[GRASS-SVN] r64508 - in grass/branches/releasebranch_7_0: gui/wxpython/rlisetup locale/po
svn_grass at osgeo.org
Sun Feb 8 10:49:03 PST 2015
Author: neteler
Date: 2015-02-08 10:49:02 -0800 (Sun, 08 Feb 2015)
New Revision: 64508
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py
grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
fix msg typo
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py 2015-02-08 18:49:02 UTC (rev 64508)
@@ -238,7 +238,7 @@
message=_("You have to select a configuration file"))
return
dlg = wx.TextEntryDialog(parent=self.parent,
- message=_('Set te new name for %s " \
+ message=_('Set the new name for %s " \
"configuration file') % confile,
caption=_('Rename configuration file'))
if dlg.ShowModal() == wx.ID_OK:
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_cs.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -1,6 +1,6 @@
-# translation of grasswxpy_cs.po to
+# translation of grasswxpy_cs.po to Czech
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2008, GRASS Development Team
+# Copyright (C) 2008-2015, GRASS Development Team
# Martin Landa <landa.martin gmail.com>, 2008.
# Jan Trochta <j.trochta seznam.cz>, 2008.
# Miroslav Hořejší <miroslav.horejsi at fsv.cvut.cz>, 2009/01.
@@ -8268,8 +8268,8 @@
#: ../gui/wxpython/wxplot/scatter.py:250
#, python-format
msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
+"Set the new name for %s \" "
+"\"configuration file"
msgstr ""
#: ../gui/wxpython/wxplot/histogram.py:45
@@ -18626,7 +18626,7 @@
#: ../gui/wxpython/rlisetup/frame.py:241
#, python-format
msgid ""
-"Set te new name for %s \" "
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_de.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5432,7 +5432,7 @@
#, python-format
-msgid "Set te new name for %s \" \"configuration file"
+msgid "Set the new name for %s \" \"configuration file"
msgstr ""
#: ../gui/wxpython/rlisetup/frame.py:243
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_el.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5372,7 +5372,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_es.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5619,7 +5619,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_fr.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5340,7 +5340,7 @@
#, python-format
msgstr "Définir le nouveau nom pour le fichier de configuration %s \" \""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_id.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5763,7 +5763,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_it.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5260,7 +5260,7 @@
#, python-format
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ja.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5614,7 +5614,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5218,7 +5218,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_lv.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5361,7 +5361,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ml.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5558,7 +5558,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pl.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5488,7 +5488,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5767,7 +5767,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_pt_br.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5912,7 +5912,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ro.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5600,7 +5600,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ru.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5735,7 +5735,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_th.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5579,7 +5579,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_tr.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5759,7 +5759,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_vi.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5768,7 +5768,7 @@
#, python-format
msgid ""
msgstr ""
Modified: grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-02-08 17:29:38 UTC (rev 64507)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_zh.po 2015-02-08 18:49:02 UTC (rev 64508)
@@ -5691,7 +5691,7 @@
#, python-format
msgstr "为设置文件%s \" \" 设定新名称"
