[GRASS-SVN] r64452 - grass-addons/grass7/raster/r.flexure
svn_grass at osgeo.org
Tue Feb 3 17:52:25 PST 2015
Author: awickert
Date: 2015-02-03 17:52:25 -0800 (Tue, 03 Feb 2015)
New Revision: 64452
grass-addons/grass7/raster/r.flexure/r.flexure.py
parser, indentation, and placeholder for dependency installation
Modified: grass-addons/grass7/raster/r.flexure/r.flexure.py
--- grass-addons/grass7/raster/r.flexure/r.flexure.py 2015-02-04 00:03:44 UTC (rev 64451)
+++ grass-addons/grass7/raster/r.flexure/r.flexure.py 2015-02-04 01:52:25 UTC (rev 64452)
@@ -163,131 +163,143 @@
# GRASS
import grass.script as grass
import grass.script.array as garray
-# GFLEX
-try:
- import gflex
-except:
- print ""
- print "MODULE IMPORT ERROR."
- print "In order to run r.flexure or g.flexure, you must download and install"
- print "gFlex. The most recent development version is available from"
- print "https://github.com/awickert/gFlex."
- print "Installation instructions are available on the page."
- grass.fatal("Software dependency must be installed.")
# PASS VARIABLES AND SOLVE #
def main():
- Gridded flexural isostatic solutions
+ Gridded flexural isostatic solutions
+ options, flags = grass.parser()
+ # if just interface description is requested, it will not get to this point
+ # so gflex will not be needed
- # This code is for 2D flexural isostasy
- flex = gflex.F2D()
- # And show that it is coming from GRASS GIS
- flex.grass = True
- # Flags
- latlon_override = flags['l']
- # Inputs
- # Solution selection
- flex.Method = options['method']
- if flex.Method == 'FD':
+ # GFLEX
+ # try to import gflex only after we know that
+ # we will actually do the computation
+ try:
+ import gflex
+ except:
+ print ""
+ print "MODULE IMPORT ERROR."
+ print "In order to run r.flexure or g.flexure, you must download and install"
+ print "gFlex. The most recent development version is available from"
+ print "https://github.com/awickert/gFlex."
+ print "Installation instructions are available on the page."
+ grass.fatal("Software dependency must be installed.")
+ # This code is for 2D flexural isostasy
+ flex = gflex.F2D()
+ # And show that it is coming from GRASS GIS
+ flex.grass = True
+ # Flags
+ latlon_override = flags['l']
+ # Inputs
+ # Solution selection
+ flex.Method = options['method']
+ if flex.Method == 'FD':
+ flex.Solver = options['solver']
+ if flex.Solver:
+ flex.ConvergenceTolerance = options['tolerance']
+ # Always use the van Wees and Cloetingh (1994) solution type.
+ # It is the best.
+ flex.PlateSolutionType = 'vWC1994'
+ # Parameters that are often changed for the solution
+ qs = options['q0']
+ flex.qs = garray.array()
+ flex.qs.read(qs)
+ # Elastic thickness
+ try:
+ flex.Te = float(options['te'])
+ except:
+ flex.Te = garray.array() # FlexureTe is the one that is used by Flexure
+ flex.Te.read(options['te'])
+ flex.Te = np.array(flex.Te)
+ if options['te_units'] == 'km':
+ flex.Te *= 1000
+ elif options['te_units'] == 'm':
+ pass
+ # No "else"; shouldn't happen
+ flex.rho_fill = float(options['rho_fill'])
+ # Parameters that often stay at their default values
+ flex.g = float(options['g'])
+ flex.E = float(options['ym']) # Can't just use "E" because reserved for "east", I think
+ flex.nu = float(options['nu'])
+ flex.rho_m = float(options['rho_m'])
+ # Solver type and iteration tolerance
- if flex.Solver:
- flex.ConvergenceTolerance = options['tolerance']
- # Always use the van Wees and Cloetingh (1994) solution type.
- # It is the best.
- flex.PlateSolutionType = 'vWC1994'
- # Parameters that are often changed for the solution
- qs = options['q0']
- flex.qs = garray.array()
- flex.qs.read(qs)
- # Elastic thickness
- try:
- flex.Te = float(options['te'])
- except:
- flex.Te = garray.array() # FlexureTe is the one that is used by Flexure
- flex.Te.read(options['te'])
- flex.Te = np.array(flex.Te)
- if options['te_units'] == 'km':
- flex.Te *= 1000
- elif options['te_units'] == 'm':
- pass
- # No "else"; shouldn't happen
- flex.rho_fill = float(options['rho_fill'])
- # Parameters that often stay at their default values
- flex.g = float(options['g'])
- flex.E = float(options['ym']) # Can't just use "E" because reserved for "east", I think
- flex.nu = float(options['nu'])
- flex.rho_m = float(options['rho_m'])
- # Solver type and iteration tolerance
- flex.Solver = options['solver']
- flex.ConvergenceTolerance = float(options['tolerance'])
- # Boundary conditions
- flex.BC_N = options['northbc']
- flex.BC_S = options['southbc']
- flex.BC_W = options['westbc']
- flex.BC_E = options['eastbc']
+ flex.ConvergenceTolerance = float(options['tolerance'])
+ # Boundary conditions
+ flex.BC_N = options['northbc']
+ flex.BC_S = options['southbc']
+ flex.BC_W = options['westbc']
+ flex.BC_E = options['eastbc']
- # Set verbosity
- if grass.verbosity() >= 2:
- flex.Verbose = True
- if grass.verbosity() >= 3:
- flex.Debug = True
- elif grass.verbosity() == 0:
- flex.Quiet = True
- # First check if output exists
- if len(grass.parse_command('g.list', type='rast', pattern=options['output'])):
- if not grass.overwrite():
- grass.fatal("Raster map '" + options['output'] + "' already exists. Use '--o' to overwrite.")
- # Get grid spacing from GRASS
- # Check if lat/lon and proceed as directed
- if grass.region_env()[6] == '3':
- if latlon_override:
- if flex.Verbose:
- print "Latitude/longitude grid."
- print "Based on r_Earth = 6371 km"
- print "Setting y-resolution [m] to 111,195 * [degrees]"
- flex.dy = grass.region()['nsres']*111195.
- NSmid = (grass.region()['n'] + grass.region()['s'])/2.
- dx_at_mid_latitude = (3.14159/180.) * 6371000. * np.cos(np.deg2rad(NSmid))
- if flex.Verbose:
- print "Setting x-resolution [m] to "+"%.2f" %dx_at_mid_latitude+" * [degrees]"
- flex.dx = grass.region()['ewres']*dx_at_mid_latitude
+ # Set verbosity
+ if grass.verbosity() >= 2:
+ flex.Verbose = True
+ if grass.verbosity() >= 3:
+ flex.Debug = True
+ elif grass.verbosity() == 0:
+ flex.Quiet = True
+ # First check if output exists
+ if len(grass.parse_command('g.list', type='rast', pattern=options['output'])):
+ if not grass.overwrite():
+ grass.fatal("Raster map '" + options['output'] + "' already exists. Use '--o' to overwrite.")
+ # Get grid spacing from GRASS
+ # Check if lat/lon and proceed as directed
+ if grass.region_env()[6] == '3':
+ if latlon_override:
+ if flex.Verbose:
+ print "Latitude/longitude grid."
+ print "Based on r_Earth = 6371 km"
+ print "Setting y-resolution [m] to 111,195 * [degrees]"
+ flex.dy = grass.region()['nsres']*111195.
+ NSmid = (grass.region()['n'] + grass.region()['s'])/2.
+ dx_at_mid_latitude = (3.14159/180.) * 6371000. * np.cos(np.deg2rad(NSmid))
+ if flex.Verbose:
+ print "Setting x-resolution [m] to "+"%.2f" %dx_at_mid_latitude+" * [degrees]"
+ flex.dx = grass.region()['ewres']*dx_at_mid_latitude
+ else:
+ grass.fatal("Need the '-l' flag to enable lat/lon solution approximation.")
+ # Otherwise straightforward
else:
- grass.fatal("Need the '-l' flag to enable lat/lon solution approximation.")
- # Otherwise straightforward
- else:
- # CALCULATE!
- flex.initialize()
- flex.run()
- flex.finalize()
+ # CALCULATE!
+ flex.initialize()
+ flex.run()
+ flex.finalize()
- # Write to GRASS
- # Create a new garray buffer and write to it
- outbuffer = garray.array() # Instantiate output buffer
- outbuffer[...] = flex.w
- outbuffer.write(options['output'], overwrite=grass.overwrite) # Write it with the desired name
- # And create a nice colormap!
- grass.run_command('r.colors', map=options['output'], color='differences', quiet=True)
+ # Write to GRASS
+ # Create a new garray buffer and write to it
+ outbuffer = garray.array() # Instantiate output buffer
+ outbuffer[...] = flex.w
+ outbuffer.write(options['output'], overwrite=grass.overwrite) # Write it with the desired name
+ # And create a nice colormap!
+ grass.run_command('r.colors', map=options['output'], color='differences', quiet=True)
- # Reinstate this with a flag or output filename
- # But I think better to let interpolation happen a posteriori
- # So the user knows what the solution is and what it isn't
- #grass.run_command('r.resamp.interp', input=output, output=output + '_interp', method='lanczos', overwrite=True, quiet=True)
- #grass.run_command('r.colors', map=output + '_interp', color='rainbow', quiet=True)#, flags='e')
+ # Reinstate this with a flag or output filename
+ # But I think better to let interpolation happen a posteriori
+ # So the user knows what the solution is and what it isn't
+ #grass.run_command('r.resamp.interp', input=output, output=output + '_interp', method='lanczos', overwrite=True, quiet=True)
+ #grass.run_command('r.colors', map=output + '_interp', color='rainbow', quiet=True)#, flags='e')
+def install_dependencies():
+ print "PLACEHOLDER"
if __name__ == "__main__":
- options, flags = grass.parser()
- main()
+ import sys
+ if len(sys.argv) > 1 and sys.argv[1] == '--install-dependencies':
+ install_dependencies()
+ else:
+ main()
