[GRASS-SVN] r64650 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Feb 16 06:40:29 PST 2015
Author: huhabla
Date: 2015-02-16 06:40:29 -0800 (Mon, 16 Feb 2015)
New Revision: 64650
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
temporal framework: One additional maplist granularity sampling test
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2015-02-16 13:36:51 UTC (rev 64649)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2015-02-16 14:40:29 UTC (rev 64650)
@@ -1185,6 +1185,32 @@
None (12, 14)
None (14, 16)
+ >>> maps = []
+ >>> map1 = tgis.RasterDataset("map1 at PERMANENT")
+ >>> check = map1.set_absolute_time(datetime(2000, 4,1), datetime(2000, 6, 1))
+ >>> maps.append(map1)
+ >>> map2 = tgis.RasterDataset("map2 at PERMANENT")
+ >>> check = map2.set_absolute_time(datetime(2000, 8,1), datetime(2000, 12, 1))
+ >>> maps.append(map2)
+ >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,datetime(2000,1,1),datetime(2001,4,1),"1 month")
+ >>> for map_list in grans:
+ ... print map_list[0].get_id(), map_list[0].get_temporal_extent_as_tuple()
+ None (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2000, 2, 1, 0, 0))
+ None (datetime.datetime(2000, 2, 1, 0, 0), datetime.datetime(2000, 3, 1, 0, 0))
+ None (datetime.datetime(2000, 3, 1, 0, 0), datetime.datetime(2000, 4, 1, 0, 0))
+ map1 at PERMANENT (datetime.datetime(2000, 4, 1, 0, 0), datetime.datetime(2000, 5, 1, 0, 0))
+ map1 at PERMANENT (datetime.datetime(2000, 5, 1, 0, 0), datetime.datetime(2000, 6, 1, 0, 0))
+ None (datetime.datetime(2000, 6, 1, 0, 0), datetime.datetime(2000, 7, 1, 0, 0))
+ None (datetime.datetime(2000, 7, 1, 0, 0), datetime.datetime(2000, 8, 1, 0, 0))
+ map2 at PERMANENT (datetime.datetime(2000, 8, 1, 0, 0), datetime.datetime(2000, 9, 1, 0, 0))
+ map2 at PERMANENT (datetime.datetime(2000, 9, 1, 0, 0), datetime.datetime(2000, 10, 1, 0, 0))
+ map2 at PERMANENT (datetime.datetime(2000, 10, 1, 0, 0), datetime.datetime(2000, 11, 1, 0, 0))
+ map2 at PERMANENT (datetime.datetime(2000, 11, 1, 0, 0), datetime.datetime(2000, 12, 1, 0, 0))
+ None (datetime.datetime(2000, 12, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0))
+ None (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2001, 2, 1, 0, 0))
+ None (datetime.datetime(2001, 2, 1, 0, 0), datetime.datetime(2001, 3, 1, 0, 0))
+ None (datetime.datetime(2001, 3, 1, 0, 0), datetime.datetime(2001, 4, 1, 0, 0))
if not maps:
