[GRASS-SVN] r64501 - grass/branches/releasebranch_7_0
svn_grass at osgeo.org
Sat Feb 7 13:41:57 PST 2015
Author: neteler
Date: 2015-02-07 13:41:57 -0800 (Sat, 07 Feb 2015)
New Revision: 64501
grass/branches/releasebranch_7_0/aclocal.m4
grass/branches/releasebranch_7_0/config.guess
grass/branches/releasebranch_7_0/config.sub
grass/branches/releasebranch_7_0/configure
updated config.guess config.sub from upstream repo; fix aclocal.m4 for hurd-i386 and kfreebsd-* architectures (trac #2580)
Modified: grass/branches/releasebranch_7_0/aclocal.m4
--- grass/branches/releasebranch_7_0/aclocal.m4 2015-02-07 21:40:47 UTC (rev 64500)
+++ grass/branches/releasebranch_7_0/aclocal.m4 2015-02-07 21:41:57 UTC (rev 64501)
@@ -486,7 +486,7 @@
LD_LIBRARY_PATH_VAR="LD_LIBRARY_PATH"
case $host in
- *-linux-*)
+ *-linux-* | *-gnu* | *-kfreebsd*-gnu)
SHLIB_CFLAGS="-fPIC"
SHLIB_LD_FLAGS=""
SHLIB_SUFFIX=".so"
Modified: grass/branches/releasebranch_7_0/config.guess
--- grass/branches/releasebranch_7_0/config.guess 2015-02-07 21:40:47 UTC (rev 64500)
+++ grass/branches/releasebranch_7_0/config.guess 2015-02-07 21:41:57 UTC (rev 64501)
@@ -1,8 +1,8 @@
#! /bin/sh
# Attempt to guess a canonical system name.
-# Copyright 1992-2014 Free Software Foundation, Inc.
+# Copyright 1992-2015 Free Software Foundation, Inc.
-timestamp='2014-03-23'
+timestamp='2015-01-01'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -24,12 +24,12 @@
# program. This Exception is an additional permission under section 7
# of the GNU General Public License, version 3 ("GPLv3").
-# Originally written by Per Bothner.
+# Originally written by Per Bothner; maintained since 2000 by Ben Elliston.
# You can get the latest version of this script from:
# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
-# Please send patches with a ChangeLog entry to config-patches at gnu.org.
+# Please send patches to <config-patches at gnu.org>.
me=`echo "$0" | sed -e 's,.*/,,'`
@@ -50,7 +50,7 @@
GNU config.guess ($timestamp)
-Copyright 1992-2014 Free Software Foundation, Inc.
+Copyright 1992-2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -579,8 +579,9 @@
else
IBM_ARCH=powerpc
fi
- if [ -x /usr/bin/oslevel ] ; then
- IBM_REV=`/usr/bin/oslevel`
+ if [ -x /usr/bin/lslpp ] ; then
+ IBM_REV=`/usr/bin/lslpp -Lqc bos.rte.libc |
+ awk -F: '{ print $3 }' | sed s/[0-9]*$/0/`
else
IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
fi
Modified: grass/branches/releasebranch_7_0/config.sub
--- grass/branches/releasebranch_7_0/config.sub 2015-02-07 21:40:47 UTC (rev 64500)
+++ grass/branches/releasebranch_7_0/config.sub 2015-02-07 21:41:57 UTC (rev 64501)
@@ -1,8 +1,8 @@
#! /bin/sh
# Configuration validation subroutine script.
-timestamp='2014-04-03'
@@ -25,7 +25,7 @@
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
@@ -68,7 +68,7 @@
version="\
GNU config.sub ($timestamp)
@@ -260,7 +260,7 @@
| c4x | c8051 | clipper \
| d10v | d30v | dlx | dsp16xx \
| epiphany \
- | fido | fr30 | frv \
+ | fido | fr30 | frv | ft32 \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
| hexagon \
| i370 | i860 | i960 | ia64 \
@@ -283,8 +283,10 @@
| mips64vr5900 | mips64vr5900el \
| mipsisa32 | mipsisa32el \
| mipsisa32r2 | mipsisa32r2el \
+ | mipsisa32r6 | mipsisa32r6el \
| mipsisa64 | mipsisa64el \
| mipsisa64r2 | mipsisa64r2el \
+ | mipsisa64r6 | mipsisa64r6el \
| mipsisa64sb1 | mipsisa64sb1el \
| mipsisa64sr71k | mipsisa64sr71kel \
| mipsr5900 | mipsr5900el \
@@ -300,6 +302,7 @@
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
+ | riscv32 | riscv64 \
| rl78 | rx \
| score \
| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
@@ -310,6 +313,7 @@
| tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
| ubicom32 \
| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
+ | visium \
| we32k \
| x86 | xc16x | xstormy16 | xtensa \
| z8k | z80)
@@ -324,6 +328,9 @@
c6x)
basic_machine=tic6x-unknown
+ leon|leon[3-9])
+ basic_machine=sparc-$basic_machine
m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip)
basic_machine=$basic_machine-unknown
os=-none
@@ -401,8 +408,10 @@
| mips64vr5900-* | mips64vr5900el-* \
| mipsisa32-* | mipsisa32el-* \
| mipsisa32r2-* | mipsisa32r2el-* \
+ | mipsisa32r6-* | mipsisa32r6el-* \
| mipsisa64-* | mipsisa64el-* \
| mipsisa64r2-* | mipsisa64r2el-* \
+ | mipsisa64r6-* | mipsisa64r6el-* \
| mipsisa64sb1-* | mipsisa64sb1el-* \
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
| mipsr5900-* | mipsr5900el-* \
@@ -432,6 +441,7 @@
| ubicom32-* \
| v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
| vax-* \
+ | visium-* \
| we32k-* \
| x86-* | x86_64-* | xc16x-* | xps100-* \
| xstormy16-* | xtensa*-* \
@@ -769,6 +779,9 @@
basic_machine=m68k-isi
os=-sysv
+ leon-*|leon[3-9]-*)
+ basic_machine=sparc-`echo $basic_machine | sed 's/-.*//'`
m68knommu)
basic_machine=m68k-unknown
os=-linux
@@ -824,6 +837,10 @@
basic_machine=powerpc-unknown
os=-morphos
+ moxiebox)
+ basic_machine=moxie-unknown
+ os=-moxiebox
msdos)
basic_machine=i386-pc
os=-msdos
@@ -1369,7 +1386,7 @@
| -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
| -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
| -linux-newlib* | -linux-musl* | -linux-uclibc* \
- | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -uxpv* | -beos* | -mpeix* | -udk* | -moxiebox* \
| -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
| -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
| -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
Modified: grass/branches/releasebranch_7_0/configure
--- grass/branches/releasebranch_7_0/configure 2015-02-07 21:40:47 UTC (rev 64500)
+++ grass/branches/releasebranch_7_0/configure 2015-02-07 21:41:57 UTC (rev 64501)
@@ -1484,7 +1484,7 @@
case $host in
- *-linux-*)
SHLIB_LD_FLAGS=""
SHLIB_SUFFIX=".so"
