[GRASS-SVN] r67447 - in grass/branches/releasebranch_7_0: . general/g.message gui/wxpython/iscatt gui/wxpython/mapwin lib/init lib/ogsf lib/python/ctypes/ctypesgencore/parser lib/python/imaging lib/vector/Vlib locale/po raster/r.basins.fill raster/r.out.gdal raster/r.statistics raster3d/r3.in.v5d raster3d/r3.out.v5d scripts/r.fillnulls vector/v.out.ascii vector/v.perturb
svn_grass at osgeo.org
Thu Dec 31 00:19:52 PST 2015
Author: neteler
Date: 2015-12-31 00:19:51 -0800 (Thu, 31 Dec 2015)
New Revision: 67447
grass/branches/releasebranch_7_0/binaryInstall.src
grass/branches/releasebranch_7_0/general/g.message/g.message.html
grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py
grass/branches/releasebranch_7_0/lib/init/grass7.html
grass/branches/releasebranch_7_0/lib/ogsf/gs.c
grass/branches/releasebranch_7_0/lib/python/ctypes/ctypesgencore/parser/cparser.py
grass/branches/releasebranch_7_0/lib/python/imaging/images2avi.py
grass/branches/releasebranch_7_0/lib/vector/Vlib/box.c
grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_fi.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
grass/branches/releasebranch_7_0/raster/r.basins.fill/main.c
grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html
grass/branches/releasebranch_7_0/raster/r.statistics/r.statistics.html
grass/branches/releasebranch_7_0/raster3d/r3.in.v5d/v5d.c
grass/branches/releasebranch_7_0/raster3d/r3.out.v5d/v5d.c
grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html
grass/branches/releasebranch_7_0/vector/v.out.ascii/main.c
grass/branches/releasebranch_7_0/vector/v.perturb/normalrs.c
grass/branches/releasebranch_7_0/vector/v.perturb/normalsv.c
various typos fixed (via Debian lintian QA tool, contributor: sebastic; trac #2841)
Modified: grass/branches/releasebranch_7_0/binaryInstall.src
--- grass/branches/releasebranch_7_0/binaryInstall.src 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/binaryInstall.src 2015-12-31 08:19:51 UTC (rev 67447)
@@ -193,7 +193,7 @@
mkdir -p $BINDIR
if [ $? -ne 0 ] ; then
- echo "An error occured trying to create $BINDIR ! Exiting."
+ echo "An error occurred trying to create $BINDIR ! Exiting."
exit
fi
fi
@@ -227,7 +227,7 @@
mkdir -p $DESTDIR
- echo "An error occured trying to create $DESTDIR! Exiting."
+ echo "An error occurred trying to create $DESTDIR! Exiting."
exit
fi
else
@@ -273,7 +273,7 @@
PACK_FILE=`echo $PACKAGE_DIR/$PACKAGE_NAME | sed 's+^//+/+g'`
cd $DESTDIR; $UNPACK -c $PACK_FILE | tar -xf -
if [ $? -eq 1 ] ; then
- echo "An error occured or user break while installing binaries! Exiting."
+ echo "An error occurred or user break while installing binaries! Exiting."
exit
fi
@@ -288,7 +288,7 @@
sed -e "s#@GISBASE@#$DESTDIR#g" \
$DESTDIR/$GRASSPRG.tmp > $BINDIR/grass-$NAME_VER
- echo "An error occured trying to create the grass start script! Exiting."
+ echo "An error occurred trying to create the grass start script! Exiting."
echo "You probably do not have permission to install into $BINDIR."
echo "You may need to be the root user to install in that directory."
exit
@@ -298,7 +298,7 @@
chmod ugo+x $BINDIR/grass-$NAME_VER
exit
Modified: grass/branches/releasebranch_7_0/general/g.message/g.message.html
--- grass/branches/releasebranch_7_0/general/g.message/g.message.html 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/general/g.message/g.message.html 2015-12-31 08:19:51 UTC (rev 67447)
@@ -41,7 +41,7 @@
While it is known that the interactive Bash instances may treat the
exclamation mark '<tt>!</tt>' character specifically (making single quoting
of it necessary), it shouldn't be the case for the non-interactive
-instances of Bash. None the less, to avoid context-based confusion later on
+instances of Bash. Nonetheless, to avoid context-based confusion later on
you are enouraged to single-quote messages that do not require
<tt>$VARIABLE</tt> expansion.
Modified: grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py
--- grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/gui/wxpython/iscatt/controllers.py 2015-12-31 08:19:51 UTC (rev 67447)
@@ -430,7 +430,7 @@
self.render_mgr.RunningProcessDone()
if event.exception:
- GError(_("Error occured during computation of scatter plot category:\n%s"),
+ GError(_("Error occurred during computation of scatter plot category:\n%s"),
parent = self.guiparent, showTraceback = False)
cat_id = event.ret
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapwin/base.py 2015-12-31 08:19:51 UTC (rev 67447)
@@ -192,7 +192,7 @@
except:
handlers.remove(handler)
GError(parent=self,
- message=_("Error occured during calling of handler: %s \n"
+ message=_("Error occurred during calling of handler: %s \n"
"Handler was unregistered.") % handler.__name__)
event.Skip()
@@ -272,7 +272,7 @@
except:
GError(parent = self,
- message = _("Error occured during unregistration of handler: %s \n \
+ message = _("Error occurred during unregistration of handler: %s \n \
@@ -305,7 +305,7 @@
% handler.__name__)
except:
Handler was unregistered") % handler.__name__)
Modified: grass/branches/releasebranch_7_0/lib/init/grass7.html
--- grass/branches/releasebranch_7_0/lib/init/grass7.html 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/lib/init/grass7.html 2015-12-31 08:19:51 UTC (rev 67447)
@@ -102,7 +102,7 @@
<p>Note that you will need to set these variables using the
appropriate method required for the UNIX shell that you use (e.g. in a
Bash shell you must <tt>export</tt> the variables for them to
-propogate).
+propagate).
<h3>User Interface Environment Variable</h3>
Modified: grass/branches/releasebranch_7_0/lib/ogsf/gs.c
--- grass/branches/releasebranch_7_0/lib/ogsf/gs.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/lib/ogsf/gs.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -358,7 +358,7 @@
- \brief Debugging, 256 interger values from buffer
+ \brief Debugging, 256 integer values from buffer
\todo G_debug ?
Modified: grass/branches/releasebranch_7_0/lib/python/ctypes/ctypesgencore/parser/cparser.py
--- grass/branches/releasebranch_7_0/lib/python/ctypes/ctypesgencore/parser/cparser.py 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/lib/python/ctypes/ctypesgencore/parser/cparser.py 2015-12-31 08:19:51 UTC (rev 67447)
@@ -120,7 +120,7 @@
def handle_error(self, message, filename, lineno):
- '''A parse error occured.
+ '''A parse error occurred.
The default implementation prints `lineno` and `message` to stderr.
The parser will try to recover from errors by synchronising at the
Modified: grass/branches/releasebranch_7_0/lib/python/imaging/images2avi.py
--- grass/branches/releasebranch_7_0/lib/python/imaging/images2avi.py 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/lib/python/imaging/images2avi.py 2015-12-31 08:19:51 UTC (rev 67447)
@@ -113,7 +113,7 @@
outPut = S.stdout.read()
if S.wait():
- # An error occured, show
+ # An error occurred, show
print(outPut)
print(S.stderr.read())
# Clean up
@@ -158,7 +158,7 @@
if S.wait():
print(outPut)
# Clean up
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/box.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/box.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/box.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -125,7 +125,7 @@
* \param c_x,c_y coordinates (s, n)
* \param Box boundary box
- * \return 1 if any clipping occured
+ * \return 1 if any clipping occurred
* \return 0 otherwise
int Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const struct bound_box *Box)
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37352,7 +37352,7 @@
#: ../vector/v.out.ascii/main.c:163
#, fuzzy
-msgid "An error occured, nothing to be exported"
+msgid "An error occurred, nothing to be exported"
msgstr "%-5d تم تخطى فئات النقط الميت\n"
#: ../vector/v.out.dxf/main.c:58
@@ -38646,11 +38646,11 @@
msgstr "لم بمكن قراءة معلومات الحقل"
#: ../vector/v.perturb/normalrs.c:31
-msgid "normalsv: restoration of unitialized block"
+msgid "normalsv: restoration of uninitialized block"
msgstr ""
#: ../vector/v.perturb/normalsv.c:29
-msgid "normalsv: save of unitialized block"
+msgid "normalsv: save of uninitialized block"
msgstr ""
#: ../vector/v.proj/main.c:70
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37737,7 +37737,7 @@
#, fuzzy
msgstr "Žádné prvky nejsou vybrány, není co editovat"
@@ -39061,11 +39061,11 @@
msgstr "Nelze dostat informace o odkazu na databázi"
msgstr "normalsv: obnovení neiniciovaného bloku"
msgstr "normalsv: uložení neiniciovaného bloku"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37864,7 +37864,7 @@
#, fuzzy
msgstr "Keine Feature selektiert, nix zu editieren."
@@ -39226,11 +39226,11 @@
msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen."
msgstr "normalsv: Restaurierung eines uninitialisierten Blocks."
msgstr "normalsv: Speichere uninitialisierten Block."
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -35867,7 +35867,7 @@
msgstr ""
msgstr ""
@@ -37115,11 +37115,11 @@
msgstr ""
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37972,7 +37972,7 @@
#, fuzzy
msgstr "Ningún elemento seleccionado, nada que editar"
@@ -39343,11 +39343,11 @@
msgstr "No se puede obtener leer la información del enlace a la base de datos"
msgstr "normalsv: restauración de bloque no inicializado"
msgstr "normalsv: guardar bloque no inicializado"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fi.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -34431,7 +34431,7 @@
msgstr ""
msgstr ""
@@ -35642,11 +35642,11 @@
msgstr ""
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -39662,7 +39662,7 @@
# c-format
#, fuzzy
msgstr "%d points sans catégorie"
@@ -41120,11 +41120,11 @@
msgstr "Impossible de lire les informations de liaison à la base de données"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37154,7 +37154,7 @@
#, fuzzy
msgstr "%d punti senza categoria non considerati"
@@ -38469,11 +38469,11 @@
msgstr ""
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37195,7 +37195,7 @@
#, fuzzy
msgstr "出力ファイルの上書き"
@@ -38514,11 +38514,11 @@
msgstr "dbリンク情報を取得できません"
msgstr "normalsv: 初期化解除されたブロックの修復"
msgstr "normalsv: 初期化されていないブロックの保存"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -36072,7 +36072,7 @@
msgstr ""
msgstr ""
@@ -37331,11 +37331,11 @@
msgstr ""
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37175,7 +37175,7 @@
#, fuzzy
msgstr "%-5d mirušo/neizmantoto punktu kategorijas izlaistas\n"
@@ -38509,11 +38509,11 @@
msgstr "Nevar nolasīt faila informāciju"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37263,7 +37263,7 @@
#, fuzzy
msgstr "Edytować plik kategorii dla [%s]? "
@@ -38552,11 +38552,11 @@
msgstr "Nie można pobrać informacji o odnośniku do bazy danych"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -38344,7 +38344,7 @@
#, fuzzy
msgstr "%d pontos sem categoria"
@@ -39736,11 +39736,11 @@
msgstr "Não consegui obter informações sobre a ligação ao BD"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -38252,7 +38252,7 @@
#, fuzzy
@@ -39643,11 +39643,11 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -34972,7 +34972,7 @@
msgstr ""
msgstr ""
@@ -36193,11 +36193,11 @@
msgstr ""
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37891,7 +37891,7 @@
#, fuzzy
msgstr "Объекты не выделены, нечего редактировать"
@@ -39228,11 +39228,11 @@
msgstr "Невозможно получить информацию о связи с БД"
msgstr "normalsv: восстановление неиннициализированного блока"
msgstr "normalsv: сохранение неиннициализированного блока"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37627,7 +37627,7 @@
#, fuzzy
msgstr "%-5d mrtvih kategorij toèk preskoèenih\n"
@@ -38922,11 +38922,11 @@
msgstr "Ne morem prebrati informacije polja"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37472,7 +37472,7 @@
#, fuzzy
msgstr "ไม่มีข้อมูลถูกเลือก, ไม่มีอะไรจะแก้ไข"
@@ -38773,12 +38773,12 @@
msgstr "ไม่สามารถอ่าน ข้อมูล db link"
-msgstr "normalsv: restoration of unitialized block"
+msgstr "normalsv: restoration of uninitialized block"
-msgstr "normalsv: save of unitialized block"
+msgstr "normalsv: save of uninitialized block"
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -36734,7 +36734,7 @@
#, fuzzy
msgstr "Hiç obje seçilmedi, hiçbirşey düzenlenmeyecek"
@@ -38002,11 +38002,11 @@
msgstr "Veritabanı bağlantı bilgisi alınamıyor"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37887,7 +37887,7 @@
#, fuzzy
msgstr "Không có đối tượng nào được chọn, không có gì để chỉnh sửa"
@@ -39235,11 +39235,11 @@
msgstr "Không thể lấy thông tin liên kết csdl"
msgstr "normalsv: phục hồi các khối không được khởi tạo"
msgstr "normalsv: lưu các khối không được khởi tạo"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -37529,7 +37529,7 @@
#, fuzzy
msgstr "%d 个点没有类别,将被忽略"
@@ -38851,11 +38851,11 @@
msgstr "无法读取字段信息"
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5836,7 +5836,7 @@
#: ../gui/wxpython/iscatt/controllers.py:433
#, python-format
msgid ""
-"Error occured during computation of scatter plot category:\n"
+"Error occurred during computation of scatter plot category:\n"
"%s"
msgstr ""
@@ -7950,14 +7950,14 @@
#: ../gui/wxpython/mapwin/base.py:195
#, python-format
msgid ""
-"Error occured during calling of handler: %s \n"
+"Error occurred during calling of handler: %s \n"
msgstr ""
#: ../gui/wxpython/mapwin/base.py:275
#, python-format
msgid ""
-"Error occured during unregistration of handler: %s \n"
+"Error occurred during unregistration of handler: %s \n"
" Handler was unregistered."
msgstr ""
@@ -7969,7 +7969,7 @@
#: ../gui/wxpython/mapwin/base.py:308
#, python-format
msgid ""
" Handler was unregistered"
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5820,7 +5820,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7943,14 +7943,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7962,7 +7962,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5585,7 +5585,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7608,14 +7608,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7627,7 +7627,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5904,7 +5904,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8067,14 +8067,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8086,7 +8086,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_fi.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_fi.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_fi.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5427,7 +5427,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7378,14 +7378,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7397,7 +7397,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5774,7 +5774,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
"Une erreur est survenue lors du calcul de la catégorie du nuage de points :\n"
@@ -7861,14 +7861,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7880,7 +7880,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -6048,7 +6048,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8204,14 +8204,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8223,7 +8223,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5655,7 +5655,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
"Un errore è occorso durante la creazione della categoria dello scatter "
@@ -7690,14 +7690,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7709,7 +7709,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5861,7 +5861,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7975,14 +7975,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7994,7 +7994,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5425,7 +5425,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7376,14 +7376,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7395,7 +7395,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5546,7 +5546,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7554,14 +7554,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7573,7 +7573,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5767,7 +5767,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7865,14 +7865,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7884,7 +7884,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5729,7 +5729,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7810,14 +7810,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7829,7 +7829,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -6044,7 +6044,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8210,14 +8210,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8229,7 +8229,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -6172,7 +6172,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8396,14 +8396,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8415,7 +8415,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5849,7 +5849,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7979,14 +7979,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7998,7 +7998,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -6003,7 +6003,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8154,14 +8154,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8173,7 +8173,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5753,7 +5753,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -7807,14 +7807,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7826,7 +7826,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -6005,7 +6005,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8164,14 +8164,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8183,7 +8183,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5994,7 +5994,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
@@ -8158,14 +8158,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -8177,7 +8177,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-12-31 08:19:51 UTC (rev 67447)
@@ -5848,7 +5848,7 @@
#, python-format
msgid ""
"%s"
msgstr ""
"计算散点图类别时发生错误:\n"
@@ -7955,14 +7955,14 @@
#, python-format
msgid ""
msgstr ""
#, python-format
msgid ""
msgstr ""
@@ -7974,7 +7974,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/raster/r.basins.fill/main.c
--- grass/branches/releasebranch_7_0/raster/r.basins.fill/main.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/raster/r.basins.fill/main.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -17,7 +17,7 @@
-/* program to propogate the link label into the hillslope areas; */
+/* program to propagate the link label into the hillslope areas; */
/* processes CELL files only and works on window derived from link */
/* label map */
Modified: grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html
--- grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/raster/r.out.gdal/r.out.gdal.html 2015-12-31 08:19:51 UTC (rev 67447)
@@ -3,7 +3,7 @@
<em>r.out.gdal</em> allows a user to export a GRASS raster map layer
into any GDAL supported raster map format. If a GRASS raster map is
exported for a particular application, the application's native format
-would be preferrable. GeoTIFF is supported by a wide range of
+would be preferable. GeoTIFF is supported by a wide range of
applications (see also <b>NOTES</b> on GeoTIFF below).
<p>To specify multiple creation options use a comma separated list
(<em>createopt="TFW=YES,COMPRESS=DEFLATE"</em>).
Modified: grass/branches/releasebranch_7_0/raster/r.statistics/r.statistics.html
--- grass/branches/releasebranch_7_0/raster/r.statistics/r.statistics.html 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/raster/r.statistics/r.statistics.html 2015-12-31 08:19:51 UTC (rev 67447)
@@ -29,7 +29,7 @@
The calculations will be performed on each area of data of the
cover layers which fall within each unique value, or category, of the base layer.
<p>Setting the <em>-c</em> flag the category lables of the covering raster
-layer will be used. This is nice to avoid the GRASS limitation to interger
+layer will be used. This is nice to avoid the GRASS limitation to integer
in raster maps because using category values floating point numbers can be
stored.
Modified: grass/branches/releasebranch_7_0/raster3d/r3.in.v5d/v5d.c
--- grass/branches/releasebranch_7_0/raster3d/r3.in.v5d/v5d.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/raster3d/r3.in.v5d/v5d.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -2866,7 +2866,7 @@
for (i = 0; i < *numvars; i++) {
if (copy_string2(names[i], varname[i], 10) == 0) {
- printf("Error: unitialized varname(%d)\n", i + 1);
+ printf("Error: uninitialized varname(%d)\n", i + 1);
return 0;
Modified: grass/branches/releasebranch_7_0/raster3d/r3.out.v5d/v5d.c
--- grass/branches/releasebranch_7_0/raster3d/r3.out.v5d/v5d.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/raster3d/r3.out.v5d/v5d.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -2868,7 +2868,7 @@
return 0;
Modified: grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html
--- grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/scripts/r.fillnulls/r.fillnulls.html 2015-12-31 08:19:51 UTC (rev 67447)
@@ -13,7 +13,7 @@
Each area boundary buffer is set to three times the map resolution to get nominally
three points around the edge. This way the algorithm interpolates into the hole with
a trained slope and curvature at the edges, in order to avoid that such a flat plane
-is generated in a hole. The widht of edge area can be adjusted by
+is generated in a hole. The width of edge area can be adjusted by
changing the edge parameter.
<p>During the interpolation following warning may occur when using the RST method:<p>
<tt>
Modified: grass/branches/releasebranch_7_0/vector/v.out.ascii/main.c
--- grass/branches/releasebranch_7_0/vector/v.out.ascii/main.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/vector/v.out.ascii/main.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -160,7 +160,7 @@
else if (ret < 0) {
- G_warning(_("An error occured, nothing to be exported"));
+ G_warning(_("An error occurred, nothing to be exported"));
if (ascii != NULL)
Modified: grass/branches/releasebranch_7_0/vector/v.perturb/normalrs.c
--- grass/branches/releasebranch_7_0/vector/v.perturb/normalrs.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/vector/v.perturb/normalrs.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -28,7 +28,7 @@
zufallrs(svbox);
klotz1_1.first = (int)svbox[608];
if (klotz1_1.first == 0)
- G_warning(_("normalsv: restoration of unitialized block"));
+ G_warning(_("normalsv: restoration of uninitialized block"));
klotz1_1.xptr = (int)svbox[609];
k = 609;
for (i = 0; i < 1024; ++i)
Modified: grass/branches/releasebranch_7_0/vector/v.perturb/normalsv.c
--- grass/branches/releasebranch_7_0/vector/v.perturb/normalsv.c 2015-12-31 08:19:29 UTC (rev 67446)
+++ grass/branches/releasebranch_7_0/vector/v.perturb/normalsv.c 2015-12-31 08:19:51 UTC (rev 67447)
@@ -26,7 +26,7 @@
/* Parameter adjustments */
- G_warning(_("normalsv: save of unitialized block"));
+ G_warning(_("normalsv: save of uninitialized block"));
/* save zufall block klotz0 */
zufallsv(svbox);
