[GRASS-SVN] r64287 - in grass/trunk/raster: r.cost r.walk
svn_grass at osgeo.org
Fri Jan 23 11:38:50 PST 2015
Author: mmetz
Date: 2015-01-23 11:38:50 -0800 (Fri, 23 Jan 2015)
New Revision: 64287
grass/trunk/raster/r.cost/cost.h
grass/trunk/raster/r.cost/main.c
grass/trunk/raster/r.cost/r.cost.html
grass/trunk/raster/r.cost/stash.h
grass/trunk/raster/r.walk/main.c
grass/trunk/raster/r.walk/r.walk.html
grass/trunk/raster/r.walk/stash.h
r.cost, r.walk: change percent_memory to memory (in MB)
Modified: grass/trunk/raster/r.cost/cost.h
--- grass/trunk/raster/r.cost/cost.h 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.cost/cost.h 2015-01-23 19:38:50 UTC (rev 64287)
@@ -1,26 +1,4 @@
- * MODULE: r.cost
- * AUTHOR(S): Antony Awaida - IESL - M.I.T.
- * James Westervelt - CERL
- * Pierre de Mouveaux <pmx audiovu com>
- * Eric G. Miller <egm2 jps net>
- * PURPOSE: Outputs a raster map layer showing the cumulative cost
- * of moving between different geographic locations on an
- * input raster map layer whose cell category values
- * represent cost.
- * COPYRIGHT: (C) 2006 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
/* cost.h in ~/src/Gcost */
Modified: grass/trunk/raster/r.cost/main.c
--- grass/trunk/raster/r.cost/main.c 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.cost/main.c 2015-01-23 19:38:50 UTC (rev 64287)
@@ -18,7 +18,7 @@
* represent cost.
- * COPYRIGHT: (C) 2006-2009 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2015 by the GRASS Development Team
@@ -132,7 +132,7 @@
struct History history;
double peak = 0.0;
int dsize, nearest_size;
- double disk_mb, mem_mb;
+ double disk_mb, mem_mb, pq_mb;
G_gisinit(argv[0]);
@@ -219,14 +219,13 @@
opt6->guisection = _("NULL cells");
opt10 = G_define_option();
- opt10->key = "percent_memory";
+ opt10->key = "memory";
opt10->type = TYPE_INTEGER;
opt10->key_desc = "value";
opt10->required = NO;
opt10->multiple = NO;
- opt10->answer = "40";
- opt10->options = "0-100";
- opt10->description = _("Percent of map to keep in memory");
+ opt10->answer = "300";
+ opt10->description = _("Maximum memory to be used in MB");
flag2 = G_define_flag();
flag2->key = 'k';
@@ -309,9 +308,8 @@
if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost);
- if (sscanf(opt10->answer, "%d", &maxmem) != 1 || maxmem < 0 ||
- maxmem > 100)
- G_fatal_error(_("Inappropriate percent memory: %d"), maxmem);
+ if (sscanf(opt10->answer, "%d", &maxmem) != 1 || maxmem <= 0)
+ G_fatal_error(_("Inappropriate amount of memory: %d"), maxmem);
if ((opt6->answer == NULL) ||
(sscanf(opt6->answer, "%lf", &null_cost) != 1)) {
@@ -379,31 +377,35 @@
else
srows = scols = SEGCOLSIZE;
- if (maxmem == 100) {
- srows = scols = 256;
/* calculate total number of segments */
nseg = ((nrows + srows - 1) / srows) * ((ncols + scols - 1) / scols);
- if (maxmem > 0)
- segments_in_memory = (maxmem * nseg) / 100;
- /* maxmem = 0 */
- else
- segments_in_memory = 4 * (nrows / srows + ncols / scols + 2);
- if (segments_in_memory == 0)
- segments_in_memory = 1;
- /* report disk space and memory requirements */
+ /* calculate disk space and memory requirements */
+ /* (nrows + ncols) * 8. * 20.0 / 1048576. for Dijkstra search */
+ pq_mb = ((double)nrows + ncols) * 8. * 20.0 / 1048576.;
+ G_debug(0, "pq MB: %g", pq_mb);
+ maxmem -= pq_mb;
+ if (maxmem < 10)
+ maxmem = 10;
if (dir == TRUE) {
disk_mb = (double) nrows * ncols * 28. / 1048576.;
- mem_mb = (double) srows * scols * 28. / 1048576. * segments_in_memory;
- mem_mb += nrows * ncols * 0.05 * 20. / 1048576.; /* for Dijkstra search */
+ segments_in_memory = maxmem /
+ ((double) srows * scols * (28. / 1048576.));
+ if (segments_in_memory < 4)
+ segments_in_memory = 4;
+ if (segments_in_memory > nseg)
+ segments_in_memory = nseg;
+ mem_mb = (double) srows * scols * (28. / 1048576.) * segments_in_memory;
else {
disk_mb = (double) nrows * ncols * 24. / 1048576.;
- mem_mb = (double) srows * scols * 24. / 1048576. * segments_in_memory;
+ ((double) srows * scols * (24. / 1048576.));
+ mem_mb = (double) srows * scols * (24. / 1048576.) * segments_in_memory;
if (flag5->answer) {
@@ -411,6 +413,9 @@
fprintf(stdout, "\n");
fprintf(stdout, _("Will need at least %.2f MB of memory"), mem_mb);
+ fprintf(stdout, _("%d of %d segments are kept in memory"),
+ segments_in_memory, nseg);
+ fprintf(stdout, "\n");
Rast_close(cost_fd);
exit(EXIT_SUCCESS);
@@ -418,6 +423,8 @@
G_verbose_message("--------------------------------------------");
G_verbose_message(_("Will need at least %.2f MB of disk space"), disk_mb);
G_verbose_message(_("Will need at least %.2f MB of memory"), mem_mb);
+ G_verbose_message(_("%d of %d segments are kept in memory"),
/* Create segmented format files for cost layer and output layer */
Modified: grass/trunk/raster/r.cost/r.cost.html
--- grass/trunk/raster/r.cost/r.cost.html 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.cost/r.cost.html 2015-01-23 19:38:50 UTC (rev 64287)
@@ -140,16 +140,16 @@
at each node in the tree for efficiently holding cells with identical
cumulative costs.
<p>
-<em>r.cost</em>, like most all GRASS raster programs, is also made to be run on
-maps larger that can fit in available computer memory. As the
-algorithm works through the dynamic list of cells it can move almost
-randomly around the entire area. <em>r.cost</em> divides the entire area
-into a number of pieces and swaps these pieces in and out of memory (to
-and from disk) as needed. This provides a virtual memory approach
-optimally designed for 2-D raster maps.
-The amount of map to hold in memory at one time can be controlled with the
-<b>percent_memory</b> option. For large maps this value will have to be set
-to a lower value.
+<em>r.cost</em>, like most all GRASS raster programs, is also made to
+be run on maps larger that can fit in available computer memory. As the
+algorithm works through the dynamic list of cells it can move almost
+randomly around the entire area. <em>r.cost</em> divides the entire
+area into a number of pieces and swaps these pieces in and out of
+memory (to and from disk) as needed. This provides a virtual memory
+approach optimally designed for 2-D raster maps. The amount of memory
+to be used by <em>r.cost</em> can be controlled with the <b>memory</b>
+option, default is 300 MB. For systems with less memory this value will
+have to be set to a lower value.
<h2>EXAMPLES</h2>
Modified: grass/trunk/raster/r.cost/stash.h
--- grass/trunk/raster/r.cost/stash.h 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.cost/stash.h 2015-01-23 19:38:50 UTC (rev 64287)
@@ -1,26 +1,15 @@
- * MODULE: r.cost
- * represent cost.
- * for details.
+/* stash.h in ~/src/Gcost */
+/* This header file declares the global variables and */
+/* the structures that are to be used for command */
+/* line processing. */
#ifndef __STASH_H__
#define __STASH_H__
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.walk/main.c 2015-01-23 19:38:50 UTC (rev 64287)
@@ -30,7 +30,7 @@
* Updated for GRASS 7
* Markus Metz
* PURPOSE: anisotropic movements on cost surfaces
- * COPYRIGHT: (C) 1999-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2015 by the GRASS Development Team
@@ -167,7 +167,7 @@
double peak = 0.0;
int dtm_dsize, cost_dsize;
/* Definition for dimension and region check */
struct Cell_head dtm_cellhd, cost_cellhd;
@@ -259,9 +259,8 @@
opt15 = G_define_option();
opt15->key = "walk_coeff";
@@ -369,9 +368,8 @@
- maxmem > 100)
/* Getting walking energy formula parameters */
if ((par_number =
@@ -492,31 +490,35 @@
else
- if (maxmem > 0)
- /* maxmem = 0 */
- else
- if (dir == 1) {
+ maxmem -= pq_mb;
+ if (maxmem < 10)
+ maxmem = 10;
+ if (dir == TRUE) {
else {
@@ -524,6 +526,9 @@
Rast_close(dtm_fd);
exit(EXIT_SUCCESS);
@@ -532,6 +537,8 @@
Modified: grass/trunk/raster/r.walk/r.walk.html
--- grass/trunk/raster/r.walk/r.walk.html 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.walk/r.walk.html 2015-01-23 19:38:50 UTC (rev 64287)
@@ -110,6 +110,17 @@
running <em><a href="r.drain.html">r.drain</a></em> to ensure the path
is computed according to the proper movement directions.
+<p>
+<em>r.walk</em>, like most all GRASS raster programs, is also made to
+randomly around the entire area. <em>r.walk</em> divides the entire
+to be used by <em>r.walk</em> can be controlled with the <b>memory</b>
<h2>REFERENCES</h2>
Modified: grass/trunk/raster/r.walk/stash.h
--- grass/trunk/raster/r.walk/stash.h 2015-01-23 03:10:42 UTC (rev 64286)
+++ grass/trunk/raster/r.walk/stash.h 2015-01-23 19:38:50 UTC (rev 64287)
@@ -14,6 +14,7 @@
#define __STASH_H__
#include <stdio.h>
#define CUM_COST_LAYER 1
#define COST_LAYER 2
#define START_PT 3
@@ -32,4 +33,4 @@
int process_answers(char **, struct start_pt **, struct start_pt **);
int time_to_stop(int, int);
-#endif
+#endif /* __STASH_H__ */
