ maxDestSize : full or partial size of buffer 'dest' (which must be already allocated)
+ return : the number of bytes written into buffer 'dest' (necessarily <= maxOutputSize)
+ or 0 if compression fails
+LZ4_decompress_safe() :
+ compressedSize : is the precise full size of the compressed block.
+ maxDecompressedSize : is the size of destination buffer, which must be already allocated.
+ return : the number of bytes decompressed into destination buffer (necessarily <= maxDecompressedSize)
+ If destination buffer is not large enough, decoding will stop and output an error code (<0).
+ If the source stream is detected malformed, the function will stop decoding and return a negative result.
+ This function is protected against buffer overflow exploits, including malicious data packets.
+ It never writes outside output buffer, nor reads outside input buffer.
+* Advanced Functions
+#define LZ4_MAX_INPUT_SIZE 0x7E000000 /* 2 113 929 216 bytes */
+#define LZ4_COMPRESSBOUND(isize) ((unsigned)(isize) > (unsigned)LZ4_MAX_INPUT_SIZE ? 0 : (isize) + ((isize)/255) + 16)
+LZ4_compressBound() :
+ Provides the maximum size that LZ4 compression may output in a "worst case" scenario (input data not compressible)
+ This function is primarily useful for memory allocation purposes (destination buffer size).
+ Macro LZ4_COMPRESSBOUND() is also provided for compilation-time evaluation (stack memory allocation for example).
+ Note that LZ4_compress_default() compress faster when dest buffer size is >= LZ4_compressBound(srcSize)
+ inputSize : max supported value is LZ4_MAX_INPUT_SIZE
+ return : maximum output size in a "worst case" scenario
+ or 0, if input size is too large ( > LZ4_MAX_INPUT_SIZE)
+int LZ4_compressBound(int inputSize);
+LZ4_compress_fast() :
+ Same as LZ4_compress_default(), but allows to select an "acceleration" factor.
+ The larger the acceleration value, the faster the algorithm, but also the lesser the compression.
+ It's a trade-off. It can be fine tuned, with each successive value providing roughly +~3% to speed.
+ An acceleration value of "1" is the same as regular LZ4_compress_default()
+ Values <= 0 will be replaced by ACCELERATION_DEFAULT (see lz4.c), which is 1.
+int LZ4_compress_fast (const char* source, char* dest, int sourceSize, int maxDestSize, int acceleration);
+LZ4_compress_fast_extState() :
+ Same compression function, just using an externally allocated memory space to store compression state.
+ Use LZ4_sizeofState() to know how much memory must be allocated,
+ and allocate it on 8-bytes boundaries (using malloc() typically).
+ Then, provide it as 'void* state' to compression function.
+int LZ4_sizeofState(void);
+int LZ4_compress_fast_extState (void* state, const char* source, char* dest, int inputSize, int maxDestSize, int acceleration);
+LZ4_compress_destSize() :
+ Reverse the logic, by compressing as much data as possible from 'source' buffer
+ into already allocated buffer 'dest' of size 'targetDestSize'.
+ This function either compresses the entire 'source' content into 'dest' if it's large enough,
+ or fill 'dest' buffer completely with as much data as possible from 'source'.
+ *sourceSizePtr : will be modified to indicate how many bytes where read from 'source' to fill 'dest'.
+ New value is necessarily <= old value.
+ return : Nb bytes written into 'dest' (necessarily <= targetDestSize)
+int LZ4_compress_destSize (const char* source, char* dest, int* sourceSizePtr, int targetDestSize);
+LZ4_decompress_fast() :
+ originalSize : is the original and therefore uncompressed size
+ return : the number of bytes read from the source buffer (in other words, the compressed size)
+ Destination buffer must be already allocated. Its size must be a minimum of 'originalSize' bytes.
+ note : This function fully respect memory boundaries for properly formed compressed data.
+ It is a bit faster than LZ4_decompress_safe().
+ However, it does not provide any protection against intentionally modified data stream (malicious input).
+ Use this function in trusted environment only (data to decode comes from a trusted source).
+int LZ4_decompress_fast (const char* source, char* dest, int originalSize);
+LZ4_decompress_safe_partial() :
+ This function decompress a compressed block of size 'compressedSize' at position 'source'
+ into destination buffer 'dest' of size 'maxDecompressedSize'.
+ The function tries to stop decompressing operation as soon as 'targetOutputSize' has been reached,
+ reducing decompression time.
+ return : the number of bytes decoded in the destination buffer (necessarily <= maxDecompressedSize)
+ Note : this number can be < 'targetOutputSize' should the compressed block to decode be smaller.
+ Always control how many bytes were decoded.
+ This function never writes outside of output buffer, and never reads outside of input buffer. It is therefore protected against malicious data packets
+int LZ4_decompress_safe_partial (const char* source, char* dest, int compressedSize, int targetOutputSize, int maxDecompressedSize);
+* Streaming Compression Functions
+#define LZ4_STREAMSIZE_U64 ((1 << (LZ4_MEMORY_USAGE-3)) + 4)
+#define LZ4_STREAMSIZE (LZ4_STREAMSIZE_U64 * sizeof(long long))
+ * LZ4_stream_t
+ * information structure to track an LZ4 stream.
+ * important : init this structure content before first use !
+ * note : only allocated directly the structure if you are statically linking LZ4
+ * If you are using liblz4 as a DLL, please use below construction methods instead.
+typedef struct { long long table[LZ4_STREAMSIZE_U64]; } LZ4_stream_t;
+ * LZ4_resetStream
+ * Use this function to init an allocated LZ4_stream_t structure
+void LZ4_resetStream (LZ4_stream_t* streamPtr);
+ * LZ4_createStream will allocate and initialize an LZ4_stream_t structure
+ * LZ4_freeStream releases its memory.
+ * In the context of a DLL (liblz4), please use these methods rather than the static struct.
+ * They are more future proof, in case of a change of LZ4_stream_t size.
+LZ4_stream_t* LZ4_createStream(void);
+int LZ4_freeStream (LZ4_stream_t* streamPtr);
+ * LZ4_loadDict
+ * Use this function to load a static dictionary into LZ4_stream.
+ * Any previous data will be forgotten, only 'dictionary' will remain in memory.
+ * Loading a size of 0 is allowed.
+ * Return : dictionary size, in bytes (necessarily <= 64 KB)
+int LZ4_loadDict (LZ4_stream_t* streamPtr, const char* dictionary, int dictSize);
+ * LZ4_compress_fast_continue
+ * Compress buffer content 'src', using data from previously compressed blocks as dictionary to improve compression ratio.
+ * Important : Previous data blocks are assumed to still be present and unmodified !
+ * 'dst' buffer must be already allocated.
+ * If maxDstSize >= LZ4_compressBound(srcSize), compression is guaranteed to succeed, and runs faster.
+ * If not, and if compressed data cannot fit into 'dst' buffer size, compression stops, and function returns a zero.
+int LZ4_compress_fast_continue (LZ4_stream_t* streamPtr, const char* src, char* dst, int srcSize, int maxDstSize, int acceleration);
+ * LZ4_saveDict
+ * If previously compressed data block is not guaranteed to remain available at its memory location
+ * save it into a safer place (char* safeBuffer)
+ * Note : you don't need to call LZ4_loadDict() afterwards,
+ * dictionary is immediately usable, you can therefore call LZ4_compress_fast_continue()
+ * Return : saved dictionary size in bytes (necessarily <= dictSize), or 0 if error
+int LZ4_saveDict (LZ4_stream_t* streamPtr, char* safeBuffer, int dictSize);
+* Streaming Decompression Functions
+#define LZ4_STREAMDECODESIZE_U64 4
+#define LZ4_STREAMDECODESIZE (LZ4_STREAMDECODESIZE_U64 * sizeof(unsigned long long))
+typedef struct { unsigned long long table[LZ4_STREAMDECODESIZE_U64]; } LZ4_streamDecode_t;
+ * LZ4_streamDecode_t
+ * init this structure content using LZ4_setStreamDecode or memset() before first use !
+ * In the context of a DLL (liblz4) please prefer usage of construction methods below.
+ * They are more future proof, in case of a change of LZ4_streamDecode_t size in the future.
+ * LZ4_createStreamDecode will allocate and initialize an LZ4_streamDecode_t structure
+ * LZ4_freeStreamDecode releases its memory.
+LZ4_streamDecode_t* LZ4_createStreamDecode(void);
+int LZ4_freeStreamDecode (LZ4_streamDecode_t* LZ4_stream);
+ * Use this function to instruct where to find the dictionary.
+ * Setting a size of 0 is allowed (same effect as reset).
+int LZ4_setStreamDecode (LZ4_streamDecode_t* LZ4_streamDecode, const char* dictionary, int dictSize);
+*_continue() :
+ Previously decoded blocks *must* remain available at the memory position where they were decoded (up to 64 KB)
+ In the case of a ring buffers, decoding buffer must be either :
+ - Exactly same size as encoding buffer, with same update rule (block boundaries at same positions)
+ In which case, the decoding & encoding ring buffer can have any size, including very small ones ( < 64 KB).
+ - Larger than encoding buffer, by a minimum of maxBlockSize more bytes.
+ maxBlockSize is implementation dependent. It's the maximum size you intend to compress into a single block.
+ In which case, encoding and decoding buffers do not need to be synchronized,
+ and encoding ring buffer can have any size, including small ones ( < 64 KB).
+ - _At least_ 64 KB + 8 bytes + maxBlockSize.
+ and encoding ring buffer can have any size, including larger than decoding buffer.
+ Whenever these conditions are not possible, save the last 64KB of decoded data into a safe buffer,
+ and indicate where it is saved using LZ4_setStreamDecode()
+int LZ4_decompress_safe_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int compressedSize, int maxDecompressedSize);
+int LZ4_decompress_fast_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int originalSize);
+*_usingDict() :
+ a combination of LZ4_setStreamDecode() followed by LZ4_decompress_x_continue()
+ They are stand-alone. They don't need nor update an LZ4_streamDecode_t structure.
+int LZ4_decompress_safe_usingDict (const char* source, char* dest, int compressedSize, int maxDecompressedSize, const char* dictStart, int dictSize);
+int LZ4_decompress_fast_usingDict (const char* source, char* dest, int originalSize, const char* dictStart, int dictSize);
+/* Deprecate Warnings */
+/* Should these warnings messages be a problem,
+ it is generally possible to disable them,
+ with -Wno-deprecated-declarations for gcc
+ or _CRT_SECURE_NO_WARNINGS in Visual for example.
+ You can also define LZ4_DEPRECATE_WARNING_DEFBLOCK. */
+#ifndef LZ4_DEPRECATE_WARNING_DEFBLOCK
+# define LZ4_DEPRECATE_WARNING_DEFBLOCK
+# define LZ4_GCC_VERSION (__GNUC__ * 100 + __GNUC_MINOR__)
+# if (LZ4_GCC_VERSION >= 405) || defined(__clang__)
+# define LZ4_DEPRECATED(message) __attribute__((deprecated(message)))
+# elif (LZ4_GCC_VERSION >= 301)
+# define LZ4_DEPRECATED(message) __attribute__((deprecated))
+# elif defined(_MSC_VER)
+# define LZ4_DEPRECATED(message) __declspec(deprecated(message))
+# else
+# pragma message("WARNING: You need to implement LZ4_DEPRECATED for this compiler")
+# endif
+#endif /* LZ4_DEPRECATE_WARNING_DEFBLOCK */
+/* Obsolete compression functions */
+/* These functions are planned to start generate warnings by r131 approximately */
+int LZ4_compress (const char* source, char* dest, int sourceSize);
+int LZ4_compress_limitedOutput (const char* source, char* dest, int sourceSize, int maxOutputSize);
+int LZ4_compress_withState (void* state, const char* source, char* dest, int inputSize);
+int LZ4_compress_limitedOutput_withState (void* state, const char* source, char* dest, int inputSize, int maxOutputSize);
+int LZ4_compress_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize);
+int LZ4_compress_limitedOutput_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize, int maxOutputSize);
+/* Obsolete decompression functions */
+/* These function names are completely deprecated and must no longer be used.
+ They are only provided here for compatibility with older programs.
+ - LZ4_uncompress is the same as LZ4_decompress_fast
+ - LZ4_uncompress_unknownOutputSize is the same as LZ4_decompress_safe
+ These function prototypes are now disabled; uncomment them only if you really need them.
+ It is highly recommended to stop using these prototypes and migrate to maintained ones */
+/* int LZ4_uncompress (const char* source, char* dest, int outputSize); */
+/* int LZ4_uncompress_unknownOutputSize (const char* source, char* dest, int isize, int maxOutputSize); */
+/* Obsolete streaming functions; use new streaming interface whenever possible */
+LZ4_DEPRECATED("use LZ4_createStream() instead") void* LZ4_create (char* inputBuffer);
+LZ4_DEPRECATED("use LZ4_createStream() instead") int LZ4_sizeofStreamState(void);
+LZ4_DEPRECATED("use LZ4_resetStream() instead") int LZ4_resetStreamState(void* state, char* inputBuffer);
+LZ4_DEPRECATED("use LZ4_saveDict() instead") char* LZ4_slideInputBuffer (void* state);
+/* Obsolete streaming decoding functions */
+LZ4_DEPRECATED("use LZ4_decompress_safe_usingDict() instead") int LZ4_decompress_safe_withPrefix64k (const char* src, char* dst, int compressedSize, int maxDstSize);
+LZ4_DEPRECATED("use LZ4_decompress_fast_usingDict() instead") int LZ4_decompress_fast_withPrefix64k (const char* src, char* dst, int originalSize);
+#endif
