[GRASS-SVN] r64750 - grass-addons/grass7/raster/r.catchment
Wed Feb 25 13:04:15 PST 2015
Author: isaacullah
Date: 2015-02-25 13:04:14 -0800 (Wed, 25 Feb 2015)
New Revision: 64750
   grass-addons/grass7/raster/r.catchment/r.catchment.py
Updated g.parser header code to the new standards. Fixed conflict with Python reserved variable names.
Modified: grass-addons/grass7/raster/r.catchment/r.catchment.py
--- grass-addons/grass7/raster/r.catchment/r.catchment.py	2015-02-25 20:11:57 UTC (rev 64749)
+++ grass-addons/grass7/raster/r.catchment/r.catchment.py	2015-02-25 21:04:14 UTC (rev 64750)
@@ -20,31 +20,23 @@
 #%END
-#%option
+#%option G_OPT_R_ELEV
 #% key: elevation
-#% type: string
-#% gisprompt: new,cell,raster
 #% description: Input elevation map (DEM)
 #% required : yes
 #%END
-#%option
+#%option G_OPT_R_INPUT
 #% key: in_cost
-#% type: string
 #% description: Input cost map (This will override the input elevation map, if none specified, one will be created from input elevation map with r.walk)
 #% required : no
 #%END
-#%option
+#%option G_OPT_V_INPUT
 #% key: start_points
-#% type: string
-#% gisprompt: new,vector,vector
 #% description: Name of input vector site points map
 #% required : yes
 #%END
-#%option
 #% key: friction
-#% type: string
 #% description: Optional map of friction costs. If no map selected, default friction=0 making output reflect time costs only
 #% answer:
 #% required : no
@@ -91,10 +83,8 @@
 #% answer: -0.2125
 #% required : no
 #%END
-#%option
 #% key: buffer
-#% type: string
 #% description: Output buffer map
 #% required : yes
 #%END
@@ -137,7 +127,7 @@
 import os
 import subprocess
 import tempfile
-import random
+#import random
 grass_install_tree = os.getenv('GISBASE')
 sys.path.append(grass_install_tree + os.sep + 'etc' + os.sep + 'python')
 import grass.script as grass
@@ -158,7 +148,7 @@
     #setting up variables for use later on
     elevation = options["elevation"]
     start_points = options["start_points"]
-    lmbda = options["lambda"]
+    lambda_ = options["lambda"]
     slope_factor = options["slope_factor"]
     a = options["a"]
     b = options["b"]
@@ -166,12 +156,14 @@
     d = options["d"]
     sigma = options["sigma"]
     area = float(options["area"])
-    buffer = options["buffer"]
+    buff = options["buffer"]
     mapval = options["map_val"]
     w_coefs = a + ',' +  b + ',' + c + ',' + d
     if "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']] and bool(options["sigma"]) is True:
         grass.message('There is already a MASK in place, and you have also selected to mask slope values above %s.\n The high slope areas (slope mask) will be temporarily added to current MASKED areas for the calcualtion of the catchment geometry.\n The original MASK will be restored when the module finishes' % sigma)
         ismask = 2
+        tempmask = "temporary.mask.%s" % pid
+        grass.run_command('g.rename', quiet = True, overwrite = grass.overwrite(), raster = "MASK,%s" % tempmask)
     elif "MASK" in grass.list_grouped('rast')[grass.gisenv()['MAPSET']]:
         grass.message('There is a MASK in place. The areas MASKed out will be ignored while calculating catchment geometry.')
         ismask = 1
@@ -197,9 +189,9 @@
         if flags["k"] is True:
             grass.message('Using Knight\'s move\n')
             #NOTE! because "lambda" is an internal python variable, it is impossible to enter the value for key "lambda" in r.walk. It ends up with a python error.
-            grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), flags = 'k', elevation = elevation, friction = friction, output = cost, start_points = start_points, walk_coeff = w_coefs, slope_factor = slope_factor)
+            grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), flags = 'k', elevation = elevation, friction = friction, output = cost, start_points = start_points, walk_coeff = w_coefs, memory = '100', slope_factor = slope_factor, lambda_ = lambda_)
         else:
-            grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), elevation = elevation, friction = friction, output = cost, start_points = start_points, percent_memory = '100', walk_coeff = w_coefs, slope_factor = slope_factor)
+            grass.run_command('r.walk', quiet = True, overwrite = grass.overwrite(), elevation = elevation, friction = friction, output = cost, start_points = start_points, memory = '100', walk_coeff = w_coefs, slope_factor = slope_factor, lambda_ = lambda_)
         if bool(options["friction"]) is False:
             grass.run_command('g.remove', quiet = True, flags = 'f', type = 'raster', name = friction)
@@ -218,7 +210,7 @@
             grass.message('\n\nCalculating list of possible catchment configurations\n')
             grass.message("cost value | catchment area")
             areadict = {}
-            out2dictnum('r.stats -Aani input=' + cost + ' fs=, nv=* nsteps=255', ',', areadict)
+            out2dictnum('r.stats -Aani input=' + cost + ' separator=, nv=* nsteps=255', ',', areadict)
             testarea = 0
             #start the loop, and list the values
             for key in sorted(areadict):
@@ -226,7 +218,7 @@
                 grass.message("%s | %s" % (int(key),  testarea))
             if flags["c"] is True:
                 if bool(options["in_cost"]) is False:
-                    grass.run_command('g.rename', overwrite = grass.overwrite(),  quiet = True,  rast = 'temporary.cost.%s,%s_cost_surface' % (pid, buffer))
+                    grass.run_command('g.rename', overwrite = grass.overwrite(),  quiet = True,  rast = 'temporary.cost.%s,%s_cost_surface' % (pid, buff))
                     grass.message('Cleaning up...(keeping cost map)')
                     grass.run_command('g.remove',  quiet = True, flags = 'f', type = 'raster', name = 'cost.reclass.%s' % pid)
                 else:
@@ -253,7 +245,7 @@
     else:
         grass.message('\n\nCalculating buffer\n')
         areadict = {}
         tot_area = 0
             tot_area = tot_area + int(float(areadict[key]))
@@ -283,12 +275,12 @@
         temp.flush()
         grass.run_command('r.reclass', overwrite = grass.overwrite(),  input = cost,  output = 'cost.reclass.%s' % pid,  rules = temp.name)
         temp.close()
-        grass.mapcalc("${out}=if(isnull(${cost}), null(), ${cost})", overwrite = grass.overwrite(), quiet = True, cost = "cost.reclass.%s" % pid, out = buffer)
-        grass.message("\nThe output catchment map will be named %s" % buffer)
-        grass.run_command('r.colors', quiet = True,  map = buffer, color = 'ryb')
+        grass.mapcalc("${out}=if(isnull(${cost}), null(), ${cost})", overwrite = grass.overwrite(), quiet = True, cost = "cost.reclass.%s" % pid, out = buff)
+        grass.message("\nThe output catchment map will be named %s" % buff)
+        grass.run_command('r.colors', quiet = True,  map = buff, color = 'ryb')
-                grass.run_command('g.rename', overwrite = grass.overwrite(),  quiet = True,  rast = 'temporary.cost,%s_cost_surface' % (buffer))
+                grass.run_command('g.rename', overwrite = grass.overwrite(),  quiet = True,  rast = 'temporary.cost,%s_cost_surface' % (buff))
             else:
