[GRASS-SVN] r64673 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Tue Feb 17 14:46:26 PST 2015
Author: mmetz
Date: 2015-02-17 14:46:26 -0800 (Tue, 17 Feb 2015)
New Revision: 64673
grass/trunk/vector/v.to.db/find.c
grass/trunk/vector/v.to.db/global.h
grass/trunk/vector/v.to.db/lines.c
grass/trunk/vector/v.to.db/main.c
grass/trunk/vector/v.to.db/report.c
v.to.db: faster
Modified: grass/trunk/vector/v.to.db/find.c
--- grass/trunk/vector/v.to.db/find.c 2015-02-17 22:45:00 UTC (rev 64672)
+++ grass/trunk/vector/v.to.db/find.c 2015-02-17 22:46:26 UTC (rev 64673)
@@ -6,7 +6,8 @@
static int bsearch_cat(int cat)
int mid, lo, hi;
+ /* tests */
if (vstat.rcat < 1)
return -1;
@@ -22,6 +23,7 @@
if (Values[lo].cat == cat)
return lo;
+ /* bsearch */
while (lo < hi) {
mid = (lo + hi) / 2;
@@ -39,36 +41,15 @@
return -1;
-/* returns index to array of values, inserts new if necessary */
-int find_cat(int cat, int add)
+/* returns index to array of values, mark as used if requested */
+int find_cat(int cat, int used)
int i;
- if ((i = bsearch_cat(cat)) >= 0)
- return i;
+ i = bsearch_cat(cat);
- if (!add)
- return -1;
+ if (i >= 0 && used)
+ Values[i].used = 1;
- /* Not found -> add new */
- for (i = vstat.rcat; i > 0; i--) {
- if (Values[i - 1].cat < cat)
- break;
- Values[i] = Values[i - 1];
- Values[i].cat = cat;
- Values[i].count1 = 0;
- Values[i].i1 = -1;
- Values[i].i2 = -1;
- Values[i].d1 = 0.0;
- Values[i].d2 = 0.0;
- Values[i].qcat = NULL;
- Values[i].nqcats = 0;
- Values[i].aqcats = 0;
- vstat.rcat++;
return (i);
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h 2015-02-17 22:45:00 UTC (rev 64672)
+++ grass/trunk/vector/v.to.db/global.h 2015-02-17 22:46:26 UTC (rev 64673)
@@ -4,6 +4,7 @@
struct value
int cat; /* category */
+ char used; /* update/report if used else not */
int count1, count2; /* Count of found values; i1: count, coor, sides; i2: sides */
/* for sides set to 2, if more than 1 area category was found, */
/* including no category (cat = -1)! */
Modified: grass/trunk/vector/v.to.db/lines.c
--- grass/trunk/vector/v.to.db/lines.c 2015-02-17 22:45:00 UTC (rev 64672)
+++ grass/trunk/vector/v.to.db/lines.c 2015-02-17 22:46:26 UTC (rev 64673)
@@ -76,6 +76,7 @@
/* Cycle through all lines */
nlines = Vect_get_num_lines(Map);
+ G_percent(0, nlines, 2);
for (line_num = 1; line_num <= nlines; line_num++) {
type = Vect_read_line(Map, Points, Cats, line_num);
if (!(type & options.type))
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2015-02-17 22:45:00 UTC (rev 64672)
+++ grass/trunk/vector/v.to.db/main.c 2015-02-17 22:46:26 UTC (rev 64673)
@@ -25,7 +25,7 @@
int main(int argc, char *argv[])
- int n;
+ int n, i, j, cat, lastcat, type, id, findex;
struct Map_info Map;
struct GModule *module;
struct field_info *Fi;
@@ -69,18 +69,63 @@
/* allocate array for values */
/* (+ 1 is for cat -1 (no category) reported at the end ) */
+ findex = Vect_cidx_get_field_index(&Map, options.field);
if (Vect_cidx_get_field_index(&Map, options.field) > -1) {
- n = Vect_cidx_get_num_unique_cats_by_index(&Map,
- Vect_cidx_get_field_index
- (&Map, options.field));
+ n = Vect_cidx_get_num_unique_cats_by_index(&Map, findex);
else {
n = 0;
G_debug(2, "%d unique cats", n);
Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
- vstat.rcat = 0;
+ /* prepopulate Values */
+ n = Vect_cidx_get_num_cats_by_index(&Map, findex);
+ i = 0;
+ Values[i].cat = -1; /* features without category */
+ Values[i].used = 0;
+ Values[i].count1 = 0;
+ Values[i].i1 = -1;
+ Values[i].i2 = -1;
+ Values[i].d1 = 0.0;
+ Values[i].d2 = 0.0;
+ Values[i].qcat = NULL;
+ Values[i].nqcats = 0;
+ Values[i].aqcats = 0;
+ i = 1;
+ lastcat = -1;
+ /* category index must be sorted,
+ * i.e. topology must have been built with GV_BUILD_ALL */
+ for (j = 0; j < n; j++) {
+ Vect_cidx_get_cat_by_index(&Map, findex, j, &cat, &type, &id);
+ if (lastcat > cat) {
+ Vect_close(&Map);
+ G_fatal_error(_("Category index for vector map <%s> is not sorted"),
+ options.name);
+ if (lastcat != cat) {
+ Values[i].cat = cat;
+ lastcat = cat;
+ i++;
+ vstat.rcat = i;
/* Read values from map */
if (options.option == O_QUERY) {
query(&Map);
@@ -93,6 +138,17 @@
read_lines(&Map);
+ /* prune unused values */
+ n = vstat.rcat;
+ j = 0;
+ for (i = 0; i < n; i++) {
+ if (Values[i].used) {
+ Values[j] = Values[i];
+ j++;
+ vstat.rcat = j;
conv_units();
if (options.print || options.total) {
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c 2015-02-17 22:45:00 UTC (rev 64672)
+++ grass/trunk/vector/v.to.db/report.c 2015-02-17 22:46:26 UTC (rev 64673)
@@ -186,7 +186,7 @@
if (vstat.rcat > 0) {
int rcat_report;
- if(find_cat(-1, 0) != -1)
+ if (find_cat(-1, 0) != -1)
rcat_report = vstat.rcat - 1;
else
rcat_report = vstat.rcat;
