[GRASS-SVN] r64509 - in grass/trunk: gui/wxpython/rlisetup locale/po
Sun Feb 8 10:49:12 PST 2015
Author: neteler
Date: 2015-02-08 10:49:12 -0800 (Sun, 08 Feb 2015)
New Revision: 64509
   grass/trunk/gui/wxpython/rlisetup/frame.py
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_fr.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_ko.po
   grass/trunk/locale/po/grasswxpy_lv.po
   grass/trunk/locale/po/grasswxpy_ml.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt.po
   grass/trunk/locale/po/grasswxpy_pt_br.po
   grass/trunk/locale/po/grasswxpy_ro.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_th.po
   grass/trunk/locale/po/grasswxpy_tr.po
   grass/trunk/locale/po/grasswxpy_vi.po
   grass/trunk/locale/po/grasswxpy_zh.po
fix msg typo
Modified: grass/trunk/gui/wxpython/rlisetup/frame.py
--- grass/trunk/gui/wxpython/rlisetup/frame.py	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/gui/wxpython/rlisetup/frame.py	2015-02-08 18:49:12 UTC (rev 64509)
@@ -238,7 +238,7 @@
                           message=_("You have to select a configuration file"))
             return
         dlg = wx.TextEntryDialog(parent=self.parent,
-                                 message=_('Set te new name for %s " \
+                                 message=_('Set the new name for %s " \
                                            "configuration file') % confile,
                                  caption=_('Rename configuration file'))
         if dlg.ShowModal() == wx.ID_OK:
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_cs.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -1,6 +1,6 @@
-# translation of grasswxpy_cs.po to
+# translation of grasswxpy_cs.po to Czech
 # This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2008, GRASS Development Team
+# Copyright (C) 2008-2015, GRASS Development Team
 # Martin Landa <landa.martin gmail.com>, 2008.
 # Jan Trochta <j.trochta seznam.cz>, 2008.
 # Miroslav Hořejší <miroslav.horejsi at fsv.cvut.cz>, 2009/01.
@@ -8268,8 +8268,8 @@
 #: ../gui/wxpython/wxplot/scatter.py:250
 #, python-format
 msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
+"Set the new name for %s \"                                            "
+"\"configuration file"
 msgstr ""
 #: ../gui/wxpython/wxplot/histogram.py:45
@@ -18626,7 +18626,7 @@
 #: ../gui/wxpython/rlisetup/frame.py:241
 #, python-format
 msgid ""
-"Set te new name for %s \"                                            "
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_de.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5581,7 +5581,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_el.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5387,7 +5387,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_es.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5634,7 +5634,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_fr.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5355,7 +5355,7 @@
 #, python-format
-msgid "Set te new name for %s \"                                            \"configuration file"
+msgid "Set the new name for %s \"                                            \"configuration file"
 msgstr "Définir le nouveau nom pour le fichier de configuration %s \"                                            \""
 #: ../gui/wxpython/rlisetup/frame.py:243
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_id.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5777,7 +5777,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_it.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5390,7 +5390,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_ja.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5629,7 +5629,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_ko.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5230,7 +5230,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_lv.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5376,7 +5376,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ml.po
--- grass/trunk/locale/po/grasswxpy_ml.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_ml.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5573,7 +5573,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_pl.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5503,7 +5503,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt.po
--- grass/trunk/locale/po/grasswxpy_pt.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_pt.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5782,7 +5782,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5926,7 +5926,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ro.po
--- grass/trunk/locale/po/grasswxpy_ro.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_ro.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5615,7 +5615,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ru.po
--- grass/trunk/locale/po/grasswxpy_ru.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_ru.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5750,7 +5750,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_th.po
--- grass/trunk/locale/po/grasswxpy_th.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_th.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5594,7 +5594,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_tr.po
--- grass/trunk/locale/po/grasswxpy_tr.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_tr.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5774,7 +5774,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_vi.po
--- grass/trunk/locale/po/grasswxpy_vi.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_vi.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5783,7 +5783,7 @@
 #, python-format
 msgid ""
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_zh.po
--- grass/trunk/locale/po/grasswxpy_zh.po	2015-02-08 18:49:02 UTC (rev 64508)
+++ grass/trunk/locale/po/grasswxpy_zh.po	2015-02-08 18:49:12 UTC (rev 64509)
@@ -5705,7 +5705,7 @@
 #, python-format
 msgstr "为设置文件%s \"                                            \" 设定新名称"
