[GRASS-SVN] r64674 - grass/trunk/gui/wxpython/tplot
svn_grass at osgeo.org
Tue Feb 17 15:08:31 PST 2015
Author: wenzeslaus
Date: 2015-02-17 15:08:30 -0800 (Tue, 17 Feb 2015)
New Revision: 64674
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
wxGUI: import only after grass.script.parser() call in g.gui.* modules (tplot forgotten in r64664, #1819)
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-02-17 22:46:26 UTC (rev 64673)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-02-17 23:08:30 UTC (rev 64674)
@@ -45,17 +45,18 @@
#% required: no
#%end
-import wx
+import grass.script as gscript
-import grass.script as grass
-from core.utils import GuiModuleMain
+def main():
+ options, flags = gscript.parser()
-def main():
+ import wx
+ from core.utils import _
try:
from tplot.frame import TplotFrame
except ImportError as e:
- grass.fatal(e.message)
+ gscript.fatal(e.message)
datasets = options['inputs'].strip().split(',')
datasets = [data for data in datasets if data]
@@ -64,7 +65,8 @@
dpi = options['dpi']
dpi = int(dpi) if dpi else None
if dpi and not output:
- grass.warning(_("No output filename set, so DPI option will not used"))
+ gscript.warning(
+ _("No output filename set, so DPI option will not used"))
app = wx.App()
frame = TplotFrame(None)
@@ -77,6 +79,4 @@
if __name__ == '__main__':
- options, flags = grass.parser()
- GuiModuleMain(main)
+ main()
