[GRASS-SVN] r64214 - in grass/trunk: include/defs lib/vector/Vlib
Fri Jan 16 03:09:54 PST 2015
Author: mmetz
Date: 2015-01-16 03:09:54 -0800 (Fri, 16 Jan 2015)
New Revision: 64214
   grass/trunk/include/defs/vector.h
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
   grass/trunk/lib/vector/Vlib/write_pg.c
   grass/trunk/lib/vector/Vlib/write_sfa.c
Vlib: fix vector IO, enable level 1 fns
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/include/defs/vector.h	2015-01-16 11:09:54 UTC (rev 64214)
@@ -253,16 +253,16 @@
                         struct line_cats *);
 off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
                       const struct line_cats *);
+off_t Vect_rewrite_line(struct Map_info *, off_t, int, const struct line_pnts *,
+                      const struct line_cats *);
+int Vect_delete_line(struct Map_info *, off_t);
+int Vect_restore_line(struct Map_info *, off_t);
 int Vect_get_num_dblinks(const struct Map_info *);
 /* Level 2 only */
 int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
                    int);
-off_t Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
-                      const struct line_cats *);
-int Vect_delete_line(struct Map_info *, int);
-int Vect_restore_line(struct Map_info *, int, off_t);
 int Vect_line_alive(const struct Map_info *, int);
 int Vect_node_alive(const struct Map_info *, int);
@@ -554,7 +554,7 @@
 int V2_delete_line_sfa(struct Map_info *, int);
 int V2_delete_line_pg(struct Map_info *, int);
 int V1_restore_line_nat(struct Map_info *, off_t);
-int V2_restore_line_nat(struct Map_info *, int, off_t);
+int V2_restore_line_nat(struct Map_info *, int);
 off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
 off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
@@ -567,17 +567,17 @@
 off_t V2_write_line_pg(struct Map_info *, int, const struct line_pnts *,
-off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
                           const struct line_pnts *, const struct line_cats *);
-off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
-off_t V1_rewrite_line_pg(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_pg(struct Map_info *, off_t, int,
-off_t V2_rewrite_line_nat(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_nat(struct Map_info *, int, int,
-off_t V2_rewrite_line_sfa(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_sfa(struct Map_info *, int, int,
-off_t V2_rewrite_line_pg(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_pg(struct Map_info *, int, int,
     /* Build topology */
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/lib/vector/Vlib/write.c	2015-01-16 11:09:54 UTC (rev 64214)
@@ -135,7 +135,7 @@
 static int (*Vect_restore_line_array[][3]) () = {
-    restore_dummy, restore_dummy, V2_restore_line_nat}
+    restore_dummy, V1_restore_line_nat, V2_restore_line_nat}
 #ifdef HAVE_OGR
 	restore_dummy, restore_dummy, restore_dummy}
@@ -183,21 +183,16 @@
     G_debug(3, "Vect_write_line(): name = %s, format = %d, level = %d",
 	    Map->name, Map->format, Map->level);
-    if (!VECT_OPEN(Map)) {
-	G_warning(_("Vector map <%s> is not opened"), Vect_get_name(Map));
+    if (!check_map(Map))
         return -1;
-    if (!(Map->plus.update_cidx)) {
-	Map->plus.cidx_up_to_date = FALSE; /* category index will be outdated */
     offset =
-	(*Vect_write_line_array[Map->format][Map->level]) (Map, type, points,
-							   cats);
+	(*Vect_write_line_array[Map->format][Map->level]) (Map, type,
+							   points, cats);
     if (offset < 0)
-	G_warning(_("Unable to write feature in vector map <%s>"), Vect_get_name(Map));
+	G_warning(_("Unable to write feature in vector map <%s>"),
+	          Vect_get_name(Map));
     return offset;
@@ -213,41 +208,31 @@
    old feature is deleted and new is written.
    \param Map pointer to Map_info structure
-   \param line feature id
+   \param line feature id (level 2) or feature offset (level 1)
    \param type feature type (GV_POINT, GV_LINE, ...)
    \param points feature geometry
    \param cats feature categories
-   \return new feature offset
+   \return new feature id (on level 2) (or 0 when build level < GV_BUILD_BASE)
+   \return offset into file where the feature starts (on level 1)
    \return -1 on error
-off_t Vect_rewrite_line(struct Map_info *Map, int line, int type,
+off_t Vect_rewrite_line(struct Map_info *Map, off_t line, int type,
 			const struct line_pnts *points, const struct line_cats *cats)
-    off_t ret, offset;
+    off_t ret;
+    G_debug(3, "Vect_rewrite_line(): name = %s, format = %d, level = %d, line/offset = %"PRI_OFF_T,
+	    Map->name, Map->format, Map->level, line);
         return -1;
-    if (line < 1 || line > Map->plus.n_lines) {
-        G_warning(_("Attempt to access feature with invalid id (%d)"), line);
-        return -1;
-    offset = Map->plus.Line[line]->offset;
-    G_debug(3, "Vect_rewrite_line(): name = %s, line = %d, offset = %lu",
-	    Map->name, line, offset);
     ret = (*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type,
-							       offset,
 							       points, cats);
     if (ret == -1)
-        G_warning(_("Unable to rewrite feature %d in vector map <%s>"), line, Vect_get_name(Map));
+        G_warning(_("Unable to rewrite feature/offset %lu in vector map <%s>"),
+	          line, Vect_get_name(Map));
     return ret;
@@ -260,33 +245,25 @@
    A warning is printed on error.
    \return 0 on success
    \return -1 on error
-int Vect_delete_line(struct Map_info *Map, int line)
+int Vect_delete_line(struct Map_info *Map, off_t line)
     int ret;
-    G_debug(3, "Vect_delete_line(): name = %s, line = %d", Map->name, line);
+    G_debug(3, "Vect_delete_line(): name = %s, line/offset = %"PRI_OFF_T,
+            Map->name, line);
         return -1;
-        return -1;
     ret = (*Vect_delete_line_array[Map->format][Map->level]) (Map, line);
     if (ret == -1)
-	G_warning(_("Unable to delete feature %d from vector map <%s>"),
+	G_warning(_("Unable to delete feature/offset %lu from vector map <%s>"),
     return ret;
@@ -306,28 +283,20 @@
    \return -1 on error
-int Vect_restore_line(struct Map_info *Map, int line, off_t offset)
+int Vect_restore_line(struct Map_info *Map, off_t line)
     int ret;
-    G_debug(3, "Vect_restore_line(): name = %s, line = %d", Map->name, line);
+    G_debug(3, "Vect_restore_line(): name = %s,level = %d, line/offset = %"PRI_OFF_T,
+            Map->name, Map->level, line);
         return -1;
-        return -1;
+    ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line);
-	Map->plus.cidx_up_to_date = 0;
-    ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line, offset);
     if (ret == -1)
-	G_warning(_("Unable to restore feature %d in vector map <%s>"),
+	G_warning(_("Unable to restore feature/offset %lu in vector map <%s>"),
     return ret;
@@ -339,12 +308,6 @@
         return 0;
-    if (Map->level < 2) {
-	G_warning(_("Vector map <%s> is not opened on topology level"),
-                  Vect_get_name(Map));
-        return 0;
     if (Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE) {
 	G_warning(_("Vector map <%s> is not opened in write mode"),
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2015-01-16 11:09:54 UTC (rev 64214)
@@ -67,7 +67,10 @@
     off_t offset;
     G_debug(3, "V2_write_line_nat(): type=%d", type);
+    if (!(Map->plus.update_cidx)) {
+	Map->plus.cidx_up_to_date = FALSE; /* category index will be outdated */
     /* write feature to 'coor' file */
     offset = V1_write_line_nat(Map, type, points, cats);
     if (offset < 0)
@@ -87,25 +90,24 @@
   Old feature is deleted (marked as dead), and a new feature written.
-  \param line feature id to be rewritten
   \param offset feature offset
-  \return feature offset (rewriten feature)
+  \return feature offset (rewritten feature)
   \return -1 on error
-off_t V1_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t offset,
+off_t V1_rewrite_line_nat(struct Map_info *Map, off_t offset, int type,
     int old_type;
     static struct line_pnts *old_points = NULL;
     static struct line_cats *old_cats = NULL;
-    G_debug(3, "V1_rewrite_line_nat(): line = %d offset = %lu",
-	    line, (unsigned long) offset);
+    G_debug(3, "V1_rewrite_line_nat(): offset = %"PRI_OFF_T,
+	    offset);
     /* First compare numbers of points and cats with tha old one */
     if (!old_points) {
 	old_points = Vect_new_line_struct();
@@ -137,7 +139,7 @@
   \brief Rewrites feature to 'coor' file at topological level (internal use only)
-  Note: Topology must be built at level >= GV_BUILD_BASE
+  Note: requires topology level >= GV_BUILD_BASE.
   Note: Function returns feature id, but is defined as off_t for
   compatibility with level 1 functions.
@@ -149,10 +151,10 @@
-  \return new feature id
+  \return new feature id or 0 (build level < GV_BUILD_BASE)
   \return -1 on error
-off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t old_offset,
+off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type,
     /* TODO: this is just quick shortcut because we have already V2_delete_nat()
@@ -162,7 +164,7 @@
      *        angles not changed etc.) */
     int old_type;
-    off_t offset;
+    off_t offset, old_offset;
     struct Plus_head *plus;
@@ -177,6 +179,17 @@
 	return V2_write_line_nat(Map, type, points, cats);
+    if (line < 1 || line > plus->n_lines) {
+        G_warning(_("Attempt to access feature with invalid id (%d)"), line);
+        return -1;
+    if (!(plus->update_cidx)) {
+	plus->cidx_up_to_date = FALSE; /* category index will be outdated */
+    old_offset = plus->Line[line]->offset;
     /* read the line */
     if (!old_points) {
@@ -229,7 +242,7 @@
     char rhead;
     struct gvfile *dig_fp;
-    G_debug(3, "V1_delete_line_nat(): offset = %lu", (unsigned long) offset);
+    G_debug(3, "V1_delete_line_nat(): offset = %"PRI_OFF_T, offset);
     dig_set_cur_port(&(Map->head.port));
     dig_fp = &(Map->dig_fp);
@@ -258,7 +271,7 @@
   \brief Deletes feature at topological level (internal use only)
   \param pointer to Map_info structure
@@ -283,23 +296,26 @@
         return -1;
     Line = Map->plus.Line[line];
     if (Line == NULL) {
         G_warning(_("Attempt to access dead feature %d"), line);
         return -1;
     /* read the line */
     if (!Points) {
 	Points = Vect_new_line_struct();
-    if (!Cats) {
 	Cats = Vect_new_cats_struct();
     type = V2_read_line_nat(Map, Points, Cats, line);
-    if (type < 0)
-        return -1;
+    if (type <= 0)
+	return -1;
     /* delete feature from coor file */
     if (0 != V1_delete_line_nat(Map, Line->offset))
@@ -326,7 +342,7 @@
     char rhead;
-    G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
+    G_debug(3, "V1_restore_line_nat(), offset = %"PRI_OFF_T, offset);
@@ -357,18 +373,18 @@
   \brief Restores feature at topological level (internal use only)
-  Note: This function requires build level >= GV_BUILD_BASE.
-  \param offset feature offset
   \return -1 on error
-int V2_restore_line_nat(struct Map_info *Map, int line, off_t offset)
+int V2_restore_line_nat(struct Map_info *Map, int line)
     int type;
+    off_t offset;
     struct P_line *Line;
     static struct line_cats *Cats = NULL;
@@ -388,6 +404,12 @@
         G_warning(_("Attempt to access alive feature %d"), line);
         return -1;
+	plus->cidx_up_to_date = 0;
+    offset = Line->offset;
     /* restore feature in 'coor' file */
     if (0 != V1_restore_line_nat(Map, offset))
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2015-01-16 11:09:54 UTC (rev 64214)
@@ -86,11 +86,11 @@
   \return -1 on error
 off_t V1_rewrite_line_ogr(struct Map_info *Map,
-			  int line, int type, off_t offset,
+			  off_t offset, int type,
-    G_debug(3, "V1_rewrite_line_ogr(): line=%d type=%d offset=%"PRI_OFF_T,
-	    line, type, offset);
+    G_debug(3, "V1_rewrite_line_ogr(): type=%d offset=%"PRI_OFF_T,
+	    type, offset);
 #ifdef HAVE_OGR
     if (type != V1_read_line_ogr(Map, NULL, NULL, offset)) {
 	G_warning(_("Unable to rewrite feature (incompatible feature types)"));
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2015-01-16 11:09:54 UTC (rev 64214)
@@ -176,12 +176,12 @@
    \return -1 on error
 off_t V1_rewrite_line_pg(struct Map_info * Map,
                          const struct line_pnts * points,
                          const struct line_cats * cats)
-    G_debug(3, "V1_rewrite_line_pg(): line=%d type=%d offset=%"PRI_OFF_T,
+    G_debug(3, "V1_rewrite_line_pg(): type=%d offset=%"PRI_OFF_T,
+            type, offset);
 #ifdef HAVE_POSTGRES
     if (type != V1_read_line_pg(Map, NULL, NULL, offset)) {
@@ -215,18 +215,19 @@
   \return offset where feature was rewritten
   \return -1 on error
-off_t V2_rewrite_line_pg(struct Map_info *Map, int line, int type, off_t old_offset,
+off_t V2_rewrite_line_pg(struct Map_info *Map, int line, int type,
-    G_debug(3, "V2_rewrite_line_pg(): line=%d type=%d offset=%"PRI_OFF_T,
-            line, type, old_offset);
+    G_debug(3, "V2_rewrite_line_pg(): line=%d type=%d",
+            line, type);
     const char *schema_name, *table_name, *keycolumn;
     char *stmt, *geom_data;
     struct Format_info_pg *pg_info;
+    off_t offset;
     geom_data = NULL;
     stmt = NULL;
     pg_info = &(Map->fInfo.pg);
@@ -241,7 +242,12 @@
         return -1;
     if (!Points)
@@ -283,7 +289,7 @@
     /* update topology
        note: offset is not changed */
-    return add_line_to_topo_pg(Map, old_offset, type, points);
+    return add_line_to_topo_pg(Map, offset, type, points);
 #else
     G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
     return -1;
@@ -396,7 +402,11 @@
             return -1;
         Vect__execute_pg(pg_info->conn, "BEGIN");
         if (Line->type & GV_POINTS) {
@@ -1338,7 +1348,11 @@
     plus = &(Map->plus);
     /* check type for nodes */
     if (is_node && type != GV_POINT) {
         G_warning(_("Invalid feature type (%d) for nodes"), type);
@@ -2732,7 +2746,7 @@
   \brief Add line to native and PostGIS topology
   \param Map vector map
-  \param line feature id to remove from topo
+  \param offset ???
   \param Points feature vertices
Modified: grass/trunk/lib/vector/Vlib/write_sfa.c
--- grass/trunk/lib/vector/Vlib/write_sfa.c	2015-01-16 10:56:51 UTC (rev 64213)
+++ grass/trunk/lib/vector/Vlib/write_sfa.c	2015-01-16 11:09:54 UTC (rev 64214)
@@ -72,7 +72,11 @@
     if (offset < 0)
 	return -1;
     /* Update topology */
     if (plus->built >= GV_BUILD_BASE) {
 	dig_line_box(points, &box);
@@ -145,11 +149,11 @@
   \return offset where line was rewritten
   \return -1 on error
-off_t V2_rewrite_line_sfa(struct Map_info *Map, int line, int type, off_t offset,
+off_t V2_rewrite_line_sfa(struct Map_info *Map, int line, int type,
-    G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d offset=%"PRI_OFF_T,
+    G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d",
+	    line, type);
@@ -205,6 +209,10 @@
         return -1;
