[GRASS-SVN] r64215 - in grass/branches/releasebranch_7_0: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Fri Jan 16 03:10:09 PST 2015
Author: mmetz
Date: 2015-01-16 03:10:08 -0800 (Fri, 16 Jan 2015)
New Revision: 64215
grass/branches/releasebranch_7_0/include/defs/vector.h
grass/branches/releasebranch_7_0/lib/vector/Vlib/write.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_nat.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_ogr.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
grass/branches/releasebranch_7_0/lib/vector/Vlib/write_sfa.c
Vlib: fix vector IO, enable level 1 fns
Modified: grass/branches/releasebranch_7_0/include/defs/vector.h
--- grass/branches/releasebranch_7_0/include/defs/vector.h 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/include/defs/vector.h 2015-01-16 11:10:08 UTC (rev 64215)
@@ -253,16 +253,16 @@
struct line_cats *);
off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
const struct line_cats *);
+off_t Vect_rewrite_line(struct Map_info *, off_t, int, const struct line_pnts *,
+ const struct line_cats *);
+int Vect_delete_line(struct Map_info *, off_t);
+int Vect_restore_line(struct Map_info *, off_t);
int Vect_get_num_dblinks(const struct Map_info *);
/* Level 2 only */
int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
int);
-off_t Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
- const struct line_cats *);
-int Vect_delete_line(struct Map_info *, int);
-int Vect_restore_line(struct Map_info *, int, off_t);
int Vect_line_alive(const struct Map_info *, int);
int Vect_node_alive(const struct Map_info *, int);
@@ -543,7 +543,7 @@
int V2_delete_line_sfa(struct Map_info *, int);
int V2_delete_line_pg(struct Map_info *, int);
int V1_restore_line_nat(struct Map_info *, off_t);
-int V2_restore_line_nat(struct Map_info *, int, off_t);
+int V2_restore_line_nat(struct Map_info *, int);
off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
@@ -556,17 +556,17 @@
off_t V2_write_line_pg(struct Map_info *, int, const struct line_pnts *,
-off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
const struct line_pnts *, const struct line_cats *);
-off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_ogr(struct Map_info *, off_t, int,
-off_t V1_rewrite_line_pg(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_pg(struct Map_info *, off_t, int,
-off_t V2_rewrite_line_nat(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_nat(struct Map_info *, int, int,
-off_t V2_rewrite_line_sfa(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_sfa(struct Map_info *, int, int,
-off_t V2_rewrite_line_pg(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_pg(struct Map_info *, int, int,
/* Build topology */
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write.c 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write.c 2015-01-16 11:10:08 UTC (rev 64215)
@@ -135,7 +135,7 @@
static int (*Vect_restore_line_array[][3]) () = {
- restore_dummy, restore_dummy, V2_restore_line_nat}
+ restore_dummy, V1_restore_line_nat, V2_restore_line_nat}
#ifdef HAVE_OGR
restore_dummy, restore_dummy, restore_dummy}
@@ -183,21 +183,16 @@
G_debug(3, "Vect_write_line(): name = %s, format = %d, level = %d",
Map->name, Map->format, Map->level);
- if (!VECT_OPEN(Map)) {
- G_warning(_("Vector map <%s> is not opened"), Vect_get_name(Map));
+ if (!check_map(Map))
return -1;
- if (!(Map->plus.update_cidx)) {
- Map->plus.cidx_up_to_date = FALSE; /* category index will be outdated */
offset =
- (*Vect_write_line_array[Map->format][Map->level]) (Map, type, points,
- cats);
+ (*Vect_write_line_array[Map->format][Map->level]) (Map, type,
+ points, cats);
if (offset < 0)
- G_warning(_("Unable to write feature in vector map <%s>"), Vect_get_name(Map));
+ G_warning(_("Unable to write feature in vector map <%s>"),
+ Vect_get_name(Map));
return offset;
@@ -213,41 +208,31 @@
old feature is deleted and new is written.
\param Map pointer to Map_info structure
- \param line feature id
+ \param line feature id (level 2) or feature offset (level 1)
\param type feature type (GV_POINT, GV_LINE, ...)
\param points feature geometry
\param cats feature categories
- \return new feature offset
+ \return new feature id (on level 2) (or 0 when build level < GV_BUILD_BASE)
+ \return offset into file where the feature starts (on level 1)
\return -1 on error
-off_t Vect_rewrite_line(struct Map_info *Map, int line, int type,
+off_t Vect_rewrite_line(struct Map_info *Map, off_t line, int type,
const struct line_pnts *points, const struct line_cats *cats)
- off_t ret, offset;
+ off_t ret;
+ G_debug(3, "Vect_rewrite_line(): name = %s, format = %d, level = %d, line/offset = %"PRI_OFF_T,
+ Map->name, Map->format, Map->level, line);
return -1;
- if (line < 1 || line > Map->plus.n_lines) {
- G_warning(_("Attempt to access feature with invalid id (%d)"), line);
- return -1;
- offset = Map->plus.Line[line]->offset;
- G_debug(3, "Vect_rewrite_line(): name = %s, line = %d, offset = %lu",
- Map->name, line, offset);
ret = (*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type,
- offset,
points, cats);
if (ret == -1)
- G_warning(_("Unable to rewrite feature %d in vector map <%s>"), line, Vect_get_name(Map));
+ G_warning(_("Unable to rewrite feature/offset %lu in vector map <%s>"),
+ line, Vect_get_name(Map));
return ret;
@@ -260,33 +245,25 @@
A warning is printed on error.
\return 0 on success
\return -1 on error
-int Vect_delete_line(struct Map_info *Map, int line)
+int Vect_delete_line(struct Map_info *Map, off_t line)
int ret;
- G_debug(3, "Vect_delete_line(): name = %s, line = %d", Map->name, line);
+ G_debug(3, "Vect_delete_line(): name = %s, line/offset = %"PRI_OFF_T,
+ Map->name, line);
return -1;
- return -1;
ret = (*Vect_delete_line_array[Map->format][Map->level]) (Map, line);
if (ret == -1)
- G_warning(_("Unable to delete feature %d from vector map <%s>"),
+ G_warning(_("Unable to delete feature/offset %lu from vector map <%s>"),
return ret;
@@ -306,28 +283,20 @@
\return -1 on error
-int Vect_restore_line(struct Map_info *Map, int line, off_t offset)
+int Vect_restore_line(struct Map_info *Map, off_t line)
int ret;
- G_debug(3, "Vect_restore_line(): name = %s, line = %d", Map->name, line);
+ G_debug(3, "Vect_restore_line(): name = %s,level = %d, line/offset = %"PRI_OFF_T,
+ Map->name, Map->level, line);
return -1;
- return -1;
+ ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line);
- Map->plus.cidx_up_to_date = 0;
- ret = (*Vect_restore_line_array[Map->format][Map->level]) (Map, line, offset);
if (ret == -1)
- G_warning(_("Unable to restore feature %d in vector map <%s>"),
+ G_warning(_("Unable to restore feature/offset %lu in vector map <%s>"),
return ret;
@@ -339,12 +308,6 @@
return 0;
- if (Map->level < 2) {
- G_warning(_("Vector map <%s> is not opened on topology level"),
- Vect_get_name(Map));
- return 0;
if (Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE) {
G_warning(_("Vector map <%s> is not opened in write mode"),
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_nat.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_nat.c 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_nat.c 2015-01-16 11:10:08 UTC (rev 64215)
@@ -24,10 +24,7 @@
#include "local_proto.h"
-static struct line_cats *Cats;
-static struct line_pnts *Points;
-static off_t V1__rewrite_line_nat(struct Map_info *, off_t, int,
+static off_t V1__write_line_nat(struct Map_info *, off_t, int,
static void V2__delete_area_cats_from_cidx_nat(struct Map_info *, int);
static void V2__add_area_cats_to_cidx_nat(struct Map_info *, int);
@@ -46,17 +43,7 @@
off_t V1_write_line_nat(struct Map_info *Map, int type,
- off_t offset;
- if (dig_fseek(&(Map->dig_fp), 0L, SEEK_END) == -1) /* set to end of file */
- return -1;
- offset = dig_ftell(&(Map->dig_fp));
- G_debug(3, "V1_write_line_nat(): offset = %lu", offset);
- if (offset == -1)
- return -1;
- return V1__rewrite_line_nat(Map, offset, type, points, cats);
+ return V1__write_line_nat(Map, -1, type, points, cats);
@@ -80,7 +67,10 @@
off_t offset;
G_debug(3, "V2_write_line_nat(): type=%d", type);
+ if (!(Map->plus.update_cidx)) {
+ Map->plus.cidx_up_to_date = FALSE; /* category index will be outdated */
/* write feature to 'coor' file */
offset = V1_write_line_nat(Map, type, points, cats);
if (offset < 0)
@@ -100,27 +90,23 @@
Old feature is deleted (marked as dead), and a new feature written.
- \param line feature id to be rewritten
\param offset feature offset
- \return feature offset (rewriten feature)
+ \return feature offset (rewritten feature)
\return -1 on error
-off_t V1_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t offset,
+off_t V1_rewrite_line_nat(struct Map_info *Map, off_t offset, int type,
int old_type;
static struct line_pnts *old_points = NULL;
static struct line_cats *old_cats = NULL;
- off_t new_offset;
- G_debug(3, "V1_rewrite_line_nat(): line = %d offset = %lu",
- line, (unsigned long) offset);
- /* TODO: enable points and cats == NULL */
+ G_debug(3, "V1_rewrite_line_nat(): offset = %"PRI_OFF_T,
+ offset);
/* First compare numbers of points and cats with tha old one */
if (!old_points) {
@@ -139,29 +125,21 @@
|| ((type & GV_LINES) && (old_type & GV_LINES)))) {
/* equal -> overwrite the old */
+ return V1__write_line_nat(Map, offset, type, points, cats);
else {
/* differ -> delete the old and append new */
/* delete old */
V1_delete_line_nat(Map, offset);
- /* write new */
- if (dig_fseek(&(Map->dig_fp), 0L, SEEK_END) == -1) /* end of file */
- return -1;
- new_offset = dig_ftell(&(Map->dig_fp));
- if (new_offset == -1)
- return -1;
- return V1__rewrite_line_nat(Map, new_offset, type, points, cats);
\brief Rewrites feature to 'coor' file at topological level (internal use only)
- Note: Topology must be built at level >= GV_BUILD_BASE
+ Note: requires topology level >= GV_BUILD_BASE.
Note: Function returns feature id, but is defined as off_t for
compatibility with level 1 functions.
@@ -173,10 +151,10 @@
- \return new feature id
+ \return new feature id or 0 (build level < GV_BUILD_BASE)
\return -1 on error
-off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type, off_t old_offset,
+off_t V2_rewrite_line_nat(struct Map_info *Map, int line, int type,
/* TODO: this is just quick shortcut because we have already V2_delete_nat()
@@ -185,20 +163,69 @@
* and cats was not changed or topology is not changed (nodes not moved,
* angles not changed etc.) */
- off_t offset;
+ int old_type;
+ off_t offset, old_offset;
+ struct Plus_head *plus;
+ static struct line_cats *old_cats = NULL;
+ static struct line_pnts *old_points = NULL;
- if (0 != V2_delete_line_nat(Map, line))
+ plus = &(Map->plus);
+ if (plus->uplist.do_uplist) {
+ /* list of updated lines: undo needs copy on write */
+ if (0 != V2_delete_line_nat(Map, line))
+ return -1;
+ return V2_write_line_nat(Map, type, points, cats);
+ if (line < 1 || line > plus->n_lines) {
+ G_warning(_("Attempt to access feature with invalid id (%d)"), line);
return -1;
- G_debug(3, "V2_write_line_nat(), line = %d", line);
- /* rewrite feature in 'coor' file */
- offset = V1_rewrite_line_nat(Map, line, type, old_offset, points, cats);
- if (offset < 0)
- return -1;
+ if (!(plus->update_cidx)) {
+ plus->cidx_up_to_date = FALSE; /* category index will be outdated */
- /* update topology */
- return V2__add_line_to_topo_nat(Map, offset, type, points, cats, -1, NULL);
+ old_offset = plus->Line[line]->offset;
+ /* read the line */
+ if (!old_points) {
+ old_points = Vect_new_line_struct();
+ if (!old_cats) {
+ old_cats = Vect_new_cats_struct();
+ old_type = V2_read_line_nat(Map, old_points, old_cats, line);
+ if (old_type == -1)
+ return -1;
+ /* rewrite feature in coor file */
+ if (old_type != -2 /* EOF -> write new line */
+ && points->n_points == old_points->n_points
+ && cats->n_cats == old_cats->n_cats
+ && (((type & GV_POINTS) && (old_type & GV_POINTS))
+ || ((type & GV_LINES) && (old_type & GV_LINES)))) {
+ /* equal -> overwrite the old */
+ offset = old_offset;
+ else {
+ /* differ -> delete the old and append new */
+ /* delete old */
+ V1_delete_line_nat(Map, old_offset);
+ offset = -1;
+ /* delete feature from topology */
+ if (0 != V2__delete_line_from_topo_nat(Map, line, type, old_points, old_cats))
+ return -1;
+ offset = V1__write_line_nat(Map, offset, type, points, cats);
+ /* update topology (build level >= GV_BUILD_BASE) */
+ return V2__add_line_to_topo_nat(Map, offset, type, points, cats, line, NULL);
@@ -215,7 +242,7 @@
char rhead;
struct gvfile *dig_fp;
- G_debug(3, "V1_delete_line_nat(): offset = %lu", (unsigned long) offset);
+ G_debug(3, "V1_delete_line_nat(): offset = %"PRI_OFF_T, offset);
dig_set_cur_port(&(Map->head.port));
dig_fp = &(Map->dig_fp);
@@ -244,7 +271,7 @@
\brief Deletes feature at topological level (internal use only)
\param pointer to Map_info structure
@@ -257,6 +284,8 @@
int type;
struct P_line *Line;
+ static struct line_cats *Cats = NULL;
+ static struct line_pnts *Points = NULL;
G_debug(3, "V2_delete_line_nat(): line = %d", line);
@@ -267,23 +296,26 @@
return -1;
Line = Map->plus.Line[line];
if (Line == NULL) {
G_warning(_("Attempt to access dead feature %d"), line);
return -1;
/* read the line */
if (!Points) {
Points = Vect_new_line_struct();
- if (!Cats) {
Cats = Vect_new_cats_struct();
type = V2_read_line_nat(Map, Points, Cats, line);
- if (type < 0)
- return -1;
+ if (type <= 0)
+ return -1;
/* delete feature from coor file */
if (0 != V1_delete_line_nat(Map, Line->offset))
@@ -310,7 +342,7 @@
char rhead;
- G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
+ G_debug(3, "V1_restore_line_nat(), offset = %"PRI_OFF_T, offset);
@@ -341,20 +373,22 @@
\brief Restores feature at topological level (internal use only)
- Note: This function requires build level >= GV_BUILD_BASE.
- \param offset feature offset
\return -1 on error
-int V2_restore_line_nat(struct Map_info *Map, int line, off_t offset)
+int V2_restore_line_nat(struct Map_info *Map, int line)
int type;
+ off_t offset;
@@ -370,12 +404,17 @@
G_warning(_("Attempt to access alive feature %d"), line);
return -1;
+ plus->cidx_up_to_date = 0;
+ offset = Line->offset;
/* restore feature in 'coor' file */
if (0 != V1_restore_line_nat(Map, offset))
return -1;
/* read feature geometry */
if (!Points)
@@ -392,8 +431,10 @@
/*** static or internal subroutines bellow ****/
- \brief Rewrites feature at the given offset
+ \brief Writes feature at the given offset or at the end of the file
+ Internal use only
@@ -403,9 +444,9 @@
\return -1 on error
-off_t V1__rewrite_line_nat(struct Map_info *Map,
- off_t offset, int type,
- const struct line_pnts *points, const struct line_cats *cats)
+off_t V1__write_line_nat(struct Map_info *Map, off_t offset, int type,
+ const struct line_pnts *points,
+ const struct line_cats *cats)
int i, n_points;
char rhead, nc;
@@ -415,9 +456,24 @@
- if (dig_fseek(dig_fp, offset, 0) == -1)
- return -1;
+ /* if the given offset is smaller than the coor header size,
+ * append new feature to the end of the coor file,
+ * else overwrite whatever exists at offset */
+ if (offset < Map->head.head_size) {
+ if (dig_fseek(&(Map->dig_fp), 0L, SEEK_END) == -1) /* set to end of file */
+ return -1;
+ offset = dig_ftell(&(Map->dig_fp));
+ G_debug(3, "V1__rewrite_line_nat(): offset = %lu", offset);
+ if (offset == -1)
+ return -1;
+ else {
+ if (dig_fseek(dig_fp, offset, 0) == -1)
+ return -1;
/* first byte: 0 bit: 1 - alive, 0 - dead
* 1 bit: 1 - categories, 0 - no category
* 2-3 bit: store type
@@ -582,7 +638,7 @@
int V2__delete_line_from_topo_nat(struct Map_info *Map, int line, int type,
- int i, first;
+ int i, first = 1;
int adjacent[4], n_adjacent;
struct bound_box box, abox;
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_ogr.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_ogr.c 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_ogr.c 2015-01-16 11:10:08 UTC (rev 64215)
@@ -86,11 +86,11 @@
\return -1 on error
off_t V1_rewrite_line_ogr(struct Map_info *Map,
- int line, int type, off_t offset,
+ off_t offset, int type,
- G_debug(3, "V1_rewrite_line_ogr(): line=%d type=%d offset=%"PRI_OFF_T,
- line, type, offset);
+ G_debug(3, "V1_rewrite_line_ogr(): type=%d offset=%"PRI_OFF_T,
+ type, offset);
#ifdef HAVE_OGR
if (type != V1_read_line_ogr(Map, NULL, NULL, offset)) {
G_warning(_("Unable to rewrite feature (incompatible feature types)"));
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_pg.c 2015-01-16 11:10:08 UTC (rev 64215)
@@ -176,12 +176,12 @@
\return -1 on error
off_t V1_rewrite_line_pg(struct Map_info * Map,
const struct line_pnts * points,
const struct line_cats * cats)
- G_debug(3, "V1_rewrite_line_pg(): line=%d type=%d offset=%"PRI_OFF_T,
+ G_debug(3, "V1_rewrite_line_pg(): type=%d offset=%"PRI_OFF_T,
+ type, offset);
#ifdef HAVE_POSTGRES
if (type != V1_read_line_pg(Map, NULL, NULL, offset)) {
@@ -215,18 +215,19 @@
\return offset where feature was rewritten
\return -1 on error
-off_t V2_rewrite_line_pg(struct Map_info *Map, int line, int type, off_t old_offset,
+off_t V2_rewrite_line_pg(struct Map_info *Map, int line, int type,
- G_debug(3, "V2_rewrite_line_pg(): line=%d type=%d offset=%"PRI_OFF_T,
- line, type, old_offset);
+ G_debug(3, "V2_rewrite_line_pg(): line=%d type=%d",
+ line, type);
const char *schema_name, *table_name, *keycolumn;
char *stmt, *geom_data;
struct Format_info_pg *pg_info;
+ off_t offset;
geom_data = NULL;
stmt = NULL;
pg_info = &(Map->fInfo.pg);
@@ -241,7 +242,12 @@
return -1;
if (!Points)
@@ -283,7 +289,7 @@
/* update topology
note: offset is not changed */
- return add_line_to_topo_pg(Map, old_offset, type, points);
+ return add_line_to_topo_pg(Map, offset, type, points);
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
return -1;
@@ -396,7 +402,11 @@
return -1;
Vect__execute_pg(pg_info->conn, "BEGIN");
if (Line->type & GV_POINTS) {
@@ -1338,7 +1348,11 @@
/* check type for nodes */
if (is_node && type != GV_POINT) {
G_warning(_("Invalid feature type (%d) for nodes"), type);
@@ -2732,7 +2746,7 @@
\brief Add line to native and PostGIS topology
\param Map vector map
- \param line feature id to remove from topo
+ \param offset ???
\param Points feature vertices
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/write_sfa.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/write_sfa.c 2015-01-16 11:09:54 UTC (rev 64214)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/write_sfa.c 2015-01-16 11:10:08 UTC (rev 64215)
@@ -72,7 +72,11 @@
if (offset < 0)
return -1;
/* Update topology */
if (plus->built >= GV_BUILD_BASE) {
dig_line_box(points, &box);
@@ -145,11 +149,11 @@
\return offset where line was rewritten
\return -1 on error
-off_t V2_rewrite_line_sfa(struct Map_info *Map, int line, int type, off_t offset,
+off_t V2_rewrite_line_sfa(struct Map_info *Map, int line, int type,
- G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d offset=%"PRI_OFF_T,
+ G_debug(3, "V2_rewrite_line_sfa(): line=%d type=%d",
+ line, type);
@@ -205,6 +209,10 @@
return -1;
