[GRASS-SVN] r64345 - grass/trunk/gui/wxpython
Wed Jan 28 10:44:35 PST 2015
Author: wenzeslaus
Date: 2015-01-28 10:44:35 -0800 (Wed, 28 Jan 2015)
New Revision: 64345
   grass/trunk/gui/wxpython/gis_set.py
wxGUI/startup: change layout of startup/welcome window/screen
Using philosophy of editing lists (list of X with buttons to manage items). There are three things to select, so there are three boxes to organzie things. Each box has a description of what it is directly in the window, so there is no need to open manual in order to understand basic things. Delete and rename is done through buttons rather then choice/combo which, unlike button, should not triger any action.
Size of the window and inner elements might be good change. Window could be wider and minimal height lower.
The green title text in the window was removed. The version and revision are now in the window title.
Some changes to layout should be considered. Head picture might be too close to the first group and the message/warning/error area could go somewhere else (typicaly at top or bottom, top would be under head image in our case); now using the old one (under gisdbase).
For location and mapset using GRASS Location, Location, GRASS Mapset and Mapset. Alternative primary names as well as box labels (e.g. with numbers) and box descriptions should be easy to introduce by simple change of the strings (without a need to modify layout).
Start button is now using 'Start GRASS session' to expose the concept of session (one can start GUI multiple times, one GRASS session on gisdbase/loc/map combination, session must run to run Pyrthon scripts, ...).
Naming of GISDBASE is unclear, programming manual is using (GRASS) database but it seems more that location is the databse and mapset the namespace and it is a quite normal directory, so startup screen is using GRASS GIS data directory.
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2015-01-28 15:51:00 UTC (rev 64344)
+++ grass/trunk/gui/wxpython/gis_set.py	2015-01-28 18:44:35 UTC (rev 64345)
@@ -32,7 +32,6 @@
 from core.utils import _
 import wx
 import wx.lib.mixins.listctrl as listmix
-import wx.lib.scrolledpanel as scrolled
 from grass.script import core as grass
@@ -41,7 +40,7 @@
 from core.utils     import GetListOfLocations, GetListOfMapsets, _
 from location_wizard.dialogs import RegionDef
 from gui_core.dialogs import TextEntryDialog
-from gui_core.widgets import GenericValidator
+from gui_core.widgets import GenericValidator, StaticWrapText
 sys.stderr = codecs.getwriter('utf8')(sys.stderr)
@@ -66,11 +65,13 @@
         wx.Frame.__init__(self, parent = parent, id = id, style = style)
         self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
-        self.panel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
+        # scroll panel was used here but not properly and is probably not need
+        # as long as it is not high too much
+        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
         # i18N
         # graphical elements
@@ -102,21 +103,14 @@
             grassVersion = versionLine
             grassRevisionStr = ''
-        self.select_box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
-                                        label = " %s " % _("Choose project location and mapset"))
+        self.gisdbase_box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                                         label=" %s " % _("Select GRASS GIS data directory"))
+        self.location_box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                                         label=" %s " % _("Select GRASS Location"))
+        self.mapset_box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                                         label=" %s " % _("Select GRASS Mapset"))
-        self.manage_box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
-                                        label = " %s " % _("Manage"))
-        self.lwelcome = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                      label = _("Welcome to GRASS GIS %s%s\n"
-                                              "The world's leading open source GIS") % (grassVersion, grassRevisionStr),
-                                      style = wx.ALIGN_CENTRE)
-        self.ltitle = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                    label = _("Select an existing project location and mapset\n"
-                                            "or define a new location"),
-        self.ldbase = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                    label = _("GIS Data Directory:"))
         # no message at the beginning
         self.lmessage = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
                                     label=_(""))
@@ -128,49 +122,69 @@
             self.lmessage.SetForegroundColour(wx.Colour(255, 0, 0))
         except AttributeError:
             pass
-        self.llocation = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                       label = _("Project location\n(projection/coordinate system)"),
-        self.lmapset = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                     label = _("Accessible mapsets\n(directories of GIS files)"),
-        self.lcreate = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                     label = _("Create new mapset\nin selected location"),
-        self.ldefine = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                     label = _("Define new location"),
-        self.lmanageloc = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                        label = _("Rename/delete selected\nmapset or location"),
+        self.gisdbase_panel = wx.Panel(parent=self.panel)
+        self.location_panel = wx.Panel(parent=self.panel)
+        self.mapset_panel = wx.Panel(parent=self.panel)
+        self.ldbase = StaticWrapText(
+            parent = self.gisdbase_panel, id = wx.ID_ANY,
+            label = _("GRASS GIS data directory contains Locations."
+                      " There can be one or more directories like this on one machine."))
+        self.llocation = StaticWrapText(
+             parent = self.location_panel, id = wx.ID_ANY,
+             label=_("Location represents a project."
+                     " All data in one Location is in the same coordinate reference system (projection)."
+                     " Location contains Mapsets."),
+             style = wx.ALIGN_LEFT)
+        #self.llocation.SetForegroundColour(wx.SystemSettings_GetColour(wx.SYS_COLOUR_GRAYTEXT))
+        self.lmapset = StaticWrapText(
+            parent = self.mapset_panel, id = wx.ID_ANY,
+            label = _("Mapset contains GIS data related"
+                      " to one task within one project,"
+                      " or to one subregion or user."
+                      " PERMANENT Mapset is in each Location and usually contains common data."),
         # buttons
         self.bstart = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                label = _("Start &GRASS"))
+                                label = _("Start &GRASS session"))
         self.bstart.SetDefault()
         self.bexit = wx.Button(parent = self.panel, id = wx.ID_EXIT)
         self.bstart.SetMinSize((180, self.bexit.GetSize()[1]))
         self.bhelp = wx.Button(parent = self.panel, id = wx.ID_HELP)
-        self.bbrowse = wx.Button(parent = self.panel, id = wx.ID_ANY,
+        self.bbrowse = wx.Button(parent = self.gisdbase_panel, id = wx.ID_ANY,
                                  label = _("&Browse"))
-        self.bmapset = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                 label = _("&Create mapset"))
-        self.bwizard = wx.Button(parent = self.panel, id = wx.ID_ANY,
-                                 label = _("&Location wizard"))
-        self.bwizard.SetToolTipString(_("Start location wizard."
+        self.bmapset = wx.Button(parent = self.mapset_panel, id = wx.ID_ANY,
+                                 label = _("&New"))
+        self.bwizard = wx.Button(parent = self.location_panel, id = wx.ID_ANY,
+                                 label = _("N&ew"))
+        self.bwizard.SetToolTipString(_("Create a new location using location wizard."
                                         " After location is created successfully,"
                                         " GRASS session is started."))
-        self.manageloc = wx.Choice(parent = self.panel, id = wx.ID_ANY,
-                                   choices = [_('Rename mapset'), _('Rename location'),
-                                            _('Delete mapset'), _('Delete location')])
-        self.manageloc.SetSelection(0)
+        self.rename_location_button = wx.Button(parent=self.location_panel, id=wx.ID_ANY,
+                                                label=_("Ren&ame"))
+        self.rename_location_button.SetToolTipString(_("Rename selected location"))
+        self.delete_location_button = wx.Button(parent=self.location_panel, id=wx.ID_ANY,
+                                                label=_("De&lete"))
+        self.delete_location_button.SetToolTipString(_("Delete selected location"))
+        self.rename_mapset_button = wx.Button(parent=self.mapset_panel, id=wx.ID_ANY,
+                                                label=_("&Rename"))
+        self.rename_mapset_button.SetToolTipString(_("Rename selected mapset"))
+        self.delete_mapset_button = wx.Button(parent=self.mapset_panel, id=wx.ID_ANY,
+                                              label=_("&Delete"))
+        self.delete_mapset_button.SetToolTipString(_("Delete selected mapset"))
         # textinputs
-        self.tgisdbase = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, value = "", size = (300, -1),
+        self.tgisdbase = wx.TextCtrl(parent = self.gisdbase_panel, id = wx.ID_ANY, value = "", size = (300, -1),
                                      style = wx.TE_PROCESS_ENTER)
         # Locations
-        self.lblocations = GListBox(parent = self.panel,
+        self.lblocations = GListBox(parent = self.location_panel,
                                     id = wx.ID_ANY, size = (180, 200),
                                     choices = self.listOfLocations)
@@ -178,14 +192,14 @@
         # TODO: sort; but keep PERMANENT on top of list
         # Mapsets
-        self.lbmapsets = GListBox(parent = self.panel,
+        self.lbmapsets = GListBox(parent = self.mapset_panel,
                                   choices = self.listOfMapsets)
         self.lbmapsets.SetColumnWidth(0, 180)
         # layout & properties
-        self._set_properties()
+        self._set_properties(grassVersion, grassRevisionStr)
         self._do_layout()
         # events
@@ -195,27 +209,33 @@
         self.bhelp.Bind(wx.EVT_BUTTON,        self.OnHelp)
         self.bmapset.Bind(wx.EVT_BUTTON,      self.OnCreateMapset)
         self.bwizard.Bind(wx.EVT_BUTTON,      self.OnWizard)
-        self.manageloc.Bind(wx.EVT_CHOICE,    self.OnManageLoc)
+        self.rename_location_button.Bind(wx.EVT_BUTTON, self.RenameLocation)
+        self.delete_location_button.Bind(wx.EVT_BUTTON, self.DeleteLocation)
+        self.rename_mapset_button.Bind(wx.EVT_BUTTON, self.RenameMapset)
+        self.delete_mapset_button.Bind(wx.EVT_BUTTON, self.DeleteMapset)
         self.lblocations.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnSelectLocation)
         self.lbmapsets.Bind(wx.EVT_LIST_ITEM_SELECTED,   self.OnSelectMapset)
         self.lbmapsets.Bind(wx.EVT_LIST_ITEM_ACTIVATED, self.OnStart)
         self.tgisdbase.Bind(wx.EVT_TEXT_ENTER, self.OnSetDatabase)
         self.Bind(wx.EVT_CLOSE,               self.OnCloseWindow)
-    def _set_properties(self):
+    def _set_properties(self, version, revision):
         """Set frame properties"""
-        self.SetTitle(_("Welcome to GRASS GIS"))
+        self.SetTitle(_("GRASS GIS %s startup%s") % (version, revision))
         self.SetIcon(wx.Icon(os.path.join(globalvar.ICONDIR, "grass.ico"),
                              wx.BITMAP_TYPE_ICO))
-        self.lwelcome.SetForegroundColour(wx.Colour(35, 142, 35))
-        self.lwelcome.SetFont(wx.Font(13, wx.DEFAULT, wx.NORMAL, wx.BOLD, 0, ""))
         self.bstart.SetForegroundColour(wx.Colour(35, 142, 35))
         self.bstart.SetToolTipString(_("Enter GRASS session"))
         self.bstart.Enable(False)
         self.bmapset.Enable(False)
-        self.manageloc.Enable(False)
+        # this all was originally a choice, perhaps just mapset needed
+        self.rename_location_button.Enable(False)
+        self.delete_location_button.Enable(False)
+        self.rename_mapset_button.Enable(False)
+        self.delete_mapset_button.Enable(False)
         # set database
         if not self.gisdbase:
@@ -270,70 +290,118 @@
     def _do_layout(self):
         sizer           = wx.BoxSizer(wx.VERTICAL)
         dbase_sizer     = wx.BoxSizer(wx.HORIZONTAL)
+        location_mapset_sizer  = wx.BoxSizer(wx.HORIZONTAL)
+        gisdbase_panel_sizer  = wx.BoxSizer(wx.VERTICAL)
+        gisdbase_boxsizer = wx.StaticBoxSizer(self.gisdbase_box, wx.VERTICAL)
+        location_panel_sizer  = wx.BoxSizer(wx.VERTICAL)
         location_sizer  = wx.BoxSizer(wx.HORIZONTAL)
-        select_boxsizer = wx.StaticBoxSizer(self.select_box, wx.VERTICAL)
-        select_sizer    = wx.FlexGridSizer(rows = 2, cols = 2, vgap = 4, hgap = 4)
-        select_sizer.AddGrowableRow(1)
-        select_sizer.AddGrowableCol(0)
-        select_sizer.AddGrowableCol(1)
-        manage_sizer    = wx.StaticBoxSizer(self.manage_box, wx.VERTICAL)
+        location_boxsizer = wx.StaticBoxSizer(self.location_box, wx.VERTICAL)
+        location_buttons_sizer = wx.BoxSizer(wx.VERTICAL)
+        mapset_panel_sizer  = wx.BoxSizer(wx.VERTICAL)
+        mapset_sizer  = wx.BoxSizer(wx.HORIZONTAL)
+        mapset_boxsizer = wx.StaticBoxSizer(self.mapset_box, wx.VERTICAL)
+        mapset_buttons_sizer = wx.BoxSizer(wx.VERTICAL)
         btns_sizer      = wx.BoxSizer(wx.HORIZONTAL)
+        self.gisdbase_panel.SetSizer(gisdbase_panel_sizer)
+        gisdbase_panel_sizer.Fit(self.gisdbase_panel)
+        self.location_panel.SetSizer(location_panel_sizer)
+        location_panel_sizer.Fit(self.location_panel)
+        self.mapset_panel.SetSizer(mapset_panel_sizer)
+        mapset_panel_sizer.Fit(self.mapset_panel)
         # gis data directory
-        dbase_sizer.Add(item = self.ldbase, proportion = 0,
-                        flag = wx.ALIGN_CENTER_VERTICAL |
-                        wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
-                        border = 3)
+        gisdbase_boxsizer.Add(item=self.gisdbase_panel, proportion=1,
+                         flag=wx.EXPAND | wx.ALL,
+                         border=3)
+        gisdbase_panel_sizer.Add(item=dbase_sizer, proportion=1,
+                         border=3)
+        gisdbase_panel_sizer.Add(item=self.ldbase, proportion=1,
+                         border=3)
         dbase_sizer.Add(item = self.tgisdbase, proportion = 1,
                         flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL,
                         border = 3)
         dbase_sizer.Add(item = self.bbrowse, proportion = 0,
                         border = 3)
+        location_boxsizer.Add(item=self.location_panel, proportion=1,
+                         border=3)
+        location_sizer.Add(item = self.lblocations, proportion = 1,
+                         border=3)
+        location_sizer.Add(item = location_buttons_sizer, proportion=0,
+                         flag=wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
+                         border=3)
-        # select sizer
-        select_sizer.Add(item = self.llocation, proportion = 0,
-                         flag = wx.ALIGN_CENTER_HORIZONTAL | wx.ALL,
-                         border = 3)
-        select_sizer.Add(item = self.lmapset, proportion = 0,
-                         border = 3)
-        select_sizer.Add(item = self.lblocations, proportion = 1,
-                         flag = wx.EXPAND)
-        select_sizer.Add(item = self.lbmapsets, proportion = 1,
-                         flag = wx.EXPAND)
+        location_buttons_sizer.Add(item=self.bwizard, proportion=0,
+                         border=3)
+        location_buttons_sizer.Add(item=self.rename_location_button, proportion=0,
+                         border=3)
+        location_buttons_sizer.Add(item=self.delete_location_button, proportion=0,
+                         border=3)
-        select_boxsizer.Add(item = select_sizer, proportion = 1,
-                            flag = wx.EXPAND)
+        location_panel_sizer.Add(item=location_sizer, proportion=1,
+                         border=3)
+        location_panel_sizer.Add(item=self.llocation, proportion=0,
+                         flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+                         border=3)
-        # define new location and mapset
-        manage_sizer.Add(item = self.ldefine, proportion = 0,
-                         border = 3)
-        manage_sizer.Add(item = self.bwizard, proportion = 0,
-                         flag = wx.ALIGN_CENTER_HORIZONTAL | wx.BOTTOM,
-                         border = 5)
-        manage_sizer.Add(item = self.lcreate, proportion = 0,
-                         border = 3)
-        manage_sizer.Add(item = self.bmapset, proportion = 0,
-                         border = 5)
-        manage_sizer.Add(item = self.lmanageloc, proportion = 0,
-                         border = 3)
-        manage_sizer.Add(item = self.manageloc, proportion = 0,
-                         border = 5)
+        mapset_sizer.Add(item=self.lbmapsets, proportion=1,
+                         border=3)
+        mapset_sizer.Add(item=mapset_buttons_sizer, proportion=0,
+                         border=3)
+        mapset_buttons_sizer.Add(item=self.bmapset, proportion=0,
+                         border=3)
+        mapset_buttons_sizer.Add(item=self.rename_mapset_button, proportion=0,
+                         border=3)
+        mapset_buttons_sizer.Add(item=self.delete_mapset_button, proportion=0,
+                         border=3)
+        mapset_boxsizer.Add(item=self.mapset_panel, proportion=1,
+                         border=3)
+        mapset_panel_sizer.Add(item=mapset_sizer, proportion=1,
+                         border=3)
+        mapset_panel_sizer.Add(item=self.lmapset, proportion=0,
+                         border=3)
         # location sizer
-        location_sizer.Add(item = select_boxsizer, proportion = 1,
+        location_mapset_sizer.Add(item=location_boxsizer, proportion=1,
                            flag = wx.LEFT | wx.RIGHT | wx.EXPAND,
                            border = 3)
-        location_sizer.Add(item = manage_sizer, proportion = 0,
+        location_mapset_sizer.Add(item=mapset_boxsizer, proportion=1,
                            flag = wx.RIGHT | wx.EXPAND,
                            border = 3)
         # buttons
         btns_sizer.Add(item = self.bstart, proportion = 0,
@@ -358,26 +426,17 @@
                   wx.ALL,
                   border = 3) # image
-        sizer.Add(item = self.lwelcome, # welcome message
-                  proportion = 0,
-                  wx.BOTTOM,
-                  border = 5)
-        sizer.Add(item = self.ltitle, # title
-                  proportion = 0,
-                  wx.ALIGN_CENTER_HORIZONTAL)
-        sizer.Add(item = dbase_sizer, proportion = 0,
+        sizer.Add(item=gisdbase_boxsizer, proportion=0,
                   wx.RIGHT | wx.LEFT | wx.EXPAND,
-                  border = 20) # GISDBASE setting
+                  border=3) # GISDBASE setting
         # warning/error message
         sizer.Add(item=self.lmessage,
                   proportion=0,
                   wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT | wx.BOTTOM, border=8)
-        sizer.Add(item = location_sizer, proportion = 1,
+        sizer.Add(item=location_mapset_sizer, proportion=1,
                   flag = wx.RIGHT | wx.LEFT | wx.EXPAND,
                   border = 1)
         sizer.Add(item = btns_sizer, proportion = 0,
@@ -544,23 +603,9 @@
                 else:
                     args = {'raster' : mapName}
                 RunCommand('g.region', flags = 's', parent = self, **args)
-    def OnManageLoc(self, event):
-        """Location management choice control handler
-        sel = event.GetSelection()
-        if sel ==  0:
-            self.RenameMapset()
-        elif sel ==  1:
-            self.RenameLocation()
-        elif sel ==  2:
-            self.DeleteMapset()
-        elif sel ==  3:
-            self.DeleteLocation()
-        event.Skip()
-    def RenameMapset(self):
+    # the event can be refactored out by using lambda in bind
+    def RenameMapset(self, event):
         """Rename selected mapset
         location = self.listOfLocations[self.lblocations.GetSelection()]
@@ -602,7 +647,7 @@
         dlg.Destroy()
-    def RenameLocation(self):
+    def RenameLocation(self, event):
         """Rename selected location
@@ -639,7 +684,7 @@
         dlg.Destroy()
-    def DeleteMapset(self):
+    def DeleteMapset(self, event):
         """Delete selected mapset
@@ -668,7 +713,7 @@
         dlg.Destroy()
-    def DeleteLocation(self):
+    def DeleteLocation(self, event):
@@ -797,12 +842,20 @@
                 self.bstart.Enable()
                 self.bstart.SetFocus()
                 self.bmapset.Enable()
-                self.manageloc.Enable()
+                # replacing disabled choice, perhaps just mapset needed
+                self.rename_location_button.Enable()
+                self.delete_location_button.Enable()
+                self.rename_mapset_button.Enable()
+                self.delete_mapset_button.Enable()
         else:
             self.lbmapsets.SetSelection(wx.NOT_FOUND)
     def OnSelectMapset(self, event):
         """Mapset selected"""
