[GRASS-SVN] r64741 - grass-addons/grass7/raster/r.viewshed.cva
Wed Feb 25 10:22:41 PST 2015
Author: isaacullah
Date: 2015-02-25 10:22:41 -0800 (Wed, 25 Feb 2015)
New Revision: 64741
Added:
   grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
Removed:
   grass-addons/grass7/raster/r.viewshed.cva/description.html
Properly renaming html man page
Deleted: grass-addons/grass7/raster/r.viewshed.cva/description.html
--- grass-addons/grass7/raster/r.viewshed.cva/description.html	2015-02-25 18:21:42 UTC (rev 64740)
+++ grass-addons/grass7/raster/r.viewshed.cva/description.html	2015-02-25 18:22:41 UTC (rev 64741)
@@ -1,76 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.viewshed.cva</em> is a module that allows for the
-construction of "Cumulative Viewshed", or "visualscape" maps from a
-series of input points stored in a vector points map. The routine is
-a python wrapper script that iterative loops through each input
-point, calculating a viewshed map, and then creates an output map
-that is coded by the number of input locations that can "see" each
-cell. <em>r.viewshed.cva</em> uses the GRASS module <em>r.viewshed</em>
-for the viewshed analysis. <it>r.viewshed</it> is very fast,
-thus allowing for a cumulative viewshed analysis to run in a
-reasonable amount of time. The final cumulative viewshed map is
-computed using the "count" method of <it>r.series</it>, rather than
-with mapcalc, as it better handles the null values in the individual
-constituent viewshed maps (and allows for interim viewshed maps to
-be coded in any way)
-<h3>Options and flags:</h3>
-<it>r.viewshed.cva</it> requires an input elevation map and an input
-vector points map.
-There is currently only one native flag for <it>r.viewshed.cva</it>
-(-k), which allows you to keep the interim viewshed maps made for
-each input point. All other flags and options are inherited from
-r.viewshed (see the<it> r.viewshed</it> help page for more
-information on these).
-<h2>NOTES</h2>
-The input vector points map can be manually digitized (with <it>
-v.digit</it>) over topographic or cultural features, or can be
-created as a series of random points (with <it>r.random</it> or <it>
-v.random</it>). Note that using the flag -k allows you to keep any
-interim viewshed maps created during the analysis, and these resultant
-viewshed maps will be named according to the cat number of the original
-input points. This is also useful for simple creating a large number
-of individual viewsheds from points in a vector file.
-<p>
-<h2>EXAMPLES</h2>
-Undertake a cumulative viewshed analysis from a digitized vector points map of prominent peaks in a region:<br>
-<div class="code"><pre>
-g.region rast=elevation_10m_dem at PERMANENT -p
-[use v.digit to digitize points]
-r.viewshed.cva.py elev=elevation10m_demPERMANENT output=peaks_CVA_map \
-  vect=prominent_peaks_points at PERMANENT x_column=x y_column=y \
-  name_column=cat obs_elev=0.0 tgt_elev=1.75 max_dist=-1 mem=1500
-</pre></div>
-<br>Undertake a cumulative viewshed analysis from a 10% sample of landscape locations in a region:<br>
-r.random input=elevation10m_demPERMANENT n=10% vector_output=rand_points_10p
-  vect=rand_points_10p at PERMANENT x_column=x y_column=y \
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.viewshed.html">r.viewshed</a>
-</em>
-<h2>AUTHOR</h2>
-Isaac Ullah
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html (from rev 64740, grass-addons/grass7/raster/r.viewshed.cva/description.html)
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html	2015-02-25 18:22:41 UTC (rev 64741)
@@ -0,0 +1,76 @@
+<h2>DESCRIPTION</h2>
+<em>r.viewshed.cva</em> is a module that allows for the
+construction of "Cumulative Viewshed", or "visualscape" maps from a
+series of input points stored in a vector points map. The routine is
+a python wrapper script that iterative loops through each input
+point, calculating a viewshed map, and then creates an output map
+that is coded by the number of input locations that can "see" each
+cell. <em>r.viewshed.cva</em> uses the GRASS module <em>r.viewshed</em>
+for the viewshed analysis. <it>r.viewshed</it> is very fast,
+thus allowing for a cumulative viewshed analysis to run in a
+reasonable amount of time. The final cumulative viewshed map is
+computed using the "count" method of <it>r.series</it>, rather than
+with mapcalc, as it better handles the null values in the individual
+constituent viewshed maps (and allows for interim viewshed maps to
+be coded in any way)
+<h3>Options and flags:</h3>
+<it>r.viewshed.cva</it> requires an input elevation map and an input
+vector points map.
+There is currently only one native flag for <it>r.viewshed.cva</it>
+(-k), which allows you to keep the interim viewshed maps made for
+each input point. All other flags and options are inherited from
+r.viewshed (see the<it> r.viewshed</it> help page for more
+information on these).
+<h2>NOTES</h2>
+The input vector points map can be manually digitized (with <it>
+v.digit</it>) over topographic or cultural features, or can be
+created as a series of random points (with <it>r.random</it> or <it>
+v.random</it>). Note that using the flag -k allows you to keep any
+interim viewshed maps created during the analysis, and these resultant
+viewshed maps will be named according to the cat number of the original
+input points. This is also useful for simple creating a large number
+of individual viewsheds from points in a vector file.
+<p>
+<h2>EXAMPLES</h2>
+Undertake a cumulative viewshed analysis from a digitized vector points map of prominent peaks in a region:<br>
+<div class="code"><pre>
+g.region rast=elevation_10m_dem at PERMANENT -p
+[use v.digit to digitize points]
+r.viewshed.cva.py elev=elevation10m_demPERMANENT output=peaks_CVA_map \
+  vect=prominent_peaks_points at PERMANENT x_column=x y_column=y \
+  name_column=cat obs_elev=0.0 tgt_elev=1.75 max_dist=-1 mem=1500
+</pre></div>
+<br>Undertake a cumulative viewshed analysis from a 10% sample of landscape locations in a region:<br>
+r.random input=elevation10m_demPERMANENT n=10% vector_output=rand_points_10p
+  vect=rand_points_10p at PERMANENT x_column=x y_column=y \
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.viewshed.html">r.viewshed</a>
+</em>
+<h2>AUTHOR</h2>
+Isaac Ullah
+<p>
+<i>Last changed: $Date$</i>
