[GRASS-SVN] r64500 - grass/trunk
Sat Feb 7 13:40:47 PST 2015
Author: neteler
Date: 2015-02-07 13:40:47 -0800 (Sat, 07 Feb 2015)
New Revision: 64500
   grass/trunk/aclocal.m4
   grass/trunk/config.guess
   grass/trunk/config.sub
   grass/trunk/configure
updated config.guess config.sub from upstream repo; fix aclocal.m4 for hurd-i386 and kfreebsd-* architectures (trac #2580)
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4	2015-02-07 19:27:11 UTC (rev 64499)
+++ grass/trunk/aclocal.m4	2015-02-07 21:40:47 UTC (rev 64500)
@@ -486,7 +486,7 @@
     LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
     case $host in
-        *-linux-*)
+        *-linux-* | *-gnu* | *-kfreebsd*-gnu)
 	    SHLIB_CFLAGS="-fPIC"
             SHLIB_LD_FLAGS=""
 	    SHLIB_SUFFIX=".so"
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess	2015-02-07 19:27:11 UTC (rev 64499)
+++ grass/trunk/config.guess	2015-02-07 21:40:47 UTC (rev 64500)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Attempt to guess a canonical system name.
-#   Copyright 1992-2014 Free Software Foundation, Inc.
+#   Copyright 1992-2015 Free Software Foundation, Inc.
-timestamp='2014-03-23'
+timestamp='2015-01-01'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -24,12 +24,12 @@
 # program.  This Exception is an additional permission under section 7
 # of the GNU General Public License, version 3 ("GPLv3").
-# Originally written by Per Bothner.
+# Originally written by Per Bothner; maintained since 2000 by Ben Elliston.
 # You can get the latest version of this script from:
 # http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
-# Please send patches with a ChangeLog entry to config-patches at gnu.org.
+# Please send patches to <config-patches at gnu.org>.
 me=`echo "$0" | sed -e 's,.*/,,'`
@@ -50,7 +50,7 @@
 GNU config.guess ($timestamp)
-Copyright 1992-2014 Free Software Foundation, Inc.
+Copyright 1992-2015 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -579,8 +579,9 @@
 	else
 		IBM_ARCH=powerpc
 	fi
-	if [ -x /usr/bin/oslevel ] ; then
-		IBM_REV=`/usr/bin/oslevel`
+	if [ -x /usr/bin/lslpp ] ; then
+		IBM_REV=`/usr/bin/lslpp -Lqc bos.rte.libc |
+			   awk -F: '{ print $3 }' | sed s/[0-9]*$/0/`
 	else
 		IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
 	fi
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub	2015-02-07 19:27:11 UTC (rev 64499)
+++ grass/trunk/config.sub	2015-02-07 21:40:47 UTC (rev 64500)
@@ -1,8 +1,8 @@
 #! /bin/sh
 # Configuration validation subroutine script.
-timestamp='2014-04-03'
@@ -25,7 +25,7 @@
 # Configuration subroutine to validate and canonicalize a configuration type.
 # Supply the specified configuration type as an argument.
@@ -68,7 +68,7 @@
 version="\
 GNU config.sub ($timestamp)
@@ -260,7 +260,7 @@
 	| c4x | c8051 | clipper \
 	| d10v | d30v | dlx | dsp16xx \
 	| epiphany \
-	| fido | fr30 | frv \
+	| fido | fr30 | frv | ft32 \
 	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
 	| hexagon \
 	| i370 | i860 | i960 | ia64 \
@@ -283,8 +283,10 @@
 	| mips64vr5900 | mips64vr5900el \
 	| mipsisa32 | mipsisa32el \
 	| mipsisa32r2 | mipsisa32r2el \
+	| mipsisa32r6 | mipsisa32r6el \
 	| mipsisa64 | mipsisa64el \
 	| mipsisa64r2 | mipsisa64r2el \
+	| mipsisa64r6 | mipsisa64r6el \
 	| mipsisa64sb1 | mipsisa64sb1el \
 	| mipsisa64sr71k | mipsisa64sr71kel \
 	| mipsr5900 | mipsr5900el \
@@ -300,6 +302,7 @@
 	| pdp10 | pdp11 | pj | pjl \
 	| powerpc | powerpc64 | powerpc64le | powerpcle \
 	| pyramid \
+	| riscv32 | riscv64 \
 	| rl78 | rx \
 	| score \
 	| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
@@ -310,6 +313,7 @@
 	| tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
 	| ubicom32 \
 	| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
+	| visium \
 	| we32k \
 	| x86 | xc16x | xstormy16 | xtensa \
 	| z8k | z80)
@@ -324,6 +328,9 @@
 	c6x)
 		basic_machine=tic6x-unknown
+	leon|leon[3-9])
+		basic_machine=sparc-$basic_machine
 	m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip)
 		basic_machine=$basic_machine-unknown
 		os=-none
@@ -401,8 +408,10 @@
 	| mips64vr5900-* | mips64vr5900el-* \
 	| mipsisa32-* | mipsisa32el-* \
 	| mipsisa32r2-* | mipsisa32r2el-* \
+	| mipsisa32r6-* | mipsisa32r6el-* \
 	| mipsisa64-* | mipsisa64el-* \
 	| mipsisa64r2-* | mipsisa64r2el-* \
+	| mipsisa64r6-* | mipsisa64r6el-* \
 	| mipsisa64sb1-* | mipsisa64sb1el-* \
 	| mipsisa64sr71k-* | mipsisa64sr71kel-* \
 	| mipsr5900-* | mipsr5900el-* \
@@ -432,6 +441,7 @@
 	| ubicom32-* \
 	| v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
 	| vax-* \
+	| visium-* \
 	| we32k-* \
 	| x86-* | x86_64-* | xc16x-* | xps100-* \
 	| xstormy16-* | xtensa*-* \
@@ -769,6 +779,9 @@
 		basic_machine=m68k-isi
 		os=-sysv
+	leon-*|leon[3-9]-*)
+		basic_machine=sparc-`echo $basic_machine | sed 's/-.*//'`
 	m68knommu)
 		basic_machine=m68k-unknown
 		os=-linux
@@ -824,6 +837,10 @@
 		basic_machine=powerpc-unknown
 		os=-morphos
+	moxiebox)
+		basic_machine=moxie-unknown
+		os=-moxiebox
 	msdos)
 		basic_machine=i386-pc
 		os=-msdos
@@ -1369,7 +1386,7 @@
 	      | -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
 	      | -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
 	      | -linux-newlib* | -linux-musl* | -linux-uclibc* \
-	      | -uxpv* | -beos* | -mpeix* | -udk* \
+	      | -uxpv* | -beos* | -mpeix* | -udk* | -moxiebox* \
 	      | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
 	      | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
 	      | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
Modified: grass/trunk/configure
--- grass/trunk/configure	2015-02-07 19:27:11 UTC (rev 64499)
+++ grass/trunk/configure	2015-02-07 21:40:47 UTC (rev 64500)
@@ -1484,7 +1484,7 @@
     case $host in
-        *-linux-*)
             SHLIB_LD_FLAGS=""
 	    SHLIB_SUFFIX=".so"
