[GRASS-SVN] r64651 - in grass/trunk/temporal/t.rast.gapfill: . testsuite
svn_grass at osgeo.org
Mon Feb 16 06:44:36 PST 2015
Author: huhabla
Date: 2015-02-16 06:44:36 -0800 (Mon, 16 Feb 2015)
New Revision: 64651
Added:
grass/trunk/temporal/t.rast.gapfill/testsuite/
grass/trunk/temporal/t.rast.gapfill/testsuite/test_gapfill.py
Removed:
grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
temporal modules: Enabled granularity gap sampling. New python tests are implemented.
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html 2015-02-16 14:40:29 UTC (rev 64650)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.html 2015-02-16 14:44:36 UTC (rev 64651)
@@ -10,14 +10,19 @@
This module uses <a href="r.series.interp.html">r.series.interp</a> to
perform the interpolation for each gap independently. Hence several
interpolation processes can be run in parallel.
+<p>
+Each gap is re-sampled by the space time raster dataset granularity.
+Therefore several time stamped raster map layers will be interpolated
+if the gap is larger than the STRDS granularity.
<h2>Examples</h2>
In this example we will create 3 raster maps and register them in the
temporal database an then in the newly created space time raster dataset.
-There are gaps of one day size between the raster maps. The values of
+There are gaps of one and two day size between the raster maps. The values of
the maps are chosen so that the interpolated values can be estimated.
-We expect two maps with values 2 and 4 after interpolation.
+We expect one map with a value of 2 for the first gap and
+two maps (values 3.666 and 4.333) for the second gap after interpolation.
<div class="code"><pre>
r.mapcalc expr="map1 = 1"
@@ -26,7 +31,7 @@
t.register type=raster maps=map1 start=2012-08-20 end=2012-08-21
t.register type=raster maps=map2 start=2012-08-22 end=2012-08-23
-t.register type=raster maps=map3 start=2012-08-24 end=2012-08-25
+t.register type=raster maps=map3 start=2012-08-25 end=2012-08-26
t.create type=strds temporaltype=absolute \
output=precipitation_daily \
@@ -40,7 +45,7 @@
name|start_time|min|max
map1|2012-08-20 00:00:00|1.0|1.0
map2|2012-08-22 00:00:00|3.0|3.0
-map3|2012-08-24 00:00:00|5.0|5.0
+map3|2012-08-25 00:00:00|5.0|5.0
t.rast.list input=precipitation_daily method=deltagaps
@@ -58,10 +63,12 @@
-gap_6|2012-08-21 00:00:00|2.0|2.0
+gap_6_1|2012-08-21 00:00:00|2.0|2.0
-gap_7|2012-08-23 00:00:00|4.0|4.0
+gap_7_1|2012-08-23 00:00:00|3.666667|3.666667
+gap_7_2|2012-08-24 00:00:00|4.333333|4.333333
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2015-02-16 14:40:29 UTC (rev 64650)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2015-02-16 14:44:36 UTC (rev 64651)
@@ -51,10 +51,15 @@
#% description: Assign the space time raster dataset start and end time to the output map
#%end
+import sys
+import copy
from multiprocessing import Process
import grass.script as grass
import grass.temporal as tgis
+import grass.pygrass.modules as pymod
+from grass.exceptions import FatalError
@@ -81,6 +86,13 @@
num = len(maps)
+ # Configure the r.to.vect module
+ gapfill_module = pymod.Module("r.series.interp",
+ overwrite=grass.overwrite(), quiet=True, run_=False,
+ finish_=False,)
+ process_queue = pymod.ParallelModuleQueue(int(nprocs))
gap_list = []
overwrite_flags = {}
@@ -91,16 +103,7 @@
count += 1
_id = "%s_%d@%s" % (base, num + count, mapset)
_map.set_id(_id)
- overwrite_flags[_id] = False
- if _map.map_exists() or _map.is_in_db(dbif):
- if not grass.overwrite:
- grass.fatal(_("Map with name <%s> already exists. "
- "Please use another base name." % (_id)))
- else:
- if _map.is_in_db(dbif):
- overwrite_flags[_id] = True
gap_list.append(_map)
if len(gap_list) == 0:
@@ -126,42 +129,57 @@
"Using the first found."))
# Interpolate the maps using parallel processing
- proc_list = []
- proc_count = 0
- num = len(gap_list)
+ result_list = []
for _map in gap_list:
predecessor = _map.get_follows()[0]
successor = _map.get_precedes()[0]
- # Build the module inputs strings
- inputs = "%s,%s" % (predecessor.get_map_id(), successor.get_map_id())
- dpos = "0,1"
- output = "%s" % (_map.get_name())
- outpos = "0.5"
+ gran = sp.get_granularity()
+ tmpval, start = predecessor.get_temporal_extent_as_tuple()
+ end, tmpval = successor.get_temporal_extent_as_tuple()
+ # Now resample the gap
+ map_matrix = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity((_map, ),start, end, gran)
+ map_names = []
+ map_positions = []
+ increment = 1.0/ (len(map_matrix) + 1.0)
+ position = increment
+ count = 0
+ for intp_list in map_matrix:
+ new_map = intp_list[0]
+ count += 1
+ new_id = "%s_%i@%s"%(_map.get_name(), count, tgis.get_current_mapset())
+ new_map.set_id(new_id)
+ overwrite_flags[new_id] = False
+ if new_map.map_exists() or new_map.is_in_db(dbif):
+ if not grass.overwrite:
+ grass.fatal(_("Map with name <%s> already exists. "
+ "Please use another base name." % (_id)))
+ else:
+ if new_map.is_in_db(dbif):
+ overwrite_flags[new_id] = True
- # Start several processes in parallel
- proc_list.append(Process(
- target=run_interp, args=(inputs, dpos, output, outpos)))
- proc_list[proc_count].start()
- proc_count += 1
+ map_names.append(new_map.get_name())
+ map_positions.append(position)
+ position += increment
+ result_list.append(new_map)
- if proc_count == nprocs or proc_count == num:
- proc_count = 0
- exitcodes = 0
- for proc in proc_list:
- proc.join()
- exitcodes += proc.exitcode
+ mod = copy.deepcopy(gapfill_module)
+ mod(input=(predecessor.get_map_id(), successor.get_map_id()),
+ datapos=(0, 1), output=map_names, samplingpos=map_positions)
+ sys.stderr.write(mod.get_bash() + "\n")
+ process_queue.put(mod)
- if exitcodes != 0:
- dbif.close()
- grass.fatal(_("Error while interpolation computation"))
+ # Wait for unfinished processes
+ process_queue.wait()
- # Empty process list
- proc_list = []
# Insert new interpolated maps in temporal database and dataset
- for _map in gap_list:
+ for _map in result_list:
id = _map.get_id()
if overwrite_flags[id] == True:
if _map.is_time_absolute():
Deleted: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
--- grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh 2015-02-16 14:40:29 UTC (rev 64650)
+++ grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh 2015-02-16 14:44:36 UTC (rev 64651)
@@ -1,37 +0,0 @@
-#!/bin/sh
-# Fill the gaps in a space time raster dataset
-# We need to set a specific region in the
-# @preprocess step of this test.
-# The region setting should work for UTM and LL test locations
-export GRASS_OVERWRITE=1
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc expr="prec_1 = 100"
-r.mapcalc expr="prec_2 = 300"
-r.mapcalc expr="prec_3 = 500"
-n1=`g.tempfile pid=1 -d`
-cat > "${n1}" << EOF
-prec_1|2001-01-01|2001-02-01
-prec_2|2001-03-01|2001-04-01
-prec_3|2001-05-01|2001-06-01
-EOF
-t.create --v type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
-t.register --v type=raster input=precip_abs file="${n1}"
-# @test
-t.rast.gapfill input=precip_abs base="prec" nprocs=2
-t.info precip_abs
-t.info type=raster input=prec_6
-t.info type=raster input=prec_7
-# @postprocess
-t.unregister --v type=raster maps=prec_1,prec_2,prec_3,prec_6,prec_7
-t.remove --v type=strds input=precip_abs
-g.remove -f type=raster name=prec_1,prec_2,prec_3,prec_6,prec_7
Added: grass/trunk/temporal/t.rast.gapfill/testsuite/test_gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/testsuite/test_gapfill.py (rev 0)
+++ grass/trunk/temporal/t.rast.gapfill/testsuite/test_gapfill.py 2015-02-16 14:44:36 UTC (rev 64651)
@@ -0,0 +1,186 @@
+"""Test t.rast.to.vect
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import subprocess
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestRasterToVector(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
+ def setUp(self):
+ self.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+ self.runModule("r.mapcalc", expression="a_2 = 400", overwrite=True)
+ self.runModule("r.mapcalc", expression="a_3 = 1200", overwrite=True)
+ self.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test",
+ overwrite=True)
+ self.runModule("t.register", flags="i", type="raster", input="A",
+ maps="a_1", start="2001-01-01",
+ increment="1 month", overwrite=True)
+ maps="a_2", start="2001-04-01",
+ increment="1 months", overwrite=True)
+ maps="a_3", start="2001-12-01",
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ def tearDown(self):
+ """Remove generated data"""
+ self.runModule("t.remove", flags="rf", type="strds",
+ inputs="A")
+ def test_simple_2procs(self):
+ self.assertModule("t.rast.gapfill", input="A",
+ basename="test", nprocs=2, verbose=True)
+ #self.assertModule("t.info", type="strds", flags="g", input="A")
+ tinfo_string="""start_time=2001-01-01 00:00:00
+ end_time=2002-01-01 00:00:00
+ granularity=1 month
+ map_time=interval
+ number_of_maps=12
+ min_min=100.0
+ min_max=1200.0
+ max_min=100.0
+ max_max=1200.0"""
+ info = SimpleModule("t.info", flags="g", type="strds", input="A")
+ self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+ text="""name|start_time|end_time|min|max
+a_1|2001-01-01 00:00:00|2001-02-01 00:00:00|100.0|100.0
+test_6_1|2001-02-01 00:00:00|2001-03-01 00:00:00|200.0|200.0
+test_6_2|2001-03-01 00:00:00|2001-04-01 00:00:00|300.0|300.0
+a_2|2001-04-01 00:00:00|2001-05-01 00:00:00|400.0|400.0
+test_7_1|2001-05-01 00:00:00|2001-06-01 00:00:00|500.0|500.0
+test_7_2|2001-06-01 00:00:00|2001-07-01 00:00:00|600.0|600.0
+test_7_3|2001-07-01 00:00:00|2001-08-01 00:00:00|700.0|700.0
+test_7_4|2001-08-01 00:00:00|2001-09-01 00:00:00|800.0|800.0
+test_7_5|2001-09-01 00:00:00|2001-10-01 00:00:00|900.0|900.0
+test_7_6|2001-10-01 00:00:00|2001-11-01 00:00:00|1000.0|1000.0
+test_7_7|2001-11-01 00:00:00|2001-12-01 00:00:00|1100.0|1100.0
+a_3|2001-12-01 00:00:00|2002-01-01 00:00:00|1200.0|1200.0
+ rast_list = SimpleModule("t.rast.list", columns=("name","start_time","end_time","min,max"), input="A")
+ self.assertModule(rast_list)
+ self.assertLooksLike(text, rast_list.outputs.stdout)
+ def test_simple_where(self):
+ self.assertModule("t.rast.gapfill", input="A", where="start_time >= '2001-03-01'",
+ basename="test", nprocs=1, verbose=True)
+ map_time=interval
+ number_of_maps=10
+ min_min=100.0
+ min_max=1200.0
+ max_min=100.0
+ max_max=1200.0"""
+test_4_1|2001-05-01 00:00:00|2001-06-01 00:00:00|500.0|500.0
+test_4_2|2001-06-01 00:00:00|2001-07-01 00:00:00|600.0|600.0
+test_4_3|2001-07-01 00:00:00|2001-08-01 00:00:00|700.0|700.0
+test_4_4|2001-08-01 00:00:00|2001-09-01 00:00:00|800.0|800.0
+test_4_5|2001-09-01 00:00:00|2001-10-01 00:00:00|900.0|900.0
+test_4_6|2001-10-01 00:00:00|2001-11-01 00:00:00|1000.0|1000.0
+test_4_7|2001-11-01 00:00:00|2001-12-01 00:00:00|1100.0|1100.0
+ def test_simple_where_2(self):
+ self.assertModule("t.rast.gapfill", input="A", where="start_time <= '2001-05-01'",
+ map_time=interval
+ number_of_maps=5
+ min_min=100.0
+ min_max=1200.0
+ max_min=100.0
+ max_max=1200.0"""
+test_4_1|2001-02-01 00:00:00|2001-03-01 00:00:00|200.0|200.0
+test_4_2|2001-03-01 00:00:00|2001-04-01 00:00:00|300.0|300.0
+ def test_simple_empty(self):
+ self.assertModule("t.rast.gapfill", input="A", where="start_time >= '2001-10-01'",
+ map_time=interval
+ number_of_maps=3
+ min_min=100.0
+ min_max=1200.0
+ max_min=100.0
+ max_max=1200.0"""
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
