[GRASS-SVN] r64714 - grass/branches/releasebranch_7_0/general/g.gui
svn_grass at osgeo.org
Sat Feb 21 06:17:02 PST 2015
Author: martinl
Date: 2015-02-21 06:17:02 -0800 (Sat, 21 Feb 2015)
New Revision: 64714
grass/branches/releasebranch_7_0/general/g.gui/main.c
g.gui: improve logic
(merge r64689 from trunk)
Modified: grass/branches/releasebranch_7_0/general/g.gui/main.c
--- grass/branches/releasebranch_7_0/general/g.gui/main.c 2015-02-21 10:01:10 UTC (rev 64713)
+++ grass/branches/releasebranch_7_0/general/g.gui/main.c 2015-02-21 14:17:02 UTC (rev 64714)
@@ -8,7 +8,7 @@
* PURPOSE: Start GRASS GUI from command line.
- * COPYRIGHT: (C) 2008-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008-2015 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -25,7 +25,7 @@
int main(int argc, char *argv[])
struct Option *type, *rc_file;
- struct Flag *update, *nolaunch;
+ struct Flag *update_ui, *nolaunch;
struct GModule *module;
const char *gui_type_env;
char progname[GPATH_MAX];
@@ -40,20 +40,21 @@
module->label =
_("Launches a GRASS graphical user interface (GUI) session.");
- module->description = _("And updates default user interface settings.");
+ module->description = _("Optionally updates default user interface settings.");
type = G_define_option();
type->key = "ui";
type->type = TYPE_STRING;
- type->label = _("User interface");
- type->description = _("Default value: GRASS_GUI if defined otherwise wxpython");
+ type->description = _("User interface");
desc = NULL;
G_asprintf(&desc,
- "wxpython;%s;text;%s",
- _("wxPython based GUI (wxGUI)"),
- _("command line interface only"));
+ "wxpython;%s;text;%s;gtext;%s;",
+ _("wxPython based GUI (wxGUI)"),
+ _("command line interface only"),
+ _("command line interface with GUI startup screen"));
type->descriptions = desc;
- type->options = "wxpython,text";
+ type->options = "wxpython,text,gtext";
+ type->answer = "wxpython";
type->guisection = _("Type");
rc_file = G_define_standard_option(G_OPT_F_INPUT);
@@ -62,10 +63,10 @@
rc_file->key_desc = "name.gxw";
rc_file->description = _("Name of workspace file to load on start-up (valid only for wxGUI)");
- update = G_define_flag();
- update->key = 'd';
- update->description = _("Update default user interface settings");
- update->guisection = _("Default");
+ update_ui = G_define_flag();
+ update_ui->key = 'd';
+ update_ui->description = _("Update default user interface settings");
+ update_ui->guisection = _("Default");
nolaunch = G_define_flag();
nolaunch->key = 'n';
@@ -76,58 +77,35 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (type->answer && strcmp(type->answer, "text") == 0 &&
- !nolaunch->answer)
- nolaunch->answer = TRUE;
- if (nolaunch->answer && !update->answer)
- update->answer = TRUE;
gui_type_env = G_getenv_nofatal("GUI");
- if (!type->answer) {
- if (gui_type_env && strcmp(gui_type_env, "text")) {
- type->answer = G_store(gui_type_env);
- else {
- type->answer = "wxpython";
+ G_debug(1, "GUI: %s", gui_type_env ? gui_type_env : "unset");
+ if (update_ui->answer) {
+ if (!gui_type_env || strcmp(type->answer, gui_type_env)) {
+ G_setenv("GUI", type->answer);
+ G_message(_("<%s> is now the default GUI"), type->answer);
- if (((gui_type_env && update->answer) &&
- strcmp(gui_type_env, type->answer) != 0) || !gui_type_env) {
- G_setenv("GUI", type->answer);
- G_message(_("<%s> is now the default GUI"), type->answer);
+ if(strcmp(type->answer, "wxpython") != 0 || nolaunch->answer) {
+ if (!update_ui->answer)
+ G_warning(_("Nothing to do. For setting up <%s> as default UI use -%c flag."),
+ type->answer, update_ui->key);
+ exit(EXIT_SUCCESS);
- else {
- if(update->answer)
- if(gui_type_env) {
- G_debug(1, "No change: old gui_type_env=[%s], new type->ans=[%s]",
- gui_type_env, type->answer);
- if(nolaunch->answer)
- exit(EXIT_SUCCESS);
G_message(_("Launching <%s> GUI in the background, please wait..."), type->answer);
- if (strcmp(type->answer, "wxpython") == 0) {
- sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
- if (rc_file->answer) {
- G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
- "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
- else {
- SF_BACKGROUND, NULL);
+ sprintf(progname, "%s/gui/wxpython/wxgui.py", G_gisbase());
+ if (rc_file->answer) {
+ G_spawn_ex(getenv("GRASS_PYTHON"), getenv("GRASS_PYTHON"), progname,
+ "--workspace", rc_file->answer, SF_BACKGROUND, NULL);
+ else {
+ SF_BACKGROUND, NULL);
/* stop the impatient from starting it again
- before the splash screen comes up */
+ before the splash screen comes up */
G_sleep(3);
exit(EXIT_SUCCESS);
