[GRASS-SVN] r64502 - in grass-addons/grass7/raster: r.stream.distance r.stream.order
svn_grass at osgeo.org
Sat Feb 7 14:30:52 PST 2015
Author: mmetz
Date: 2015-02-07 14:30:52 -0800 (Sat, 07 Feb 2015)
New Revision: 64502
grass-addons/grass7/raster/r.stream.distance/distance_calc.c
grass-addons/grass7/raster/r.stream.order/stream_topology.c
r.stream.*: sync ram and seg mode
Modified: grass-addons/grass7/raster/r.stream.distance/distance_calc.c
--- grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2015-02-07 21:41:57 UTC (rev 64501)
+++ grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2015-02-07 22:30:52 UTC (rev 64502)
@@ -36,7 +36,7 @@
POINT n_cell;
double cur_dist = 0;
double tmp_dist = 0;
- double target_elev; /* elevation at stream or outlet */
+ DCELL target_elev; /* elevation at stream or outlet */
double easting, northing;
double cell_easting, cell_northing;
struct Cell_head window;
@@ -139,7 +139,7 @@
POINT n_cell;
- double target_elev; /* eleavation at stream or outlet */
CELL dirs_cell;
@@ -158,6 +158,8 @@
Segment_get(elevation, &target_elev, r, c);
Segment_put(elevation, &zero_cell, r, c);
+ else
+ Rast_set_d_null_value(&target_elev, 1);
while (tail != head) {
easting = window.west + (c + .5) * window.ew_res;
@@ -535,13 +537,10 @@
Segment_get(distance, &distance_cell, r, c);
Segment_get(dirs, &dirs_cell, r, c);
- if (distance_cell == 1) {
- if (distance_cell == 1 && dirs_cell > 0)
- n_inits++;
- else if (dirs_cell > 0)
- Segment_put(distance, &minus_one_cell, r, c);
+ if (distance_cell == 1 && dirs_cell > 0)
+ n_inits++;
+ else if (dirs_cell > 0)
+ Segment_put(distance, &minus_one_cell, r, c);
Modified: grass-addons/grass7/raster/r.stream.order/stream_topology.c
--- grass-addons/grass7/raster/r.stream.order/stream_topology.c 2015-02-07 21:41:57 UTC (rev 64501)
+++ grass-addons/grass7/raster/r.stream.order/stream_topology.c 2015-02-07 22:30:52 UTC (rev 64502)
@@ -372,7 +372,7 @@
next_r = NR(d);
next_c = NC(d);
if (NOT_IN_REGION(d))
- Rast_set_c_null_value(&next_stream, 1);
+ next_stream = 0;
else
Segment_get(streams, &next_stream, next_r, next_c);
