[GRASS-SVN] r65555 - grass/trunk/general/g.list
svn_grass at osgeo.org
Thu Jul 9 10:40:39 PDT 2015
Author: hcho
Date: 2015-07-09 10:40:39 -0700 (Thu, 09 Jul 2015)
New Revision: 65555
Added:
grass/trunk/general/g.list/global.h
grass/trunk/general/g.list/list.c
grass/trunk/general/g.list/main.c
g.list: Split out list functions
Added: grass/trunk/general/g.list/global.h
--- grass/trunk/general/g.list/global.h (rev 0)
+++ grass/trunk/general/g.list/global.h 2015-07-09 17:40:39 UTC (rev 65555)
@@ -0,0 +1,21 @@
+#include <stdio.h>
+#include <grass/gis.h>
+#include <grass/manage.h>
+enum {
+ TYPE_RAST,
+ TYPE_RAST3D,
+ TYPE_VECT,
+ TYPE_OTHERS
+struct elist
+ char *type;
+ char *name;
+ char *mapset;
+void make_list(struct elist **, int *, int *, const struct list *, const char *,
+ const struct Cell_head *);
+void print_list(FILE *, struct elist *, int, const char *, int, int);
Added: grass/trunk/general/g.list/list.c
--- grass/trunk/general/g.list/list.c (rev 0)
+++ grass/trunk/general/g.list/list.c 2015-07-09 17:40:39 UTC (rev 65555)
@@ -0,0 +1,171 @@
+#include "global.h"
+#include <stdlib.h>
+#include <unistd.h>
+#include <string.h>
+#include <grass/raster3d.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+static int region_overlaps(const struct Cell_head *, const char *, const char *,
+ int);
+void make_list(struct elist **el, int *lcount, int *lalloc,
+ const struct list *elem, const char *mapset,
+ const struct Cell_head *window)
+ char path[GPATH_MAX];
+ const char *element, *alias;
+ char **list;
+ int count, i;
+ int type;
+ element = elem->element[0];
+ alias = elem->alias;
+ G_file_name(path, element, "", mapset);
+ if (access(path, 0) != 0)
+ return;
+ if ((list = G_ls2(path, &count)) == NULL)
+ return;
+ if (strcmp(alias, "raster") == 0)
+ type = TYPE_RAST;
+ else if (strcmp(alias, "raster_3d") == 0)
+ type = TYPE_RAST3D;
+ else if (strcmp(alias, "vector") == 0)
+ type = TYPE_VECT;
+ else
+ type = TYPE_OTHERS;
+ /* Suppress "... found in more mapsets" warnings from G_find_file2. */
+ G_suppress_warnings(1);
+ if (*lcount + count > *lalloc) {
+ *lalloc = *lcount + count + 10;
+ *el = G_realloc(*el, *lalloc * sizeof(struct elist));
+ for (i = 0; i < count; i++) {
+ /* If region= is used, read the map region. */
+ if (window) {
+ /* If the map region doesn't overlap with the input region, don't
+ * print the map. */
+ if (!region_overlaps(window, list[i], mapset, type))
+ continue;
+ (*el)[*lcount].type = G_store(alias);
+ (*el)[*lcount].name = list[i];
+ (*el)[*lcount].mapset = G_store(mapset);
+ (*lcount)++;
+ G_suppress_warnings(0);
+ G_free(list);
+int cmp(const void *a, const void *b)
+ struct elist *al = (struct elist *)a;
+ struct elist *bl = (struct elist *)b;
+ int ret;
+ if (!(ret = strcmp(al->type, bl->type))) {
+ if (!(ret = strcmp(al->name, bl->name)))
+ ret = strcmp(al->mapset, bl->mapset);
+ return ret;
+void print_list(FILE *fp, struct elist *el, int count, const char *separator,
+ int add_type, int add_mapset)
+ int i;
+ if (!count)
+ return;
+ qsort(el, count, sizeof(struct elist), cmp);
+ int need_mapset = 0;
+ if (i != 0)
+ fprintf(fp, "%s", separator);
+ if (add_type)
+ fprintf(fp, "%s/", el[i].type);
+ fprintf(fp, "%s", el[i].name);
+ if (!add_mapset) {
+ if (i + 1 < count)
+ need_mapset = strcmp(el[i].name, el[i + 1].name) == 0;
+ if (!need_mapset && i > 0)
+ need_mapset = strcmp(el[i].name, el[i - 1].name) == 0;
+ if (add_mapset || need_mapset)
+ fprintf(fp, "@%s", el[i].mapset);
+ fflush(fp);
+static int region_overlaps(const struct Cell_head *window, const char *name,
+ const char *mapset, int type)
+ int has_region;
+ struct Cell_head map_window;
+ RASTER3D_Region region3d;
+ struct Map_info Map;
+ struct bound_box box;
+ switch (type) {
+ case TYPE_RAST:
+ Rast_get_cellhd(name, mapset, &map_window);
+ has_region = 1;
+ break;
+ case TYPE_RAST3D:
+ if (Rast3d_read_region_map(name, mapset, ®ion3d) < 0)
+ G_fatal_error(_("Unable to read header of 3D raster map <%s@%s>"),
+ name, mapset);
+ Rast3d_region_to_cell_head(®ion3d, &map_window);
+ has_region = 1;
+ break;
+ case TYPE_VECT:
+ Vect_set_open_level(2);
+ if (Vect_open_old_head(&Map, name, mapset) < 2)
+ G_fatal_error(_("Unable to open vector map <%s@%s> on topological level"),
+ name, mapset);
+ Vect_get_map_box(&Map, &box);
+ Vect_close(&Map);
+ map_window.north = box.N;
+ map_window.south = box.S;
+ map_window.west = box.W;
+ map_window.east = box.E;
+ has_region = 1;
+ break;
+ default:
+ has_region = 0;
+ break;
+ /* If an element doesn't have a concept of region at all, return 1 so we
+ * can always print it. */
+ if (!has_region)
+ return 1;
+ /* If the map region is outside the input region, return 0. Otherwise
+ * return 1 */
+ return !(window->north <= map_window.south ||
+ window->south >= map_window.north ||
+ window->west >= map_window.east ||
+ window->east <= map_window.west);
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c 2015-07-09 13:28:34 UTC (rev 65554)
+++ grass/trunk/general/g.list/main.c 2015-07-09 17:40:39 UTC (rev 65555)
@@ -17,39 +17,16 @@
+#define _MAIN_C_
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
-#include <grass/raster3d.h>
-#include <grass/vector.h>
#include <grass/spawn.h>
-enum {
- TYPE_RAST,
- TYPE_RAST3D,
- TYPE_VECT,
- TYPE_OTHERS
-struct elist
- char *type;
- char *name;
- char *mapset;
-static int any = 0;
-static void make_list(struct elist **, int *, int *,
- const struct list *, const char *,
- struct Cell_head *);
-static void print_list(FILE *, struct elist *, int,
- const char *, int, int);
-static int region_overlaps(struct Cell_head *, const char *, const char *, int);
int main(int argc, char *argv[])
struct GModule *module;
@@ -370,7 +347,7 @@
if (flag.pretty->answer || flag.full->answer)
fclose(stdout);
- else if (any)
+ else if (lcount)
fprintf(fp, "\n");
if (use_pager)
@@ -386,164 +363,3 @@
exit(EXIT_SUCCESS);
-static void make_list(struct elist **el, int *lcount, int *lalloc,
- const struct list *elem, const char *mapset,
- struct Cell_head *window)
- char path[GPATH_MAX];
- const char *element, *alias;
- char **list;
- int count, i;
- int type;
- element = elem->element[0];
- alias = elem->alias;
- G_file_name(path, element, "", mapset);
- if (access(path, 0) != 0)
- return;
- if ((list = G_ls2(path, &count)) == NULL)
- return;
- if (strcmp(alias, "raster") == 0)
- type = TYPE_RAST;
- else if (strcmp(alias, "raster_3d") == 0)
- type = TYPE_RAST3D;
- else if (strcmp(alias, "vector") == 0)
- type = TYPE_VECT;
- else
- type = TYPE_OTHERS;
- /* Suppress "... found in more mapsets" warnings from G_find_file2. */
- G_suppress_warnings(1);
- if (*lcount + count > *lalloc) {
- *lalloc = *lcount + count + 10;
- *el = G_realloc(*el, *lalloc * sizeof(struct elist));
- for (i = 0; i < count; i++) {
- /* If region= is used, read the map region. */
- if (window) {
- /* If the map region doesn't overlap with the input region, don't
- * print the map. */
- if (!region_overlaps(window, list[i], mapset, type))
- continue;
- (*el)[*lcount].type = G_store(alias);
- (*el)[*lcount].name = list[i];
- (*el)[*lcount].mapset = G_store(mapset);
- (*lcount)++;
- any++;
- G_suppress_warnings(0);
- G_free(list);
-int cmp(const void *a, const void *b)
- struct elist *al = (struct elist *)a;
- struct elist *bl = (struct elist *)b;
- int ret;
- if (!(ret = strcmp(al->type, bl->type))) {
- if (!(ret = strcmp(al->name, bl->name)))
- ret = strcmp(al->mapset, bl->mapset);
- return ret;
-static void print_list(FILE *fp, struct elist *el, int count,
- const char *separator, int add_type, int add_mapset)
- int i;
- if (!count)
- return;
- qsort(el, count, sizeof(struct elist), cmp);
- int need_mapset = 0;
- if (i != 0)
- fprintf(fp, "%s", separator);
- if (add_type)
- fprintf(fp, "%s/", el[i].type);
- fprintf(fp, "%s", el[i].name);
- if (!add_mapset) {
- if (i + 1 < count)
- need_mapset = strcmp(el[i].name, el[i + 1].name) == 0;
- if (!need_mapset && i > 0)
- need_mapset = strcmp(el[i].name, el[i - 1].name) == 0;
- if (add_mapset || need_mapset)
- fprintf(fp, "@%s", el[i].mapset);
- fflush(fp);
-static int region_overlaps(struct Cell_head *window, const char *name,
- const char *mapset, int type)
- int has_region;
- struct Cell_head map_window;
- RASTER3D_Region region3d;
- struct Map_info Map;
- struct bound_box box;
- switch (type) {
- case TYPE_RAST:
- Rast_get_cellhd(name, mapset, &map_window);
- has_region = 1;
- break;
- case TYPE_RAST3D:
- if (Rast3d_read_region_map(name, mapset, ®ion3d) < 0)
- G_fatal_error(_("Unable to read header of 3D raster map <%s@%s>"),
- name, mapset);
- Rast3d_region_to_cell_head(®ion3d, &map_window);
- has_region = 1;
- break;
- case TYPE_VECT:
- Vect_set_open_level(2);
- if (Vect_open_old_head(&Map, name, mapset) < 2)
- G_fatal_error(_("Unable to open vector map <%s@%s> on topological level"),
- name, mapset);
- Vect_get_map_box(&Map, &box);
- Vect_close(&Map);
- map_window.north = box.N;
- map_window.south = box.S;
- map_window.west = box.W;
- map_window.east = box.E;
- has_region = 1;
- break;
- default:
- has_region = 0;
- break;
- /* If an element doesn't have a concept of region at all, return 1 so we
- * can always print it. */
- if (!has_region)
- return 1;
- /* If the map region is outside the input region, return 0. Otherwise
- * return 1 */
- return !(window->north <= map_window.south ||
- window->south >= map_window.north ||
- window->west >= map_window.east ||
- window->east <= map_window.west);
