[GRASS-SVN] r64286 - in grass/branches/releasebranch_7_0: display/d.vect raster/r.external raster/r.mapcalc raster/r.neighbors raster/r.quant raster/r.resamp.filter raster/r.series raster/r.series.interp raster/r.stats.quantile vector/v.colors vector/v.external.out
svn_grass at osgeo.org
Thu Jan 22 19:10:42 PST 2015
Author: annakrat
Date: 2015-01-22 19:10:42 -0800 (Thu, 22 Jan 2015)
New Revision: 64286
grass/branches/releasebranch_7_0/display/d.vect/shape.c
grass/branches/releasebranch_7_0/raster/r.external/main.c
grass/branches/releasebranch_7_0/raster/r.mapcalc/main.c
grass/branches/releasebranch_7_0/raster/r.neighbors/main.c
grass/branches/releasebranch_7_0/raster/r.quant/main.c
grass/branches/releasebranch_7_0/raster/r.resamp.filter/main.c
grass/branches/releasebranch_7_0/raster/r.series.interp/main.c
grass/branches/releasebranch_7_0/raster/r.series/main.c
grass/branches/releasebranch_7_0/raster/r.stats.quantile/main.c
grass/branches/releasebranch_7_0/vector/v.colors/main.c
grass/branches/releasebranch_7_0/vector/v.external.out/args.c
Consolite option/flag mutually exslusive messages (merge from trunk, r60703)
Modified: grass/branches/releasebranch_7_0/display/d.vect/shape.c
--- grass/branches/releasebranch_7_0/display/d.vect/shape.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/display/d.vect/shape.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -183,8 +183,8 @@
z_style = NULL;
else if (rgb_column) {
- G_warning(_("Options <%s> and <%s> are mutually exclusive. "
- "Option <%s> will be ignored."), "zcolor", "rgb_column", "zcolor");
+ G_warning(_("%s= and %s= are mutually exclusive. "
+ "%s= will be ignored."), "zcolor", "rgb_column", "zcolor");
z_style = NULL;
else {
Modified: grass/branches/releasebranch_7_0/raster/r.external/main.c
--- grass/branches/releasebranch_7_0/raster/r.external/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.external/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -140,11 +140,11 @@
title = NULL;
if (!input && !source)
- G_fatal_error(_("One of options <%s> or <%s> must be given"),
+ G_fatal_error(_("%s= or %s= must be given"),
parm.input->key, parm.source->key);
if (input && source)
- G_fatal_error(_("Option <%s> and <%s> are mutually exclusive"),
+ G_fatal_error(_("%s= and %s= are mutually exclusive"),
if (input && !G_is_absolute_path(input)) {
Modified: grass/branches/releasebranch_7_0/raster/r.mapcalc/main.c
--- grass/branches/releasebranch_7_0/raster/r.mapcalc/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.mapcalc/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -156,7 +156,8 @@
overwrite_flag = module->overwrite;
if (expr->answer && file->answer)
- G_fatal_error(_("file= and expression= are mutually exclusive"));
+ expr->key, file->key);
if (seed->answer && random->answer)
G_fatal_error(_("%s= and -%c are mutually exclusive"),
Modified: grass/branches/releasebranch_7_0/raster/r.neighbors/main.c
--- grass/branches/releasebranch_7_0/raster/r.neighbors/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.neighbors/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -259,10 +259,12 @@
ncb.dist = ncb.nsize / 2;
if (parm.weight->answer && flag.circle->answer)
- G_fatal_error(_("weight= and -c are mutually exclusive"));
+ G_fatal_error(_("-%c and %s= are mutually exclusive"),
+ flag.circle->key, parm.weight->key);
if (parm.weight->answer && parm.gauss->answer)
- G_fatal_error(_("weight= and gauss= are mutually exclusive"));
+ parm.weight->key, parm.gauss->key);
ncb.oldcell = parm.input->answer;
@@ -288,7 +290,8 @@
for (i = 0; parm.method->answers[i]; i++)
if (num_outputs != i)
- G_fatal_error(_("output= and method= must have the same number of values"));
+ G_fatal_error(_("%s= and %s= must have the same number of values"),
+ parm.output->key, parm.method->key);
outputs = G_calloc(num_outputs, sizeof(struct output));
Modified: grass/branches/releasebranch_7_0/raster/r.quant/main.c
--- grass/branches/releasebranch_7_0/raster/r.quant/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.quant/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -108,7 +108,8 @@
if (rules->answer)
i++;
if (i > 1)
- G_fatal_error(_("-t, -r, rules=, basemap= and fprange= are mutually exclusive"));
+ G_fatal_error(_("-%c, -%c, %s=, %s= and %s= are mutually exclusive"),
+ trunc->key, rnd->key, rules->key, basemap->key, fprange->key);
i = 0;
if (fprange->answer)
@@ -116,7 +117,8 @@
if (range->answer)
i++;
if (i == 1)
- G_fatal_error(_("fprange= and range= must be used together"));
+ G_fatal_error(_("%s= and %s= must be used together"),
+ fprange->key, range->key);
for (noi = 0; input->answers[noi]; noi++)
@@ -158,9 +160,11 @@
else if (fprange->answer)
if (sscanf(fprange->answer, "%lf,%lf", &new_dmin, &new_dmax) != 2)
- G_fatal_error(_("invalid value for fprange= <%s>"), fprange->answer);
+ G_fatal_error(_("invalid value for %s= <%s>"),
+ fprange->key, fprange->answer);
if (sscanf(range->answer, "%d,%d", &new_min, &new_max) != 2)
- G_fatal_error(_("invalid value for range= <%s>"), range->answer);
+ range->key, range->answer);
G_message(_("Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"),
new_dmin, new_dmax, new_min, new_max);
Rast_quant_add_rule(&quant_struct, new_dmin, new_dmax, new_min, new_max);
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.filter/main.c
--- grass/branches/releasebranch_7_0/raster/r.resamp.filter/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.filter/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -429,13 +429,16 @@
if (parm.radius->answer) {
if (parm.x_radius->answer || parm.y_radius->answer)
- G_fatal_error(_("radius= and x_radius=/y_radius= are mutually exclusive"));
+ G_fatal_error(_("%s= and %s=/%s= are mutually exclusive"),
+ parm.radius->key, parm.x_radius->key, parm.y_radius->key);
else {
if (!parm.x_radius->answer && !parm.y_radius->answer)
- G_fatal_error(_("Either radius= or x_radius=/y_radius= required"));
+ G_fatal_error(_("Either %s= or %s=/%s= required"),
if (!parm.x_radius->answer || !parm.y_radius->answer)
- G_fatal_error(_("Both x_radius= and y_radius= required"));
+ G_fatal_error(_("Both %s= and %s= required"),
+ parm.x_radius->key, parm.y_radius->key);
nulls = flag.nulls->answer;
Modified: grass/branches/releasebranch_7_0/raster/r.series/main.c
--- grass/branches/releasebranch_7_0/raster/r.series/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.series/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -195,10 +195,12 @@
if (parm.input->answer && parm.file->answer)
- G_fatal_error(_("input= and file= are mutually exclusive"));
+ parm.input->key, parm.file->key);
if (!parm.input->answer && !parm.file->answer)
- G_fatal_error(_("Please specify input= or file="));
+ G_fatal_error(_("Please specify %s= or %s="),
/* process the input maps from the file */
Modified: grass/branches/releasebranch_7_0/raster/r.series.interp/main.c
--- grass/branches/releasebranch_7_0/raster/r.series.interp/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.series.interp/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -115,28 +115,36 @@
exit(EXIT_FAILURE);
if (parm.output->answer && parm.outfile->answer)
- G_fatal_error(_("output= and outfile= are mutually exclusive"));
+ parm.output->key, parm.outfile->key);
if (parm.samplingpos->answer && parm.outfile->answer)
- G_fatal_error(_("samplingpos= and outfile= are mutually exclusive"));
+ parm.samplingpos->key, parm.outfile->key);
if (!parm.output->answer && !parm.outfile->answer)
- G_fatal_error(_("Please specify output= or outfile="));
if (parm.output->answer && !parm.samplingpos->answer)
- G_fatal_error(_("Please specify output= and samplingpos="));
+ G_fatal_error(_("Please specify %s= and %s="),
+ parm.output->key, parm.samplingpos->key);
if (parm.input->answer && parm.infile->answer)
- G_fatal_error(_("input= and infile= are mutually exclusive"));
+ parm.input->key, parm.infile->key);
if (parm.datapos->answer && parm.infile->answer)
- G_fatal_error(_("datapos= and infile= are mutually exclusive"));
+ parm.datapos->key, parm.infile->key);
if (!parm.input->answer && !parm.infile->answer)
- G_fatal_error(_("Please specify input= or infile="));
if (parm.input->answer && !parm.datapos->answer)
- G_fatal_error(_("Please specify input= and datapos="));
+ parm.input->key, parm.datapos->key);
if(G_strncasecmp(parm.method->answer, "linear", 6) == 0)
interpol_method = LINEAR_INTERPOLATION;
Modified: grass/branches/releasebranch_7_0/raster/r.stats.quantile/main.c
--- grass/branches/releasebranch_7_0/raster/r.stats.quantile/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/raster/r.stats.quantile/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -439,10 +439,12 @@
print = flag.p->answer;
if (!print && !opt.output->answers)
- G_fatal_error(_("Either -p or output= must be given"));
+ G_fatal_error(_("Either -%c or %s= must be given"),
+ flag.p->key, opt.output->key);
if (print && opt.output->answers)
- G_fatal_error(_("-p and output= are mutually exclusive"));
num_slots = atoi(opt.slots->answer);
Modified: grass/branches/releasebranch_7_0/vector/v.colors/main.c
--- grass/branches/releasebranch_7_0/vector/v.colors/main.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/vector/v.colors/main.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -204,7 +204,7 @@
if (opt.rast->answer && opt.volume->answer)
- G_fatal_error(_("Options <%s> and <%s> are mutually exclusive"),
opt.rast->key, opt.volume->key);
cmap = NULL;
@@ -214,21 +214,20 @@
cmap = opt.volume->answer;
if (!cmap && !style && !rules && !remove && !convert)
- G_fatal_error(_("One of -%c, -%c or options <%s>, <%s> or <%s> "
+ G_fatal_error(_("One of -%c, -%c or %s=, %s= or %s= "
"must be specified"), flag.r->key, flag.c->key,
opt.colr->key, opt.rast->key, opt.rules->key);
if (!!style + !!cmap + !!rules > 1)
- G_fatal_error(_("Options <%s>, <%s>, and <%s> are mutually "
- "exclusive"), opt.colr->key, opt.rules->key,
- opt.rast->key);
+ G_fatal_error(_("%s=, %s= and %s= are mutually exclusive"),
+ opt.colr->key, opt.rules->key, opt.rast->key);
if (flag.g->answer && flag.a->answer)
- G_fatal_error(_("Flags -%c and -%c are mutually exclusive"),
+ G_fatal_error(_("-%c and -%c are mutually exclusive"),
flag.g->key, flag.a->key);
if (flag.c->answer && !rgbcolumn)
- G_fatal_error(_("Option <%s> required for flag -%c"),
+ G_fatal_error(_("%s= required for -%c"),
opt.rgbcol->key, flag.c->key);
is_from_stdin = rules && strcmp(rules, "-") == 0;
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/args.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/args.c 2015-01-23 02:47:14 UTC (rev 64285)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/args.c 2015-01-23 03:10:42 UTC (rev 64286)
@@ -87,17 +87,17 @@
/* check options */
if (options->dsn->answer && options->format->answer &&
options->input->answer)
- G_fatal_error(_("Options <%s/%s> and <%s> are mutually exclusive"),
- options->dsn->key, options->format->key,
- options->input->key);
+ options->input->key,
+ options->dsn->key, options->format->key);
if (flags->f->answer || flags->p->answer || flags->r->answer || flags->g->answer ||
options->output->answer)
return;
if (!options->dsn->answer && !options->input->answer)
- G_fatal_error(_("One of options <%s> or <%s> must be specified"),
+ G_fatal_error(_("%s= or %s= must be specified"),
options->dsn->key, options->input->key);
if (options->dsn->answer && !options->format->answer)
- G_fatal_error(_("Option <%s> must be specified"),
+ G_fatal_error(_("%s= must be specified"),
