[GRASS-SVN] r64742 - grass-addons/grass7/raster/r.viewshed.cva
Wed Feb 25 10:24:42 PST 2015
Author: isaacullah
Date: 2015-02-25 10:24:42 -0800 (Wed, 25 Feb 2015)
New Revision: 64742
Added:
   grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva
Removed:
   grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
Removing ".py" extention from the script, which causes it to fail to load.
Copied: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva (from rev 64740, grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py)
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva	                        (rev 0)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva	2015-02-25 18:24:42 UTC (rev 64742)
@@ -0,0 +1,183 @@
+#!/usr/bin/env python
+# MODULE:       	r.viewshed.cva.py
+# AUTHOR(S):	Isaac Ullah
+# PURPOSE:	 Undertakes a "cumulative viewshed analysis" using a vector points map as input "viewing" locations, using r.viewshed to calculate the individual viewsheds.
+# COPYRIGHT:	(C) 2015 by Isaac Ullah
+# REFERENCES:    r.viewshed
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Undertakes a "cumulative viewshed analysis" using a vector points map as input "viewing" locations, using r.viewshed to calculate the individual viewsheds.
+#%End
+#%option
+#% key: elev
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Input elevation map (DEM)
+#% required : yes
+#%END
+#%option
+#% key: output
+#% type: string
+#% description: Output CVA raster
+#% required : yes
+#%END
+#%option
+#% key: vect
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: Name of input vector points map containg the set of sites for this analysis.
+#% required : yes
+#%END
+#%option
+#% key: observer_elevation
+#% type: string
+#% description: Height of observation points off the ground
+#%answer: 0.0
+#% required : yes
+#%END
+#%option
+#% key: target_elevation
+#% type: string
+#% description: Height of target areas off the ground
+#%answer: 1.75
+#% required : yes
+#%END
+#%option
+#% key: max_distance
+#% type: string
+#% description: Maximum viewing distance (-1 = infinity)
+#%answer: -1
+#% required : yes
+#%END
+#%option
+#% key: memory
+#% type: string
+#% description: Amount of memory to use (in MB)
+#%answer: 1500
+#% required : yes
+#%END
+#%option
+#% key: refraction_coeff
+#% type: string
+#% description: Refraction coefficient (with flag -r)
+#%answer: 0.14286
+#% required : no
+#%END
+#%flag
+#% key: k
+#% description: -k Keep all interim viewshed maps produced by the routine (maps will be named "vshed_'name'", where 'name' is the value in "name_column" for each input point)
+#%END
+#%flag
+#% key: c
+#% description: -c Consider the curvature of the earth (current ellipsoid)
+#%END
+#%flag
+#% key: r
+#% description: -r Consider the effect of atmospheric refraction
+#%END
+#%flag
+#% key: b
+#% description: -b   Output format is {0 (invisible) 1 (visible)}
+#%END
+#%flag
+#% key: e
+#% description:  -e   Output format is invisible = NULL, else current elev - viewpoint_elev
+#%END
+import sys
+import os
+grass_install_tree = os.getenv('GISBASE')
+sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
+import grass.script as grass
+#main block of code starts here
+def main():
+    #bring in input variables
+    elev = options["elev"]
+    vect = options["vect"]
+    observer_elevation =options["observer_elevation"]
+    target_elevation = options['target_elevation']
+    max_distance = options["max_distance"]
+    memory = options["memory"]
+    refraction_coeff = options["refraction_coeff"]
+    out = options["output"]
+    #assemble flag string
+    if flags['r'] is True:
+        f1 = "r"
+    else:
+        f1 = ""
+    if flags['c'] is True:
+        f2 = "c"
+    else:
+        f2 = ""
+    if flags['b'] is True:
+        f3 = "b"
+    else:
+        f3 = ""
+    if flags['e'] is True:
+        f4 = "e"
+    else:
+        f4 = ""
+    flagstring = f1 + f2 + f3 +f4
+    #make a tempfile, and write out the coords from the vector map.
+    tmp1 = grass.tempfile()
+    grass.run_command("v.out.ascii", flags = 'r', input = vect, type = "point", output = tmp1, format = "point", separator = ",")
+    # note that the "r" flag will constrain to points in the current geographic region.
+    grass.message("Note that the routine is constrained to points in the current geographic region.")
+    #read the temp file back in, and parse it up.
+    f = open(tmp1, 'r')
+    masterlist = []
+    for line in f.readlines():
+        masterlist.append(line.strip('\n').split(','))
+    f.close() #close the file
+    #now, loop through the master list and run r.viewshed for each of the sites, and append the viewsheds to a list (so we can work with them later)
+    vshed_list = []
+    for site in masterlist:
+        grass.message('Calculating viewshed for location %s,%s (point name = %s)\n' % (site[0], site[1], site[2]))
+        tempry = "vshed_%s" % site[2]
+        vshed_list.append(tempry)
+        grass.run_command("r.viewshed", quiet = "True", overwrite = grass.overwrite(), flags = flagstring,  input = elev, output = tempry, coordinates = site[0] + "," + site[1], observer_elevation = observer_elevation, target_elevation = target_elevation, max_distance = max_distance, memory = memory,  refraction_coeff = refraction_coeff)
+    #now make a mapcalc statement to add all the viewsheds together to make the outout cumulative viewsheds map
+    grass.message("Calculating \"Cumulative Viewshed\" map")
+    #grass.mapcalc("${output}=${command_string}", quiet = "True", output = out, command_string = ("+").join(vshed_list))
+    grass.run_command("r.series", quiet = "True", overwrite = grass.overwrite(), input = (",").join(vshed_list), output = out, method = "count")
+    #Clean up temporary maps, if requested
+    if os.getenv('GIS_FLAG_k') == '1':
+        grass.message("Temporary viewshed maps will not removed")
+    else:
+        grass.message("Removing temporary viewshed maps")
+        grass.run_command("g.remove",  quiet = "True", flags = 'f', type = 'raster', name = (",").join(vshed_list))
+    return
+# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
+    exit(0)
Deleted: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py	2015-02-25 18:22:41 UTC (rev 64741)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py	2015-02-25 18:24:42 UTC (rev 64742)
@@ -1,183 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       	r.viewshed.cva.py
-# AUTHOR(S):	Isaac Ullah
-# PURPOSE:	 Undertakes a "cumulative viewshed analysis" using a vector points map as input "viewing" locations, using r.viewshed to calculate the individual viewsheds.
-# COPYRIGHT:	(C) 2015 by Isaac Ullah
-# REFERENCES:    r.viewshed
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%Module
-#%  description: Undertakes a "cumulative viewshed analysis" using a vector points map as input "viewing" locations, using r.viewshed to calculate the individual viewsheds.
-#%End
-#%option
-#% key: elev
-#% type: string
-#% gisprompt: new,cell,raster
-#% description: Input elevation map (DEM)
-#% required : yes
-#%END
-#%option
-#% key: output
-#% type: string
-#% description: Output CVA raster
-#% required : yes
-#%END
-#%option
-#% key: vect
-#% type: string
-#% gisprompt: new,vector,vector
-#% description: Name of input vector points map containg the set of sites for this analysis.
-#% required : yes
-#%END
-#%option
-#% key: observer_elevation
-#% type: string
-#% description: Height of observation points off the ground
-#%answer: 0.0
-#% required : yes
-#%END
-#%option
-#% key: target_elevation
-#% type: string
-#% description: Height of target areas off the ground
-#%answer: 1.75
-#% required : yes
-#%END
-#%option
-#% key: max_distance
-#% type: string
-#% description: Maximum viewing distance (-1 = infinity)
-#%answer: -1
-#% required : yes
-#%END
-#%option
-#% key: memory
-#% type: string
-#% description: Amount of memory to use (in MB)
-#%answer: 1500
-#% required : yes
-#%END
-#%option
-#% key: refraction_coeff
-#% type: string
-#% description: Refraction coefficient (with flag -r)
-#%answer: 0.14286
-#% required : no
-#%END
-#%flag
-#% key: k
-#% description: -k Keep all interim viewshed maps produced by the routine (maps will be named "vshed_'name'", where 'name' is the value in "name_column" for each input point)
-#%END
-#%flag
-#% key: c
-#% description: -c Consider the curvature of the earth (current ellipsoid)
-#%END
-#%flag
-#% key: r
-#% description: -r Consider the effect of atmospheric refraction
-#%END
-#%flag
-#% key: b
-#% description: -b   Output format is {0 (invisible) 1 (visible)}
-#%END
-#%flag
-#% key: e
-#% description:  -e   Output format is invisible = NULL, else current elev - viewpoint_elev
-#%END
-import sys
-import os
-grass_install_tree = os.getenv('GISBASE')
-sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
-import grass.script as grass
-#main block of code starts here
-def main():
-    #bring in input variables
-    elev = options["elev"]
-    vect = options["vect"]
-    observer_elevation =options["observer_elevation"]
-    target_elevation = options['target_elevation']
-    max_distance = options["max_distance"]
-    memory = options["memory"]
-    refraction_coeff = options["refraction_coeff"]
-    out = options["output"]
-    #assemble flag string
-    if flags['r'] is True:
-        f1 = "r"
-    else:
-        f1 = ""
-    if flags['c'] is True:
-        f2 = "c"
-    else:
-        f2 = ""
-    if flags['b'] is True:
-        f3 = "b"
-    else:
-        f3 = ""
-    if flags['e'] is True:
-        f4 = "e"
-    else:
-        f4 = ""
-    flagstring = f1 + f2 + f3 +f4
-    #make a tempfile, and write out the coords from the vector map.
-    tmp1 = grass.tempfile()
-    grass.run_command("v.out.ascii", flags = 'r', input = vect, type = "point", output = tmp1, format = "point", separator = ",")
-    # note that the "r" flag will constrain to points in the current geographic region.
-    grass.message("Note that the routine is constrained to points in the current geographic region.")
-    #read the temp file back in, and parse it up.
-    f = open(tmp1, 'r')
-    masterlist = []
-    for line in f.readlines():
-        masterlist.append(line.strip('\n').split(','))
-    f.close() #close the file
-    #now, loop through the master list and run r.viewshed for each of the sites, and append the viewsheds to a list (so we can work with them later)
-    vshed_list = []
-    for site in masterlist:
-        grass.message('Calculating viewshed for location %s,%s (point name = %s)\n' % (site[0], site[1], site[2]))
-        tempry = "vshed_%s" % site[2]
-        vshed_list.append(tempry)
-        grass.run_command("r.viewshed", quiet = "True", overwrite = grass.overwrite(), flags = flagstring,  input = elev, output = tempry, coordinates = site[0] + "," + site[1], observer_elevation = observer_elevation, target_elevation = target_elevation, max_distance = max_distance, memory = memory,  refraction_coeff = refraction_coeff)
-    #now make a mapcalc statement to add all the viewsheds together to make the outout cumulative viewsheds map
-    grass.message("Calculating \"Cumulative Viewshed\" map")
-    #grass.mapcalc("${output}=${command_string}", quiet = "True", output = out, command_string = ("+").join(vshed_list))
-    grass.run_command("r.series", quiet = "True", overwrite = grass.overwrite(), input = (",").join(vshed_list), output = out, method = "count")
-    #Clean up temporary maps, if requested
-    if os.getenv('GIS_FLAG_k') == '1':
-        grass.message("Temporary viewshed maps will not removed")
-    else:
-        grass.message("Removing temporary viewshed maps")
-        grass.run_command("g.remove",  quiet = "True", flags = 'f', type = 'raster', name = (",").join(vshed_list))
-    return
-# here is where the code in "main" actually gets executed. This way of programming is neccessary for the way g.parser needs to run.
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
-    exit(0)
