[GRASS-SVN] r67310 - in grass/trunk: gui/wxpython/animation gui/wxpython/datacatalog gui/wxpython/dbmgr gui/wxpython/gcp gui/wxpython/gmodeler gui/wxpython/gui_core gui/wxpython/iclass gui/wxpython/mapswipe gui/wxpython/psmap gui/wxpython/rlisetup gui/wxpython/timeline gui/wxpython/tplot gui/wxpython/vdigit lib/init lib/python/script
svn_grass at osgeo.org
Mon Dec 21 17:14:53 PST 2015
Author: martinl
Date: 2015-12-21 17:14:53 -0800 (Mon, 21 Dec 2015)
New Revision: 67310
grass/trunk/gui/wxpython/animation/g.gui.animation.py
grass/trunk/gui/wxpython/datacatalog/g.gui.datacatalog.py
grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
grass/trunk/lib/init/grass.py
grass/trunk/lib/python/script/setup.py
remove wxpath from PYTHONPATH (set path only locally)
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -61,6 +61,10 @@
# to avoid issues when only interface is needed
import grass.temporal as tgis
import wx
+ from grass.script.setup import set_gui_path
+ set_gui_path()
from core.globalvar import CheckWxVersion
from core.utils import _
from core.giface import StandaloneGrassInterface
Modified: grass/trunk/gui/wxpython/datacatalog/g.gui.datacatalog.py
--- grass/trunk/gui/wxpython/datacatalog/g.gui.datacatalog.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/datacatalog/g.gui.datacatalog.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -33,7 +33,10 @@
# import wx only after running parser
import wx
+ set_gui_path()
from datacatalog.frame import DataCatalogFrame
Modified: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -35,6 +35,10 @@
options, flags = gscript.parser()
import wx
+ set_gui_path()
from dbmgr.manager import AttributeManager
Modified: grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
--- grass/trunk/gui/wxpython/gcp/g.gui.gcp.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/gcp/g.gui.gcp.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -47,6 +47,10 @@
import wx
+ set_gui_path()
from core.settings import UserSettings
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -36,11 +36,14 @@
import grass.script as gscript
def main():
import wx
+ set_gui_path()
from gmodeler.frame import ModelFrame
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -82,6 +82,9 @@
from grass.script import core as grass
from grass.script import task as gtask
+from grass.script.setup import set_gui_path
+set_gui_path()
from core import globalvar
from gui_core.widgets import StaticWrapText, ScrolledPanel, ColorTablesComboBox, \
BarscalesComboBox, NArrowsComboBox
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -58,6 +58,10 @@
import wx
+ set_gui_path()
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -52,6 +52,10 @@
import wx
+ set_gui_path()
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -39,6 +39,10 @@
import wx
+ set_gui_path()
from psmap.frame import PsMapFrame
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -33,6 +33,10 @@
gscript.parser()
import wx
+ set_gui_path()
from rlisetup.frame import RLiSetupFrame
Modified: grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
--- grass/trunk/gui/wxpython/timeline/g.gui.timeline.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/timeline/g.gui.timeline.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -40,6 +40,10 @@
import wx
+ set_gui_path()
try:
from timeline.frame import TimelineFrame
except ImportError as e:
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -78,6 +78,10 @@
import wx
+ set_gui_path()
try:
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -46,6 +46,10 @@
# to avoid issues with complex imports when only interface is needed
import wx
+ set_gui_path()
from core.render import Map
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/lib/init/grass.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -574,8 +574,6 @@
path_prepend(gpath('bin'), 'PATH')
# Set PYTHONPATH to find GRASS Python modules
- if os.path.exists(gpath('gui', 'wxpython')):
- path_prepend(gpath('gui', 'wxpython'), 'PYTHONPATH')
if os.path.exists(gpath('etc', 'python')):
path_prepend(gpath('etc', 'python'), 'PYTHONPATH')
Modified: grass/trunk/lib/python/script/setup.py
--- grass/trunk/lib/python/script/setup.py 2015-12-21 22:17:28 UTC (rev 67309)
+++ grass/trunk/lib/python/script/setup.py 2015-12-22 01:14:53 UTC (rev 67310)
@@ -109,10 +109,16 @@
return gisrc
+def set_gui_path():
+ """Insert wxPython GRASS path to sys.path."""
+ gui_path = os.path.join(os.environ['GISBASE'], 'gui', 'wxpython')
+ if gui_path and gui_path not in sys.path:
+ sys.path.insert(0, gui_path)
# TODO: there should be a function to do the clean up
# (unset the GISRC and delete the file)
-def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT',
- initgui=False):
+def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
"""Initialize system variables to run GRASS modules
This function is for running GRASS GIS without starting it
@@ -142,7 +148,6 @@
:param dbase: path to GRASS database (default: '')
:param location: location name (default: 'demolocation')
:param mapset: mapset within given location (default: 'PERMANENT')
- :param initgui: add also GRASS wxPython packages to PYTHONPATH
:returns: path to ``gisrc`` file (to be deleted later)
@@ -183,8 +188,6 @@
path = os.getenv('PYTHONPATH')
etcpy = os.path.join(gisbase, 'etc', 'python')
- if initgui:
- etcpy += os.pathsep + os.path.join(gisbase, 'gui', 'wxpython')
if path:
path = etcpy + os.pathsep + path
else:
