[GRASS-SVN] r64335 - grass/trunk/lib/init
Tue Jan 27 08:21:39 PST 2015
Author: annakrat
Date: 2015-01-27 08:21:38 -0800 (Tue, 27 Jan 2015)
New Revision: 64335
   grass/trunk/lib/init/grass.py
startup: attempt to fix #2552 by encoding string
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2015-01-27 08:33:32 UTC (rev 64334)
+++ grass/trunk/lib/init/grass.py	2015-01-27 16:21:38 UTC (rev 64335)
@@ -70,7 +70,9 @@
 grass_gui = None
 exit_grass = None
 force_gislock_removal = None
+encoding = None
 def warning(text):
     sys.stderr.write(_("WARNING") + ': ' + text + os.linesep)
@@ -776,7 +778,7 @@
     import locale
     language = 'None' # Such string sometimes is present in wx file
-    encoding = None
+    global encoding
     # Override value is stored in wxGUI preferences file.
     # As it's the only thing required, we'll just grep it out.
@@ -1124,7 +1126,7 @@
     else:
         f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
-    f.write("""grass_prompt() {
+    f.write(("""grass_prompt() {
 	LOCATION="`g.gisenv get=GISDBASE,LOCATION_NAME,MAPSET separator='/'`"
 	if test -d "$LOCATION/grid3/G3D_MASK" && test -f "$LOCATION/cell/MASK" ; then
 		echo [%s]
@@ -1136,7 +1138,7 @@
 PROMPT_COMMAND=grass_prompt\n""" % (_("2D and 3D raster MASKs present"),
                                     _("Raster MASK present"),
-                                    _("3D raster MASK present")))
+                                    _("3D raster MASK present"))).encode(encoding))
     # read environmental variables
     path = os.path.join(userhome, ".grass.bashrc") # left for backward compatibility
