[GRASS-SVN] r64334 - grass/branches/releasebranch_6_4/raster/r.in.gdal
svn_grass at osgeo.org
Tue Jan 27 00:33:32 PST 2015
Author: neteler
Date: 2015-01-27 00:33:32 -0800 (Tue, 27 Jan 2015)
New Revision: 64334
grass/branches/releasebranch_6_4/raster/r.in.gdal/description.html
r.in.gdal: NOAA DEM url fix (trac #2562); minor cleanup
Modified: grass/branches/releasebranch_6_4/raster/r.in.gdal/description.html
--- grass/branches/releasebranch_6_4/raster/r.in.gdal/description.html 2015-01-27 08:32:48 UTC (rev 64333)
+++ grass/branches/releasebranch_6_4/raster/r.in.gdal/description.html 2015-01-27 08:33:32 UTC (rev 64334)
@@ -4,26 +4,25 @@
or imagery group, from any GDAL supported raster map format, with an optional
title. The imported file may also be optionally used to create a new location.
-<!--<h2>OPTIONS</h2>
Extended explanations:
-<h3>Flags:</h3>
<dt><b>-e</b>
<dd>Extend the DEFAULT_WIND in PERMANENT mapset to include the region of
the new map layer. Old resolution is preserved, but the region, and rows/cols
are updated. This will fail if the user doesn't have write access to the
PERMANENT mapset.
-</dl>-->
+</dl>
<h3>GDAL supported raster formats</h3>
-Full details on GDAL supported formats are available at:<p>
+Full details on GDAL supported formats are available at:
+<p>
+<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a>
+<p>
+Selected formats of the more than 80 supported formats:
-<a href="http://www.gdal.org/formats_list.html">http://www.gdal.org/formats_list.html</a><p>
-Selected formats of the more than 80 supported formats:
<div class="code"><pre>
Long Format Name Code Creation Georeferencing Maximum File Size
@@ -94,7 +93,6 @@
<b>-o</b> flag to override the projection check.
<p>
If the user wishes to import the data with the full projection definition,
it is possible to have r.in.gdal automatically create a new location based
on the projection and extents of the file being read. This is accomplished
@@ -103,13 +101,14 @@
created (with only a PERMANENT mapset), and the raster will have been
imported with the indicated <b>output</b> name into the PERMANENT mapset.
+<h3>Support for GCPs</h3>
+In case the image contains GCPs they are written to a
+POINTS file within an imagery group. They can directly be used for
+<a href="i.rectify.html">i.rectify</a>.
<p>
-Support for GCPs: In case the image contains GCPs they are written to a
-POINTS file within an imagery group. They can directly be used for
-<a href=i.rectify.html>i.rectify</a>. The <b>target</b> option allows you to
-automatically re-project the GCPs from their own projection into another
-projection read from the PROJ_INFO file of the location name
-<b>target</b>.
+The <b>target</b> option allows you to automatically re-project the GCPs
+from their own projection into another projection read from the
+PROJ_INFO file of the location name <b>target</b>.
<h2>NOTES</h2>
@@ -121,7 +120,6 @@
the underlying format driver supports it:
<p>
<dl>
<dt> Color Table
@@ -232,10 +230,11 @@
<h3>GLOBE DEM</h3>
-To import <a href="http://www.ngdc.noaa.gov/seg/topo/gltiles.shtml">GLOBE DEM tiles</a>
+To import <a href="http://www.ngdc.noaa.gov/mgg/topo/elev/">GLOBE DEM tiles</a>
(approx 1km resolution, better than GTOPO30 DEM data), the user has to download
-additionally the related <a href="ftp://ftp.ngdc.noaa.gov/GLOBE_DEM/data/elev/esri/hdr/">HDR file(s)</a>.
+additionally the related <a href="http://www.ngdc.noaa.gov/mgg/topo/elev/esri/hdr/">HDR file(s)</a>.
Finally, e.g. the 'terrain' color table can be assigned to the imported map with <em>r.colors</em>.
+See also their <a href="http://www.ngdc.noaa.gov/mgg/dem/demportal.html">DEM portal</a>.
<h3>Worldclim.org</h3>
To import <a href="http://www.worldclim.org">Worldclim</a> data, the following
@@ -273,6 +272,8 @@
<a href="r.in.bin.html">r.in.bin</a>,
<a href="r.null.html">r.null</a>
</em>
+<p>
+GRASS GIS Wiki page: Import of <a href="http://grasswiki.osgeo.org/wiki/Global_datasets">Global datasets</a>
<h2>REFERENCES</h2>
