[GRASS-SVN] r65554 - grass-addons/tools
Thu Jul 9 06:28:34 PDT 2015
Author: wenzeslaus
Date: 2015-07-09 06:28:34 -0700 (Thu, 09 Jul 2015)
New Revision: 65554
Added:
   grass-addons/tools/std_dataset_display.py
tools: script to render pictures of basic maps in standard dataset and their derivatives
Added: grass-addons/tools/std_dataset_display.py
--- grass-addons/tools/std_dataset_display.py	                        (rev 0)
+++ grass-addons/tools/std_dataset_display.py	2015-07-09 13:28:34 UTC (rev 65554)
@@ -0,0 +1,97 @@
+#!/usr/bin/env python
+import os
+import grass.script as gscript
+# before the script runs, old maps and existing images must be removed
+# g.remove type=raster name=slope,aspect,profile_curvature,shade -f
+def description_box(title):
+    gscript.write_command('d.graph', stdin="""
+    color white
+    polygon
+        0 0
+        0 16
+        100 16
+        100 0
+    gscript.run_command('d.text', text=title, at='2,11', size=5, color='black')
+def legend_item(color, text, x, y):
+    color {color}
+    polygon
+        {x1} {y2}
+        {x1} {y1}
+        {x2} {y1}
+        {x2} {y2}
+    """.format(color=color, x1=x, y1=y, x2=x + 2, y2=y + 2))
+    gscript.run_command('d.text', text=text, at=(x + 3, y + 0.5), size=2, color='black')
+def d_rast_legend(raster, title):
+    gscript.run_command('d.rast', map=raster)
+    description_box(title)
+    gscript.run_command('d.legend', raster=raster, at='6,9,6,50')
+    gscript.run_command('d.barscale', style='classic', at='55,9', color='black', text_position='over')
+def main():
+    elevation = 'elevation'
+    slope = 'slope'
+    aspect = 'aspect'
+    profile_curvature = 'profile_curvature'
+    shade = 'shade'
+    streams = 'streams'
+    streams_color = 'aqua'
+    roadsmajor = 'roadsmajor'
+    roads_color = 'yellow'
+    # we set region for the whole session (i.e. also outside the script)
+    gscript.run_command('g.region', raster=elevation)
+    gscript.run_command('r.slope.aspect', elevation=elevation,
+                        slope=slope, aspect=aspect, pcurvature=profile_curvature)
+    gscript.run_command('r.relief', input=elevation, output=shade)
+    # render maps
+    # set variables for rendering into a file
+    os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+    os.environ['GRASS_RENDER_WIDTH'] = '600'
+    os.environ['GRASS_RENDER_HEIGHT'] = '600'
+    os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
+    os.environ['GRASS_FONT'] = 'sans'
+    # shaded map with vectors
+    os.environ['GRASS_RENDER_FILE'] = 'shaded_elevation.png'
+    gscript.run_command('d.shade', shade=shade, color=elevation)
+    gscript.run_command('d.vect', map=streams, width=1, color=streams_color)
+    gscript.run_command('d.vect', map=roadsmajor, width=2, color=roads_color)
+    description_box('Overview map')
+    legend_item(streams_color, 'Streams', 3, 3)
+    legend_item(roads_color, 'Major roads', 3, 6)
+    gscript.run_command('d.legend', raster=elevation, at='3,6,30,50')
+    gscript.run_command('d.text', text='Elevation', at='30,7', size=2, color='black')
+    # individual rasters
+    os.environ['GRASS_RENDER_FILE'] = 'slope.png'
+    d_rast_legend(slope, 'Slope')
+    os.environ['GRASS_RENDER_FILE'] = 'aspect.png'
+    d_rast_legend(aspect, 'Aspect')
+    os.environ['GRASS_RENDER_FILE'] = 'profile_curvature.png'
+    d_rast_legend(profile_curvature, 'Profile curvature')
+    # post processing
+    # convert shaded_elevation.png slope.png aspect.png profile_curvature.png +append stripe.png
+if __name__ == "__main__":
+    main()
Property changes on: grass-addons/tools/std_dataset_display.py
___________________________________________________________________
Added: svn:executable
