[GRASS-SVN] r65560 - grass-addons/tools
svn_grass at osgeo.org
Fri Jul 10 03:30:08 PDT 2015
Author: lucadelu
Date: 2015-07-10 03:30:08 -0700 (Fri, 10 Jul 2015)
New Revision: 65560
grass-addons/tools/std_dataset_display.py
updated script to create images from standard dataset
Modified: grass-addons/tools/std_dataset_display.py
--- grass-addons/tools/std_dataset_display.py 2015-07-10 08:15:45 UTC (rev 65559)
+++ grass-addons/tools/std_dataset_display.py 2015-07-10 10:30:08 UTC (rev 65560)
@@ -2,12 +2,17 @@
import os
import grass.script as gscript
+from PIL import Image
+import argparse
# before the script runs, old maps and existing images must be removed
# g.remove type=raster name=slope,aspect,profile_curvature,shade -f
+# the size of images could be different between different dataset
+DATASET = {'north_carolina': {'w': 600, 'h': 600},
+ 'piemonte': {'w': 600, 'h': 800}}
def description_box(title):
gscript.write_command('d.graph', stdin="""
color white
@@ -29,45 +34,118 @@
{x2} {y1}
{x2} {y2}
""".format(color=color, x1=x, y1=y, x2=x + 2, y2=y + 2))
- gscript.run_command('d.text', text=text, at=(x + 3, y + 0.5), size=2, color='black')
+ gscript.run_command('d.text', text=text, at=(x + 3, y + 0.5), size=2,
+ color='black')
def d_rast_legend(raster, title):
+ """Print raster and its legend
+ :param str raster: the name of raster to print
+ :param str title: the text to append to the legend
gscript.run_command('d.rast', map=raster)
gscript.run_command('d.legend', raster=raster, at='6,9,6,50')
- gscript.run_command('d.barscale', style='classic', at='55,9', color='black', text_position='over')
+ gscript.run_command('d.barscale', style='classic', at='55,9',
+ color='black', text_position='over')
+def join_output(inputs, output, width, height, resize=None):
+ """Attach several images in a collage
+ :param list inputs: a list with the input images to attach together
+ :param str output: the output name
+ :param int width: the width of images
+ :param int height: the height of images
+ :param float resize: value beetwen 0 and 1 to resize the finale output
+ out = Image.new("RGB", (width * len(inputs), height), "white")
+ x = 0
+ for inp in inputs:
+ out.paste(Image.open(inp), (x, 0))
+ x += width
+ if resize and resize < 1.0:
+ out = out.resize(width * resize, height * resize)
+ out.save(output)
+def cleanup(maps):
+ """Remove all the created maps"""
+ gscript.run_command('g.remove', type='raster', name=','.join(maps),
+ flags='f')
+def get_parser():
+ """Create the parser for running as script"""
+ parser = argparse.ArgumentParser(description='')
+ parser.add_argument('dataset', type=str, metavar='DATASET',
+ help='Name of dataset you are using, possible choices'
+ ' are: {va}'.format(va=', '.join(DATASET.keys())),
+ choices=DATASET.keys())
+ parser.add_argument('-o', '--output', type=str, metavar='OUTPUT',
+ help='Name of output collage', dest='output')
+ parser.add_argument('-e', '--elevation', type=str,
+ default='shaded_elevation.png',
+ dest='ele', help='Name of shaded elevation output')
+ parser.add_argument('-s', '--slope', type=str, default='slope.png',
+ dest='slope', help='Name of slope output')
+ parser.add_argument('-a', '--aspect', type=str, default='aspect.png',
+ dest='aspect', help='Name of aspect output')
+ parser.add_argument('-p', '--profile', type=str, dest='profile',
+ default='profile_curvature.png',
+ help='Name of profile curvature output')
+ parser.add_argument('-r', '--resize', type=float, default=1.0,
+ dest='resize', help='Value to resize the final output')
+ parser.add_argument('-c', '--cleanup', action='store_true', default=False,
+ dest='cleanup', help='Remove the maps created by this'
+ ' script')
+ return parser
def main():
+ """Main function to run the script"""
+ parser = get_parser()
+ args = parser.parse_args()
+ # original maps
elevation = 'elevation'
+ streams = 'streams'
+ roadsmajor = 'roadsmajor'
+ # color
+ streams_color = 'aqua'
+ roads_color = 'yellow'
+ # created maps, to be removed
slope = 'slope'
aspect = 'aspect'
profile_curvature = 'profile_curvature'
shade = 'shade'
- streams = 'streams'
- streams_color = 'aqua'
- roadsmajor = 'roadsmajor'
- roads_color = 'yellow'
+ # final png outfile
+ ele_out = args.ele
+ aspect_out = args.aspect
+ slope_out = args.slope
+ profile_out = args.profile
+ data = DATASET[args.dataset]
+ width = data['w']
+ height = data['h']
# we set region for the whole session (i.e. also outside the script)
gscript.run_command('g.region', raster=elevation)
gscript.run_command('r.slope.aspect', elevation=elevation,
- slope=slope, aspect=aspect, pcurvature=profile_curvature)
+ slope=slope, aspect=aspect,
+ pcurvature=profile_curvature)
gscript.run_command('r.relief', input=elevation, output=shade)
# render maps
# set variables for rendering into a file
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
- os.environ['GRASS_RENDER_WIDTH'] = '600'
- os.environ['GRASS_RENDER_HEIGHT'] = '600'
+ os.environ['GRASS_RENDER_WIDTH'] = str(width)
+ os.environ['GRASS_RENDER_HEIGHT'] = str(height)
os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
os.environ['GRASS_FONT'] = 'sans'
# shaded map with vectors
- os.environ['GRASS_RENDER_FILE'] = 'shaded_elevation.png'
+ os.environ['GRASS_RENDER_FILE'] = ele_out
gscript.run_command('d.shade', shade=shade, color=elevation)
gscript.run_command('d.vect', map=streams, width=1, color=streams_color)
gscript.run_command('d.vect', map=roadsmajor, width=2, color=roads_color)
@@ -75,23 +153,28 @@
legend_item(streams_color, 'Streams', 3, 3)
legend_item(roads_color, 'Major roads', 3, 6)
gscript.run_command('d.legend', raster=elevation, at='3,6,30,50')
- gscript.run_command('d.text', text='Elevation', at='30,7', size=2, color='black')
+ gscript.run_command('d.text', text='Elevation', at='30,7', size=2,
+ color='black')
# individual rasters
- os.environ['GRASS_RENDER_FILE'] = 'slope.png'
+ os.environ['GRASS_RENDER_FILE'] = slope_out
d_rast_legend(slope, 'Slope')
- os.environ['GRASS_RENDER_FILE'] = 'aspect.png'
+ os.environ['GRASS_RENDER_FILE'] = aspect_out
d_rast_legend(aspect, 'Aspect')
- os.environ['GRASS_RENDER_FILE'] = 'profile_curvature.png'
+ os.environ['GRASS_RENDER_FILE'] = profile_out
d_rast_legend(profile_curvature, 'Profile curvature')
- # post processing
- # convert shaded_elevation.png slope.png aspect.png profile_curvature.png +append stripe.png
+ if args.output:
+ join_inputs = [ele_out, aspect_out, slope_out, profile_out]
+ join_output(join_inputs, args.output, width, height, args.resize)
+ if args.cleanup:
+ clean_maps = [slope, aspect, profile_curvature, shade]
+ cleanup(clean_maps)
if __name__ == "__main__":
main()
