[GRASS-SVN] r67309 - in grass/branches/releasebranch_6_4/raster/r.watershed: ram seg
Mon Dec 21 14:17:28 PST 2015
Author: mmetz
Date: 2015-12-21 14:17:28 -0800 (Mon, 21 Dec 2015)
New Revision: 67309
   grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_astar.c
   grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_cum.c
   grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_astar.c
   grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_cum.c
r.watershed: fix correction for diagonal flow bias
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_astar.c
--- grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_astar.c	2015-12-21 15:58:18 UTC (rev 67308)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_astar.c	2015-12-21 22:17:28 UTC (rev 67309)
@@ -71,8 +71,9 @@
 	    /* get r, c (upr, upc) for this neighbour */
 	    upr = r + nextdr[ct_dir];
 	    upc = c + nextdc[ct_dir];
-	    slope[ct_dir] = alt_nbr[ct_dir] = 0;
-	    /* check that r, c are within region */
+	    slope[ct_dir] = -1;
+	    alt_nbr[ct_dir] = 0;
+	    /* check if r, c are within region */
 	    if (upr >= 0 && upr < nrows && upc >= 0 && upc < ncols) {
 		index_up = SEG_INDEX(alt_seg, upr, upc);
 		/* check if neighbour is in the list */
@@ -87,16 +88,16 @@
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
-		if (!is_in_list) {
+		if (!is_in_list || (!is_worked && asp[index_up] < 0)) {
 		    if (ct_dir > 3 && slope[ct_dir] > 0) {
-			if (slope[nbr_ew[ct_dir]] > 0) {
+			if (slope[nbr_ew[ct_dir]] >= 0) {
 			    /* slope to ew nbr > slope to center */
 			    if (slope[ct_dir] <
 				get_slope2(alt_nbr[nbr_ew[ct_dir]],
 					   alt_nbr[ct_dir], ew_res))
 				skip_diag = 1;
-			if (!skip_diag && slope[nbr_ns[ct_dir]] > 0) {
+			if (!skip_diag && slope[nbr_ns[ct_dir]] >= 0) {
 			    /* slope to ns nbr > slope to center */
 			    if (slope[ct_dir] <
 				get_slope2(alt_nbr[nbr_ns[ct_dir]],
@@ -107,12 +108,12 @@
 		/* add neighbour as new point if not in the list */
-		if (is_in_list == 0 && skip_diag == 0) {
+		if (!is_in_list && !skip_diag) {
 		    add_pt(upr, upc, alt_nbr[ct_dir], alt_val);
 		    /* set flow direction */
 		    asp[index_up] = drain[upr - r + 1][upc - c + 1];
-		else if (is_in_list && is_worked == 0) {
+		else if (!is_worked && !skip_diag && slope[ct_dir] > 0) {
 		    /* neighbour is edge in list, not yet worked */
 		    if (asp[index_up] < 0) {
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_cum.c
--- grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_cum.c	2015-12-21 15:58:18 UTC (rev 67308)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/ram/do_cum.c	2015-12-21 22:17:28 UTC (rev 67309)
@@ -198,7 +198,7 @@
 			stream_cells++;
 		    is_worked = FLAG_GET(worked, r_nbr, c_nbr);
-		    if (is_worked == 0) {
+		    if (!is_worked) {
 			is_null = G_is_c_null_value(&ele_nbr);
 			edge = is_null;
 			if (ele_nbr != ele)
@@ -225,6 +225,8 @@
 			    if (dr == r_nbr && dc == c_nbr) {
 				astar_not_set = 0;
+			    if (value < 0 && valued > 0)
+				wat[nbr_index] = -valued;
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_astar.c
--- grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_astar.c	2015-12-21 15:58:18 UTC (rev 67308)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_astar.c	2015-12-21 22:17:28 UTC (rev 67309)
@@ -79,12 +79,14 @@
-	    /* check that upr, upc are within region */
+	    /* check if upr, upc are within region */
 		/* avoid diagonal flow direction bias */
 		bseg_get(&in_list, &in_val, upr, upc);
 		bseg_get(&worked, &work_val, upr, upc);
+		cseg_get(&asp, &asp_up, upr, upc);
 		skip_diag = 0;
 		if (!work_val) {
 		    cseg_get(&alt, &alt_up, upr, upc);
@@ -93,16 +95,16 @@
-		if (!in_val) {
+		if (!in_val || (!work_val && asp_up < 0)) {
 			    if (slope[ct_dir] <
 				skip_diag = 1;
 			    if (slope[ct_dir] <
@@ -112,15 +114,14 @@
 		/* put neighbour in search list if not yet in */
-		if (in_val == 0 && skip_diag == 0) {
+		if (!skip_diag && !in_val) {
 		    /* flow direction is set here */
 		    drain_val = drain[upr - r + 1][upc - c + 1];
 		    cseg_put(&asp, &drain_val, upr, upc);
 		/* check if neighbour has not been worked on */
-		else if (in_val && !work_val) {
-		    cseg_get(&asp, &asp_up, upr, upc);
+		else if (!skip_diag && in_val && !work_val && slope[ct_dir] > 0) {
 		    if (asp_up < 0) {
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_cum.c
--- grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_cum.c	2015-12-21 15:58:18 UTC (rev 67308)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/seg/do_cum.c	2015-12-21 22:17:28 UTC (rev 67309)
@@ -241,6 +241,10 @@
 				astar_not_set = 0;
+			    if (value < 0 && wat_nbr[ct_dir] > 0) {
+				valued = -wat_nbr[ct_dir];
+				dseg_put(&wat, &valued, r_nbr, c_nbr);
