[GRASS-SVN] r64344 - in grass/trunk/temporal: . t.rast.what
svn_grass at osgeo.org
Wed Jan 28 07:51:00 PST 2015
Author: huhabla
Date: 2015-01-28 07:51:00 -0800 (Wed, 28 Jan 2015)
New Revision: 64344
Added:
grass/trunk/temporal/t.rast.what/
grass/trunk/temporal/t.rast.what/Makefile
grass/trunk/temporal/t.rast.what/t.rast.what.html
grass/trunk/temporal/t.rast.what/t.rast.what.py
temporal modules: New module that utilizes r.what for STRDS sampling
Added: grass/trunk/temporal/t.rast.what/Makefile
--- grass/trunk/temporal/t.rast.what/Makefile (rev 0)
+++ grass/trunk/temporal/t.rast.what/Makefile 2015-01-28 15:51:00 UTC (rev 64344)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.what
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.rast.what/t.rast.what.html
--- grass/trunk/temporal/t.rast.what/t.rast.what.html (rev 0)
+++ grass/trunk/temporal/t.rast.what/t.rast.what.html 2015-01-28 15:51:00 UTC (rev 64344)
@@ -0,0 +1,102 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.what</em> is designed to sample space time raster datasets
+at specific coordinates using <a href="r.what.html">r.what</a> internally.
+The output of <a href="r.what.html">r.what</a>
+is transformed in different output layouts.
+The output layouts can be specified using the option <em>layout</em>.
+Please have a look at the output layout demonstration in the example.
+<p>
+This module is designed to run several instances of r.what to sample
+parts of a space time raster dataset in parallel. Several intermediate
+text files will be produces that are merged into a single file at the
+and of the processing.
+<p>
+Coordinates can be provided using the <em>coordinates</em> option
+or as vector map using the <em>points</em> option.
+<p>
+An output file must be provided with the <em>output</em> option.
+<h2>EXAMPLE</h2>
+In this example we sample a space time raster dataset that contains
+4 raster map layer with 3 random vector points. The generated output
+of all layout options are demonstrated.
+<div class="code"><pre>
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# Generate data
+r.mapcalc expr="a_1 = 1" -s
+r.mapcalc expr="a_2 = 2" -s
+r.mapcalc expr="a_3 = 3" -s
+r.mapcalc expr="a_4 = 4" -s
+v.random output=points n=3
+t.create type=strds output=A title="A test" descr="A test"
+t.register -i type=raster input=A maps=a_1,a_2,a_3,a_4 \
+ start='1990-01-01' increment="1 month"
+# Now we create 3 outputs of the same data using different layouts
+# Output in "row" order
+t.rast.what strds=A points=points output=result.txt layout=row -n
+cat result.txt
+x|y|start|end|value
+107.9761951|14.4780173|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+107.9761951|14.4780173|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+107.9761951|14.4780173|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+107.9761951|14.4780173|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+48.1672585|75.5186798|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+48.1672585|75.5186798|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+48.1672585|75.5186798|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+48.1672585|75.5186798|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+114.3944372|36.2390227|1990-01-01 00:00:00|1990-02-01 00:00:00|1
+114.3944372|36.2390227|1990-02-01 00:00:00|1990-03-01 00:00:00|2
+114.3944372|36.2390227|1990-03-01 00:00:00|1990-04-01 00:00:00|3
+114.3944372|36.2390227|1990-04-01 00:00:00|1990-05-01 00:00:00|4
+# Output in column order
+t.rast.what strds=A points=points output=result.txt layout=col -n
+cat result.txt
+star|end|107.9761951;14.4780173|107.9761951;14.4780173|107.9761951;14.4780173
+1990-01-01 00:00:00|1990-02-01 00:00:00|1|1|1
+1990-02-01 00:00:00|1990-03-01 00:00:00|2|2|2
+1990-03-01 00:00:00|1990-04-01 00:00:00|3|3|3
+1990-04-01 00:00:00|1990-05-01 00:00:00|4|4|4
+# Output in one time series per row order
+t.rast.what strds=A points=points output=result.txt layout=timerow -n
+cat result.txt
+x|y|1990-01-01 00:00:00;1990-02-01 00:00:00|1990-02-01 00:00:00;1990-03-01 00:00:00|1990-03-01 00:00:00;1990-04-01 00:00:00|1990-04-01 00:00:00;1990-05-01 00:00:00
+107.976195095579|14.4780172666265|1|2|3|4
+48.1672585088805|75.5186797967386|1|2|3|4
+114.394437197952|36.2390227089844|1|2|3|4
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.what.html">r.what</a> ,
+<a href="r.neighbors.html">r.neighbors</a>,
+<a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a>,
+<a href="t.rast.extract.html">t.rast.extract</a>,
+<a href="t.info.html">t.info</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.mask.html">r.mask</a>
+</em>
+<h2>AUTHOR</h2>
+Sören Gebbert, Thünen Institute of Climate-Smart Agriculture
+<p><i>Last changed: $Date: 2014-12-03 20:39:26 +0100 (Mi, 03. Dez 2014) $</i>
Added: grass/trunk/temporal/t.rast.what/t.rast.what.py
--- grass/trunk/temporal/t.rast.what/t.rast.what.py (rev 0)
+++ grass/trunk/temporal/t.rast.what/t.rast.what.py 2015-01-28 15:51:00 UTC (rev 64344)
@@ -0,0 +1,449 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.what
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Sample a space time raster dataset at specific coordinates
+# and write the output to stdout using different layouts
+# COPYRIGHT: (C) 2015 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Sample a space time raster dataset at specific coordinates and write the output to stdout using different layouts
+#% keyword: temporal
+#% keyword: raster
+#% keyword: sampling
+#%end
+#%option G_OPT_V_INPUT
+#% key: points
+#%end
+#%option G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option G_OPT_F_OUTPUT
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option G_OPT_M_COORDS
+#%end
+#%option G_OPT_M_NULL_VALUE
+#%end
+#%option G_OPT_F_SEP
+#%end
+#%option
+#% key: order
+#% type: string
+#% description: Sort the maps by category
+#% required: no
+#% multiple: yes
+#% options: id, name, creator, mapset, creation_time, modification_time, start_time, end_time, north, south, west, east, min, max
+#% answer: start_time
+#%end
+#%option
+#% key: layout
+#% type: string
+#% description: The layout of the ouput. One point per row (row), one point per column (col), all timsteps in one row (timerow)
+#% required: no
+#% multiple: no
+#% options: row, col, timerow
+#% answer: row
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.neighbor processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%flag
+#% key: n
+#% description: Output header row
+#%end
+#%flag
+#% key: f
+#% description: Show the category labels of the grid cell(s)
+#%end
+#%flag
+#% key: r
+#% description: Output color values as RRR:GGG:BBB
+#%end
+#%flag
+#% key: i
+#% description: Output integer category values, not cell values
+#%end
+import copy
+import grass.script as grass
+import grass.temporal as tgis
+import grass.pygrass.modules as pymod
+def main(options, flags):
+ # Get the options
+ points = options["points"]
+ strds = options["strds"]
+ output = options["output"]
+ where = options["where"]
+ order = options["order"]
+ layout = options["layout"]
+ coordinates = options["coordinates"]
+ null_value = options["null_value"]
+ separator = options["separator"]
+ nprocs = int(options["nprocs"])
+ write_header = flags["n"]
+ output_cat_label = flags["f"]
+ output_color = flags["r"]
+ output_cat = flags["i"]
+ overwrite = grass.overwrite()
+ if coordinates and points:
+ grass.error(_("Options coordinates and points are mutually exclusive"))
+ # Make sure the temporal database exists
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ sp = tgis.open_old_stds(strds, "strds", dbif)
+ maps = sp.get_registered_maps_as_objects(where=where, order=order,
+ dbif=dbif)
+ dbif.close()
+ if not maps:
+ grass.warning(_("Space time raster dataset <%s> is empty") % sp.get_id())
+ return
+ # Setup separator
+ if separator == "pipe":
+ separator = "|"
+ if separator == "comma":
+ separator = ","
+ if separator == "space":
+ separator = " "
+ if separator == "tab":
+ separator = "\t"
+ if separator == "newline":
+ separator = "\n"
+ # Setup flags
+ flags = ""
+ if output_cat_label is True:
+ flags += "f"
+ if output_color is True:
+ flags += "r"
+ if output_cat is True:
+ flags += "f"
+ # Configure the r.what module
+ if points:
+ r_what = pymod.Module("r.what", map="dummy",
+ output="dummy", run_=False,
+ separator=separator, points=points,
+ overwrite=overwrite, flags=flags,
+ quiet=True)
+ elif coordinates:
+ coordinates=coordinates,
+ quiet=True)
+ else:
+ grass.error(_("Please specify points or coordinates"))
+ # The module queue for parallel execution
+ process_queue = pymod.ParallelModuleQueue(int(nprocs))
+ num_maps = len(maps)
+ # 400 Maps is the absolute maximum in r.what
+ # We need to determie the number of maps that can be processed
+ # in parallel
+ # First estimate the number of maps per process. We use 400 maps
+ # simultaniously as maximum for a single process
+ num_loops = int(num_maps / (400 * nprocs))
+ remaining_maps = num_maps % (400 * nprocs)
+ if num_loops == 0:
+ num_loops = 1
+ remaining_maps = 0
+ # Compute the number of maps for each process
+ maps_per_loop = int((num_maps - remaining_maps) / num_loops)
+ maps_per_process = int(maps_per_loop / nprocs)
+ remaining_maps_per_loop = maps_per_loop % nprocs
+ # We put the output files in an ordered list
+ output_files = []
+ output_time_list = []
+ count = 0
+ for loop in range(num_loops):
+ file_name = "out_%i"%(loop)
+ count = process_loop(nprocs, maps, file_name, count, maps_per_process,
+ remaining_maps_per_loop, output_files,
+ output_time_list, r_what, process_queue)
+ process_queue.wait()
+ print "Remaining maps", remaining_maps, count, len(maps)
+ if remaining_maps > 0:
+ # Use a single process if less then 400 maps
+ if remaining_maps <= 100:
+ print "Single remain process"
+ mod = copy.deepcopy(r_what)
+ mod(map=map_names, output=file_name)
+ process_queue.put(mod)
+ else:
+ maps_per_process = int(remaining_maps / nprocs)
+ remaining_maps_per_loop = remaining_maps % nprocs
+ file_name = "out_remain"
+ process_loop(nprocs, maps, file_name, count, maps_per_process,
+ # Wait for unfinished processes
+ # Out the output files in the correct order together
+ if layout == "row":
+ one_point_per_row_output(separator, output_files, output_time_list,
+ output, write_header)
+ elif layout == "col":
+ one_point_per_col_output(separator, output_files, output_time_list,
+ else:
+ one_point_per_timerow_output(separator, output_files, output_time_list,
+def one_point_per_row_output(separator, output_files, output_time_list,
+ output, write_header):
+ """Write one point per row
+ output is of type: x,y,start,end,value
+ # open the output file for writing
+ out_file = open(output, "w")
+ if write_header is True:
+ out_file.write("x%(sep)sy%(sep)sstart%(sep)send%(sep)svalue\n"\
+ %({"sep":separator}))
+ for count in range(len(output_files)):
+ file_name = output_files[count]
+ map_list = output_time_list[count]
+ print "Transform", file_name
+ in_file = open(file_name, "r")
+ for line in in_file:
+ line = line.split(separator)
+ x = line[0]
+ y = line[1]
+ # We ignore the site name
+ values = line[3:]
+ for i in range(len(values)):
+ start, end = map_list[i].get_temporal_extent_as_tuple()
+ coor_string = "%(x)10.7f%(sep)s%(y)10.7f%(sep)s"\
+ %({"x":float(x),"y":float(y),"sep":separator})
+ time_string = "%(start)s%(sep)s%(end)s%(sep)s%(val)s\n"\
+ %({"start":str(start), "end":str(end),
+ "val":(values[i].strip()),"sep":separator})
+ out_file.write(coor_string + time_string)
+ in_file.close()
+ out_file.close()
+def one_point_per_col_output(separator, output_files, output_time_list,
+ """Write one point per col
+ start,end,point_1 value,point_2 value,...,point_n value
+ Each row represents a single raster map, hence a single time stamp
+ first = True
+ lines = in_file.readlines()
+ matrix = []
+ for line in lines:
+ matrix.append(line.split(separator))
+ num_cols = len(matrix[0])
+ if first is True:
+ out_file.write("star%(sep)send"%({"sep":separator}))
+ x = matrix[0][0]
+ y = matrix[0][1]
+ out_file.write("%(sep)s%(x)10.7f;%(y)10.7f"\
+ %({"sep":separator,
+ "x":float(x),
+ "y":float(y)}))
+ out_file.write("\n")
+ first = False
+ for col in xrange(num_cols - 3):
+ start, end = output_time_list[count][col].get_temporal_extent_as_tuple()
+ time_string = "%(start)s%(sep)s%(end)s"\
+ "sep":separator})
+ out_file.write(time_string)
+ for row in xrange(len(matrix)):
+ value = matrix[row][col + 3]
+ out_file.write("%(sep)s%(value)s"\
+ "value":value.strip()}))
+ in_file.close()
+ out_file.close()
+def one_point_per_timerow_output(separator, output_files, output_time_list,
+ """Use the original layout of the r.waht output and print instead of
+ the raster names, the time stamps as header
+ One point per line for all time stamps:
+ x|y|1991-01-01 00:00:00;1991-01-02 00:00:00|1991-01-02 00:00:00;1991-01-03 00:00:00|1991-01-03 00:00:00;1991-01-04 00:00:00|1991-01-04 00:00:00;1991-01-05 00:00:00
+ 3730731.49590371|5642483.51236521|6|8|7|7
+ 3581249.04638104|5634411.97526282|5|8|7|7
+ matrix = []
+ header = ""
+ first = True
+ print "Transform orig", file_name
+ if write_header:
+ if first is True:
+ header = "x%(sep)sy"%({"sep":separator})
+ for map in map_list:
+ start, end = map.get_temporal_extent_as_tuple()
+ time_string = "%(sep)s%(start)s;%(end)s"\
+ "sep":separator})
+ header += time_string
+ for i in xrange(len(lines)):
+ cols = lines[i].split(separator)
+ if first is True:
+ matrix.append(cols[:2])
+ matrix[i] = matrix[i] + cols[3:]
+ first = False
+ in_file.close()
+ out_file.write(header + "\n")
+ for row in matrix:
+ first = True
+ for col in row:
+ value = col.strip()
+ if first is False:
+ out_file.write("%s"%(separator))
+ out_file.write(value)
+ first = False
+ out_file.close()
+def process_loop(nprocs, maps, file_name, count, maps_per_process,
+ output_time_list, r_what, process_queue):
+ """Call r.what in parallel subprocesses"""
+ first = True
+ for process in range(nprocs):
+ num = maps_per_process
+ # Add the remaining maps to the first process
+ if first is True:
+ num += remaining_maps_per_loop
+ first = False
+ # Temporary output file
+ final_file_name = file_name + "_%i"%(process)
+ output_files.append(final_file_name)
+ map_names = []
+ map_list = []
+ for i in range(num):
+ map = maps[count]
+ map_names.append(map.get_id())
+ map_list.append(map)
+ count += 1
+ output_time_list.append(map_list)
+ print "Process", process, "Maps", len(map_names)
+ mod(map=map_names, output=final_file_name)
+ #print(mod.get_bash())
+ return count
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main(options, flags)
Property changes on: grass/trunk/temporal/t.rast.what/t.rast.what.py
___________________________________________________________________
Added: svn:executable
