[GRASS-SVN] r64713 - grass/branches/releasebranch_7_0/vector/v.surf.bspline
svn_grass at osgeo.org
Sat Feb 21 02:01:10 PST 2015
Author: martinl
Date: 2015-02-21 02:01:10 -0800 (Sat, 21 Feb 2015)
New Revision: 64713
grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
v.surf.bspline: more guisections
logical order of parameters
(merge r64675 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c 2015-02-21 08:55:32 UTC (rev 64712)
+++ grass/branches/releasebranch_7_0/vector/v.surf.bspline/main.c 2015-02-21 10:01:10 UTC (rev 64713)
@@ -110,7 +110,15 @@
in_opt->label = _("Name of input vector point map");
dfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+ dfield_opt->guisection = _("Settings");
+ col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
+ col_opt->required = NO;
+ col_opt->label =
+ _("Name of the attribute column with values to be used for approximation");
+ col_opt->description = _("If not given and input is 3D vector map then z-coordinates are used.");
+ col_opt->guisection = _("Settings");
in_ext_opt = G_define_standard_option(G_OPT_V_INPUT);
in_ext_opt->key = "sparse_input";
in_ext_opt->required = NO;
@@ -119,17 +127,19 @@
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
out_opt->required = NO;
+ out_opt->guisection = _("Outputs");
out_map_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_map_opt->key = "raster_output";
out_map_opt->required = NO;
+ out_map_opt->guisection = _("Outputs");
mask_opt = G_define_standard_option(G_OPT_R_INPUT);
mask_opt->key = "mask";
mask_opt->label = _("Raster map to use for masking (applies to raster output only)");
mask_opt->description = _("Only cells that are not NULL and not zero are interpolated");
mask_opt->required = NO;
stepE_opt = G_define_option();
stepE_opt->key = "ew_step";
stepE_opt->type = TYPE_DOUBLE;
@@ -168,13 +178,6 @@
lambda_f_opt->answer = "0.01";
lambda_f_opt->guisection = _("Settings");
- col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- col_opt->required = NO;
- col_opt->label =
- _("Name of the attribute column with values to be used for approximation");
- col_opt->description = _("If not given and input is 3D vector map then z-coordinates are used.");
- col_opt->guisection = _("Settings");
solver = N_define_standard_option(N_OPT_SOLVER_SYMM);
solver->options = "cholesky,cg";
solver->answer = "cholesky";
