[GRASS-SVN] r64644 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Mon Feb 16 03:17:39 PST 2015
Author: mmetz
Date: 2015-02-16 03:17:39 -0800 (Mon, 16 Feb 2015)
New Revision: 64644
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/write_nat.c
grass/trunk/lib/vector/Vlib/write_ogr.c
grass/trunk/lib/vector/Vlib/write_pg.c
grass/trunk/lib/vector/Vlib/write_sfa.c
Vlib: sync write fns, fix for #2583
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2015-02-16 09:48:14 UTC (rev 64643)
+++ grass/trunk/include/defs/vector.h 2015-02-16 11:17:39 UTC (rev 64644)
@@ -550,11 +550,11 @@
int V1_delete_line_nat(struct Map_info *, off_t);
int V1_delete_line_ogr(struct Map_info *, off_t);
int V1_delete_line_pg(struct Map_info *, off_t);
-int V2_delete_line_nat(struct Map_info *, int);
-int V2_delete_line_sfa(struct Map_info *, int);
-int V2_delete_line_pg(struct Map_info *, int);
+int V2_delete_line_nat(struct Map_info *, off_t);
+int V2_delete_line_sfa(struct Map_info *, off_t);
+int V2_delete_line_pg(struct Map_info *, off_t);
int V1_restore_line_nat(struct Map_info *, off_t);
-int V2_restore_line_nat(struct Map_info *, int);
+int V2_restore_line_nat(struct Map_info *, off_t);
off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
const struct line_cats *);
off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
@@ -573,11 +573,11 @@
const struct line_pnts *, const struct line_cats *);
off_t V1_rewrite_line_pg(struct Map_info *, off_t, int,
-off_t V2_rewrite_line_nat(struct Map_info *, int, int,
+off_t V2_rewrite_line_nat(struct Map_info *, off_t, int,
-off_t V2_rewrite_line_sfa(struct Map_info *, int, int,
+off_t V2_rewrite_line_sfa(struct Map_info *, off_t, int,
-off_t V2_rewrite_line_pg(struct Map_info *, int, int,
+off_t V2_rewrite_line_pg(struct Map_info *, off_t, int,
/* Build topology */
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2015-02-16 09:48:14 UTC (rev 64643)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2015-02-16 11:17:39 UTC (rev 64644)
@@ -145,16 +145,15 @@
compatibility with level 1 functions.
\param Map pointer to Map_info structure
- \param type feature type (GV_POINT, GV_LINE, ...)
\param line feature id to be rewritten
- \param old_offset feature offset
+ \param type feature type (GV_POINT, GV_LINE, ...)
\param points feature geometry
\param cats feature categories
\return new feature id or 0 (build level < GV_BUILD_BASE)
\return -1 on error
-off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type,
+off_t V2_rewrite_line_nat(struct Map_info *Map, off_t line, int type,
const struct line_pnts *points, const struct line_cats *cats)
/* TODO: this is just quick shortcut because we have already V2_delete_nat()
@@ -180,7 +179,7 @@
if (line < 1 || line > plus->n_lines) {
- G_warning(_("Attempt to access feature with invalid id (%d)"), line);
+ G_warning(_("Attempt to access feature with invalid id (%d)"), (int)line);
return -1;
@@ -279,7 +278,7 @@
\return 0 on success
\return -1 on error
-int V2_delete_line_nat(struct Map_info *Map, int line)
+int V2_delete_line_nat(struct Map_info *Map, off_t line)
int type;
struct P_line *Line;
@@ -287,19 +286,19 @@
static struct line_cats *Cats = NULL;
static struct line_pnts *Points = NULL;
- G_debug(3, "V2_delete_line_nat(): line = %d", line);
+ G_debug(3, "V2_delete_line_nat(): line = %d", (int)line);
Line = NULL;
plus = &(Map->plus);
return -1;
Line = Map->plus.Line[line];
if (Line == NULL) {
- G_warning(_("Attempt to access dead feature %d"), line);
+ G_warning(_("Attempt to access dead feature %d"), (int)line);
return -1;
@@ -381,7 +380,7 @@
\return -1 on error
-int V2_restore_line_nat(struct Map_info *Map, int line)
+int V2_restore_line_nat(struct Map_info *Map, off_t line)
int type;
off_t offset;
@@ -392,16 +391,16 @@
- G_debug(3, "V2_restore_line_nat(), line = %d", line);
+ G_debug(3, "V2_restore_line_nat(), line = %d", (int)line);
return -1;
if (Line != NULL) {
- G_warning(_("Attempt to access alive feature %d"), line);
+ G_warning(_("Attempt to access alive feature %d"), (int)line);
return -1;
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2015-02-16 09:48:14 UTC (rev 64643)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2015-02-16 11:17:39 UTC (rev 64644)
@@ -82,7 +82,7 @@
\param points pointer to line_pnts structure (feature geometry)
\param cats pointer to line_cats structure (feature categories)
- \return feature offset (rewriten feature)
+ \return feature offset (rewritten feature)
\return -1 on error
off_t V1_rewrite_line_ogr(struct Map_info *Map,
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2015-02-16 09:48:14 UTC (rev 64643)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2015-02-16 11:17:39 UTC (rev 64644)
@@ -172,7 +172,7 @@
\return -1 on error
off_t V1_rewrite_line_pg(struct Map_info * Map,
@@ -207,19 +207,19 @@
\todo Store original geometry in tmp table for restore
+ \param line feature id
- \param line feature id
\return offset where feature was rewritten
\return -1 on error
-off_t V2_rewrite_line_pg(struct Map_info *Map, int line, int type,
+off_t V2_rewrite_line_pg(struct Map_info *Map, off_t line, int type,
G_debug(3, "V2_rewrite_line_pg(): line=%d type=%d",
- line, type);
+ (int)line, type);
#ifdef HAVE_POSTGRES
const char *schema_name, *table_name, *keycolumn;
char *stmt, *geom_data;
@@ -233,13 +233,13 @@
pg_info = &(Map->fInfo.pg);
if (line < 1 || line > Map->plus.n_lines) {
return -1;
if (Line == NULL) {
return -1;
offset = Line->offset;
@@ -282,7 +282,7 @@
G_free(geom_data);
if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
- G_warning(_("Unable to rewrite feature %d"), line);
+ G_warning(_("Unable to rewrite feature %d"), (int)line);
Vect__execute_pg(pg_info->conn, "ROLLBACK");
return -1;
@@ -369,7 +369,7 @@
\return -1 on error
-int V2_delete_line_pg(struct Map_info *Map, int line)
+int V2_delete_line_pg(struct Map_info *Map, off_t line)
int ret;
@@ -378,7 +378,7 @@
return -1;
@@ -393,13 +393,13 @@
return -1;
if (!Line) {
return -1;
@@ -450,7 +450,7 @@
pg_info->toposchema_name, table_name, keycolumn, (int)Line->offset);
G_warning(_("Unable to delete feature (%s) %d"), keycolumn,
- line);
+ (int)line);
return -1;
Modified: grass/trunk/lib/vector/Vlib/write_sfa.c
--- grass/trunk/lib/vector/Vlib/write_sfa.c 2015-02-16 09:48:14 UTC (rev 64643)
+++ grass/trunk/lib/vector/Vlib/write_sfa.c 2015-02-16 11:17:39 UTC (rev 64644)
@@ -142,21 +142,20 @@
\param type feature type (see V1_write_line_ogr() for supported types)
- \param offset unused (kept for consistency)
\param cats pointer to line_cats structure feature categories
- \return offset where line was rewritten
+ \return feature index in offset array (related to pseudo-topology)
\return -1 on error
-off_t V2_rewrite_line_sfa(struct Map_info *Map, int line, int type,
+off_t V2_rewrite_line_sfa(struct Map_info *Map, off_t line, int type,
G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d",
- line, type);
+ (int)line, type);
return -1;
@@ -189,7 +188,7 @@
\return -1 on error
-int V2_delete_line_sfa(struct Map_info *Map, int line)
+int V2_delete_line_sfa(struct Map_info *Map, off_t line)
#if defined HAVE_OGR || defined HAVE_POSTGRES
int ret, i, type, first;
@@ -198,14 +197,14 @@
- G_debug(3, "V2_delete_line_sfa(): line = %d", line);
+ G_debug(3, "V2_delete_line_sfa(): line = %d", (int)line);
type = first = 0;
Line = NULL;
return -1;
