[GRASS-SVN] r64453 - grass-addons/grass7/vector/v.flexure
svn_grass at osgeo.org
Tue Feb 3 18:07:34 PST 2015
Author: awickert
Date: 2015-02-03 18:07:34 -0800 (Tue, 03 Feb 2015)
New Revision: 64453
grass-addons/grass7/vector/v.flexure/v.flexure.py
parser before importing foreign dependency; indentation (thanks Vaclav)
Modified: grass-addons/grass7/vector/v.flexure/v.flexure.py
--- grass-addons/grass7/vector/v.flexure/v.flexure.py 2015-02-04 01:52:25 UTC (rev 64452)
+++ grass-addons/grass7/vector/v.flexure/v.flexure.py 2015-02-04 02:07:34 UTC (rev 64453)
@@ -116,17 +116,6 @@
# GRASS
import grass.script as grass
from grass.pygrass import vector
-# GFLEX
-try:
- import gflex
-except:
- print ""
- print "MODULE IMPORT ERROR."
- print "In order to run r.flexure or g.flexure, you must download and install"
- print "gFlex. The most recent development version is available from"
- print "https://github.com/awickert/gFlex."
- print "Installation instructions are available on the page."
- grass.fatal("Software dependency must be installed.")
@@ -134,17 +123,17 @@
def get_points_xy(vect_name):
- to find x and y using pygrass, see my (A. Wickert's) StackOverflow answer:
- http://gis.stackexchange.com/questions/28061/how-to-access-vector-coordinates-in-grass-gis-from-python
- points = vector.VectorTopo(vect_name)
- points.open('r')
- coords = []
- for i in range(len(points)):
- coords.append(points.read(i+1).coords())
- coords = np.array(coords)
- return coords[:,0], coords[:,1] # x, y
+ to find x and y using pygrass, see my (A. Wickert's) StackOverflow answer:
+ http://gis.stackexchange.com/questions/28061/how-to-access-vector-coordinates-in-grass-gis-from-python
+ points = vector.VectorTopo(vect_name)
+ points.open('r')
+ coords = []
+ for i in range(len(points)):
+ coords.append(points.read(i+1).coords())
+ coords = np.array(coords)
+ return coords[:,0], coords[:,1] # x, y
@@ -152,117 +141,141 @@
def main():
- Superposition of analytical solutions in gFlex for flexural isostasy in
- GRASS GIS
- # SET-UP #
- # This code is for 2D flexural isostasy
- flex = gflex.F2D()
- # And show that it is coming from GRASS GIS
- flex.grass = True
- # Method
- flex.Method = 'SAS_NG'
- # Parameters that are often changed for the solution
- # x, y, q
- flex.x, flex.y = get_points_xy(options['q0'])
- # xw, yw: gridded output
- if len(grass.parse_command('g.list', type='vect', pattern=options['output'])):
- if not grass.overwrite():
- grass.fatal("Vector map '" + options['output'] + "' already exists. Use '--o' to overwrite.")
- # Just check raster at the same time if it exists
- if len(grass.parse_command('g.list', type='rast', pattern=options['raster_output'])):
- grass.fatal("Raster map '" + options['raster_output'] + "' already exists. Use '--o' to overwrite.")
- grass.run_command('v.mkgrid', map=options['output'], type='point', overwrite=grass.overwrite(), quiet=True)
- grass.run_command('v.db.addcolumn', map=options['output'], columns='w double precision', quiet=True)
- flex.xw, flex.yw = get_points_xy(options['output']) # gridded output coordinates
- vect_db = grass.vector_db_select(options['q0'])
- col_names = np.array(vect_db['columns'])
- q_col = (col_names == options['column'])
- if np.sum(q_col):
- col_values = np.array(vect_db['values'].values()).astype(float)
- flex.q = col_values[:, q_col].squeeze() # Make it 1D for consistency w/ x, y
- else:
- grass.fatal("provided column name, "+options['column']+" does not match\nany column in "+options['q0']+".")
- # Elastic thickness
- flex.Te = float(options['te'])
- if options['te_units'] == 'km':
- flex.Te *= 1000
- elif options['te_units'] == 'm':
- pass
- else:
- grass.fatal("Inappropriate te_units. How? Options should be limited by GRASS.")
- flex.rho_fill = float(options['rho_fill'])
- # Parameters that often stay at their default values
- flex.g = float(options['g'])
- flex.E = float(options['ym']) # Can't just use "E" because reserved for "east", I think
- flex.nu = float(options['nu'])
- flex.rho_m = float(options['rho_m'])
+ Superposition of analytical solutions in gFlex for flexural isostasy in
+ GRASS GIS
+ options, flags = grass.parser()
+ # if just interface description is requested, it will not get to this point
+ # so gflex will not be needed
- # Set verbosity
- if grass.verbosity() >= 2:
- flex.Verbose = True
- if grass.verbosity() >= 3:
- flex.Debug = True
- elif grass.verbosity() == 0:
- flex.Quiet = True
- # Check if lat/lon and let user know if verbosity is True
- if grass.region_env()[6] == '3':
- flex.latlon = True
- flex.PlanetaryRadius = float(grass.parse_command('g.proj', flags='j')['+a'])
- if flex.Verbose:
- print "Latitude/longitude grid."
- print "Based on r_Earth = 6371 km"
- print "Computing distances between load points using great circle paths"
+ # GFLEX
+ # try to import gflex only after we know that
+ # we will actually do the computation
+ try:
+ import gflex
+ except:
+ print ""
+ print "MODULE IMPORT ERROR."
+ print "In order to run r.flexure or g.flexure, you must download and install"
+ print "gFlex. The most recent development version is available from"
+ print "https://github.com/awickert/gFlex."
+ print "Installation instructions are available on the page."
+ grass.fatal("Software dependency must be installed.")
- # SOLVE! #
+ # SET-UP #
+ # This code is for 2D flexural isostasy
+ flex = gflex.F2D()
+ # And show that it is coming from GRASS GIS
+ flex.grass = True
+ # Method
+ flex.Method = 'SAS_NG'
+ # Parameters that are often changed for the solution
+ # x, y, q
+ flex.x, flex.y = get_points_xy(options['q0'])
+ # xw, yw: gridded output
+ if len(grass.parse_command('g.list', type='vect', pattern=options['output'])):
+ if not grass.overwrite():
+ grass.fatal("Vector map '" + options['output'] + "' already exists. Use '--o' to overwrite.")
+ # Just check raster at the same time if it exists
+ if len(grass.parse_command('g.list', type='rast', pattern=options['raster_output'])):
+ grass.fatal("Raster map '" + options['raster_output'] + "' already exists. Use '--o' to overwrite.")
+ grass.run_command('v.mkgrid', map=options['output'], type='point', overwrite=grass.overwrite(), quiet=True)
+ grass.run_command('v.db.addcolumn', map=options['output'], columns='w double precision', quiet=True)
+ flex.xw, flex.yw = get_points_xy(options['output']) # gridded output coordinates
+ vect_db = grass.vector_db_select(options['q0'])
+ col_names = np.array(vect_db['columns'])
+ q_col = (col_names == options['column'])
+ if np.sum(q_col):
+ col_values = np.array(vect_db['values'].values()).astype(float)
+ flex.q = col_values[:, q_col].squeeze() # Make it 1D for consistency w/ x, y
+ else:
+ grass.fatal("provided column name, "+options['column']+" does not match\nany column in "+options['q0']+".")
+ # Elastic thickness
+ flex.Te = float(options['te'])
+ if options['te_units'] == 'km':
+ flex.Te *= 1000
+ elif options['te_units'] == 'm':
+ pass
+ else:
+ grass.fatal("Inappropriate te_units. How? Options should be limited by GRASS.")
+ flex.rho_fill = float(options['rho_fill'])
+ # Parameters that often stay at their default values
+ flex.g = float(options['g'])
+ flex.E = float(options['ym']) # Can't just use "E" because reserved for "east", I think
+ flex.nu = float(options['nu'])
+ flex.rho_m = float(options['rho_m'])
- flex.initialize()
- flex.run()
- flex.finalize()
- # Now to use lower-level GRASS vector commands to work with the database
- # table and update its entries
- # See for help:
- # http://nbviewer.ipython.org/github/zarch/workshop-pygrass/blob/master/02_Vector.ipynb
- w = vector.VectorTopo(options['output'])
- w.open('rw') # Get ready to read and write
- wdb = w.dblinks[0]
- wtable = wdb.table()
- col = int((np.array(wtable.columns.names()) == 'w').nonzero()[0]) # update this column
- for i in range(1, len(w)+1):
- # ignoring 1st column: assuming it will be category (always true here)
- wnewvalues = w[i].attrs.values()[1:col] + tuple([flex.w[i-1]]) + w[i].attrs.values()[col+1:]
- wtable.update(key=i, values=wnewvalues)
- wtable.conn.commit() # Save this
- w.close(build=False) # don't build here b/c it is always verbose
- grass.run_command('v.build', map=options['output'], quiet=True)
- # And raster export
- # "w" vector defined by raster resolution, so can do direct v.to.rast
- # though if this option isn't selected, the user can do a finer-grained
- # interpolation, which shouldn't introduce much error so long as these
- # outputs are spaced at << 1 flexural wavelength.
- if options['raster_output']:
- grass.run_command('v.to.rast', input=options['output'], output=options['raster_output'], use='attr', attribute_column='w', type='point', overwrite=grass.overwrite(), quiet=True)
- # And create a nice colormap!
- grass.run_command('r.colors', map=options['raster_output'], color='differences', quiet=True)
+ # Set verbosity
+ if grass.verbosity() >= 2:
+ flex.Verbose = True
+ if grass.verbosity() >= 3:
+ flex.Debug = True
+ elif grass.verbosity() == 0:
+ flex.Quiet = True
+ # Check if lat/lon and let user know if verbosity is True
+ if grass.region_env()[6] == '3':
+ flex.latlon = True
+ flex.PlanetaryRadius = float(grass.parse_command('g.proj', flags='j')['+a'])
+ if flex.Verbose:
+ print "Latitude/longitude grid."
+ print "Based on r_Earth = 6371 km"
+ print "Computing distances between load points using great circle paths"
+ # SOLVE! #
+ flex.initialize()
+ flex.run()
+ flex.finalize()
+ # Now to use lower-level GRASS vector commands to work with the database
+ # table and update its entries
+ # See for help:
+ # http://nbviewer.ipython.org/github/zarch/workshop-pygrass/blob/master/02_Vector.ipynb
+ w = vector.VectorTopo(options['output'])
+ w.open('rw') # Get ready to read and write
+ wdb = w.dblinks[0]
+ wtable = wdb.table()
+ col = int((np.array(wtable.columns.names()) == 'w').nonzero()[0]) # update this column
+ for i in range(1, len(w)+1):
+ # ignoring 1st column: assuming it will be category (always true here)
+ wnewvalues = w[i].attrs.values()[1:col] + tuple([flex.w[i-1]]) + w[i].attrs.values()[col+1:]
+ wtable.update(key=i, values=wnewvalues)
+ wtable.conn.commit() # Save this
+ w.close(build=False) # don't build here b/c it is always verbose
+ grass.run_command('v.build', map=options['output'], quiet=True)
+ # And raster export
+ # "w" vector defined by raster resolution, so can do direct v.to.rast
+ # though if this option isn't selected, the user can do a finer-grained
+ # interpolation, which shouldn't introduce much error so long as these
+ # outputs are spaced at << 1 flexural wavelength.
+ if options['raster_output']:
+ grass.run_command('v.to.rast', input=options['output'], output=options['raster_output'], use='attr', attribute_column='w', type='point', overwrite=grass.overwrite(), quiet=True)
+ # And create a nice colormap!
+ grass.run_command('r.colors', map=options['raster_output'], color='differences', quiet=True)
+def install_dependencies():
+ print "PLACEHOLDER"
if __name__ == "__main__":
- options, flags = grass.parser()
- main()
+ import sys
+ if len(sys.argv) > 1 and sys.argv[1] == '--install-dependencies':
+ install_dependencies()
+ else:
+ main()
