[GRASS-SVN] r64751 - grass-addons/grass7/raster/r.viewshed.cva
svn_grass at osgeo.org
Wed Feb 25 16:46:45 PST 2015
Author: annakrat
Date: 2015-02-25 16:46:45 -0800 (Wed, 25 Feb 2015)
New Revision: 64751
grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
r.viewshed.cva: fix man page, it tags are not supported
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html 2015-02-25 21:04:14 UTC (rev 64750)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html 2015-02-26 00:46:45 UTC (rev 64751)
@@ -7,30 +7,30 @@
point, calculating a viewshed map, and then creates an output map
that is coded by the number of input locations that can "see" each
cell. <em>r.viewshed.cva</em> uses the GRASS module <em>r.viewshed</em>
-for the viewshed analysis. <it>r.viewshed</it> is very fast,
+for the viewshed analysis. <em>r.viewshed</em> is very fast,
thus allowing for a cumulative viewshed analysis to run in a
reasonable amount of time. The final cumulative viewshed map is
-computed using the "count" method of <it>r.series</it>, rather than
+computed using the "count" method of <em>r.series</em>, rather than
with mapcalc, as it better handles the null values in the individual
constituent viewshed maps (and allows for interim viewshed maps to
be coded in any way)
<h3>Options and flags:</h3>
-<it>r.viewshed.cva</it> requires an input elevation map and an input
+<em>r.viewshed.cva</em> requires an input elevation map and an input
vector points map.
-There is currently only one native flag for <it>r.viewshed.cva</it>
+There is currently only one native flag for <em>r.viewshed.cva</em>
(-k), which allows you to keep the interim viewshed maps made for
each input point. All other flags and options are inherited from
-r.viewshed (see the<it> r.viewshed</it> help page for more
+r.viewshed (see the<em> r.viewshed</em> help page for more
information on these).
<h2>NOTES</h2>
-The input vector points map can be manually digitized (with <it>
-v.digit</it>) over topographic or cultural features, or can be
-created as a series of random points (with <it>r.random</it> or <it>
-v.random</it>). Note that using the flag -k allows you to keep any
+The input vector points map can be manually digitized (with <em>
+v.digit</em>) over topographic or cultural features, or can be
+created as a series of random points (with <em>r.random</em> or <em>
+v.random</em>). Note that using the flag -k allows you to keep any
interim viewshed maps created during the analysis, and these resultant
viewshed maps will be named according to the cat number of the original
input points. This is also useful for simple creating a large number
