[GRASS-SVN] r64171 - grass-addons/grass7/raster/r.massmov
Wed Jan 14 05:29:48 PST 2015
Author: neteler
Date: 2015-01-14 05:29:48 -0800 (Wed, 14 Jan 2015)
New Revision: 64171
   grass-addons/grass7/raster/r.massmov/main.c
r.massmov addon: source code indenting with grass_indent.sh; fix open comment
Modified: grass-addons/grass7/raster/r.massmov/main.c
--- grass-addons/grass7/raster/r.massmov/main.c	2015-01-14 13:17:32 UTC (rev 64170)
+++ grass-addons/grass7/raster/r.massmov/main.c	2015-01-14 13:29:48 UTC (rev 64171)
@@ -1,3 +1,4 @@
  * MODULE:	r.massmov
@@ -22,7 +23,7 @@
-/* libraries*/
+/* libraries */
 #include <math.h>
 #include <stdio.h>
 #include <stdlib.h>
@@ -35,22 +36,22 @@
 #include "omp.h"
 /* numerical stability control */
-#define CFLlimsup  0.5 			/* Higher value of the Courant-Friedrichs-Levy */
-#define CFLliminf  0.3			/* Lower value of the Courant-Friedrichs-Levy */
-#define MinNLoops  1 		    /* Minimum number of internal loops */
-#define MaxNLoops  124 			/* Maximum number of internal loops */
-#define InitialLoops  1  		/* Initial number of internal loops */
-#define laxfactor  0.5 			/* Low pass filtering for the lax function (0 = no filtering) */
-#define dTLeap  0.3 	   		/* Fraction of dT, used for time extrapolation of fluxes */
-#define verysmall 0.000001 		/* threshold to avoid div by very small values */
-#define small  0.001 		    /* threshold to avoid div by very small values */
+#define CFLlimsup  0.5		/* Higher value of the Courant-Friedrichs-Levy */
+#define CFLliminf  0.3		/* Lower value of the Courant-Friedrichs-Levy */
+#define MinNLoops  1		/* Minimum number of internal loops */
+#define MaxNLoops  124		/* Maximum number of internal loops */
+#define InitialLoops  1		/* Initial number of internal loops */
+#define laxfactor  0.5		/* Low pass filtering for the lax function (0 = no filtering) */
+#define dTLeap  0.3		/* Fraction of dT, used for time extrapolation of fluxes */
+#define verysmall 0.000001	/* threshold to avoid div by very small values */
+#define small  0.001		/* threshold to avoid div by very small values */
 #define nullo -999.9f
 /* timestep control */
-#define dT 1.0              /* Timeslice */
+#define dT 1.0			/* Timeslice */
 /* other constants */
-#define grav 9.8		        /* Gravity acceleration */
+#define grav 9.8		/* Gravity acceleration */
 /* functions definition  */
 #define min(A,B) ((A) < (B) ? (A):(B))
@@ -66,255 +67,275 @@
-int main(int argc, char *argv[]) {
-	struct Cell_head cellhd; /* it stores region information and header information of rasters */
-	struct Cell_head window;
-	struct History history; /*  holds meta-data */
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/* it stores region information and header information of rasters */
+    struct Cell_head window;
+    struct History history;	/*  holds meta-data */
-	/* mapset name locator */
-	char *mapset_ELEV;
-	char *mapset_HINI;
-	char *mapset_DIST;
+    /* mapset name locator */
+    char *mapset_ELEV;
+    char *mapset_HINI;
+    char *mapset_DIST;
-	/* input buffer */
-	DCELL *inrast_ELEV;
-	DCELL *inrast_HINI;
-	DCELL *inrast_DIST;
+    /* input buffer */
+    DCELL *inrast_ELEV;
+    DCELL *inrast_HINI;
+    DCELL *inrast_DIST;
-	/* output buffer */
-	double *outrast_H;
-	double *outrast_V;
+    /* output buffer */
+    double *outrast_H;
+    double *outrast_V;
-	/* input file descriptor */
-	int infd_ELEV;
-	int infd_HINI;
-	int infd_DIST;
+    /* input file descriptor */
+    int infd_ELEV;
+    int infd_HINI;
+    int infd_DIST;
-	/* output file descriptor */
-	int outfd_H;
-	int outfd_V;
+    /* output file descriptor */
+    int outfd_H;
+    int outfd_V;
-	/* cell counters */
-	int row, col;
-	int nrows, ncols;
-	double res_ns, res_ew, ca;
+    /* cell counters */
+    int row, col;
+    int nrows, ncols;
+    double res_ns, res_ew, ca;
-	/* input & output arguments */
-	int TIMESTEPS, DELTAT, RHEOL_TYPE,STEP_THRES,THREADS;
-	double RHO, YSTRESS, CHEZY, VISCO, BFRICT, IFRICT, FLUID,STOP_THRES;
-	char name1[20],timestr[256];
-	char *name_ELEV;
-	char *name_HINI;
-	char *name_DIST;
-	char *result_H;
-	char *result_V;
-	char *result_HMAX;
-	char *result_VMAX;
+    /* input & output arguments */
+    int TIMESTEPS, DELTAT, RHEOL_TYPE, STEP_THRES, THREADS;
+    double RHO, YSTRESS, CHEZY, VISCO, BFRICT, IFRICT, FLUID, STOP_THRES;
+    char name1[20], timestr[256];
+    char *name_ELEV;
+    char *name_HINI;
+    char *name_DIST;
+    char *result_H;
+    char *result_V;
+    char *result_HMAX;
+    char *result_VMAX;
-	/* memory matrix */
-	double **m_ELEV, **m_HINI, **m_DIST;
-	int **m_OUTLET;
-	double **m_gx, **m_ca_gx,**m_gy, **m_ca_gy,**m_slope;
-	double **m_H, **m_Hloop_dt, **m_Hloop, **m_V, **m_Vloop, **m_Vloop_dt, **m_U,
-			**m_Uloop, **m_Uloop_dt, **m_HUloop, **m_HVloop, **m_Hold, **m_Hmax, **m_Vmax;
-	double **m_K, **m_Kloop;
-	double mem;
+    /* memory matrix */
+    double **m_ELEV, **m_HINI, **m_DIST;
+    int **m_OUTLET;
+    double **m_gx, **m_ca_gx, **m_gy, **m_ca_gy, **m_slope;
+    double **m_H, **m_Hloop_dt, **m_Hloop, **m_V, **m_Vloop, **m_Vloop_dt,
+	**m_U, **m_Uloop, **m_Uloop_dt, **m_HUloop, **m_HVloop, **m_Hold,
+	**m_Hmax, **m_Vmax;
+    double **m_K, **m_Kloop;
+    double mem;
-	/* variables */
+    /* variables */
-	double elev_fcell_val, dist_fcell_val, hini_fcell_val;
+    double elev_fcell_val, dist_fcell_val, hini_fcell_val;
-	double gx, gy, slope;
-	double k_act, k_pas;
-	double G_x, G_y, I_x, I_y, P_x, P_y, T, T_x, T_y, T_x_b, T_y_b, T_b;
-	double ddt, dt;
-	double Uloop_a, Vloop_a, Uloop_b, Vloop_b, vel, vel_b, Uloop_dt, Vloop_dt, Hloop_a, Hloop_dt, dH_dT, H_fluid;
-	double CFL, CFL_u, CFL_v;
-	double mbe;
-	double pears;
-	int testPar;
+    double gx, gy, slope;
+    double k_act, k_pas;
+    double G_x, G_y, I_x, I_y, P_x, P_y, T, T_x, T_y, T_x_b, T_y_b, T_b;
+    double ddt, dt;
+    double Uloop_a, Vloop_a, Uloop_b, Vloop_b, vel, vel_b, Uloop_dt, Vloop_dt,
+	Hloop_a, Hloop_dt, dH_dT, H_fluid;
+    double CFL, CFL_u, CFL_v;
+    double mbe;
+    double pears;
+    int testPar;
-	/* GRASS structure */
-	struct GModule *module;
-	struct Option *input_ELEV, *input_HINI,*input_DIST,
-			*input_RHEOL, *input_RHO, *input_YSTRESS, *input_CHEZY,
-			*input_VISCO, *input_BFRICT, *input_IFRICT, *input_FLUID,
-			*input_TIMESTEPS, *input_DELTAT, *output_H, *output_VEL, *input_STOP_THRES, *input_STEP_THRES,*input_THREADS,*output_HMAX, *output_VMAX;
-	struct Flag *flag_i,*flag_mem;
+    /* GRASS structure */
+    struct GModule *module;
+    struct Option *input_ELEV, *input_HINI, *input_DIST,
+	*input_RHEOL, *input_RHO, *input_YSTRESS, *input_CHEZY,
+	*input_VISCO, *input_BFRICT, *input_IFRICT, *input_FLUID,
+	*input_TIMESTEPS, *input_DELTAT, *output_H, *output_VEL,
+	*input_STOP_THRES, *input_STEP_THRES, *input_THREADS, *output_HMAX,
+	*output_VMAX;
+    struct Flag *flag_i, *flag_mem;
-	/* initialize GIS environment */
-	G_gisinit(argv[0]);
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);
-	/* initialize module */
-	module = G_define_module();
-	G_add_keyword(_("raster"));
-	G_add_keyword(_("landslide"));
-	G_add_keyword(_("model"));
-	module->description =_("Estimation of run-out and deposition of landslide phenomena over a complex topography");
+    /* initialize module */
+    module = G_define_module();
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("landslide"));
+    G_add_keyword(_("model"));
+    module->description =
+	_("Estimation of run-out and deposition of landslide phenomena over a complex topography");
-	/* define the different options */
+    /* define the different options */
-	input_ELEV = G_define_option();
-	input_ELEV->key = "elev";
-	input_ELEV->type = TYPE_STRING;
-	input_ELEV->required = YES;
-	input_ELEV->gisprompt = "old,cell,raster";
-	input_ELEV->description = _("Name of elevation raster map");
-	input_ELEV->guisection = _("Input options");
+    input_ELEV = G_define_option();
+    input_ELEV->key = "elev";
+    input_ELEV->type = TYPE_STRING;
+    input_ELEV->required = YES;
+    input_ELEV->gisprompt = "old,cell,raster";
+    input_ELEV->description = _("Name of elevation raster map");
+    input_ELEV->guisection = _("Input options");
-	input_HINI = G_define_option();
-	input_HINI->key = "h_ini";
-	input_HINI->type = TYPE_STRING;
-	input_HINI->required = YES;
-	input_HINI->gisprompt = "old,cell,raster";
-	input_HINI->description = _("Name of landslide initial body thickness raster map");
-	input_HINI->guisection = _("Input options");
+    input_HINI = G_define_option();
+    input_HINI->key = "h_ini";
+    input_HINI->type = TYPE_STRING;
+    input_HINI->required = YES;
+    input_HINI->gisprompt = "old,cell,raster";
+    input_HINI->description =
+	_("Name of landslide initial body thickness raster map");
+    input_HINI->guisection = _("Input options");
-	input_DIST = G_define_option();
-	input_DIST->key = "fluiddist";
-	input_DIST->type = TYPE_STRING;
-	input_DIST->required = YES;
-	input_DIST->gisprompt = "old,cell,raster";
-	input_DIST->description = _("Name of distance from the landlide toe raster map");
-	input_DIST->guisection = _("Input options");
+    input_DIST = G_define_option();
+    input_DIST->key = "fluiddist";
+    input_DIST->type = TYPE_STRING;
+    input_DIST->required = YES;
+    input_DIST->gisprompt = "old,cell,raster";
+    input_DIST->description =
+	_("Name of distance from the landlide toe raster map");
+    input_DIST->guisection = _("Input options");
-	input_RHEOL = G_define_option();
-	input_RHEOL->key = "rheology";
-	input_RHEOL->type = TYPE_STRING;
-	input_RHEOL->required = YES;
-	input_RHEOL->options = "frictional,Voellmy,viscoplastic";
-	input_RHEOL->description = _("Name of rheological law");
-	input_RHEOL->guisection = _("Input options");
+    input_RHEOL = G_define_option();
+    input_RHEOL->key = "rheology";
+    input_RHEOL->type = TYPE_STRING;
+    input_RHEOL->required = YES;
+    input_RHEOL->options = "frictional,Voellmy,viscoplastic";
+    input_RHEOL->description = _("Name of rheological law");
+    input_RHEOL->guisection = _("Input options");
-	input_RHO = G_define_option();
-	input_RHO->key = "rho";
-	input_RHO->type = TYPE_DOUBLE;
-	input_RHO->required = NO;
-	input_RHO->multiple = NO;
-	input_RHO->description =_("Density of the flow [Kg/m3]. Required only for viscous rheologies.");
-	input_RHO->guisection = _("Input options");
+    input_RHO = G_define_option();
+    input_RHO->key = "rho";
+    input_RHO->type = TYPE_DOUBLE;
+    input_RHO->required = NO;
+    input_RHO->multiple = NO;
+    input_RHO->description =
+	_("Density of the flow [Kg/m3]. Required only for viscous rheologies.");
+    input_RHO->guisection = _("Input options");
-	input_YSTRESS = G_define_option();
-	input_YSTRESS->key = "ystress";
-	input_YSTRESS->type = TYPE_DOUBLE;
-	input_YSTRESS->required = NO;
-	input_YSTRESS->multiple = NO;
-	input_YSTRESS->description =_("Apparent yield stress [Pa]. Used only for viscous rheologies (optional).");
-	input_YSTRESS->guisection = _("Input options");
+    input_YSTRESS = G_define_option();
+    input_YSTRESS->key = "ystress";
+    input_YSTRESS->type = TYPE_DOUBLE;
+    input_YSTRESS->required = NO;
+    input_YSTRESS->multiple = NO;
+    input_YSTRESS->description =
+	_("Apparent yield stress [Pa]. Used only for viscous rheologies (optional).");
+    input_YSTRESS->guisection = _("Input options");
-	input_VISCO = G_define_option();
-	input_VISCO->key = "visco";
-	input_VISCO->type = TYPE_DOUBLE;
-	input_VISCO->required = NO;
-	input_VISCO->multiple = NO;
-	input_VISCO->description = _("Dynamic viscosity [Pa*s]. Required only for viscous rheologies");
-	input_VISCO->guisection = _("Input options");
+    input_VISCO = G_define_option();
+    input_VISCO->key = "visco";
+    input_VISCO->type = TYPE_DOUBLE;
+    input_VISCO->required = NO;
+    input_VISCO->multiple = NO;
+    input_VISCO->description =
+	_("Dynamic viscosity [Pa*s]. Required only for viscous rheologies");
+    input_VISCO->guisection = _("Input options");
-	input_CHEZY = G_define_option();
-	input_CHEZY->key = "chezy";
-	input_CHEZY->type = TYPE_DOUBLE;
-	input_CHEZY->required = NO;
-	input_CHEZY->multiple = NO;
-	input_CHEZY->description =_("Chezy roughness coefficient [m/s2]. Required only for Voellmy rheology");
-	input_CHEZY->guisection = _("Input options");
+    input_CHEZY = G_define_option();
+    input_CHEZY->key = "chezy";
+    input_CHEZY->type = TYPE_DOUBLE;
+    input_CHEZY->required = NO;
+    input_CHEZY->multiple = NO;
+    input_CHEZY->description =
+	_("Chezy roughness coefficient [m/s2]. Required only for Voellmy rheology");
+    input_CHEZY->guisection = _("Input options");
-	input_BFRICT = G_define_option();
-	input_BFRICT->key = "bfrict";
-	input_BFRICT->type = TYPE_DOUBLE;
-	input_BFRICT->required = NO;
-	input_BFRICT->multiple = NO;
-	input_BFRICT->description = _("Angle of basal friction [deg]");
-	input_BFRICT->guisection = _("Input options");
+    input_BFRICT = G_define_option();
+    input_BFRICT->key = "bfrict";
+    input_BFRICT->type = TYPE_DOUBLE;
+    input_BFRICT->required = NO;
+    input_BFRICT->multiple = NO;
+    input_BFRICT->description = _("Angle of basal friction [deg]");
+    input_BFRICT->guisection = _("Input options");
-	input_IFRICT = G_define_option();
-	input_IFRICT->key = "ifrict";
-	input_IFRICT->type = TYPE_DOUBLE;
-	input_IFRICT->required = YES;
-	input_IFRICT->multiple = NO;
-	input_IFRICT->description = _("Angle of internal friction [deg]");
-	input_IFRICT->guisection = _("Input options");
+    input_IFRICT = G_define_option();
+    input_IFRICT->key = "ifrict";
+    input_IFRICT->type = TYPE_DOUBLE;
+    input_IFRICT->required = YES;
+    input_IFRICT->multiple = NO;
+    input_IFRICT->description = _("Angle of internal friction [deg]");
+    input_IFRICT->guisection = _("Input options");
-	input_FLUID = G_define_option();
-	input_FLUID->key = "fluid";
-	input_FLUID->type = TYPE_DOUBLE;
-	input_FLUID->required = YES;
-	input_FLUID->multiple = NO;
-	input_FLUID->description = _("Upward velocity of transition from solid to fluid of the landsliding mass [m/s]");
-	input_FLUID->guisection = _("Input options");
+    input_FLUID = G_define_option();
+    input_FLUID->key = "fluid";
+    input_FLUID->type = TYPE_DOUBLE;
+    input_FLUID->required = YES;
+    input_FLUID->multiple = NO;
+    input_FLUID->description =
+	_("Upward velocity of transition from solid to fluid of the landsliding mass [m/s]");
+    input_FLUID->guisection = _("Input options");
-	input_TIMESTEPS = G_define_option();
-	input_TIMESTEPS->key = "timesteps";
-	input_TIMESTEPS->type = TYPE_INTEGER;
-	input_TIMESTEPS->required = YES;
-	input_TIMESTEPS->multiple = NO;
-	input_TIMESTEPS->description = _(
-			"Maximum number of time steps of the simulation [s]");
-	input_TIMESTEPS->guisection = _("Input options");
+    input_TIMESTEPS = G_define_option();
+    input_TIMESTEPS->key = "timesteps";
+    input_TIMESTEPS->type = TYPE_INTEGER;
+    input_TIMESTEPS->required = YES;
+    input_TIMESTEPS->multiple = NO;
+    input_TIMESTEPS->description =
+	_("Maximum number of time steps of the simulation [s]");
+    input_TIMESTEPS->guisection = _("Input options");
-	input_DELTAT = G_define_option();
-	input_DELTAT->key = "deltatime";
-	input_DELTAT->type = TYPE_INTEGER;
-	input_DELTAT->required = NO;
-	input_DELTAT->multiple = NO;
-	input_DELTAT->description = _("Reporting time frequency [s]");
-	input_DELTAT->guisection = _("Input options");
+    input_DELTAT = G_define_option();
+    input_DELTAT->key = "deltatime";
+    input_DELTAT->type = TYPE_INTEGER;
+    input_DELTAT->required = NO;
+    input_DELTAT->multiple = NO;
+    input_DELTAT->description = _("Reporting time frequency [s]");
+    input_DELTAT->guisection = _("Input options");
-	input_STOP_THRES = G_define_option();
-	input_STOP_THRES->key = "stop_thres";
-	input_STOP_THRES->type = TYPE_DOUBLE;
-	input_STOP_THRES->required = NO;
-	input_STOP_THRES->multiple = NO;
-	input_STOP_THRES->description = _("Pearson value threshold for simulation stop [-]");
-	input_STOP_THRES->guisection = _("Input options");
-        input_STEP_THRES = G_define_option();
-	input_STEP_THRES->key = "step_thres";
-	input_STEP_THRES->type = TYPE_INTEGER;
-	input_STEP_THRES->required = NO;
-	input_STEP_THRES->multiple = NO;
-	input_STEP_THRES->description = _("Number of time steps for evaluating stop_thres value [-]");
-	input_STEP_THRES->guisection = _("Input options");
-	input_THREADS = G_define_option();
-	input_THREADS->key = "threads";
-	input_THREADS->type = TYPE_INTEGER;
-	input_THREADS->required = NO;
-	input_THREADS->multiple = NO;
-	input_THREADS->description = _("Number of threads for parallel computing");
-	input_THREADS->guisection = _("Input options");
+    input_STOP_THRES = G_define_option();
+    input_STOP_THRES->key = "stop_thres";
+    input_STOP_THRES->type = TYPE_DOUBLE;
+    input_STOP_THRES->required = NO;
+    input_STOP_THRES->multiple = NO;
+    input_STOP_THRES->description =
+	_("Pearson value threshold for simulation stop [-]");
+    input_STOP_THRES->guisection = _("Input options");
-	output_H = G_define_option();
-	output_H->key = "h";
-	output_H->type = TYPE_STRING;
-	output_H->required = NO;
-	output_H->gisprompt = "new,cell,raster";
-	output_H->description = _("Prefix for flow thickness output raster maps");
-	output_H->guisection = _("Output options");
+    input_STEP_THRES = G_define_option();
+    input_STEP_THRES->key = "step_thres";
+    input_STEP_THRES->type = TYPE_INTEGER;
+    input_STEP_THRES->required = NO;
+    input_STEP_THRES->multiple = NO;
+    input_STEP_THRES->description =
+	_("Number of time steps for evaluating stop_thres value [-]");
+    input_STEP_THRES->guisection = _("Input options");
-	output_HMAX = G_define_option();
-	output_HMAX->key = "h_max";
-	output_HMAX->type = TYPE_STRING;
-	output_HMAX->required = NO;
-	output_HMAX->gisprompt = "new,cell,raster";
-	output_HMAX->description = _("Prefix for maximum flow thickness output raster maps");
-	output_HMAX->guisection = _("Output options");
+    input_THREADS = G_define_option();
+    input_THREADS->key = "threads";
+    input_THREADS->type = TYPE_INTEGER;
+    input_THREADS->required = NO;
+    input_THREADS->multiple = NO;
+    input_THREADS->description =
+	_("Number of threads for parallel computing");
+    input_THREADS->guisection = _("Input options");
-	output_VEL = G_define_option();
-	output_VEL->key = "v";
-	output_VEL->type = TYPE_STRING;
-	output_VEL->required = NO;
-	output_VEL->gisprompt = "new,cell,raster";
-	output_VEL->description = _("Prefix for flow velocity output raster maps");
-	output_VEL->guisection = _("Output options");
+    output_H = G_define_option();
+    output_H->key = "h";
+    output_H->type = TYPE_STRING;
+    output_H->required = NO;
+    output_H->gisprompt = "new,cell,raster";
+    output_H->description = _("Prefix for flow thickness output raster maps");
+    output_H->guisection = _("Output options");
-	output_VMAX = G_define_option();
-	output_VMAX->key = "v_max";
-	output_VMAX->type = TYPE_STRING;
-	output_VMAX->required = NO;
-	output_VMAX->gisprompt = "new,cell,raster";
-	output_VMAX->description = _("Prefix for maximum flow velocity output raster maps");
-	output_VMAX->guisection = _("Output options");
+    output_HMAX = G_define_option();
+    output_HMAX->key = "h_max";
+    output_HMAX->type = TYPE_STRING;
+    output_HMAX->required = NO;
+    output_HMAX->gisprompt = "new,cell,raster";
+    output_HMAX->description =
+	_("Prefix for maximum flow thickness output raster maps");
+    output_HMAX->guisection = _("Output options");
+    output_VEL = G_define_option();
+    output_VEL->key = "v";
+    output_VEL->type = TYPE_STRING;
+    output_VEL->required = NO;
+    output_VEL->gisprompt = "new,cell,raster";
+    output_VEL->description =
+	_("Prefix for flow velocity output raster maps");
+    output_VEL->guisection = _("Output options");
+    output_VMAX = G_define_option();
+    output_VMAX->key = "v_max";
+    output_VMAX->type = TYPE_STRING;
+    output_VMAX->required = NO;
+    output_VMAX->gisprompt = "new,cell,raster";
+    output_VMAX->description =
+	_("Prefix for maximum flow velocity output raster maps");
+    output_VMAX->guisection = _("Output options");
     flag_i = G_define_flag();
     flag_i->key = 'i';
     flag_i->description = _("Print input data");
@@ -324,925 +345,1024 @@
     flag_mem->description = _("Print memory usage requirements");
-	if (G_parser(argc, argv))
-		exit(EXIT_FAILURE);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-	/* get entered parameters */
+    /* get entered parameters */
-	name_ELEV = input_ELEV->answer;
-	name_DIST = input_DIST->answer;
-	name_HINI = input_HINI->answer;
+    name_ELEV = input_ELEV->answer;
+    name_DIST = input_DIST->answer;
+    name_HINI = input_HINI->answer;
-	result_H = output_H->answer;
-	result_V = output_VEL->answer;
-	result_HMAX = output_HMAX->answer;
-	result_VMAX = output_VMAX->answer;
+    result_H = output_H->answer;
+    result_V = output_VEL->answer;
+    result_HMAX = output_HMAX->answer;
+    result_VMAX = output_VMAX->answer;
-	G_debug(1,"Getting numeric input data...");
+    G_debug(1, "Getting numeric input data...");
-	if (strcmp(input_RHEOL->answer, "frictional") == 0)
-		RHEOL_TYPE = 1;
-	if (strcmp(input_RHEOL->answer, "Voellmy") == 0)
-		RHEOL_TYPE = 2;
-	if (strcmp(input_RHEOL->answer, "viscoplastic") == 0)
-		RHEOL_TYPE = 3;
+    if (strcmp(input_RHEOL->answer, "frictional") == 0)
+	RHEOL_TYPE = 1;
+    if (strcmp(input_RHEOL->answer, "Voellmy") == 0)
+	RHEOL_TYPE = 2;
+    if (strcmp(input_RHEOL->answer, "viscoplastic") == 0)
+	RHEOL_TYPE = 3;
-	if (input_RHO->answer)
-		sscanf(input_RHO->answer, "%lf", &RHO);
-	else
-		RHO = -1;
+    if (input_RHO->answer)
+	sscanf(input_RHO->answer, "%lf", &RHO);
+    else
+	RHO = -1;
-	if (input_YSTRESS->answer)
-		sscanf(input_YSTRESS->answer, "%lf", &YSTRESS);
-	else
-		YSTRESS = -1;
+    if (input_YSTRESS->answer)
+	sscanf(input_YSTRESS->answer, "%lf", &YSTRESS);
+    else
+	YSTRESS = -1;
-	if (input_CHEZY->answer)
-		sscanf(input_CHEZY->answer, "%lf", &CHEZY);
-	else
-		CHEZY = -1;
-	if (input_VISCO->answer)
-		sscanf(input_VISCO->answer, "%lf", &VISCO);
-	else
-		VISCO = -1;
-	if (input_BFRICT->answer)
-		sscanf(input_BFRICT->answer, "%lf", &BFRICT);
-	else
-		BFRICT = -1;
+    if (input_CHEZY->answer)
+	sscanf(input_CHEZY->answer, "%lf", &CHEZY);
+    else
+	CHEZY = -1;
-	if (input_STOP_THRES->answer)
-		sscanf(input_STOP_THRES->answer, "%lf", &STOP_THRES);
-	else
-		STOP_THRES = -1;
+    if (input_VISCO->answer)
+	sscanf(input_VISCO->answer, "%lf", &VISCO);
+    else
+	VISCO = -1;
-	sscanf(input_IFRICT->answer, "%lf", &IFRICT);
+    if (input_BFRICT->answer)
+	sscanf(input_BFRICT->answer, "%lf", &BFRICT);
+    else
+	BFRICT = -1;
-	sscanf(input_FLUID->answer, "%lf", &FLUID);
+    if (input_STOP_THRES->answer)
+	sscanf(input_STOP_THRES->answer, "%lf", &STOP_THRES);
+    else
+	STOP_THRES = -1;
-	if (input_DELTAT->answer)
-		DELTAT = atoi(input_DELTAT->answer);
-	else
-		DELTAT = -1;
-	if (input_STEP_THRES->answer)
-		STEP_THRES = atoi(input_STEP_THRES->answer);
-	else
-		STEP_THRES = -1;
+    sscanf(input_IFRICT->answer, "%lf", &IFRICT);
-	TIMESTEPS = atoi(input_TIMESTEPS->answer);
-	if (input_THREADS->answer)
-		THREADS = atoi(input_THREADS->answer);
+    sscanf(input_FLUID->answer, "%lf", &FLUID);
+    if (input_DELTAT->answer)
+	DELTAT = atoi(input_DELTAT->answer);
+    else
+	DELTAT = -1;
+    if (input_STEP_THRES->answer)
+	STEP_THRES = atoi(input_STEP_THRES->answer);
+    else
+	STEP_THRES = -1;
+    TIMESTEPS = atoi(input_TIMESTEPS->answer);
+    if (input_THREADS->answer)
+	THREADS = atoi(input_THREADS->answer);
+    else
+	THREADS = -1;
+    /* setting number of threads */
+    if (THREADS != -1) {
+	int max_th = omp_get_max_threads();
+	if (THREADS <= max_th)
+	    omp_set_num_threads(THREADS);
 	else
-		THREADS = -1;
-    /* setting number of threads */
-    if (THREADS!=-1) {
-        int max_th = omp_get_max_threads( );
-        if (THREADS<=max_th)
-            omp_set_num_threads(THREADS);
-        else
-            G_fatal_error(_("The maximum number of parallel threads available is %i"),max_th);
+	    G_fatal_error(_("The maximum number of parallel threads available is %i"),
+			  max_th);
-	/* check outputs required */
-	if (!((result_H) || (result_V) || (result_HMAX) || (result_VMAX))){
-		G_fatal_error(_("No output specified"));
-	/* check simulation stopping parameters required */
-	if (((STOP_THRES!=-1)&&(STEP_THRES==-1))||((STEP_THRES!=-1)&&(STOP_THRES==-1))){
-		G_fatal_error(_("To apply the stopping criterion both the threshold value and the calculation step of stopping criterion are required"));
-	/* check rheology parameters */
-	testPar = check_rheol_par(RHEOL_TYPE, CHEZY, VISCO, RHO);
-	if (testPar == -2)
-		G_fatal_error(_("For the selected rheology Chezy parameter is required"));
-	if (testPar == -3)
-		G_fatal_error(_("For the selected rheology viscosity and density parameters are required"));
-	/* report Input Data */
-	if (flag_i->answer){
-		report_input(IFRICT,RHO, YSTRESS, VISCO, CHEZY, BFRICT,FLUID, STOP_THRES, STEP_THRES, TIMESTEPS, DELTAT,THREADS);
+    /* check outputs required */
+    if (!((result_H) || (result_V) || (result_HMAX) || (result_VMAX))) {
+	G_fatal_error(_("No output specified"));
-	G_debug(2,"Verifiyng raster maps input data...");
+    /* check simulation stopping parameters required */
+    if (((STOP_THRES != -1) && (STEP_THRES == -1)) ||
+	((STEP_THRES != -1) && (STOP_THRES == -1))) {
+	G_fatal_error(_("To apply the stopping criterion both the threshold value and the calculation step of stopping criterion are required"));
-	/* find maps in mapset */
-	mapset_ELEV = (char *) G_find_raster2(name_ELEV, "");
-	if (mapset_ELEV == NULL)
-		G_fatal_error(_("cell file [%s] not found"), name_ELEV);
+    /* check rheology parameters */
+    testPar = check_rheol_par(RHEOL_TYPE, CHEZY, VISCO, RHO);
-	mapset_DIST = (char *) G_find_raster2(name_DIST, "");
-	if (mapset_DIST == NULL)
-		G_fatal_error(_("cell file [%s] not found"), name_DIST);
+    if (testPar == -2)
+	G_fatal_error(_("For the selected rheology Chezy parameter is required"));
-	mapset_HINI = (char *) G_find_raster2(name_HINI, "");
-	if (mapset_HINI == NULL)
-		G_fatal_error(_("cell file [%s] not found"), name_HINI);
+    if (testPar == -3)
+	G_fatal_error(_("For the selected rheology viscosity and density parameters are required"));
-	/* rast_open_old */
-	if ((infd_ELEV = Rast_open_old(name_ELEV, mapset_ELEV)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), name_ELEV);
+    /* report Input Data */
+    if (flag_i->answer) {
+	report_input(IFRICT, RHO, YSTRESS, VISCO, CHEZY, BFRICT, FLUID,
+		     STOP_THRES, STEP_THRES, TIMESTEPS, DELTAT, THREADS);
-	if ((infd_DIST = Rast_open_old(name_DIST, mapset_DIST)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), name_DIST);
+    G_debug(2, "Verifiyng raster maps input data...");
-	if ((infd_HINI = Rast_open_old(name_HINI, mapset_HINI)) < 0)
-		G_fatal_error(_("Cannot open cell file [%s]"), name_HINI);
+    /* find maps in mapset */
+    mapset_ELEV = (char *)G_find_raster2(name_ELEV, "");
+    if (mapset_ELEV == NULL)
+	G_fatal_error(_("cell file [%s] not found"), name_ELEV);
+    mapset_DIST = (char *)G_find_raster2(name_DIST, "");
+    if (mapset_DIST == NULL)
+	G_fatal_error(_("cell file [%s] not found"), name_DIST);
-	/* controlling if we can open input raster */
-	Rast_get_cellhd(name_ELEV, mapset_ELEV, &cellhd);
-	G_debug(3, "number of rows %d", cellhd.rows);
+    mapset_HINI = (char *)G_find_raster2(name_HINI, "");
+    if (mapset_HINI == NULL)
+	G_fatal_error(_("cell file [%s] not found"), name_HINI);
-	Rast_get_cellhd(name_DIST, mapset_DIST, &cellhd);
+    /* rast_open_old */
+    if ((infd_ELEV = Rast_open_old(name_ELEV, mapset_ELEV)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), name_ELEV);
-	Rast_get_cellhd(name_HINI, mapset_HINI, &cellhd);
+    if ((infd_DIST = Rast_open_old(name_DIST, mapset_DIST)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), name_DIST);
+    if ((infd_HINI = Rast_open_old(name_HINI, mapset_HINI)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), name_HINI);
-	/* allocate input buffer */
-	inrast_ELEV = Rast_allocate_d_buf();
-	inrast_DIST = Rast_allocate_d_buf();
-	inrast_HINI = Rast_allocate_d_buf();
-	G_debug(1,"Getting region extension...");
+    /* controlling if we can open input raster */
+    Rast_get_cellhd(name_ELEV, mapset_ELEV, &cellhd);
+    G_debug(3, "number of rows %d", cellhd.rows);
-	/* get windows rows & cols */
-	nrows = Rast_window_rows();
-	ncols = Rast_window_cols();
-	G_get_window(&window);
-	res_ew = window.ew_res;
-	res_ns = window.ns_res;
-	ca = res_ns * res_ew;
+    Rast_get_cellhd(name_DIST, mapset_DIST, &cellhd);
+    Rast_get_cellhd(name_HINI, mapset_HINI, &cellhd);
+    /* allocate input buffer */
+    inrast_ELEV = Rast_allocate_d_buf();
+    inrast_DIST = Rast_allocate_d_buf();
+    inrast_HINI = Rast_allocate_d_buf();
+    G_debug(1, "Getting region extension...");
+    /* get windows rows & cols */
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    G_get_window(&window);
+    res_ew = window.ew_res;
+    res_ns = window.ns_res;
+    ca = res_ns * res_ew;
     /* memory flag */
-	if (flag_mem->answer){
-        mem = (((25.0*sizeof(double)*nrows*ncols)/pow(1024.0,2))+0.55);
-		fprintf(stdout,"The memory required to run the model on the selected region is about %f MB\n", mem);
+    if (flag_mem->answer) {
+	mem =
+	    (((25.0 * sizeof(double) * nrows * ncols) / pow(1024.0, 2)) +
+	     0.55);
+	fprintf(stdout,
+		"The memory required to run the model on the selected region is about %f MB\n",
+		mem);
-	G_debug(2,"Allocating memory matrix...");
+    G_debug(2, "Allocating memory matrix...");
-	/* allocate memory matrix */
-	m_ELEV = G_alloc_matrix(nrows, ncols);
-	m_OUTLET = G_alloc_imatrix(nrows, ncols);
-	m_DIST = G_alloc_matrix(nrows, ncols);
-	m_HINI = G_alloc_matrix(nrows, ncols);
-	m_gx = G_alloc_matrix(nrows, ncols);
-	m_ca_gx = G_alloc_matrix(nrows, ncols);
-	m_gy = G_alloc_matrix(nrows, ncols);
-	m_ca_gy = G_alloc_matrix(nrows, ncols);
-	m_slope = G_alloc_matrix(nrows, ncols);
-	m_U = G_alloc_matrix(nrows, ncols);
-	m_Uloop = G_alloc_matrix(nrows, ncols);
-	m_Uloop_dt = G_alloc_matrix(nrows, ncols);
-	m_V = G_alloc_matrix(nrows, ncols);
-	m_Vloop = G_alloc_matrix(nrows, ncols);
-	m_Vloop_dt = G_alloc_matrix(nrows, ncols);
-	m_H = G_alloc_matrix(nrows, ncols);
-	m_Hloop = G_alloc_matrix(nrows, ncols);
-	m_Hloop_dt = G_alloc_matrix(nrows, ncols);
-	m_K = G_alloc_matrix(nrows, ncols);
-	m_Kloop = G_alloc_matrix(nrows, ncols);
-	m_HUloop = G_alloc_matrix(nrows, ncols);
-	m_HVloop = G_alloc_matrix(nrows, ncols);
+    /* allocate memory matrix */
+    m_ELEV = G_alloc_matrix(nrows, ncols);
+    m_OUTLET = G_alloc_imatrix(nrows, ncols);
+    m_DIST = G_alloc_matrix(nrows, ncols);
+    m_HINI = G_alloc_matrix(nrows, ncols);
+    m_gx = G_alloc_matrix(nrows, ncols);
+    m_ca_gx = G_alloc_matrix(nrows, ncols);
+    m_gy = G_alloc_matrix(nrows, ncols);
+    m_ca_gy = G_alloc_matrix(nrows, ncols);
+    m_slope = G_alloc_matrix(nrows, ncols);
+    m_U = G_alloc_matrix(nrows, ncols);
+    m_Uloop = G_alloc_matrix(nrows, ncols);
+    m_Uloop_dt = G_alloc_matrix(nrows, ncols);
+    m_V = G_alloc_matrix(nrows, ncols);
+    m_Vloop = G_alloc_matrix(nrows, ncols);
+    m_Vloop_dt = G_alloc_matrix(nrows, ncols);
+    m_H = G_alloc_matrix(nrows, ncols);
+    m_Hloop = G_alloc_matrix(nrows, ncols);
+    m_Hloop_dt = G_alloc_matrix(nrows, ncols);
+    m_K = G_alloc_matrix(nrows, ncols);
+    m_Kloop = G_alloc_matrix(nrows, ncols);
+    m_HUloop = G_alloc_matrix(nrows, ncols);
+    m_HVloop = G_alloc_matrix(nrows, ncols);
-	if (STOP_THRES!=-1){
-		m_Hold= G_alloc_matrix(nrows, ncols);
+    if (STOP_THRES != -1) {
+	m_Hold = G_alloc_matrix(nrows, ncols);
-	if (result_HMAX){
-		m_Hmax = G_alloc_matrix(nrows, ncols);
+    if (result_HMAX) {
+	m_Hmax = G_alloc_matrix(nrows, ncols);
-	if (result_VMAX){
-		m_Vmax = G_alloc_matrix(nrows, ncols);
+    if (result_VMAX) {
+	m_Vmax = G_alloc_matrix(nrows, ncols);
-	/* read rows */
-	G_debug(2,"Reading input maps...");
-	for (row = 0; row < nrows; row++) {
+    /* read rows */
+    G_debug(2, "Reading input maps...");
+    for (row = 0; row < nrows; row++) {
-		/* read a line input maps into buffers*/
-		Rast_get_d_row(infd_ELEV, inrast_ELEV, row);
-		Rast_get_d_row(infd_DIST, inrast_DIST, row);
-		Rast_get_d_row(infd_HINI, inrast_HINI, row);
+	/* read a line input maps into buffers */
+	Rast_get_d_row(infd_ELEV, inrast_ELEV, row);
+	Rast_get_d_row(infd_DIST, inrast_DIST, row);
+	Rast_get_d_row(infd_HINI, inrast_HINI, row);
-		for (col = 0; col < ncols; col++) {
-			elev_fcell_val = ((DCELL *) inrast_ELEV)[col];
-			dist_fcell_val = ((DCELL *) inrast_DIST)[col];
-			hini_fcell_val = ((DCELL *) inrast_HINI)[col];
+	for (col = 0; col < ncols; col++) {
+	    elev_fcell_val = ((DCELL *) inrast_ELEV)[col];
+	    dist_fcell_val = ((DCELL *) inrast_DIST)[col];
+	    hini_fcell_val = ((DCELL *) inrast_HINI)[col];
-			/* elevation map */
-			if (Rast_is_d_null_value(&elev_fcell_val) == 1) {
-				m_ELEV[row][col] = nullo;
-			} else {
-				m_ELEV[row][col] = ((DCELL *) inrast_ELEV)[col];
+	    /* elevation map */
+	    if (Rast_is_d_null_value(&elev_fcell_val) == 1) {
+		m_ELEV[row][col] = nullo;
+	    else {
+		m_ELEV[row][col] = ((DCELL *) inrast_ELEV)[col];
-			/* distance map */
-			if (Rast_is_d_null_value(&dist_fcell_val) == 1) {
-				m_DIST[row][col] = nullo;
-			} else {
-				m_DIST[row][col] = ((DCELL *) inrast_DIST)[col];
+	    /* distance map */
+	    if (Rast_is_d_null_value(&dist_fcell_val) == 1) {
+		m_DIST[row][col] = nullo;
+	    else {
+		m_DIST[row][col] = ((DCELL *) inrast_DIST)[col];
-			/* hini map */
-			if (Rast_is_d_null_value(&hini_fcell_val) == 1) {
-				m_HINI[row][col] = nullo;
-			} else {
-				m_HINI[row][col] = ((DCELL *) inrast_HINI)[col];
+	    /* hini map */
+	    if (Rast_is_d_null_value(&hini_fcell_val) == 1) {
+		m_HINI[row][col] = nullo;
+	    else {
+		m_HINI[row][col] = ((DCELL *) inrast_HINI)[col];
-	/* memory cleanup */
-	G_free(inrast_ELEV);
-	G_free(inrast_DIST);
-	G_free(inrast_HINI);
+    /* memory cleanup */
+    G_free(inrast_ELEV);
+    G_free(inrast_DIST);
+    G_free(inrast_HINI);
-	/* closing raster map */
-	Rast_close(infd_ELEV);
-	Rast_close(infd_DIST);
-	Rast_close(infd_HINI);
+    /* closing raster map */
+    Rast_close(infd_ELEV);
+    Rast_close(infd_DIST);
+    Rast_close(infd_HINI);
-	/* earth pressure coefficient */
-	k_act = (1 - sin((M_PI * IFRICT) / 180.0))
-			/ (1 + sin((M_PI * IFRICT) / 180.0));
+    /* earth pressure coefficient */
+    k_act = (1 - sin((M_PI * IFRICT) / 180.0))
+	/ (1 + sin((M_PI * IFRICT) / 180.0));
-	k_pas = (1 + sin((M_PI * IFRICT) / 180.0))
-			/ (1 - sin((M_PI * IFRICT) / 180.0));
+    k_pas = (1 + sin((M_PI * IFRICT) / 180.0))
+	/ (1 - sin((M_PI * IFRICT) / 180.0));
-	G_debug(1,"K_pas value = %f",k_pas);
-	G_debug(1,"K_act value = %f",k_act);
+    G_debug(1, "K_pas value = %f", k_pas);
+    G_debug(1, "K_act value = %f", k_act);
-	/* matrix initialisation */
+    /* matrix initialisation */
-	#pragma omp parallel for private (row,col)
+#pragma omp parallel for private (row,col)
-			m_H[row][col] = 0;
-			m_Hloop[row][col] = 0;
-			m_Hloop_dt[row][col] = 0;
-			m_U[row][col] = 0;
-			m_Uloop[row][col] = 0;
-			m_Uloop_dt[row][col] = 0;
-			m_V[row][col] = 0;
-			m_Vloop[row][col] = 0;
-			m_Vloop_dt[row][col] = 0;
-			m_K[row][col] = nullo;
-			m_gx[row][col] = nullo;
-			m_ca_gx[row][col] = nullo;
-			m_gy[row][col] = nullo;
-			m_ca_gy[row][col] = nullo;
-			m_slope[row][col] = nullo;
-			m_HUloop[row][col] = 0;
-			m_HVloop[row][col] = 0;
+	    m_H[row][col] = 0;
+	    m_Hloop[row][col] = 0;
+	    m_Hloop_dt[row][col] = 0;
+	    m_U[row][col] = 0;
+	    m_Uloop[row][col] = 0;
+	    m_Uloop_dt[row][col] = 0;
+	    m_V[row][col] = 0;
+	    m_Vloop[row][col] = 0;
+	    m_Vloop_dt[row][col] = 0;
+	    m_K[row][col] = nullo;
+	    m_gx[row][col] = nullo;
+	    m_ca_gx[row][col] = nullo;
+	    m_gy[row][col] = nullo;
+	    m_ca_gy[row][col] = nullo;
+	    m_slope[row][col] = nullo;
+	    m_HUloop[row][col] = 0;
+	    m_HVloop[row][col] = 0;
-			if (row==0 || row==1 || col==0 || col==1 || row==nrows-1 || col==ncols-1 || row==nrows-2 || col==ncols-2)
-				m_OUTLET[row][col]=1;
-			else
-				m_OUTLET[row][col]=0;
+	    if (row == 0 || row == 1 || col == 0 || col == 1 ||
+		row == nrows - 1 || col == ncols - 1 || row == nrows - 2 ||
+		col == ncols - 2)
+		m_OUTLET[row][col] = 1;
+	    else
+		m_OUTLET[row][col] = 0;
-				m_Hold[row][col] = 0;
+		m_Hold[row][col] = 0;
-	if (result_HMAX){
-				m_Hmax[row][col] = 0;
+		m_Hmax[row][col] = 0;
-	if (result_VMAX){
-				m_Vmax[row][col] = 0;
+		m_Vmax[row][col] = 0;
-   /* Calculation of slope matrix */
+    /* Calculation of slope matrix */
-    #pragma omp parallel for private (row,col,gx,gy,slope)
+#pragma omp parallel for private (row,col,gx,gy,slope)
+    for (row = 1; row < nrows - 1; row++) {
+	for (col = 1; col < ncols - 1; col++) {
+	    gx = gradx2(m_ELEV, row, col, res_ew, 0);
+	    gy = grady2(m_ELEV, row, col, res_ns, 0);
+	    /* Slope calculation using Horn 3x3 */
+	    slope =
+		sqrt(pow(gradx3(m_ELEV, row, col, res_ew, 0), 2) +
+		     pow(grady3(m_ELEV, row, col, res_ns, 0), 2));
+	    m_gx[row][col] = gx;
+	    m_ca_gx[row][col] = cos(atan(gx));
+	    m_gy[row][col] = gy;
+	    m_ca_gy[row][col] = cos(atan(gy));
+	    m_slope[row][col] = cos(atan(slope));
+    /* Starting loops */
+    int t = 1;
+    int i;
+    int loop, n_loops = 1, dn_loops = 0;
+    int STOP_count = 0;
+    double Vol_in = 0;
+    double Vol_sim = 0;
+    double Vol_out_t = 0;
+    double Vol_in_tot = 0;
+    double Vol_out_tot_corr = 0;
+    double Vol_in_tot_loop = 0;
+    double Vol_out_tot_corr_loop = 0;
+    /* while: for each timestep or until STOP_count<3 */
+    while (STOP_count < 3 && t <= TIMESTEPS) {
+	i = t - 1;
+	double CFL_max = 0;
+	int stable = 0;
-		for (col = 1; col < ncols - 1; col++) {
+		/* H_ini cells completely activated */
+		if (m_HINI[row][col] > 0.0) {
+		    if (t * dT * FLUID >=
+			m_DIST[row][col] + (res_ew + res_ns) / 4) {
+			m_H[row][col] += m_HINI[row][col];
+			Vol_in +=
+			    (m_HINI[row][col] / (m_slope[row][col])) * ca;
+			m_HINI[row][col] = 0;
-			gx = gradx2(m_ELEV, row, col, res_ew, 0);
-			gy = grady2(m_ELEV, row, col, res_ns, 0);
+			/* H_ini cells partially activated */
+		    else if ((t * dT * FLUID <=
+			      m_DIST[row][col] + (res_ew + res_ns) / 4) &&
+			     (t * dT * FLUID >
+			      m_DIST[row][col] - (res_ew + res_ns) / 4)) {
+			m_H[row][col] +=
+			    ((t * dT * FLUID) -
+			     (m_DIST[row][col] -
+			      (res_ew + res_ns) / 4)) / ((res_ew +
+							  res_ns) / 2) *
+			    m_HINI[row][col];
+			Vol_in +=
+			    ((((t * dT * FLUID) -
+							    res_ns) / 2) *
+			      m_HINI[row][col]) / (m_slope[row][col])) * ca;
+			m_HINI[row][col] -=
+							  res_ns) / 2) *
+			    m_HINI[row][col];
-			/* Slope calculation using Horn 3x3 */
-			slope = sqrt(pow(gradx3(m_ELEV, row, col, res_ew, 0), 2) + pow(grady3(m_ELEV, row, col, res_ns, 0), 2));
-			m_gx[row][col] = gx;
-			m_ca_gx[row][col] = cos(atan(gx));
-			m_gy[row][col] = gy;
-			m_ca_gy[row][col] = cos(atan(gy));
-			m_slope[row][col] = cos(atan(slope));
+			/* otherwise continue */
+		    else {
+			continue;
+	    }			/* row */
+	}			/* col */
+	G_debug(1, "\nTIMESTEP %i", t);
+	G_debug(1, "Volume increment = %f", Vol_in);
+	/* ciclo while */
+	while (stable == 0) {
+	    int exit = 0;
+	    n_loops = n_loops + dn_loops;
+	    dn_loops = 0;
+	    G_debug(2, "Updating maps and volumes");
+	    /* Hloop,Vloop e Uloop updating */
+		    m_Hloop[row][col] = m_H[row][col];
+		    m_Uloop[row][col] = m_U[row][col];
+		    m_Vloop[row][col] = m_V[row][col];
+	    /* volumes updating */
+	    Vol_in_tot = Vol_in_tot_loop;
+	    Vol_out_tot_corr = Vol_out_tot_corr_loop;
-	/* Starting loops*/
-	int t=1;
-	int i;
-	int loop, n_loops = 1,dn_loops=0;
-	int STOP_count = 0;
-	double Vol_in=0;
-	double Vol_sim=0;
-	double Vol_out_t=0;
-	double Vol_in_tot=0;
-	double Vol_out_tot_corr=0;
-	double Vol_in_tot_loop=0;
-	double Vol_out_tot_corr_loop=0;
+	    /* for each iteration */
+	    G_debug(1, "\n---NLOOPS=%i---", n_loops);
+	    for (loop = 1; loop <= n_loops && exit == 0; loop++) {
+		G_debug(1, "\n-LOOP=%i", loop);
-	/* while: for each timestep or until STOP_count<3 */
-    while (STOP_count<3 && t<=TIMESTEPS) {
-		i = t - 1;
+		G_debug(2, "Updating K and Kloop matrix");
-		double CFL_max = 0;
-		int stable = 0;
-				/* H_ini cells completely activated */
-				if (m_HINI[row][col] > 0.0){
-					if (t * dT * FLUID >= m_DIST[row][col]+(res_ew+res_ns)/4) {
-						m_H[row][col] += m_HINI[row][col];
-						Vol_in += (m_HINI[row][col]/(m_slope[row][col]))*ca;
-						m_HINI[row][col] = 0;
-				/* H_ini cells partially activated */
-					} else if ( (t * dT * FLUID <= m_DIST[row][col]+(res_ew+res_ns)/4) && (t * dT * FLUID > m_DIST[row][col]-(res_ew+res_ns)/4) ) {
-						m_H[row][col] += ((t * dT * FLUID)-(m_DIST[row][col]-(res_ew+res_ns)/4))/((res_ew+res_ns)/2)*m_HINI[row][col];
-						Vol_in += ((((t * dT * FLUID)-(m_DIST[row][col]-(res_ew+res_ns)/4))/((res_ew+res_ns)/2)*m_HINI[row][col])/(m_slope[row][col]))*ca;
-						m_HINI[row][col] -= ((t * dT * FLUID)-(m_DIST[row][col]-(res_ew+res_ns)/4))/((res_ew+res_ns)/2)*m_HINI[row][col];
+			if ((gradx2(m_Uloop, row, col, res_ew, 0)
+			     + grady2(m_Vloop, row, col, res_ns, 0)) >= 0)
+			    m_K[row][col] = k_act;
+			else
+			    m_K[row][col] = k_pas;
-				/* otherwise continue */
-					} else {
-						continue;
-			} /* row */
-		} /* col */
+			m_Kloop[row][col] = lax(m_K, row, col, laxfactor);
-		G_debug(1,"\nTIMESTEP %i",t);
-		G_debug(1,"Volume increment = %f",Vol_in);
-		/* ciclo while */
-		while (stable==0) {
-			int exit = 0;
-			n_loops = n_loops+dn_loops;
-			dn_loops=0;
+		/* ciclo row-col per calcolare G, P, I, T, Tb */
+		G_debug(2, "Calculating G, P, I, T, Tb");
+#pragma omp parallel for private (row,col,G_x,G_y,I_x,I_y,P_x,P_y,T,vel,T_x,T_y,ddt,Uloop_a,Uloop_b,Vloop_a,Vloop_b,vel_b,T_b,T_x_b,T_y_b,Uloop_dt,Vloop_dt,dt,CFL_u,CFL_v,CFL) shared (dn_loops,CFL_max)
+		    if (exit == 1)
+			continue;
+			if (exit == 1)
+			    continue;
-			G_debug(2,"Updating maps and volumes");
+			/* G_x and G_y calculation */
-			/* Hloop,Vloop e Uloop updating */
-			for (row = 1; row < nrows - 1; row++) {
-					m_Hloop[row][col] = m_H[row][col];
-					m_Uloop[row][col] = m_U[row][col];
-					m_Vloop[row][col] = m_V[row][col];
+			if (m_Hloop[row][col] > verysmall) {
+			    G_x = -grav * (sin(atan(m_gx[row][col])));
+			else {
+			    G_x = 0.0;
-			/* volumes updating */
-			Vol_in_tot = Vol_in_tot_loop;
-			Vol_out_tot_corr = Vol_out_tot_corr_loop;
+			    G_y = -grav * (sin(atan(m_gy[row][col])));
+			else {
+			    G_y = 0.0;
-			/* for each iteration */
-			G_debug(1,"\n---NLOOPS=%i---",n_loops);
-			for (loop = 1; loop <= n_loops && exit == 0; loop++) {
-				G_debug(1,"\n-LOOP=%i",loop);
+			/* I_x and I_y calculation */
-				G_debug(2,"Updating K and Kloop matrix");
+			I_x = -((m_Uloop[row][col] * (m_ca_gx[row][col])
+				 * gradx2(m_Uloop, row, col, res_ew, 1))
+				+ (m_Vloop[row][col] * (m_ca_gy[row][col])
+				   * grady2(m_Uloop, row, col, res_ew, 1)));
-						if ((gradx2(m_Uloop, row, col, res_ew, 0)
-								+ grady2(m_Vloop, row, col, res_ns, 0)) >= 0)
-							m_K[row][col] = k_act;
-						else
-							m_K[row][col] = k_pas;
+			I_y = -((m_Uloop[row][col] * (m_ca_gx[row][col])
+				 * gradx2(m_Vloop, row, col, res_ew, 1))
+				   * grady2(m_Vloop, row, col, res_ns, 1)));
-						m_Kloop[row][col] = lax(m_K, row, col, laxfactor);
+			/* P_x and P_y calculation */
+			    P_x = -m_Kloop[row][col] * m_ca_gx[row][col]
+				* gradPx2(m_Hloop, m_HINI, m_gx, row, col,
+					  res_ew);
+			else {
+			    P_x = 0.0;
-				/* ciclo row-col per calcolare G, P, I, T, Tb */
-				G_debug(2,"Calculating G, P, I, T, Tb");
+			    P_y = -m_Kloop[row][col] * m_ca_gy[row][col]
+				* gradPy2(m_Hloop, m_HINI, m_gy, row, col,
+					  res_ns);
+			else {
+			    P_y = 0.0;
-                #pragma omp parallel for private (row,col,G_x,G_y,I_x,I_y,P_x,P_y,T,vel,T_x,T_y,ddt,Uloop_a,Uloop_b,Vloop_a,Vloop_b,vel_b,T_b,T_x_b,T_y_b,Uloop_dt,Vloop_dt,dt,CFL_u,CFL_v,CFL) shared (dn_loops,CFL_max)
-				    if (exit == 1) continue;
-						/* G_x and G_y calculation */
+			/* T_x and T_y calculation */
-						if (m_Hloop[row][col] > verysmall) {
-							G_x = -grav * (sin(atan(m_gx[row][col])));
-						} else {
-							G_x = 0.0;
+			vel = sqrt(pow(m_Uloop[row][col], 2)
+				   + pow(m_Vloop[row][col], 2));
-							G_y = -grav * (sin(atan(m_gy[row][col])));
-						} else {
-							G_y = 0.0;
+			if (RHEOL_TYPE == 1) {
+			    T = t_frict(m_Hloop, row, col, BFRICT);
+			if (RHEOL_TYPE == 2) {
+			    T = t_voellmy(vel, m_Hloop, row, col, BFRICT,
+					  CHEZY);
-						/* I_x and I_y calculation */
+			if (RHEOL_TYPE == 3) {
+			    T = t_visco(vel, m_Hloop, row, col, BFRICT, RHO,
+					VISCO, YSTRESS);
-						I_x = -((m_Uloop[row][col] * (m_ca_gx[row][col])
-								* gradx2(m_Uloop, row, col, res_ew, 1))
-								+ (m_Vloop[row][col] * (m_ca_gy[row][col])
-										* grady2(m_Uloop, row, col, res_ew, 1)));
+			if (m_Hloop[row][col] > verysmall && vel > verysmall) {
+			    T_x = fabs(m_Uloop[row][col]) / vel * grav
+				* (m_ca_gx[row][col]) * T;
+			    T_y = fabs(m_Vloop[row][col]) / vel * grav
+				* (m_ca_gy[row][col]) * T;
-						I_y = -((m_Uloop[row][col] * (m_ca_gx[row][col])
-								* gradx2(m_Vloop, row, col, res_ew, 1))
-										* grady2(m_Vloop, row, col, res_ns, 1)));
+			else {
+			    T_x = grav * (m_ca_gx[row][col]) * T;
+			    T_y = grav * (m_ca_gy[row][col]) * T;
-						/* P_x and P_y calculation */
+			/* flow estimation at t + ddt */
+			ddt = dTLeap * dT / n_loops;
-							P_x = -m_Kloop[row][col] * m_ca_gx[row][col]
-									* gradPx2(m_Hloop, m_HINI, m_gx, row, col,
-											res_ew);
-						} else {
-							P_x = 0.0;
+			/* if(is_df,lax(Uloop,Vloop),0) */
-							P_y = -m_Kloop[row][col] * m_ca_gy[row][col]
-									* gradPy2(m_Hloop, m_HINI, m_gy, row, col,
-											res_ns);
-						} else {
-							P_y = 0.0;
+			Uloop_a =
+			    filter_lax(m_Uloop, row, col, laxfactor, m_Hloop,
+				       0.01, 0.0);
+			Vloop_a =
+			    filter_lax(m_Vloop, row, col, laxfactor, m_Hloop,
+				       0.01, 0.0);
+			/* U_loop_b and V_loop_b calculation */
-						/* T_x and T_y calculation */
+			Uloop_b = veldt(Uloop_a, ddt, G_x, P_x, I_x, T_x);
+			Vloop_b = veldt(Vloop_a, ddt, G_y, P_y, I_y, T_y);
-						vel = sqrt(
-								pow(m_Uloop[row][col], 2)
-										+ pow(m_Vloop[row][col], 2));
+			/* calculation of T_x_b and T_y_b as function of Uloop_b and Vloop_b */
-						if (RHEOL_TYPE == 1) {
-							T = t_frict(m_Hloop, row, col, BFRICT);
+			vel_b = sqrt(pow(Uloop_b, 2) + pow(Vloop_b, 2));
-						if (RHEOL_TYPE == 2) {
-							T = t_voellmy(vel, m_Hloop, row, col, BFRICT, CHEZY);
-						if (RHEOL_TYPE == 3) {
-							T = t_visco(vel, m_Hloop, row, col, BFRICT, RHO, VISCO,
-									YSTRESS);
+			    T_b = T;
-						if (m_Hloop[row][col] > verysmall && vel > verysmall) {
-							T_x = fabs(m_Uloop[row][col]) / vel * grav
-									* (m_ca_gx[row][col]) * T;
-							T_y = fabs(m_Vloop[row][col]) / vel * grav
-									* (m_ca_gy[row][col]) * T;
+			    T_b = t_voellmy(vel_b, m_Hloop, row, col, BFRICT,
+					    CHEZY);
-						else {
-							T_x = grav * (m_ca_gx[row][col]) * T;
-							T_y = grav * (m_ca_gy[row][col]) * T;
+			    T_b =
+				t_visco(vel_b, m_Hloop, row, col, BFRICT, RHO,
+					VISCO, YSTRESS);
-						/* flow estimation at t + ddt */
-						ddt = dTLeap * dT / n_loops;
+			    vel_b > verysmall) {
+			    T_x_b =
+				fabs(Uloop_b) / vel_b * grav *
+				(m_ca_gx[row][col]) * T_b;
+			    T_y_b =
+				fabs(Vloop_b) / vel_b * grav *
+				(m_ca_gy[row][col]) * T_b;
+			else {
+			    T_x_b = grav * (m_ca_gx[row][col]) * T_b;
+			    T_y_b = grav * (m_ca_gy[row][col]) * T_b;
-						/* if(is_df,lax(Uloop,Vloop),0) */
-						Uloop_a = filter_lax(m_Uloop, row, col, laxfactor, m_Hloop, 0.01, 0.0);
-						Vloop_a = filter_lax(m_Vloop, row, col, laxfactor, m_Hloop, 0.01, 0.0);
+			/* Flow estimation at t + dt */
-						/* U_loop_b and V_loop_b calculation */
+			dt = dT / n_loops;
+			Uloop_dt = veldt(Uloop_a, dt, G_x, P_x, I_x, T_x_b);
+			Vloop_dt = veldt(Vloop_a, dt, G_y, P_y, I_y, T_y_b);
-						Uloop_b = veldt(Uloop_a, ddt, G_x, P_x, I_x, T_x);
-						Vloop_b = veldt(Vloop_a, ddt, G_y, P_y, I_y, T_y);
+			/* Courant-Friedrichs-Levy value calculation */
+			CFL_u = dt * sqrt(2)
+			    * fabs((m_ca_gx[row][col]) * Uloop_dt)
+			    / res_ew;
-						/* calculation of T_x_b and T_y_b as function of Uloop_b and Vloop_b */
+			CFL_v = dt * sqrt(2)
+			    * fabs((m_ca_gy[row][col]) * Vloop_dt)
+			    / res_ns;
-						vel_b = sqrt(pow(Uloop_b, 2) + pow(Vloop_b, 2));
+			CFL = max(CFL_u, CFL_v);
-							T_b = T;
+			if (CFL > CFL_max)
+			    CFL_max = CFL;
-							T_b = t_voellmy(vel_b, m_Hloop, row, col, BFRICT,
-									CHEZY);
+			/*      stability condition */
-							T_b = t_visco(vel_b, m_Hloop, row, col, BFRICT, RHO,
-									VISCO, YSTRESS);
+			if (CFL_max > CFLlimsup && n_loops < MaxNLoops) {
+			    exit = 1;
+			    dn_loops = 1;
+			    //n_loops += 1;
+			    CFL_max = 0;
+			else {
+			    m_Uloop_dt[row][col] = Uloop_dt;
+			    m_Vloop_dt[row][col] = Vloop_dt;
-						if (m_Hloop[row][col] > verysmall && vel_b > verysmall) {
-							T_x_b = fabs(Uloop_b) / vel_b * grav
-									* (m_ca_gx[row][col]) * T_b;
-							T_y_b = fabs(Vloop_b) / vel_b * grav
-									* (m_ca_gy[row][col]) * T_b;
-						} else {
-							T_x_b = grav * (m_ca_gx[row][col]) * T_b;
-							T_y_b = grav * (m_ca_gy[row][col]) * T_b;
+				    m_Hloop[row][col] * Uloop_dt;
+				    m_Hloop[row][col] * Vloop_dt;
+			    else {
+				m_HUloop[row][col] = 0.0;
+				m_HVloop[row][col] = 0.0;
+		    }		/*chiusura FOR cols */
+		}		/*chiusura FOR rows */
+		G_debug(2, "CFL_max=%f", CFL_max);
-						/* Flow estimation at t + dt*/
+		if (exit == 0) {
+		    G_debug(2, "Calculating Hloop_dt without mbe for loop");
-						dt = dT / n_loops;
-						Uloop_dt = veldt(Uloop_a, dt, G_x, P_x, I_x, T_x_b);
-						Vloop_dt = veldt(Vloop_a, dt, G_y, P_y, I_y, T_y_b);
+#pragma omp parallel for private (row,col,dH_dT,Hloop_a,Hloop_dt)
-						/* Courant-Friedrichs-Levy value calculation */
+			    /* dH/dT calculation */
-						CFL_u = dt * sqrt(2)
-								* fabs((m_ca_gx[row][col]) * Uloop_dt)
-								/ res_ew;
+			    dH_dT =
+				-m_ca_gx[row][col] *
+				(shift0
+				 (m_HUloop, row, col, nrows - 1, ncols - 1, 1,
+				  1, 0, -1) - shift0(m_HUloop, row, col,
+						     nrows - 1, ncols - 1, 1,
+						     1, 0,
+						     1)) / (2 * res_ew /
+							    m_ca_gx[row][col])
+				m_ca_gy[row][col] *
+				(shift0
+				 (m_HVloop, row, col, nrows - 1, ncols - 1, 1,
+				  1, 1, 0) - shift0(m_HVloop, row, col,
+						    1, -1,
+						    0)) / (2 * res_ns /
+							   m_ca_gy[row][col]);
-						CFL_v = dt * sqrt(2)
-								* fabs((m_ca_gy[row][col]) * Vloop_dt)
-								/ res_ns;
-						CFL = max(CFL_u,CFL_v);
+			    /* Lax su Hloop e calcolo Hloop_dt (senza mbe) */
+			    if (dH_dT == 0) {
+				Hloop_a = m_Hloop[row][col];
+			    else {
+				Hloop_a =
+				    filter_lax(m_Hloop, row, col, laxfactor,
+					       m_Hloop, 0.01, 0.0);
-						if (CFL > CFL_max)
-							CFL_max = CFL;
+			    Hloop_dt = Hloop_a - dT / n_loops * dH_dT;
-						/*	stability condition */
+			    /* matrice H_loop_dtemp */
+			    if (Hloop_dt > verysmall)
+				m_Hloop_dt[row][col] = Hloop_dt;
+			    else
+				m_Hloop_dt[row][col] = 0.0;
-						if (CFL_max > CFLlimsup && n_loops < MaxNLoops) {
-							exit = 1;
-							dn_loops = 1;
-							//n_loops += 1;
-							CFL_max=0;
-						} else {
-							m_Uloop_dt[row][col] = Uloop_dt;
-							m_Vloop_dt[row][col] = Vloop_dt;
+			}	/*chiusura FOR col */
+		    }		/*chiusura FOR row */
-								m_HUloop[row][col] = m_Hloop[row][col] * Uloop_dt;
-								m_HVloop[row][col] = m_Hloop[row][col] * Vloop_dt;
-							} else {
-								m_HUloop[row][col] = 0.0;
-								m_HVloop[row][col] = 0.0;
-					} /*chiusura FOR cols*/
-				} /*chiusura FOR rows*/
+			    /* Vol_out_t */
+			    if (m_OUTLET[row][col] == 1) {
+				Vol_out_t +=
+				    m_Hloop_dt[row][col] /
+				    (m_slope[row][col]) * ca;
-				G_debug(2,"CFL_max=%f",CFL_max);
+			    /* Vol_sim */
+			    Vol_sim +=
+				(m_Hloop_dt[row][col] / (m_slope[row][col]) *
+				 ca);
-				if (exit==0) {
-					G_debug(2,"Calculating Hloop_dt without mbe for loop");
-                    #pragma omp parallel for private (row,col,dH_dT,Hloop_a,Hloop_dt)
-							/* dH/dT calculation */
-							dH_dT = -m_ca_gx[row][col]* (shift0(m_HUloop,row,col,nrows-1,ncols-1,1,1,0,-1)-shift0(m_HUloop,row,col,nrows-1,ncols-1,1,1,0,1))/(2*res_ew/m_ca_gx[row][col])
-									-m_ca_gy[row][col]* (shift0(m_HVloop,row,col,nrows-1,ncols-1,1,1,1,0)-shift0(m_HVloop,row,col,nrows-1,ncols-1,1,1,-1,0))/(2*res_ns/m_ca_gy[row][col]);
+		    /* m.b.e */
+		    G_debug(2, "Calculating mass balance error");
-							/* Lax su Hloop e calcolo Hloop_dt (senza mbe) */
-							if (dH_dT==0) {
-								Hloop_a=m_Hloop[row][col];
-							} else {
+		    Vol_in_tot += Vol_in / n_loops;
+		    mbe =
+			(Vol_sim + Vol_out_t) / (Vol_in_tot -
+						 Vol_out_tot_corr);
-								Hloop_a = filter_lax(m_Hloop, row, col, laxfactor, m_Hloop, 0.01, 0.0);
-							Hloop_dt = Hloop_a - dT/n_loops * dH_dT;
+		    G_debug(2, "mbe=%f", mbe);
-							/* matrice H_loop_dtemp */
-							if (Hloop_dt> verysmall)
-								m_Hloop_dt[row][col] = Hloop_dt;
-							else
-								m_Hloop_dt[row][col] = 0.0;
-						}/*chiusura FOR col*/
-					}/*chiusura FOR row*/
+		    /* Hloop_dt con mbe */
+		    G_debug(2, "Calculating Hloop_dt with mbe for loop");
+			    if (mbe > 0.01) {
+				    m_Hloop_dt[row][col] / mbe;
+		    /* Setting volumi */
+		    Vol_out_tot_corr += Vol_out_t / mbe;
+		    Vol_sim = 0;
+		    Vol_out_t = 0;
-					        /* Vol_out_t */
-							if (m_OUTLET[row][col]==1){
-								Vol_out_t += m_Hloop_dt[row][col]/(m_slope[row][col])*ca;
-							/* Vol_sim */
-							Vol_sim += (m_Hloop_dt[row][col]/(m_slope[row][col])*ca);
+		    /* loop<n_loops */
+		    if (loop < n_loops) {
+			G_debug(2, "loop<n_loops");
+			    //if(exit==1) continue;
+				m_Hloop[row][col] = m_Hloop_dt[row][col];
+				m_Uloop[row][col] = m_Uloop_dt[row][col];
+				m_Vloop[row][col] = m_Vloop_dt[row][col];
+		}		/* chiusura IF exit */
+	    }			/*chiusura FOR loops */
+	    if (exit == 0) {
+		G_debug(2, "FINISH N_LOOPS");
-					/* m.b.e */
-					G_debug(2,"Calculating mass balance error");
+				/*------Pearson correlation index-------*/
-					Vol_in_tot += Vol_in/n_loops;
-					mbe = (Vol_sim+Vol_out_t)/(Vol_in_tot-Vol_out_tot_corr);
+		    if (t == 1) {
+				m_Hold[row][col] = m_Hloop_dt[row][col];
-					G_debug(2,"mbe=%f",mbe);
+		    if (t % STEP_THRES == 0) {
+			G_debug(1, "Calculating Pearson index for t=%i", t);
+			pears = pearson(m_Hold, m_Hloop_dt, nrows, ncols);
+			G_debug(1, "Pearson=%f", pears);
+			if (pears > STOP_THRES) {
+			    STOP_count = 3;
+			else {
+			    STOP_count = 0;
+		    G_debug(1, "STOP count=%i", STOP_count);
-					/* Hloop_dt con mbe */
-					G_debug(2,"Calculating Hloop_dt with mbe for loop");
-							if (mbe > 0.01){
-								m_Hloop_dt[row][col]=m_Hloop_dt[row][col]/mbe;
+		/* Aggiornamento carte fine timestep */
+			m_H[row][col] = m_Hloop_dt[row][col];
+			m_U[row][col] = m_Uloop_dt[row][col];
+			m_V[row][col] = m_Vloop_dt[row][col];
+			if (STOP_THRES != -1 && t % STEP_THRES == 0) {
-					/* Setting volumi */
-					Vol_out_tot_corr += Vol_out_t/mbe;
-					Vol_sim = 0;
-					Vol_out_t = 0;
+			    if (m_H[row][col] + m_HINI[row][col] >
+				m_Hmax[row][col])
+				    m_H[row][col] + m_HINI[row][col];
-					/* loop<n_loops */
-					if (loop<n_loops) {
-						G_debug(2,"loop<n_loops");
-						    //if(exit==1) continue;
-								m_Hloop[row][col]=m_Hloop_dt[row][col];
-								m_Uloop[row][col]=m_Uloop_dt[row][col];
-								m_Vloop[row][col]=m_Vloop_dt[row][col];
+			    if (m_H[row][col] > verysmall) {
+				if ((sqrt
+				     (pow(m_U[row][col], 2) +
+				      pow(m_V[row][col],
+					  2))) > m_Vmax[row][col]) {
+					(sqrt
+					  pow(m_V[row][col], 2)));
-				}/* chiusura IF exit*/
+		stable = 1;
+		G_debug(1, "Vol_out_tot_corr=%f\n", Vol_out_tot_corr);
-			} /*chiusura FOR loops*/
+		Vol_in_tot_loop = Vol_in_tot;
+		Vol_out_tot_corr_loop = Vol_out_tot_corr;
+		Vol_in = 0.0;
-			if (exit==0) {
-				G_debug(2,"FINISH N_LOOPS");
+		if (CFL_max <= CFLliminf) {
+		    n_loops = max(n_loops - 1, MinNLoops);
-				/*------Pearson correlation index-------*/
-				    if (t==1){
-				                m_Hold[row][col]=m_Hloop_dt[row][col];
-				    if (t%STEP_THRES==0){
-				    	G_debug(1,"Calculating Pearson index for t=%i",t);
-				        pears = pearson(m_Hold,m_Hloop_dt,nrows, ncols);
-				        G_debug(1,"Pearson=%f",pears);
-				        if (pears > STOP_THRES){
-				            STOP_count = 3;
-				        } else {
-				            STOP_count = 0;
-				    G_debug(1,"STOP count=%i",STOP_count);
+		/* Stampa degli output */
-				/* Aggiornamento carte fine timestep*/
-						m_H[row][col]=m_Hloop_dt[row][col];
-						m_U[row][col]=m_Uloop_dt[row][col];
-						m_V[row][col]=m_Vloop_dt[row][col];
-						if (STOP_THRES!=-1 && t%STEP_THRES==0){
+		if ((DELTAT != -1 && t % DELTAT == 0)) {
+		    if (result_H) {
+			sprintf(name1, "%s_t%d", result_H, t);
+			out_sum_print(m_HINI, m_H, m_U, m_V, name1, nrows,
+				      ncols, 1, small);
+			Rast_short_history(name1, "raster", &history);
+			Rast_command_history(&history);
+			Rast_write_history(name1, &history);
+		    if (result_V) {
+			sprintf(name1, "%s_t%d", result_V, t);
+				      ncols, 2, small);
-				if (result_HMAX){
-							if(m_H[row][col]+m_HINI[row][col] > m_Hmax[row][col])
-								m_Hmax[row][col] = m_H[row][col]+m_HINI[row][col];
+		if ((t == TIMESTEPS) || (STOP_count == 3)) {
+		    sprintf(timestr,
+			    "Calculated in %d steps; %0.2f of %0.2f mc gone outbound",
+			    t, Vol_out_tot_corr_loop, Vol_in_tot);
+		    if (result_H) {
+			sprintf(name1, "%s", result_H);
+				      ncols, 1, small);
+			Rast_set_history(&history, HIST_KEYWRD, timestr);
+		    if (result_V) {
+			sprintf(name1, "%s", result_V);
+				      ncols, 2, small);
-				if (result_VMAX){
-							if (m_H[row][col]>verysmall){
-								if ((sqrt(pow(m_U[row][col],2)+pow(m_V[row][col],2)))>m_Vmax[row][col]){
-									m_Vmax[row][col]=(sqrt(pow(m_U[row][col],2)+pow(m_V[row][col],2)));
-				stable=1;
-				G_debug(1,"Vol_out_tot_corr=%f\n",Vol_out_tot_corr);
-				Vol_in_tot_loop = Vol_in_tot;
-				Vol_out_tot_corr_loop = Vol_out_tot_corr;
-				Vol_in = 0.0;
-				if (CFL_max<=CFLliminf) {
-					n_loops=max(n_loops-1,MinNLoops);
+		if ((result_HMAX) && ((t == TIMESTEPS) || (STOP_count == 3))) {
+		    sprintf(name1, "%s", result_HMAX);
+		    out_print(m_Hmax, name1, nrows, ncols, small);
+		if ((result_VMAX) && ((t == TIMESTEPS) || (STOP_count == 3))) {
+		    sprintf(name1, "%s", result_VMAX);
+		    out_print(m_Vmax, name1, nrows, ncols, small);
-                /* Stampa degli output*/
-				if((DELTAT!=-1 && t%DELTAT==0)){
-					if(result_H){
-						sprintf(name1,"%s_t%d",result_H,t);
-						out_sum_print(m_HINI,m_H,m_U,m_V,name1,nrows,ncols,1,small);
-						Rast_short_history(name1, "raster", &history);
-						Rast_command_history(&history);
-						Rast_write_history(name1, &history);
-					if(result_V){
-						sprintf(name1,"%s_t%d",result_V,t);
-						out_sum_print(m_HINI,m_H,m_U,m_V,name1,nrows,ncols,2,small);
-				if((t==TIMESTEPS) || (STOP_count==3)){
-                    sprintf(timestr,"Calculated in %d steps; %0.2f of %0.2f mc gone outbound",t,Vol_out_tot_corr_loop,Vol_in_tot);
-					if(result_H){
-						sprintf(name1,"%s",result_H);
-						Rast_set_history(&history, HIST_KEYWRD, timestr);
-					if(result_V){
-						sprintf(name1,"%s",result_V);
+	    }			/*chiusura IF exit */
+	}			/*chiusura WHILE */
+	t++;
+    }				/* chiusura WHILE STOP_count */
-				if((result_HMAX) && ((t==TIMESTEPS) || (STOP_count==3))){
-					sprintf(name1,"%s",result_HMAX);
-					out_print(m_Hmax,name1,nrows,ncols,small);
-				if((result_VMAX) && ((t==TIMESTEPS) || (STOP_count==3))){
-					sprintf(name1,"%s",result_VMAX);
-					out_print(m_Vmax,name1,nrows,ncols,small);
-			} /*chiusura IF exit*/
-		} /*chiusura WHILE*/
-		t++;
-	} /* chiusura WHILE STOP_count*/
+    if (Vol_out_tot_corr_loop > 0) {
+	G_warning
+	    ("The flow run out of the current computational domain. You may need to change the region extension.\nSee raster metadata (r.info) for more information.");
-	if (Vol_out_tot_corr_loop>0){
-		G_warning("The flow run out of the current computational domain. You may need to change the region extension.\nSee raster metadata (r.info) for more information.");
+    /* deallocate memory matrix */
+    G_free_matrix(m_ELEV);
+    G_free_imatrix(m_OUTLET);
+    G_free_matrix(m_DIST);
+    G_free_matrix(m_HINI);
+    G_free_matrix(m_gx);
+    G_free_matrix(m_ca_gx);
+    G_free_matrix(m_gy);
+    G_free_matrix(m_ca_gy);
+    G_free_matrix(m_slope);
+    G_free_matrix(m_H);
+    G_free_matrix(m_Hloop);
+    G_free_matrix(m_Hloop_dt);
+    G_free_matrix(m_U);
+    G_free_matrix(m_Uloop);
+    G_free_matrix(m_Uloop_dt);
+    G_free_matrix(m_V);
+    G_free_matrix(m_Vloop);
+    G_free_matrix(m_Vloop_dt);
+    G_free_matrix(m_K);
+    G_free_matrix(m_Kloop);
+    G_free_matrix(m_HUloop);
+    G_free_matrix(m_HVloop);
+	G_free_matrix(m_Hold);
-	/* deallocate memory matrix */
-	G_free_matrix(m_ELEV);
-	G_free_imatrix(m_OUTLET);
-	G_free_matrix(m_DIST);
-	G_free_matrix(m_HINI);
-	G_free_matrix(m_gx);
-	G_free_matrix(m_ca_gx);
-	G_free_matrix(m_gy);
-	G_free_matrix(m_ca_gy);
-	G_free_matrix(m_slope);
-	G_free_matrix(m_H);
-	G_free_matrix(m_Hloop);
-	G_free_matrix(m_Hloop_dt);
-	G_free_matrix(m_U);
-	G_free_matrix(m_Uloop);
-	G_free_matrix(m_Uloop_dt);
-	G_free_matrix(m_V);
-	G_free_matrix(m_Vloop);
-	G_free_matrix(m_Vloop_dt);
-	G_free_matrix(m_K);
-	G_free_matrix(m_Kloop);
-	G_free_matrix(m_HUloop);
-	G_free_matrix(m_HVloop);
+    if (result_VMAX)
+	G_free_matrix(m_Vmax);
-		G_free_matrix(m_Hold);
+    if (result_HMAX)
+	G_free_matrix(m_Hmax);
-	if (result_VMAX)
-		G_free_matrix(m_Vmax);
-	if (result_HMAX)
-		G_free_matrix(m_Hmax);
-	exit(EXIT_SUCCESS);
+    exit(EXIT_SUCCESS);
